path: root/fs/posix_acl.c
2012-09-18userns: Convert vfs posix_acl support to use kuids and kgidsEric W. Biederman
- In setxattr if we are setting a posix acl convert uids and gids from the current user namespace into the initial user namespace, before the xattrs are passed to the underlying filesystem. Untranslatable uids and gids are represented as -1 which posix_acl_from_xattr will represent as INVALID_UID or INVALID_GID. posix_acl_valid will fail if an acl from userspace has any INVALID_UID or INVALID_GID values. In net this guarantees that untranslatable posix acls will not be stored by filesystems. - In getxattr if we are reading a posix acl convert uids and gids from the initial user namespace into the current user namespace. Uids and gids that can not be tranlsated into the current user namespace will be represented as -1. - Replace e_id in struct posix_acl_entry with an anymouns union of e_uid and e_gid. For the short term retain the e_id field until all of the users are converted. - Don't set struct posix_acl.e_id in the cases where the acl type does not use e_id. Greatly reducing the use of ACL_UNDEFINED_ID. - Rework the ordering checks in posix_acl_valid so that I use kuid_t and kgid_t types throughout the code, and so that I don't need arithmetic on uid and gid types. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-28vfs: pass all mask flags check_acl and posix_acl_permissionAndreas Gruenbacher
Acked-by: J. Bruce Fields <bfields@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andreas Gruenbacher <agruen@kernel.org> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-08-01switch posix_acl_chmod() to umode_tAl Viro
again, that's what all callers pass to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_from_mode() to umode_tAl Viro
... seeing that this is what all callers pass to it anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25bury posix_acl_..._masq() variantsAl Viro
made static; no callers left outside of posix_acl.c. posix_acl_clone() also has lost all external callers and became static... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-25NFS: Prevent memory allocation failure in nfsacl_encode()Chuck Lever
nfsacl_encode() allocates memory in certain cases. This of course is not guaranteed to work. Since commit 9f06c719 "SUNRPC: New xdr_streams XDR encoder API", the kernel's XDR encoders can't return a result indicating possibly a failure, so a memory allocation failure in nfsacl_encode() has become fatal (ie, the XDR code Oopses) in some cases. However, the allocated memory is a tiny fixed amount, on the order of 40-50 bytes. We can easily use a stack-allocated buffer for this, with only a wee bit of nose-holding. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-11-14CRED: Wrap task credential accesses in the filesystem subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2006-10-01[PATCH] kmemdup: some usersAlexey Dobriyan
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
