path: root/fs/orangefs/protocol.h
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-26orangefs: remove ORANGEFS_READDIR macrosMartin Brandenburg
They are clones of the ORANGEFS_ITERATE macros in use elsewhere. Delete ORANGEFS_ITERATE_NEXT which is a hack previously used by readdir. Signed-off-by: Martin Brandenburg <martin@omnibond.com> Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2016-08-15orangefs: clean up debugfs globalsMartin Brandenburg
Mostly this is moving code into orangefs-debugfs.c so that globals turn into static globals. Then gossip_debug_mask is renamed orangefs_gossip_debug_mask but keeps global visibility, so it can be used from a macro. Signed-off-by: Martin Brandenburg <martin@omnibond.com>
2016-08-02orangefs: Cache getattr results.Martin Brandenburg
The userspace component attempts to do this, but this will prevent us from even needing to go into userspace to satisfy certain getattr requests. Signed-off-by: Martin Brandenburg <martin@omnibond.com>
2016-04-08orangefs: Add KERN_<LEVEL> to gossip_<level> macrosJoe Perches
Emit the logging messages at the appropriate levels. Miscellanea: o Change format to fmt o Use the more common ##__VA_ARGS__ Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2016-04-08Orangefs: optimize boilerplate code.Mike Marshall
Suggested by David Binderman <dcb314@hotmail.com> The former can potentially be a performance win over the latter. memcpy(d, s, len); memset(d+len, c, size-len); memset(d, c, size); memcpy(d, s, len); Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2016-03-31orangefs: minimum userspace version is 2.9.3Martin Brandenburg
Version 2.9.4 isn't even released yet. Signed-off-by: Martin Brandenburg <martin@omnibond.com>
2016-02-24orangefs: we never lookup with sym_follow setMartin Brandenburg
2016-02-04orangefs: Implement inode_operations->permission().Martin Brandenburg
Thus d_revalidate is not obliged to check on as much, which will eventually lead the way to hammering the filesystem servers much less. Signed-off-by: Martin Brandenburg <martin@omnibond.com> Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2016-01-13Orangefs: define a minimum compatible userspace version.Mike Marshall
2015-12-04Orangefs: change pvfs2 filenames to orangefsMike Marshall
Also changed references within source files that referred to header files whose names had changed. Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2015-12-03OrangeFS: Change almost all instances of the string PVFS2 to OrangeFS.Yi Liu
OrangeFS was formerly known as PVFS2 and retains the name in many places. I leave the device /dev/pvfs2-req since this affects userspace. I leave the filesystem type pvfs2 since this affects userspace. Further the OrangeFS sysint library reads fstab for an entry of type pvfs2 independently of kernel mounts. I leave extended attribute keys user.pvfs2 and system.pvfs2 as the sysint library understands these. I leave references to userspace binaries still named pvfs2. I leave the filenames. Signed-off-by: Yi Liu <yi9@clemson.edu> [martin@omnibond.com: clairify above constraints and merge] Signed-off-by: Martin Brandenburg <martin@omnibond.com> Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2015-10-05Orangefs: fix some checkpatch.pl complaints that had creeped in.Mike Marshall
2015-10-03Orangefs: Clean up error decoding.Martin Brandenburg
Errors from the server need to be decoded. A bunch of code was imported from the server to do this but much of it is convoluted and not even needed. The result is better but still as convoluted as required by the protocol. Signed-off-by: Martin Brandenburg <martin@omnibond.com> Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2015-10-03Orangefs: Don't opencode memcpy.Mike Marshall
2015-10-03Orangefs: put PVFS_util_min out of its misery.Mike Marshall
2015-10-03Orangefs: fix dir_emit code in pvfs2_readdir.Mike Marshall
Al Viro glanced at readdir and surmised that getdents would misbehave the way it was written... and sure enough. Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2015-10-03Orangefs: Swap order of include filesGuenter Roeck
spinlock_types.h requires types from linux/types.h. Including spinlock_types.h first may result in the following build errors, as seen with arm:allmodconfig. arch/arm/include/asm/spinlock_types.h:12:3: error: unknown type name 'u32' arch/arm/include/asm/spinlock_types.h:16:4: error: unknown type name 'u16' Fixes: deb4fb58ff73 ("Orangefs: kernel client part 2") Cc: Mark Brown <broonie@kernel.org> Cc: Mike Marshall <hubcap@omnibond.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2015-10-03Orangefs: sooth most sparse complaintsMike Marshall
2015-10-03Orangefs: kernel client update 1.Mike Marshall
Stephen Rothwell noticed that orangefs would not compile on powerpc... Signed-off-by: Mike Marshall <hubcap@omnibond.com>
2015-10-03Orangefs: kernel client part 1Mike Marshall
OrangeFS (formerly PVFS) is an lgpl licensed userspace networked parallel file system. OrangeFS can be accessed through included system utilities, user integration libraries, MPI-IO and can be used by the Hadoop ecosystem as an alternative to the HDFS filesystem. OrangeFS is used widely for parallel science, data analytics and engineering applications. While applications often don't require Orangefs to be mounted into the VFS, users do like to be able to access their files in the normal way. The Orangefs kernel client allows Orangefs filesystems to be mounted as a VFS. The kernel client communicates with a userspace daemon which in turn communicates with the Orangefs server daemons that implement the filesystem. The server daemons (there's almost always more than one) need not be running on the same host as the kernel client. Orangefs filesystems can also be mounted with FUSE, and we ship code and instructions to facilitate that, but most of our users report preferring to use our kernel module instead. Further, as an example of a problem we can't solve with fuse, we have in the works a not-yet-ready-for-prime-time version of a file_operations lock function that accounts for the server daemons being distributed across more than one running kernel. Many people and organizations, including Clemson University, Argonne National Laboratories and Acxiom Corporation have helped to create what has become Orangefs over more than twenty years. Some of the more recent contributors to the kernel client include: Mike Marshall Christoph Hellwig Randy Martin Becky Ligon Walt Ligon Michael Moore Rob Ross Phil Carnes Signed-off-by: Mike Marshall <hubcap@omnibond.com>
