path: root/fs/partitions/ibm.c
2010-08-13[S390] partitions: fix build error in ibm partition detection codeHeiko Carstens
9c867fbe "partitions: fix sometimes unreadable partition strings" coverted one line within the ibm partition code incorrectly. Fix this to get rid of a build error. fs/partitions/ibm.c: In function 'ibm_partition': [...] fs/partitions/ibm.c:185: error: too many arguments to function 'strlcat' Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-08-11partitions: fix sometimes unreadable partition stringsAlexey Dobriyan
Fix this garbage happening quite often: ==> sda: scsi 3:0:0:0: CD-ROM TOSHIBA ==> sda1 sda2 sda3 sda4 <sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray ^^^ Uniform CD-ROM driver Revision: 3.20 sr 3:0:0:0: Attached scsi CD-ROM sr0 ==> sda5 sda6 sda7 > Make "sda: sda1 ..." lines actually lines. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-19[S390] dasd: use correct label location for diag fba disksPeter Oberparleiter
Partition boundary calculation fails for DASD FBA disks under the following conditions: - disk is formatted with CMS FORMAT with a blocksize of more than 512 bytes - all of the disk is reserved to a single CMS file using CMS RESERVE - the disk is accessed using the DIAG mode of the DASD driver Under these circumstances, the partition detection code tries to read the CMS label block containing partition-relevant information from logical block offset 1, while it is in fact located at physical block offset 1. Fix this problem by using the correct CMS label block location depending on the device type as determined by the DASD SENSE ID information. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-05-21block: use struct parsed_partitions *state universally in partition check codeTejun Heo
Make the following changes to partition check code. * Add ->bdev to struct parsed_partitions. * Introduce read_part_sector() which is a simple wrapper around read_dev_sector() which takes struct parsed_partitions *state instead of @bdev. * For functions which used to take @state and @bdev, drop @bdev. For functions which used to take @bdev, replace it with @state. * While updating, drop superflous checks on NULL state/bdev in ldm.c. This cleans up the API a bit and enables better handling of IO errors during partition check as the generic partition check code now has much better visibility into what went wrong in the low level code paths. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ben Hutchings <ben@decadent.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26[S390] dasd: add large volume supportStefan Weinhuber
The dasd device driver will now support ECKD devices with more then 65520 cylinders. In the traditional ECKD adressing scheme each track is addressed by a 16-bit cylinder and 16-bit head number. The new addressing scheme makes use of the fact that the actual number of heads is never larger then 15, so 12 bits of the head number can be redefined to be part of the cylinder address. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-07-10[S390] fixed cdl-format detection.Stefan Haberland
CDL formated DASDs are now detected correctly even if no VOL1 label is on the disk. This prevents possible loss of data. Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-07[PATCH] Fix check_partition routinesSuzuki K P
check_partition() stops its probe once it hits an I/O error from the partition checkers. This would prevent the actual partition checker getting a chance to verify the partition. So this patch lets check_partition() continue probing untill it hits a success while recording the I/O error which might have been reported by the checking routines. Also, it does some cleanup of the partition methods for ibm, atari and amiga to return -1 upon hitting an I/O error. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s390: Remove old history/whitespave from partition codeHorst Hummel
Remove obsolete history and trailing whitespace. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08[PATCH] s390: dasd partition detectionHorst Hummel
DASD allows to open a device as soon as gendisk is registered, which means the device is a fake device (capacity=0) and we do know nothing about blocksize and partitions at that point of time. In case the device is opened by someone, the bdev and inode creation is done with the fake device info and the following partition detection code is just using the wrong data. To avoid this modify the DASD state machine to make sure that the open is rejected until the device analysis is either finished or an unformatted device was detected. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cms volume label definitionsPeter Oberparleiter
Moved definition of CMS volume label to vtoc.h and modify partitions/ibm.c to use this volume label definition instead of anonymous array. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] s390: cleanup of include/asm-s390/vtoc.hPeter Oberparleiter
