commit e8d4bfe3a71537284a90561f77c85dea6c154369 upstream.
When executing filesystem sync or umount on overlayfs,
dirty data does not get synced as expected on upper filesystem.
This patch fixes sync filesystem method to keep data consistency
for overlayfs.
Signed-off-by: Chengguang Xu <cgxu@mykernel.net>
Fixes: e593b2bf513d ("ovl: properly implement sync_filesystem()")
Cc: <stable@vger.kernel.org> #4.11
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 31747eda41ef3c30c09c5c096b380bf54013746a upstream.
fsnotify pins a watched directory inode in cache, but if directory dentry
is released, new lookup will allocate a new dentry and a new inode.
Directory events will be notified on the new inode, while fsnotify listener
is watching the old pinned inode.
Hash all directory inodes to reuse the pinned inode on lookup. Pure upper
dirs are hashes by real upper inode, merge and lower dirs are hashed by
real lower inode.
The reference to lower inode was being held by the lower dentry object
in the overlay dentry (oe->lowerstack[0]). Releasing the overlay dentry
may drop lower inode refcount to zero. Add a refcount on behalf of the
overlay inode to prevent that.
As a by-product, hashing directory inodes also detects multiple
redirected dirs to the same lower dir and uncovered redirected dir
target on and returns -ESTALE on lookup.
The reported issue dates back to initial version of overlayfs, but this
patch depends on ovl_inode code that was introduced in kernel v4.13.
Cc: <stable@vger.kernel.org> #v4.13
Reported-by: Niklas Cassel <niklas.cassel@axis.com>
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Tested-by: Niklas Cassel <niklas.cassel@axis.com>
This was detected by fault injection test
Signed-off-by: Hirofumi Nakagawa <nklabs@gmail.com>
Fixes: 13cf199d0088 ("ovl: allocate an ovl_inode struct")
Cc: <stable@vger.kernel.org> # v4.13
Enforcing exclusive ownership on upper/work dirs caused a docker
regression: https://github.com/moby/moby/issues/34672.
Euan spotted the regression and pointed to the offending commit.
Vivek has brought the regression to my attention and provided this
reproducer:
Terminal 1:
mount -t overlay -o workdir=work,lowerdir=lower,upperdir=upper none
merged/
Terminal 2:
unshare -m
Terminal 1:
umount merged
merged/
mount: /root/overlay-testing/merged: none already mounted or mount point
busy
To fix the regression, I replaced the error with an alarming warning.
With index feature enabled, mount does fail, but logs a suggestion to
override exclusive dir protection by disabling index.
Note that index=off mount does take the inuse locks, so a concurrent
index=off will issue the warning and a concurrent index=on mount will fail.
Documentation was updated to reflect this change.
Fixes: 2cac0c00a6cd ("ovl: get exclusive ownership on upper/work dirs")
Reported-by: Euan Kemp <euank@euank.com>
Reported-by: Vivek Goyal <vgoyal@redhat.com>
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
Need to treat non-regular overlayfs files the same as regular files when
checking for an atime update.
Add a d_real() flag to make it return the upper dentry for all file types.
Reported-by: "zhangyi (F)" <yi.zhang@huawei.com>
Add a separate flags argument (in addition to the open flags) to control
the behavior of d_real().
d_real() is never called with a negative dentry. So remove the
d_is_negative() check (which would never trigger anyway, since d_is_reg()
returns false for a negative dentry).
Impure directories are ones which contain objects with origins (i.e. those
that have been copied up). These are relevant to readdir operation only
because of the d_ino field, no other transformation is necessary. Also a
directory can become impure between two getdents(2) calls.
This patch creates a cache for impure directories. Unlike the cache for
merged directories, this one only contains entries with origin and is not
refcounted but has a its lifetime tied to that of the dentry.
Similarly to the merged cache, the impure cache is invalidated based on a
version number. This version number is incremented when an entry with
origin is added or removed from the directory.
If the cache is empty, then the impure xattr is removed from the directory.
This patch also fixes up handling of d_ino for the ".." entry if the parent
directory is merged.
inode_doinit_with_dentry() in SELinux wants to read the upper inode's xattr
to get security label, and ovl_xattr_get() calls ovl_dentry_real(), which
depends on dentry->d_inode, but d_inode is null and not initialized yet at
this point resulting in an Oops.
Fix by getting the upperdentry info from the inode directly in this case.
Reported-by: Eryu Guan <eguan@redhat.com>
Fixes: 09d8b586731b ("ovl: move __upperdentry to ovl_inode")
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
ovl_workdir_create() returns a valid index dentry or NULL.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
On failure to prepare_creds(), mount fails with a random
return value, as err was last set to an integer cast of
a valid lower mnt pointer or set to 0 if inodes index feature
is enabled.
Fixes: 3fe6e52f0626 ("ovl: override creds with the ones from ...")
Cc: <stable@vger.kernel.org> # v4.7
index entry should live only as long as there are upper or lower
hardlinks.
Cleanup orphan index entries on mount and when dropping the last
overlay inode nlink.
When about to cleanup or link up to orphan index and the index inode
nlink > 1, admit that something went wrong and adjust overlay nlink
to index inode nlink - 1 to prevent it from dropping below zero.
This could happen when adding lower hardlinks underneath a mounted
overlay and then trying to unlink them.
For rename, we need to ensure that an upper alias exists for hard links
before attempting the operation. Introduce a flag in ovl_entry to track
the state of the upper alias.
Bad index entries are entries whose name does not match the
origin file handle stored in trusted.overlay.origin xattr.
Bad index entries could be a result of a system power off in
the middle of copy up.
Stale index entries are entries whose origin file handle is
stale. Stale index entries could be a result of copying layers
or removing lower entries while the overlay is not mounted.
The case of copying layers should be detected earlier by the
verification of upper root dir origin and index dir origin.
Both bad and stale index entries are detected and removed
on mount.
An index dir contains persistent hardlinks to files in upper dir.
Therefore, we must never mount an existing index dir with a differnt
upper dir.
Store the upper root dir file handle in index dir inode when index
dir is created and verify the file handle before using an existing
index dir on mount.
Add an 'is_upper' flag to the overlay file handle encoding and set it
when encoding the upper root file handle. This is not critical for index
dir verification, but it is good practice towards a standard overlayfs
file handle format for NFS export.
When inodes index feature is enabled, verify that the file handle stored
in upper root dir matches the lower root dir or fail to mount.
If upper root dir has no stored file handle, encode and store the lower
root dir file handle in overlay.origin xattr.
Create the index dir on mount. The index dir will contain hardlinks to
upper inodes, named after the hex representation of their origin lower
inodes.
The index dir is going to be used to prevent breaking lower hardlinks
on copy up and to implement overlayfs NFS export.
Because the feature is not fully backward compat, enabling the feature
is opt-in by config/module/mount option.
Pass in the subdir name to create and specify if subdir is persistent
or if it should be cleaned up on every mount.
Move fallback to readonly mount on failure to create dir and print of error
message into the helper.
This function is going to be used for creating the persistent 'index' dir
under workbasedir.
Bad things can happen if several concurrent overlay mounts try to
use the same upperdir/workdir path.
Try to get the 'inuse' advisory lock on upperdir and workdir.
Fail mount if another overlay mount instance or another user
holds the 'inuse' lock on these directories.
Note that this provides no protection for concurrent overlay
mount that use overlapping (i.e. descendant) upper/work dirs.
Use the new ovl_inode mutex to synchonize concurrent copy up
instead of the super block copy up workqueue.
Moving the synchronization object from the overlay dentry to
the overlay inode is needed for synchonizing concurrent copy up
of lower hardlinks to the same upper inode.
We need some more space to store overlay inode data in memory,
so allocate overlay inodes from a slab of struct ovl_inode.
An upper dir is marked "impure" to let ovl_iterate() know that this
directory may contain non pure upper entries whose d_ino may need to be
read from the origin inode.
We already mark a non-merge dir "impure" when moving a non-pure child
entry inside it, to let ovl_iterate() know not to iterate the non-merge
dir directly.
Mark also a merge dir "impure" when moving a non-pure child entry inside
it and when copying up a child entry inside it.
This can be used to optimize ovl_iterate() to perform a "pure merge" of
upper and lower directories, merging the content of the directories,
without having to read d_ino from origin inodes.
xattr are needed by overlayfs for setting opaque dir, redirect dir
and copy up origin.
Check at mount time by trying to set the overlay.opaque xattr on the
workdir and if that fails issue a warning message.
Some features can only work when all layers are on the same fs. Test this
condition during mount time, so features can check them later.
Add helper ovl_same_sb() to return the common super block in case all
For overlay file open, check IS_APPEND() on the real upper inode
inside d_real(), because the overlay inode does not have the
S_APPEND flag and IS_APPEND() can only be checked at open time.
Note that because overlayfs does not copy up the chattr inode flags
(i.e. S_APPEND, S_IMMUTABLE), the IS_APPEND() check is only relevant
for upper inodes that were set with chattr +a and not to lower
inodes that had chattr +a before copy up.
Prepare to mark sensitive kernel structures for randomization by making
sure they're using designated initializers. These were identified during
allyesconfig builds of x86, arm, and arm64, with most initializer fixes
extracted from grsecurity.
For these cases, use { }, which will be zero-filled, instead of
undesignated NULLs.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs updates from Miklos Szeredi:
"Because copy up can take a long time, serialized copy ups could be a
big performance bottleneck. This update allows concurrent copy up of
regular files eliminating this potential problem.
There are also minor fixes"
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ovl: drop CAP_SYS_RESOURCE from saved mounter's credentials
ovl: concurrent copy up of regular files
ovl: introduce copy up waitqueue
ovl: copy up regular file using O_TMPFILE
ovl: rearrange code in ovl_copy_up_locked()
ovl: check if upperdir fs supports O_TMPFILE
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
If overlay was mounted by root then quota set for upper layer does not work
because overlay now always use mounter's credentials for operations.
Also overlay might deplete reserved space and inodes in ext4.
This patch drops capability SYS_RESOURCE from saved credentials.
This affects creation new files, whiteouts, and copy-up operations.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Fixes: 1175b6b8d963 ("ovl: do operations on underlying file system in mounter's context")
Cc: Vivek Goyal <vgoyal@redhat.com>
overlayfs syncs all inode pages on sync_filesystem(), but it also
needs to call s_op->sync_fs() of upper fs for metadata sync.
This fixes correctness of syncfs(2) as demonstrated by following
xfs specific test:
xfs_sync_stats()
echo $1
echo -n "xfs_log_force = "
grep log /proc/fs/xfs/stat | awk '{ print $5 }'
xfs_sync_stats "before touch"
touch x
xfs_sync_stats "after touch"
xfs_io -c syncfs .
xfs_sync_stats "after syncfs"
xfs_io -c fsync x
xfs_sync_stats "after fsync"
xfs_io -c fsync x
xfs_sync_stats "after fsync #2"
When this test is run in overlay mount over xfs, log force
count does not increase with syncfs command.
The overlay sb 'copyup_wq' and overlay inode 'copying' condition
variable are about to replace the upper sb rename_lock, as finer
grained synchronization objects for concurrent copy up.
Suggested-by: Miklos Szeredi <miklos@szeredi.hu>
This is needed for choosing between concurrent copyup
using O_TMPFILE and legacy copyup using workdir+rename.
If kcalloc() failed, the return value of ovl_fill_super() is -EINVAL,
not -ENOMEM. So this patch sets this value to -ENOMEM before calling
kcalloc(), and sets it back to -EINVAL after calling kcalloc().
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
FWIW, there's a bit of abuse of struct kstat in overlayfs object
creation paths - for one thing, it ends up with a very small subset
of struct kstat (mode + rdev), for another it also needs link in
case of symlinks and ends up passing it separately.
IMO it would be better to introduce a separate object for that.
In principle, we might even lift that thing into general API and switch
->mkdir()/->mknod()/->symlink() to identical calling conventions. Hell
knows, perhaps ->create() as well...
Show the value of redirect_dir in /proc/mounts.
This patch introduces a kernel config option and a module param. Both can
be used independently to turn the default value of redirect_dir on or off.
Current code returns EXDEV when a directory would need to be copied up to
move. We could copy up the directory tree in this case, but there's
another, simpler solution: point to old lower directory from moved upper
directory.
This is achieved with a "trusted.overlay.redirect" xattr storing the path
relative to the root of the overlay. After such attribute has been set,
the directory can be moved without further actions required.
This is a backward incompatible feature, old kernels won't be able to
correctly mount an overlay containing redirected directories.
If a directory has the "trusted.overlay.redirect" xattr, it means that the
value of the xattr should be used to find the underlying directory on the
next lower layer.
The redirect may be relative or absolute. Absolute redirects begin with a
slash.
A relative redirect means: instead of the current dentry's name use the
value of the redirect to find the directory in the next lower
layer. Relative redirects must not contain a slash.
An absolute redirect means: look up the directory relative to the root of
the overlay using the value of the redirect in the next lower layer.
Redirects work on lower layers as well.
When the upper overlayfs checks "trusted.overlay.*" xattr on the underlying
overlayfs mount, it gets -EPERM, which confuses the upper overlayfs.
Fix this by returning -EOPNOTSUPP instead of -EPERM from
ovl_own_xattr_get() and ovl_own_xattr_set(). This behavior is consistent
with the behavior of ovl_listxattr(), which filters out the private
overlayfs xattrs.
Note: nested overlays are deprecated. But this change makes sense
regardless: these xattrs are private to the overlay and should always be
hidden. Hence getting and setting them should indicate this.
[SzMi: Use EOPNOTSUPP instead of ENODATA and use it for both getting and
setting "trusted.overlay." xattrs. This is a perfectly valid error code
for "we don't support this prefix", which is the case here.]
We already calculate f_namelen in statfs as the maximum of the name lengths
provided by the filesystems taking part in the overlay.
fs/overlayfs/super.c is the biggest of the overlayfs source files and it
contains various utility functions as well as the rather complicated lookup
code. Split these parts out to separate files.
Before:
1446 fs/overlayfs/super.c
After:
919 fs/overlayfs/super.c
267 fs/overlayfs/namei.c
235 fs/overlayfs/util.c
51 fs/overlayfs/ovl_entry.h
