commit 9883035ae7edef3ec62ad215611cb8e17d6a1a5d upstream.
The actual internal pipe implementation is already really about
individual packets (called "pipe buffers"), and this simply exposes that
as a special packetized mode.
When we are in the packetized mode (marked by O_DIRECT as suggested by
Alan Cox), a write() on a pipe will not merge the new data with previous
writes, so each write will get a pipe buffer of its own. The pipe
buffer is then marked with the PIPE_BUF_FLAG_PACKET flag, which in turn
will tell the reader side to break the read at that boundary (and throw
away any partial packet contents that do not fit in the read buffer).
End result: as long as you do writes less than PIPE_BUF in size (so that
the pipe doesn't have to split them up), you can now treat the pipe as a
packet interface, where each read() system call will read one packet at
a time. You can just use a sufficiently big read buffer (PIPE_BUF is
sufficient, since bigger than that doesn't guarantee atomicity anyway),
and the return value of the read() will naturally give you the size of
the packet.
NOTE! We do not support zero-sized packets, and zero-sized reads and
writes to a pipe continue to be no-ops. Also note that big packets will
currently be split at write time, but that the size at which that
happens is not really specified (except that it's bigger than PIPE_BUF).
Currently that limit is the system page size, but we might want to
explicitly support bigger packets some day.
The main user for this is going to be the autofs packet interface,
allowing us to stop having to care so deeply about exact packet sizes
(which have had bugs with 32/64-bit compatibility modes). But user
space can create packetized pipes with "pipe2(fd, O_DIRECT)", which will
fail with an EINVAL on kernels that do not support this interface.
Tested-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Ian Kent <raven@themaw.net>
Cc: Thomas Meyer <thomas@m3y3r.de>
Currently a statfs on a pipe's /proc/<pid>/fd/ link returns -ENOSYS. Wire
pipfs up so that the statfs succeeds.
This is required by checkpoint-restart in the userspace to make it
possible to distinguish pipes from fifos.
When we dump information about task's open files we use the /proc/pid/fd
directoy's symlinks and the fact that opening any of them gives us exactly
the same dentry->inode pair as the original process has. Now if a task
we're dumping has opened pipe and fifo we need to detect this and act
accordingly. Knowing that an fd with type S_ISFIFO resides on a pipefs is
the most precise way.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Workloads using pipes and sockets hit inode_sb_list_lock contention.
superblock s_inodes list is needed for quota, dirty, pagecache and
fsnotify management. pipe/anon/socket fs are clearly not candidates for
these.
For a number of file systems that don't have a mount point (e.g. sockfs
and pipefs), they are not marked as long term. Therefore in
mntput_no_expire, all locks in vfs_mount lock are taken instead of just
local cpu's lock to aggregate reference counts when we release
reference to file objects. In fact, only local lock need to have been
taken to update ref counts as these file systems are in no danger of
going away until we are ready to unregister them.
The attached patch marks file systems using kern_mount without
mount point as long term. The contentions of vfs_mount lock
is now eliminated. Before un-registering such file system,
kern_unmount should be called to remove the long term flag and
make the mount point ready to be freed.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Commit e462c448fdc8 ("pipe: use event aware wakeups") optimized the pipe
event wakeup calls to avoid wakeups if the events do not match the
requested set.
However, the optimization was buggy, in that it didn't actually use the
correct sets for the events: when we make room for more data to be
written, the pipe poll() routine will return both the POLLOUT _and_
POLLWRNORM bits. Similarly for read.
And most critically, when a pipe is released, that will potentially
result in POLLHUP|POLLERR (depending on whether it was the last reader
or writer), not just the regular POLLIN|POLLOUT.
This bug showed itself as a hung gnome-screensaver-dialog process, stuck
forever (or at least until it was poked by a signal or by being traced)
in a poll() system call.
Cc: Davide Libenzi <davidel@xmailserver.org>
Instead of splitting refcount between (per-cpu) mnt_count
and (SMP-only) mnt_longrefs, make all references contribute
to mnt_count again and keep track of how many are longterm
ones.
Accounting rules for longterm count:
* 1 for each fs_struct.root.mnt
* 1 for each fs_struct.pwd.mnt
* 1 for having non-NULL ->mnt_ns
* decrement to 0 happens only under vfsmount lock exclusive
That allows nice common case for mntput() - since we can't drop the
final reference until after mnt_longterm has reached 0 due to the rules
above, mntput() can grab vfsmount lock shared and check mnt_longterm.
If it turns out to be non-zero (which is the common case), we know
that this is not the final mntput() and can just blindly decrement
percpu mnt_count. Otherwise we grab vfsmount lock exclusive and
do usual decrement-and-check of percpu mnt_count.
For fs_struct.c we have mnt_make_longterm() and mnt_make_shortterm();
namespace.c uses the latter in places where we don't already hold
vfsmount lock exclusive and opencodes a few remaining spots where
we need to manipulate mnt_longterm.
Note that we mostly revert the code outside of fs/namespace.c back
to what we used to have; in particular, normal code doesn't need
to care about two kinds of references, etc. And we get to keep
the optimization Nick's variant had bought us...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits)
fs: add documentation on fallocate hole punching
Gfs2: fail if we try to use hole punch
Btrfs: fail if we try to use hole punch
Ext4: fail if we try to use hole punch
Ocfs2: handle hole punching via fallocate properly
XFS: handle hole punching via fallocate properly
fs: add hole punching to fallocate
vfs: pass struct file to do_truncate on O_TRUNC opens (try #2)
fix signedness mess in rw_verify_area() on 64bit architectures
fs: fix kernel-doc for dcache::prepend_path
fs: fix kernel-doc for dcache::d_validate
sanitize ecryptfs ->mount()
switch afs
move internal-only parts of ncpfs headers to fs/ncpfs
switch ncpfs
switch 9p
pass default dentry_operations to mount_pseudo()
switch hostfs
switch affs
switch configfs
Send the events the wakeup refers to, so that epoll, and even the new poll
code in fs/select.c can avoid wakeups if the events do not match the
requested set.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
The problem that this patch aims to fix is vfsmount refcounting scalability.
We need to take a reference on the vfsmount for every successful path lookup,
which often go to the same mount point.
The fundamental difficulty is that a "simple" reference count can never be made
scalable, because any time a reference is dropped, we must check whether that
was the last reference. To do that requires communication with all other CPUs
that may have taken a reference count.
We can make refcounts more scalable in a couple of ways, involving keeping
distributed counters, and checking for the global-zero condition less
frequently.
- check the global sum once every interval (this will delay zero detection
for some interval, so it's probably a showstopper for vfsmounts).
- keep a local count and only taking the global sum when local reaches 0 (this
is difficult for vfsmounts, because we can't hold preempt off for the life of
a reference, so a counter would need to be per-thread or tied strongly to a
particular CPU which requires more locking).
- keep a local difference of increments and decrements, which allows us to sum
the total difference and hence find the refcount when summing all CPUs. Then,
keep a single integer "long" refcount for slow and long lasting references,
and only take the global sum of local counters when the long refcount is 0.
This last scheme is what I implemented here. Attached mounts and process root
and working directory references are "long" references, and everything else is
a short reference.
This allows scalable vfsmount references during path walking over mounted
subtrees and unattached (lazy umounted) mounts with processes still running
in them.
This results in one fewer atomic op in the fastpath: mntget is now just a
per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock
and non-atomic decrement in the common case. However code is otherwise bigger
and heavier, so single threaded performance is basically a wash.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Regardless of how much we possibly try to scale dcache, there is likely
always going to be some fundamental contention when adding or removing children
under the same parent. Pseudo filesystems do not seem need to have connected
dentries because by definition they are disconnected.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Pseudo filesystems that don't put inode on RCU list or reachable by
rcu-walk dentries do not need to RCU free their inodes.
This avoids some include-file hell, and the function isn't really
important enough to be inlined anyway.
Reported-by: Ingo Molnar <mingo@elte.hu>
And in particular, use it in 'pipe_fcntl()'.
The other pipe functions do not need to use the 'careful' version, since
they are only ever called for things that are already known to be pipes.
The normal read/write/ioctl functions are called through the file
operations structures, so if a file isn't a pipe, they'd never get
called. But pipe_fcntl() is special, and called directly from the
generic fcntl code, and needs to use the same careful function that the
splice code is using.
Cc: Jens Axboe <jaxboe@fusionio.com>
Cc: Dave Jones <davej@redhat.com>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
The arguments were transposed, we want to assign the error code to
'ret', which is being returned.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Cc: stable@kernel.org
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
As it stands this check compares the number of pages to the page size.
This makes no sense and makes the fcntl fail in almost any sane case.
Fix it by checking if nr_pages is not zero (it can become zero only if
arg is too big and round_pipe_size() overflows).
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
pipe_set_size() needs to copy pipe bufs from the old circular buffer
to the new.
The current code gets this wrong in multiple ways, resulting in oops.
Test program is available here:
http://www.kernel.org/pub/linux/kernel/people/mszeredi/piperesize/
This changes the interface to be based on bytes instead. The API
matches that of F_SETPIPE_SZ in that it rounds up the passed in
size so that the resulting page array is a power-of-2 in size.
The proc file is renamed to /proc/sys/fs/pipe-max-size to
reflect this change.
Change it to CAP_SYS_RESOURCE, as that more accurately models what
we want to control.
Suggested-by: Michael Kerrisk <mtk.manpages@googlemail.com>
We don't need to pages to guarantee the POSIX requirement
that upto a page size write must be atomic to an empty
pipe.
fs/pipe.c
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
mm: export generic_pipe_buf_*() to modules
fuse: support splice() reading from fuse device
fuse: allow splice to move pages
mm: export remove_from_page_cache() to modules
mm: export lru_cache_add_*() to modules
fuse: support splice() writing to fuse device
fuse: get page reference for readpages
fuse: use get_user_pages_fast()
fuse: remove unneeded variable
Add a mutex_unlock missing on the error path. At other exists from the
function that return an error flag, the mutex is unlocked, so do the same
here.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression E1;
* mutex_lock(E1,...);
<+... when != E1
if (...) {
... when != E1
* return ...;
* mutex_unlock(E1,...);
// </smpl>
This is needed by fuse device code which wants to create pipe buffers.
Instead of requiring an exact number of pages as the argument and
return value, change the API to deal with number of bytes instead.
This also relaxes the requirement that the passed in size must
result in a power-of-2 page array size. Round up to the nearest
power-of-2 automatically and return the resulting size of the pipe
on success.
If the passed in size is larger than what has been set as the
system wide limit and the user is not root, we want to return
permission denied (not invalid value).
We need at least two to guarantee proper POSIX behaviour, so
never allow a smaller limit than that.
Also expose a /proc/sys/fs/pipe-max-pages sysctl file that allows
root to define a sane upper limit. Make it default to 16 times the
default size, which is 16 pages.
This patch adds F_GETPIPE_SZ and F_SETPIPE_SZ fcntl() actions for
growing and shrinking the size of a pipe and adjusts pipe.c and splice.c
(and relay and network splice) usage to work with these larger (or smaller)
pipes.
Filesystems outside the regular namespace do not have to clear DCACHE_UNHASHED
in order to have a working /proc/$pid/fd/XXX. Nothing in proc prevents the
fd link from being used if its dentry is not in the hash.
Also, it does not get put into the dcache hash if DCACHE_UNHASHED is clear;
that depends on the filesystem calling d_add or d_rehash.
So delete the misleading comments and needless code.
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
Signed-off-by: Nick Piggin <npiggin@suse.de>
... and have the caller grab both mnt and dentry; kill
leak in infiniband, while we are at it.
This patch fixes a null pointer exception in pipe_rdwr_open() which
generates the stack trace:
> Unable to handle kernel NULL pointer dereference at 0000000000000028 RIP:
> [<ffffffff802899a5>] pipe_rdwr_open+0x35/0x70
> [<ffffffff8028125c>] __dentry_open+0x13c/0x230
> [<ffffffff8028143d>] do_filp_open+0x2d/0x40
> [<ffffffff802814aa>] do_sys_open+0x5a/0x100
> [<ffffffff8021faf3>] sysenter_do_call+0x1b/0x67
The failure mode is triggered by an attempt to open an anonymous
pipe via /proc/pid/fd/* as exemplified by this script:
while : ; do
{ echo y ; sleep 1 ; } | { while read ; do echo z$REPLY; done ; } &
PID=$!
OUT=$(ps -efl | grep 'sleep 1' | grep -v grep |
{ read PID REST ; echo $PID; } )
OUT="${OUT%% *}"
DELAY=$((RANDOM * 1000 / 32768))
usleep $((DELAY * 1000 + RANDOM % 1000 ))
echo n > /proc/$OUT/fd/1 # Trigger defect
done
Note that the failure window is quite small and I could only
reliably reproduce the defect by inserting a small delay
in pipe_rdwr_open(). For example:
static int
pipe_rdwr_open(struct inode *inode, struct file *filp)
msleep(100);
mutex_lock(&inode->i_mutex);
Although the defect was observed in pipe_rdwr_open(), I think it
makes sense to replicate the change through all the pipe_*_open()
functions.
The core of the change is to verify that inode->i_pipe has not
been released before attempting to manipulate it. If inode->i_pipe
is no longer present, return ENOENT to indicate so.
The comment about potentially using atomic_t for i_pipe->readers
and i_pipe->writers has also been removed because it is no longer
relevant in this context. The inode->i_mutex lock must be used so
that inode->i_pipe can be dealt with correctly.
Signed-off-by: Earl Chew <earl_chew@agilent.com>
The presumed use of the pipe_double_lock() routine is to lock 2 locks in
a deadlock free way by ordering the locks by their address. However it
fails to keep the specified lock classes in order and explicitly
annotates a deadlock.
Rectify this.
LKML-Reference: <1248163763.15751.11098.camel@twins>
If f_op->splice_read() is not implemented, fall back to a plain read.
Use vfs_readv() to read into previously allocated pages.
This will allow splice and functions using splice, such as the loop
device, to work on all filesystems. This includes "direct_io" files
in fuse which bypass the page cache.
There are lots of sequences like this, especially in splice code:
if (pipe->inode)
mutex_lock(&pipe->inode->i_mutex);
/* do something */
if (pipe->inode)
mutex_unlock(&pipe->inode->i_mutex);
so introduce helpers which do the conditional locking and unlocking.
Also replace the inode_double_lock() call with a pipe_double_lock()
helper to avoid spreading the use of this functionality beyond the
pipe code.
This patch is just a cleanup, and should cause no behavioral changes.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits)
fs: avoid I_NEW inodes
Merge code for single and multiple-instance mounts
Remove get_init_pts_sb()
Move common mknod_ptmx() calls into caller
Parse mount options just once and copy them to super block
Unroll essentials of do_remount_sb() into devpts
vfs: simple_set_mnt() should return void
fs: move bdev code out of buffer.c
constify dentry_operations: rest
constify dentry_operations: configfs
constify dentry_operations: sysfs
constify dentry_operations: JFS
constify dentry_operations: OCFS2
constify dentry_operations: GFS2
constify dentry_operations: FAT
constify dentry_operations: FUSE
constify dentry_operations: procfs
constify dentry_operations: ecryptfs
constify dentry_operations: CIFS
constify dentry_operations: AFS
The last user of do_pipe is in arch/alpha/, after replacing it with
do_pipe_flags, the do_pipe can be totally dropped.
Signed-off-by: Cheng Renquan <crquan@gmail.com>
Acked-by: Richard Henderson <rth@twiddle.net>
Most fasync implementations do something like:
return fasync_helper(...);
But fasync_helper() will return a positive value at times - a feature used
in at least one place. Thus, a number of other drivers do:
err = fasync_helper(...);
if (err < 0)
return err;
return 0;
In the interests of consistency and more concise code, it makes sense to
map positive return values onto zero where ->fasync() is called.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
If the second fasync_helper() fails, pipe_rdwr_fasync() returns the error
but leaves the file on ->fasync_readers.
This was always wrong, but since 233e70f4228e78eb2f80dc6650f65d3ae3dbf17c
"saner FASYNC handling on file close" we have the new problem. Because in
this case setfl() doesn't set FASYNC bit, __fput() will not do
->fasync(0), and we leak fasync_struct with ->fa_file pointing to the
freed file.
Cc: Jonathan Corbet <corbet@lwn.net>
Remove __attribute__((weak)) from common code sys_pipe implemantation.
IA64, ALPHA, SUPERH (32bit) and SPARC (32bit) have own implemantations
with the same name. Just rename them.
For sys_pipe2 there is no architecture specific implementation.
Cc: Richard Henderson <rth@twiddle.net>
* no allocations
* return void
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
As it is, all instances of ->release() for files that have ->fasync()
need to remember to evict file from fasync lists; forgetting that
creates a hole and we actually have a bunch that *does* forget.
So let's keep our lives simple - let __fput() check FASYNC in
file->f_flags and call ->fasync() there if it's been set. And lose that
crap in ->release() instances - leaving it there is still valid, but we
don't have to bother anymore.
Merge fifo and pipe file_operations.
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com>
