commit 6889ee5a53b8d969aa542047f5ac8acdc0e79a91 upstream.
In ovl_rename(), if new upper is hardlinked to old upper underneath
overlayfs before upper dirs are locked, user will get an ESTALE error
and a WARN_ON will be printed.
Changes to underlying layers while overlayfs is mounted may result in
unexpected behavior, but it shouldn't crash the kernel and it shouldn't
trigger WARN_ON() either, so relax this WARN_ON().
Reported-by: syzbot+bb1836a212e69f8e201a@syzkaller.appspotmail.com
Fixes: 804032fabb3b ("ovl: don't check rename to self")
Cc: <stable@vger.kernel.org> # v4.9+
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
commit 5c2e9f346b815841f9bed6029ebcb06415caf640 upstream.
When filtering xattr list for reading, presence of trusted xattr
results in a security audit log. However, if there is other content
no errno will be set, and if there isn't, the errno will be -ENODATA
and not -EPERM as is usually associated with a lack of capability.
The check does not block the request to list the xattrs present.
Switch to ns_capable_noaudit to reflect a more appropriate check.
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
Cc: linux-security-module@vger.kernel.org
Cc: kernel-team@android.com
Cc: stable@vger.kernel.org # v3.18+
Fixes: a082c6f680da ("ovl: filter trusted xattr for non-admin")
commit 5e1275808630ea3b2c97c776f40e475017535f72 upstream.
Kaixuxia repors that it's possible to crash overlayfs by removing the
whiteout on the upper layer before creating a directory over it. This is a
reproducer:
mkdir lower upper work merge
touch lower/file
mount -t overlay overlay -olowerdir=lower,upperdir=upper,workdir=work merge
rm merge/file
ls -al merge/file
rm upper/file
ls -al merge/
mkdir merge/file
Before commencing with a vfs_rename(..., RENAME_EXCHANGE) verify that the
lookup of "upper" is positive and is a whiteout, and return ESTALE
otherwise.
Reported by: kaixuxia <xiakaixu1987@gmail.com>
Fixes: e9be9d5e76e3 ("overlay filesystem")
Cc: <stable@vger.kernel.org> # v3.18
commit 6cd078702f2f33cb6b19a682de3e9184112f1a46 upstream.
linking a non-copied-up file into a non-copied-up parent results in a
nested call to mutex_lock_interruptible(&oi->lock). Fix this by copying up
target parent before ovl_nlink_start(), same as done in ovl_rename().
~/unionmount-testsuite$ ./run --ov -s
~/unionmount-testsuite$ ln /mnt/a/foo100 /mnt/a/dir100/
WARNING: possible recursive locking detected
ln/1545 is trying to acquire lock:
00000000bcce7c4c (&ovl_i_lock_key[depth]){+.+.}, at:
ovl_copy_up_start+0x28/0x7d
but task is already holding lock:
0000000026d73d5b (&ovl_i_lock_key[depth]){+.+.}, at:
ovl_nlink_start+0x3c/0xc1
[SzM: this seems to be a false positive, but doing the copy-up first is
harmless and removes the lockdep splat]
Reported-by: syzbot+3ef5c0d1a5cb0b21e6be@syzkaller.appspotmail.com
Fixes: 5f8415d6b87e ("ovl: persistent overlay inode nlink for...")
Cc: <stable@vger.kernel.org> # v4.13
[amir: backport to v4.18]
commit babf4770be0adc69e6d2de150f4040f175e24beb upstream.
We hit a BUG on kfree of an ERR_PTR()...
Reported-by: syzbot+ff03fe05c717b82502d0@syzkaller.appspotmail.com
Fixes: 8b88a2e64036 ("ovl: verify upper root dir matches lower root dir")
commit a725356b6659469d182d662f22d770d83d3bc7b5 upstream.
Commit 031a072a0b8a ("vfs: call vfs_clone_file_range() under freeze
protection") created a wrapper do_clone_file_range() around
vfs_clone_file_range() moving the freeze protection to former, so
overlayfs could call the latter.
The more common vfs practice is to call do_xxx helpers from vfs_xxx
helpers, where freeze protecction is taken in the vfs_xxx helper, so
this anomality could be a source of confusion.
It seems that commit 8ede205541ff ("ovl: add reflink/copyfile/dedup
support") may have fallen a victim to this confusion -
ovl_clone_file_range() calls the vfs_clone_file_range() helper in the
hope of getting freeze protection on upper fs, but in fact results in
overlayfs allowing to bypass upper fs freeze protection.
Swap the names of the two helpers to conform to common vfs practice
and call the correct helpers from overlayfs and nfsd.
Fixes: 031a072a0b8a ("vfs: call vfs_clone_file_range() under freeze...")
commit 1a8f8d2a443ef9ad9a3065ba8c8119df714240fa upstream.
Format has a typo: it was meant to be "%.*s", not "%*s". But at some point
callers grew nonprintable values as well, so use "%*pE" instead with a
maximized length.
Reported-by: Amir Goldstein <amir73il@gmail.com>
Fixes: 3a1e819b4e80 ("ovl: store file handle of lower inode on copy up")
Cc: <stable@vger.kernel.org> # v4.12
commit 63e132528032ce937126aba591a7b37ec593a6bb upstream.
The memory leak was detected by kmemleak when running xfstests
overlay/051,053
Fixes: caf70cb2ba5d ("ovl: cleanup orphan index entries")
commit 601350ff58d5415a001769532f6b8333820e5786 upstream.
KASAN detected slab-out-of-bounds access in printk from overlayfs,
because string format used %*s instead of %.*s.
> BUG: KASAN: slab-out-of-bounds in string+0x298/0x2d0 lib/vsprintf.c:604
> Read of size 1 at addr ffff8801c36c66ba by task syz-executor2/27811
> CPU: 0 PID: 27811 Comm: syz-executor2 Not tainted 4.19.0-rc5+ #36
> printk+0xa7/0xcf kernel/printk/printk.c:1996
> ovl_lookup_index.cold.15+0xe8/0x1f8 fs/overlayfs/namei.c:689
Reported-by: syzbot+376cea2b0ef340db3dd4@syzkaller.appspotmail.com
Fixes: 359f392ca53e ("ovl: lookup index entry for copy up origin")
commit 764baba80168ad3adafb521d2ab483ccbc49e344 upstream.
Commit 31747eda41ef ("ovl: hash directory inodes for fsnotify")
fixed an issue of inotify watch on directory that stops getting
events after dropping dentry caches.
A similar issue exists for non-dir non-upper files, for example:
$ mkdir -p lower upper work merged
$ touch lower/foo
$ mount -t overlay -o
lowerdir=lower,workdir=work,upperdir=upper none merged
$ inotifywait merged/foo &
$ echo 2 > /proc/sys/vm/drop_caches
$ cat merged/foo
inotifywait doesn't get the OPEN event, because ovl_lookup() called
from 'cat' allocates a new overlay inode and does not reuse the
watched inode.
Fix this by hashing non-dir overlay inodes by lower real inode in
the following cases that were not hashed before this change:
- A non-upper overlay mount
- A lower non-hardlink when index=off
A helper ovl_hash_bylower() was added to put all the logic and
documentation about which real inode an overlay inode is hashed by
into one place.
The issue dates back to initial version of overlayfs, but this
patch depends on ovl_inode code that was introduced in kernel v4.13.
Cc: <stable@vger.kernel.org> #v4.13
Signed-off-by: Mark Salyzyn <salyzyn@android.com> #4.14
commit 67810693077afc1ebf9e1646af300436cb8103c2 upstream.
Only upper dir can be impure, but if we are in the middle of
iterating a lower real dir, dir could be copied up and marked
impure. We only want the impure cache if we started iterating
a real upper dir to begin with.
Aditya Kali reported that the following reproducer hits the
WARN_ON(!cache->refcount) in ovl_get_cache():
docker run --rm drupal:8.5.4-fpm-alpine \
sh -c 'cd /var/www/html/vendor/symfony && \
chown -R www-data:www-data . && ls -l .'
Reported-by: Aditya Kali <adityakali@google.com>
Tested-by: Aditya Kali <adityakali@google.com>
Fixes: 4edb83bb1041 ('ovl: constant d_ino for non-merge dirs')
Cc: <stable@vger.kernel.org> # v4.14
commit e8d4bfe3a71537284a90561f77c85dea6c154369 upstream.
When executing filesystem sync or umount on overlayfs,
dirty data does not get synced as expected on upper filesystem.
This patch fixes sync filesystem method to keep data consistency
for overlayfs.
Signed-off-by: Chengguang Xu <cgxu@mykernel.net>
Fixes: e593b2bf513d ("ovl: properly implement sync_filesystem()")
Cc: <stable@vger.kernel.org> #4.11
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
commit 3ec9b3fafcaf441cc4d46b9742cd6ec0c79f8df0 upstream.
As of now if we encounter an opaque dir while looking for a dentry, we set
d->last=true. This means that there is no need to look further in any of
the lower layers. This works fine as long as there are no redirets or
relative redircts. But what if there is an absolute redirect on the
children dentry of opaque directory. We still need to continue to look into
next lower layer. This patch fixes it.
Here is an example to demonstrate the issue. Say you have following setup.
upper: /redirect (redirect=/a/b/c)
lower1: /a/[b]/c ([b] is opaque) (c has absolute redirect=/a/b/d/)
lower0: /a/b/d/foo
Now "redirect" dir should merge with lower1:/a/b/c/ and lower0:/a/b/d.
Note, despite the fact lower1:/a/[b] is opaque, we need to continue to look
into lower0 because children c has an absolute redirect.
Following is a reproducer.
Watch me make foo disappear:
$ mkdir lower middle upper work work2 merged
$ mkdir lower/origin
$ touch lower/origin/foo
$ mount -t overlay none merged/ \
-olowerdir=lower,upperdir=middle,workdir=work2
$ mkdir merged/pure
$ mv merged/origin merged/pure/redirect
$ umount merged
-olowerdir=middle:lower,upperdir=upper,workdir=work
$ mv merged/pure/redirect merged/redirect
Now you see foo inside a twice redirected merged dir:
$ ls merged/redirect
foo
$ umount merged
After mount cycle you don't see foo inside the same dir:
During middle layer lookup, the opaqueness of middle/pure is left in
the lookup state and then middle/pure/redirect is wrongly treated as
opaque.
Fixes: 02b69b284cd7 ("ovl: lookup redirects")
Cc: <stable@vger.kernel.org> #v4.10
Signed-off-by: Vivek Goyal <vgoyal@redhat.com>
commit 31747eda41ef3c30c09c5c096b380bf54013746a upstream.
fsnotify pins a watched directory inode in cache, but if directory dentry
is released, new lookup will allocate a new dentry and a new inode.
Directory events will be notified on the new inode, while fsnotify listener
is watching the old pinned inode.
Hash all directory inodes to reuse the pinned inode on lookup. Pure upper
dirs are hashes by real upper inode, merge and lower dirs are hashed by
real lower inode.
The reference to lower inode was being held by the lower dentry object
in the overlay dentry (oe->lowerstack[0]). Releasing the overlay dentry
may drop lower inode refcount to zero. Add a refcount on behalf of the
overlay inode to prevent that.
As a by-product, hashing directory inodes also detects multiple
redirected dirs to the same lower dir and uncovered redirected dir
target on and returns -ESTALE on lookup.
The reported issue dates back to initial version of overlayfs, but this
Reported-by: Niklas Cassel <niklas.cassel@axis.com>
Tested-by: Niklas Cassel <niklas.cassel@axis.com>
commit a5a927a7c82e28ea76599dee4019c41e372c911f upstream.
The optimization in ovl_cache_get_impure() that tries to remove an
unneeded "impure" xattr needs to take mnt_want_write() on upper fs.
Fixes: 4edb83bb1041 ("ovl: constant d_ino for non-merge dirs")
commit d796e77f1dd541fe34481af2eee6454688d13982 upstream.
As a writable mount, it is not expected for overlayfs to return
EINVAL/EROFS for fsync, even if dir/file is not changed.
This commit fixes the case of fsync of directory, which is easier to
address, because overlayfs already implements fsync file operation for
directories.
The problem reported by Raphael is that new PostgreSQL 10.0 with a
database in overlayfs where lower layer in squashfs fails to start.
The failure is due to fsync error, when PostgreSQL does fsync on all
existing db directories on startup and a specific directory exists
lower layer with no changes.
Reported-by: Raphael Hertzog <raphael@ouaza.com>
Tested-by: Raphaël Hertzog <hertzog@debian.org>
commit 3382290ed2d5e275429cef510ab21889d3ccd164 upstream.
[ Note, this is a Git cherry-pick of the following commit:
506458efaf15 ("locking/barriers: Convert users of lockless_dereference() to READ_ONCE()")
... for easier x86 PTI code testing and back-porting. ]
READ_ONCE() now has an implicit smp_read_barrier_depends() call, so it
can be used instead of lockless_dereference() without any change in
semantics.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1508840570-22169-4-git-send-email-will.deacon@arm.com
commit b02a16e6413a2f782e542ef60bad9ff6bf212f8a upstream.
This fixes a regression with readdir of impure dir in overlayfs
that is shared to VM via 9p fs.
Reported-by: Miguel Bernal Marin <miguel.bernal.marin@linux.intel.com>
Tested-by: Miguel Bernal Marin <miguel.bernal.marin@linux.intel.com>
commit 08d8f8a5b094b66b29936e8751b4a818b8db1207 upstream.
Right now we seem to be passing index as "lowerdentry" and origin.dentry
as "upperdentry". IIUC, we should pass these parameters in reversed order
and this looks like a bug.
Acked-by: Amir Goldstein <amir73il@gmail.com>
commit 5455f92b54e516995a9ca45bbf790d3629c27a93 upstream.
If ovl_check_origin() fails, we should put upperdentry. We have a reference
on it by now. So goto out_put_upper instead of out.
Fixes: a9d019573e88 ("ovl: lookup non-dir copy-up-origin by file handle")
With index=on, ovl_indexdir_cleanup() tries to cleanup invalid index
entries (e.g. bad index name). This behavior could result in cleaning of
entries created by newer kernels and is therefore undesirable.
Instead, abort mount if such entries are encountered. We still cleanup
'stale' entries and 'orphan' entries, both those cases can be a result
of offline changes to lower and upper dirs.
When encoutering an index entry of type directory or whiteout, kernel
was supposed to fallback to read-only mount, but the fill_super()
operation returns EROFS in this case instead of returning success with
read-only mount flag, so mount fails when encoutering directory or
whiteout index entries. Bless this behavior by returning -EINVAL on
directory and whiteout index entries as we do for all unsupported index
entries.
Fixes: 61b674710cd9 ("ovl: do not cleanup directory and whiteout index..")
Treat ENOENT from index entry lookup the same way as treating a returned
negative dentry. Apparently, either could be returned if file is not
found, depending on the underlying file system.
Commit fbaf94ee3cd5 ("ovl: don't set origin on broken lower hardlink")
attempt to avoid the condition of non-indexed upper inode with lower
hardlink as origin. If this condition is found, lookup returns EIO.
The protection of commit mentioned above does not cover the case of lower
that is not a hardlink when it is copied up (with either index=off/on)
and then lower is hardlinked while overlay is offline.
Changes to lower layer while overlayfs is offline should not result in
unexpected behavior, so a permanent EIO error after creating a link in
lower layer should not be considered as correct behavior.
This fix replaces EIO error with success in cases where upper has origin
but no index is found, or index is found that does not match upper
inode. In those cases, lookup will not fail and the returned overlay inode
will be hashed by upper inode instead of by lower origin inode.
The error code is missing here so it means we return ERR_PTR(0) or NULL.
The other error paths all return an error code so this probably should
as well.
Reviewed-by: Chandan Rajendra <chandan@linux.vnet.ibm.com>
This was detected by fault injection test
Signed-off-by: Hirofumi Nakagawa <nklabs@gmail.com>
Fixes: 13cf199d0088 ("ovl: allocate an ovl_inode struct")
Enforcing exclusive ownership on upper/work dirs caused a docker
regression: https://github.com/moby/moby/issues/34672.
Euan spotted the regression and pointed to the offending commit.
Vivek has brought the regression to my attention and provided this
reproducer:
Terminal 1:
mount -t overlay -o workdir=work,lowerdir=lower,upperdir=upper none
merged/
Terminal 2:
unshare -m
Terminal 1:
umount merged
merged/
mount: /root/overlay-testing/merged: none already mounted or mount point
busy
To fix the regression, I replaced the error with an alarming warning.
With index feature enabled, mount does fail, but logs a suggestion to
override exclusive dir protection by disabling index.
Note that index=off mount does take the inuse locks, so a concurrent
index=off will issue the warning and a concurrent index=on mount will fail.
Documentation was updated to reflect this change.
Fixes: 2cac0c00a6cd ("ovl: get exclusive ownership on upper/work dirs")
Reported-by: Euan Kemp <euank@euank.com>
Reported-by: Vivek Goyal <vgoyal@redhat.com>
Use the ovl_lock_rename_workdir() helper which requires
unlock_rename() only on lock success.
Fixes: ("fd210b7d67ee ovl: move copy up lock out")
index dentry was not released when breaking out of the loop
due to index verification error.
Fixes: 415543d5c64f ("ovl: cleanup bad and stale index entries on mount")
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
GFP_TEMPORARY was introduced by commit e12ba74d8ff3 ("Group short-lived
and reclaimable kernel allocations") along with __GFP_RECLAIMABLE. It's
primary motivation was to allow users to tell that an allocation is
short lived and so the allocator can try to place such allocations close
together and prevent long term fragmentation. As much as this sounds
like a reasonable semantic it becomes much less clear when to use the
highlevel GFP_TEMPORARY allocation flag. How long is temporary? Can the
context holding that memory sleep? Can it take locks? It seems there is
no good answer for those questions.
The current implementation of GFP_TEMPORARY is basically GFP_KERNEL |
__GFP_RECLAIMABLE which in itself is tricky because basically none of
the existing caller provide a way to reclaim the allocated memory. So
this is rather misleading and hard to evaluate for any benefits.
I have checked some random users and none of them has added the flag
with a specific justification. I suspect most of them just copied from
other existing users and others just thought it might be a good idea to
use without any measuring. This suggests that GFP_TEMPORARY just
motivates for cargo cult usage without any reasoning.
I believe that our gfp flags are quite complex already and especially
those with highlevel semantic should be clearly defined to prevent from
confusion and abuse. Therefore I propose dropping GFP_TEMPORARY and
replace all existing users to simply use GFP_KERNEL. Please note that
SLAB users with shrinkers will still get __GFP_RECLAIMABLE heuristic and
so they will be placed properly for memory fragmentation prevention.
I can see reasons we might want some gfp flag to reflect shorterm
allocations but I propose starting from a clear semantic definition and
only then add users with proper justification.
This was been brought up before LSF this year by Matthew [1] and it
turned out that GFP_TEMPORARY really doesn't have a clear semantic. It
seems to be a heuristic without any measured advantage for most (if not
all) its current users. The follow up discussion has revealed that
opinions on what might be temporary allocation differ a lot between
developers. So rather than trying to tweak existing users into a
semantic which they haven't expected I propose to simply remove the flag
and start from scratch if we really need a semantic for short term
allocations.
[1] http://lkml.kernel.org/r/20170118054945.GD18349@bombadil.infradead.org
[akpm@linux-foundation.org: fix typo]
[sfr@canb.auug.org.au: drm/i915: fix up]
Link: http://lkml.kernel.org/r/20170816144703.378d4f4d@canb.auug.org.au
Link: http://lkml.kernel.org/r/20170728091904.14627-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "Theodore Ts'o" <tytso@mit.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs updates from Miklos Szeredi:
"This fixes d_ino correctness in readdir, which brings overlayfs on par
with normal filesystems regarding inode number semantics, as long as
all layers are on the same filesystem.
There are also some bug fixes, one in particular (random ioctl's
shouldn't be able to modify lower layers) that touches some vfs code,
but of course no-op for non-overlay fs"
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ovl: fix false positive ESTALE on lookup
ovl: don't allow writing ioctl on lower layer
ovl: fix relatime for directories
vfs: add flags to d_real()
ovl: cleanup d_real for negative
ovl: constant d_ino across copy up
ovl: fix readdir error value
ovl: check snprintf return
Commit b9ac5c274b8c ("ovl: hash overlay non-dir inodes by copy up origin")
verifies that the origin lower inode stored in the overlayfs inode matched
the inode of a copy up origin dentry found by lookup.
There is a false positive result in that check when lower fs does not
support file handles and copy up origin cannot be followed by file handle
at lookup time.
The false negative happens when finding an overlay inode in cache on a
copied up overlay dentry lookup. The overlay inode still 'remembers' the
copy up origin inode, but the copy up origin dentry is not available for
verification.
Relax the check in case copy up origin dentry is not available.
Fixes: b9ac5c274b8c ("ovl: hash overlay non-dir inodes by copy up...")
Reported-by: Jordi Pujol <jordipujolp@gmail.com>
Need to treat non-regular overlayfs files the same as regular files when
checking for an atime update.
Add a d_real() flag to make it return the upper dentry for all file types.
Reported-by: "zhangyi (F)" <yi.zhang@huawei.com>
Add a separate flags argument (in addition to the open flags) to control
the behavior of d_real().
d_real() is never called with a negative dentry. So remove the
d_is_negative() check (which would never trigger anyway, since d_is_reg()
returns false for a negative dentry).
While we could replace the smp_mb__before_spinlock() with the new
smp_mb__after_spinlock(), the normal pattern is to use
smp_store_release() to publish an object that is used for
lockless_dereference() -- and mirrors the regular rcu_assign_pointer()
/ rcu_dereference() patterns.
Impure directories are ones which contain objects with origins (i.e. those
that have been copied up). These are relevant to readdir operation only
because of the d_ino field, no other transformation is necessary. Also a
directory can become impure between two getdents(2) calls.
This patch creates a cache for impure directories. Unlike the cache for
merged directories, this one only contains entries with origin and is not
refcounted but has a its lifetime tied to that of the dentry.
Similarly to the merged cache, the impure cache is invalidated based on a
version number. This version number is incremented when an entry with
origin is added or removed from the directory.
If the cache is empty, then the impure xattr is removed from the directory.
This patch also fixes up handling of d_ino for the ".." entry if the parent
directory is merged.
When all layers are on the same fs, and iterating a directory which may
contain copy up entries, call vfs_getattr() on the overlay entries to make
sure that d_ino will be consistent with st_ino from stat(2).
There is an overhead of lookup per upper entry in readdir.
The overhead is minimal if the iterated entries are already in dcache. It
is also quite useful for the common case of 'ls -l' that readdir() pre
populates the dcache with the listed entries, making the following stat()
calls faster.
actor's return value is taken as a bool (filled/not filled) so we need to
return the error in the context.
Index should always be of the same file type as origin, except for
the case of a whiteout index. A whiteout index should only exist
if all lower aliases have been unlinked, which means that finding
a lower origin on lookup whose index is a whiteout should be treated
as a lookup error.
Directory index entries are going to be used for looking up
redirected upper dirs by lower dir fh when decoding an overlay
file handle of a merge dir.
Whiteout index entries are going to be used as an indication that
an exported overlay file handle should be treated as stale (i.e.
after unlink of the overlay inode).
We don't know the verification rules for directory and whiteout
index entries, because they have not been implemented yet, so fail
to mount overlay rw if those entries are found to avoid corrupting
an index that was created by a newer kernel.
inode_doinit_with_dentry() in SELinux wants to read the upper inode's xattr
to get security label, and ovl_xattr_get() calls ovl_dentry_real(), which
depends on dentry->d_inode, but d_inode is null and not initialized yet at
this point resulting in an Oops.
Fix by getting the upperdentry info from the inode directly in this case.
Reported-by: Eryu Guan <eguan@redhat.com>
Fixes: 09d8b586731b ("ovl: move __upperdentry to ovl_inode")
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
ovl_workdir_create() returns a valid index dentry or NULL.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Commit 54fb347e836f ("ovl: verify index dir matches upper dir")
introduced a new ovl_fh flag OVL_FH_FLAG_PATH_UPPER to indicate
an upper file handle, but forgot to add the flag to the mask of
valid flags, so index dir origin verification always discards
existing origin and stores a new one.
When linking a file with copy up origin into a new parent, mark the
new parent dir "impure".
Fixes: ee1d6d37b6b8 ("ovl: mark upper dir with type origin entries "impure"")
On failure to prepare_creds(), mount fails with a random
return value, as err was last set to an integer cast of
a valid lower mnt pointer or set to 0 if inodes index feature
is enabled.
Fixes: 3fe6e52f0626 ("ovl: override creds with the ones from ...")
Cc: <stable@vger.kernel.org> # v4.7
