[ Upstream commit 5ec0811d30378ae104f250bfc9b3640242d81e3f ]
When the first propgated copy was a slave the following oops would result:
> BUG: unable to handle kernel NULL pointer dereference at 0000000000000010
> IP: [<ffffffff811fba4e>] propagate_one+0xbe/0x1c0
> PGD bacd4067 PUD bac66067 PMD 0
> Oops: 0000 [#1] SMP
> Modules linked in:
> CPU: 1 PID: 824 Comm: mount Not tainted 4.6.0-rc5userns+ #1523
> Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
> task: ffff8800bb0a8000 ti: ffff8800bac3c000 task.ti: ffff8800bac3c000
> RIP: 0010:[<ffffffff811fba4e>] [<ffffffff811fba4e>] propagate_one+0xbe/0x1c0
> RSP: 0018:ffff8800bac3fd38 EFLAGS: 00010283
> RAX: 0000000000000000 RBX: ffff8800bb77ec00 RCX: 0000000000000010
> RDX: 0000000000000000 RSI: ffff8800bb58c000 RDI: ffff8800bb58c480
> RBP: ffff8800bac3fd48 R08: 0000000000000001 R09: 0000000000000000
> R10: 0000000000001ca1 R11: 0000000000001c9d R12: 0000000000000000
> R13: ffff8800ba713800 R14: ffff8800bac3fda0 R15: ffff8800bb77ec00
> FS: 00007f3c0cd9b7e0(0000) GS:ffff8800bfb00000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
> CR2: 0000000000000010 CR3: 00000000bb79d000 CR4: 00000000000006e0
> Stack:
> ffff8800bb77ec00 0000000000000000 ffff8800bac3fd88 ffffffff811fbf85
> ffff8800bac3fd98 ffff8800bb77f080 ffff8800ba713800 ffff8800bb262b40
> 0000000000000000 0000000000000000 ffff8800bac3fdd8 ffffffff811f1da0
> Call Trace:
> [<ffffffff811fbf85>] propagate_mnt+0x105/0x140
> [<ffffffff811f1da0>] attach_recursive_mnt+0x120/0x1e0
> [<ffffffff811f1ec3>] graft_tree+0x63/0x70
> [<ffffffff811f1f6b>] do_add_mount+0x9b/0x100
> [<ffffffff811f2c1a>] do_mount+0x2aa/0xdf0
> [<ffffffff8117efbe>] ? strndup_user+0x4e/0x70
> [<ffffffff811f3a45>] SyS_mount+0x75/0xc0
> [<ffffffff8100242b>] do_syscall_64+0x4b/0xa0
> [<ffffffff81988f3c>] entry_SYSCALL64_slow_path+0x25/0x25
> Code: 00 00 75 ec 48 89 0d 02 22 22 01 8b 89 10 01 00 00 48 89 05 fd 21 22 01 39 8e 10 01 00 00 0f 84 e0 00 00 00 48 8b 80 d8 00 00 00 <48> 8b 50 10 48 89 05 df 21 22 01 48 89 15 d0 21 22 01 8b 53 30
> RIP [<ffffffff811fba4e>] propagate_one+0xbe/0x1c0
> RSP <ffff8800bac3fd38>
> ---[ end trace 2725ecd95164f217 ]---
This oops happens with the namespace_sem held and can be triggered by
non-root users. An all around not pleasant experience.
To avoid this scenario when finding the appropriate source mount to
copy stop the walk up the mnt_master chain when the first source mount
is encountered.
Further rewrite the walk up the last_source mnt_master chain so that
it is clear what is going on.
The reason why the first source mount is special is that it it's
mnt_parent is not a mount in the dest_mnt propagation tree, and as
such termination conditions based up on the dest_mnt mount propgation
tree do not make sense.
To avoid other kinds of confusion last_dest is not changed when
computing last_source. last_dest is only used once in propagate_one
and that is above the point of the code being modified, so changing
the global variable is meaningless and confusing.
Cc: stable@vger.kernel.org
fixes: f2ebb3a921c1ca1e2ddd9242e95a1989a50c4c68 ("smarter propagate_mnt()")
Reported-by: Tycho Andersen <tycho.andersen@canonical.com>
Reviewed-by: Seth Forshee <seth.forshee@canonical.com>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
[ Upstream commit 7ae8fd0351f912b075149a1e03a017be8b903b9a ]
propagate_one(m) calculates "type" argument for copy_tree() like this:
> if (m->mnt_group_id == last_dest->mnt_group_id) {
> type = CL_MAKE_SHARED;
> } else {
> type = CL_SLAVE;
> if (IS_MNT_SHARED(m))
> type |= CL_MAKE_SHARED;
The "type" argument then governs clone_mnt() behavior with respect to flags
and mnt_master of new mount. When we iterate through a slave group, it is
possible that both current "m" and "last_dest" are not shared (although,
both are slaves, i.e. have non-NULL mnt_master-s). Then the comparison
above erroneously makes new mount shared and sets its mnt_master to
last_source->mnt_master. The patch fixes the problem by handling zero
mnt_group_id-s as though they are unequal.
The similar problem exists in the implementation of "else" clause above
when we have to ascend upward in the master/slave tree by calling:
> last_source = last_source->mnt_master;
> last_dest = last_source->mnt_parent;
proper number of times. The last step is governed by
"n->mnt_group_id != last_dest->mnt_group_id" condition that may lie if
both are zero. The patch fixes this case in the same way as the former one.
[AV: don't open-code an obvious helper...]
Signed-off-by: Maxim Patlasov <mpatlasov@virtuozzo.com>
If the first mount in shared subtree is locked don't unmount the
shared subtree.
This is ensured by walking through the mounts parents before children
and marking a mount as unmountable if it is not locked or it is locked
but it's parent is marked.
This allows recursive mount detach to propagate through a set of
mounts when unmounting them would not reveal what is under any locked
mount.
A prerequisite of calling umount_tree is that the point where the tree
is mounted at is valid to unmount.
If we are propagating the effect of the unmount clear MNT_LOCKED in
every instance where the same filesystem is mounted on the same
mountpoint in the mount tree, as we know (by virtue of the fact
that umount_tree was called) that it is safe to reveal what
is at that mountpoint.
- Modify __lookup_mnt_hash_last to ignore mounts that have MNT_UMOUNTED set.
- Don't remove mounts from the mount hash table in propogate_umount
- Don't remove mounts from the mount hash table in umount_tree before
the entire list of mounts to be umounted is selected.
- Remove mounts from the mount hash table as the last thing that
happens in the case where a mount has a parent in umount_tree.
Mounts without parents are not hashed (by definition).
This paves the way for delaying removal from the mount hash table even
farther and fixing the MNT_LOCKED vs MNT_DETACH issue.
In some instances it is necessary to know if the the unmounting
process has begun on a mount. Add MNT_UMOUNT to make that reliably
testable.
This fix gets used in fixing locked mounts in MNT_DETACH
umount_tree builds a list of mounts that need to be unmounted.
Utilize mnt_list for this purpose instead of mnt_hash. This begins to
allow keeping a mount on the mnt_hash after it is unmounted, which is
necessary for a properly functioning MNT_LOCKED implementation.
The fact that mnt_list is an ordinary list makding available list_move
is nice bonus.
Clear MNT_LOCKED in the callers of copy_tree except copy_mnt_ns, and
collect_mounts. In copy_mnt_ns it is necessary to create an exact
copy of a mount tree, so not clearing MNT_LOCKED is important.
Similarly collect_mounts is used to take a snapshot of the mount tree
for audit logging purposes and auditing using a faithful copy of the
tree is important.
This becomes particularly significant when we start setting MNT_LOCKED
on rootfs to prevent it from being unmounted.
The check in __propagate_umount() ("has somebody explicitly mounted
something on that slave?") is done *before* taking the already doomed
victims out of the child lists.
The current mainline has copies propagated to *all* nodes, then
tears down the copies we made for nodes that do not contain
counterparts of the desired mountpoint. That sets the right
propagation graph for the copies (at teardown time we move
the slaves of removed node to a surviving peer or directly
to master), but we end up paying a fairly steep price in
useless allocations. It's fairly easy to create a situation
where N calls of mount(2) create exactly N bindings, with
O(N^2) vfsmounts allocated and freed in process.
Fortunately, it is possible to avoid those allocations/freeings.
The trick is to create copies in the right order and find which
one would've eventually become a master with the current algorithm.
It turns out to be possible in O(nodes getting propagation) time
and with no extra allocations at all.
One part is that we need to make sure that eventual master will be
created before its slaves, so we need to walk the propagation
tree in a different order - by peer groups. And iterate through
the peers before dealing with the next group.
Another thing is finding the (earlier) copy that will be a master
of one we are about to create; to do that we are (temporary) marking
the masters of mountpoints we are attaching the copies to.
Either we are in a peer of the last mountpoint we'd dealt with,
or we have the following situation: we are attaching to mountpoint M,
the last copy S_0 had been attached to M_0 and there are sequences
S_0...S_n, M_0...M_n such that S_{i+1} is a master of S_{i},
S_{i} mounted on M{i} and we need to create a slave of the first S_{k}
such that M is getting propagation from M_{k}. It means that the master
of M_{k} will be among the sequence of masters of M. On the
other hand, the nearest marked node in that sequence will either
be the master of M_{k} or the master of M_{k-1} (the latter -
in the case if M_{k-1} is a slave of something M gets propagation
from, but in a wrong peer group).
So we go through the sequence of masters of M until we find
a marked one (P). Let N be the one before it. Then we go through
the sequence of masters of S_0 until we find one (say, S) mounted
on a node D that has P as master and check if D is a peer of N.
If it is, S will be the master of new copy, if not - the master of S
will be.
That's it for the hard part; the rest is fairly simple. Iterator
is in next_group(), handling of one prospective mountpoint is
propagate_one().
It seems to survive all tests and gives a noticably better performance
than the current mainline for setups that are seriously using shared
subtrees.
fixes RCU bug - walking through hlist is safe in face of element moves,
since it's self-terminating. Cyclic lists are not - if we end up jumping
to another hash chain, we'll loop infinitely without ever hitting the
original list head.
[fix for dumb braino folded]
Spotted by: Max Kellermann <mk@cm4all.com>
Instead of passing the direction as argument (and checking it on every
step through the hash chain), just have separate __lookup_mnt() and
__lookup_mnt_last(). And use the standard iterators...
aka br_write_{lock,unlock} of vfsmount_lock. Inlines in fs/mount.h,
vfsmount_lock extern moved over there as well.
When the group id of a shared mount is not allocated, the umount still
tries to call mnt_release_group_id(), which eventually hits a kernel
warning at ida_remove() spewing a message like:
ida_remove called for id=0 which is not allocated.
This patch fixes the bug simply checking the group id in the caller.
Reported-by: Cristian Rodríguez <crrodriguez@opensuse.org>
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
which allows to kill the last argument of umount_tree() and make release_mounts()
static.
As a matter of policy MNT_READONLY should not be changable if the
original mounter had more privileges than creator of the mount
namespace.
Add the flag CL_UNPRIVILEGED to note when we are copying a mount from
a mount namespace that requires more privileges to a mount namespace
that requires fewer privileges.
When the CL_UNPRIVILEGED flag is set cause clone_mnt to set MNT_NO_REMOUNT
if any of the mnt flags that should never be changed are set.
This protects both mount propagation and the initial creation of a less
privileged mount namespace.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Andy Lutomirski <luto@amacapital.net>
copy_tree() can theoretically fail in a case other than ENOMEM, but always
returns NULL which is interpreted by callers as -ENOMEM. Change it to return
an explicit error.
Also change clone_mnt() for consistency and because union mounts will add new
error cases.
Thanks to Andreas Gruenbacher <agruen@suse.de> for a bug fix.
[AV: folded braino fix by Dan Carpenter]
Original-author: Valerie Aurora <vaurora@redhat.com>
Cc: Valerie Aurora <valerie.aurora@gmail.com>
Cc: Andreas Gruenbacher <agruen@suse.de>
lglocks and brlocks are currently generated with some complicated macros
in lglock.h. But there's no reason to not just use common utility
functions and put all the data into a common data structure.
In preparation, this patch changes the API to look more like normal
function calls with pointers, not magic macros.
The patch is rather large because I move over all users in one go to keep
it bisectable. This impacts the VFS somewhat in terms of lines changed.
But no actual behaviour change.
[akpm@linux-foundation.org: checkpatch fixes]
make IS_MNT_SLAVE take struct mount * at the same time
next pile of horrors, similar to mnt_parent one; this time it's
mnt_master.
the second victim...
taken out of struct vfsmount into struct mount
switch __lookup_mnt() to returning struct mount *; callers adjusted.
a) mount --move is checking that ->mnt_parent is non-NULL before
looking if that parent happens to be shared; ->mnt_parent is never
NULL and it's not even an misspelled !mnt_has_parent()
b) pivot_root open-codes is_path_reachable(), poorly.
c) so does path_is_under(), while we are at it.
vfsmounts have ->mnt_parent pointing either to a different vfsmount
or to itself; it's never NULL and termination condition in loops
traversing the tree towards root is mnt == mnt->mnt_parent. At least
one place (see the next patch) is confused about what's going on;
let's add an explicit helper checking it right way and use it in
all places where we need it. Not that there had been too many,
but...
