[ Upstream commit 073931017b49d9458aa351605b43a7e34598caef ]
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Philipp Hahn <hahn@univention.de>
[ Upstream commit 485e71e8fb6356c08c7fc6bcce4bf02c9a9a663f ]
Factor out part of posix_acl_xattr_set into a common function that takes
a posix_acl, which nfsd can also call.
The prototype already exists in include/linux/posix_acl.h.
Cc: stable@vger.kernel.org
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
get_acl gets a reference which we must release in the error cases.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
Various filesystems don't bother checking for a NULL ACL in
posix_acl_equiv_mode, and thus can dereference a NULL pointer when it
gets passed one. This usually happens from the NFS server, as the ACL tools
never pass a NULL ACL, but instead of one representing the mode bits.
Instead of adding boilerplat to all filesystems put this check into one place,
which will allow us to remove the check from other filesystems as well later
on.
Reported-by: Ben Greear <greearb@candelatech.com>
Reported-by: Marco Munderloh <munderl@tnt.uni-hannover.de>,
Cc: Chuck Lever <chuck.lever@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw
Pull GFS2 updates from Steven Whitehouse:
"One of the main highlights this time, is not the patches themselves
but instead the widening contributor base. It is good to see that
interest is increasing in GFS2, and I'd like to thank all the
contributors to this patch set.
In addition to the usual set of bug fixes and clean ups, there are
patches to improve inode creation performance when xattrs are required
and some improvements to the transaction code which is intended to
help improve scalability after further changes in due course.
Journal extent mapping is also updated to make it more efficient and
again, this is a foundation for future work in this area.
The maximum number of ACLs has been increased to 300 (for a 4k block
size) which means that even with a few additional xattrs from selinux,
everything should fit within a single fs block.
There is also a patch to bring GFS2's own copy of the writepages code
up to the same level as the core VFS. Eventually we may be able to
merge some of this code, since it is fairly similar.
The other major change this time, is bringing consistency to the
printing of messages via fs_<level>, pr_<level> macros"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw: (29 commits)
GFS2: Fix address space from page function
GFS2: Fix uninitialized VFS inode in gfs2_create_inode
GFS2: Fix return value in slot_get()
GFS2: inline function gfs2_set_mode
GFS2: Remove extraneous function gfs2_security_init
GFS2: Increase the max number of ACLs
GFS2: Re-add a call to log_flush_wait when flushing the journal
GFS2: Ensure workqueue is scheduled after noexp request
GFS2: check NULL return value in gfs2_ok_to_move
GFS2: Convert gfs2_lm_withdraw to use fs_err
GFS2: Use fs_<level> more often
GFS2: Use pr_<level> more consistently
GFS2: Move recovery variables to journal structure in memory
GFS2: global conversion to pr_foo()
GFS2: return -E2BIG if hit the maximum limits of ACLs
GFS2: Clean up journal extent mapping
GFS2: replace kmalloc - __vmalloc / memset 0
GFS2: Remove extra "if" in gfs2_log_flush()
fs: NULL dereference in posix_acl_to_xattr()
GFS2: Move log buffer accounting to transaction
This patch moves the dereference of "buffer" after the check for NULL.
The only place which passes a NULL parameter is gfs2_set_acl().
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
posix_acl_xattr_get requires get_acl() to return EOPNOTSUPP if the
filesystem cannot support acls. This is needed for NFS, which can't
know whether or not the server supports acls until it tries to get/set
one.
This patch converts posix_acl_chmod and posix_acl_create to deal with
EOPNOTSUPP return values from get_acl().
Reported-by: Russell King <linux@arm.linux.org.uk>
Link: http://lkml.kernel.org/r/20140130140834.GW15937@n2100.arm.linux.org.uk
Cc: Al Viro viro@zeniv.linux.org.uk>
Tested-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Pull vfs updates from Al Viro:
"Assorted stuff; the biggest pile here is Christoph's ACL series. Plus
assorted cleanups and fixes all over the place...
There will be another pile later this week"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits)
__dentry_path() fixes
vfs: Remove second variable named error in __dentry_path
vfs: Is mounted should be testing mnt_ns for NULL or error.
Fix race when checking i_size on direct i/o read
hfsplus: remove can_set_xattr
nfsd: use get_acl and ->set_acl
fs: remove generic_acl
nfs: use generic posix ACL infrastructure for v3 Posix ACLs
gfs2: use generic posix ACL infrastructure
jfs: use generic posix ACL infrastructure
xfs: use generic posix ACL infrastructure
reiserfs: use generic posix ACL infrastructure
ocfs2: use generic posix ACL infrastructure
jffs2: use generic posix ACL infrastructure
hfsplus: use generic posix ACL infrastructure
f2fs: use generic posix ACL infrastructure
ext2/3/4: use generic posix ACL infrastructure
btrfs: use generic posix ACL infrastructure
fs: make posix_acl_create more useful
fs: make posix_acl_chmod more useful
And instead convert tmpfs to use the new generic ACL code, with two stub
methods provided for in-memory filesystems.
Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
With the ->set_acl inode operation we can implement the Posix ACL
xattr handlers in generic code instead of duplicating them all
over the tree.
Factor out the code to get an ACL either from the inode or disk from
check_acl, so that it can be used elsewhere later on.
So far, POSIX ACLs are using a canonical representation that keeps all ACL
entries in a strict order; the ACL_USER and ACL_GROUP entries for specific
users and groups are ordered by user and group identifier, respectively.
The user-space code provides ACL entries in this order; the kernel
verifies that the ACL entry order is correct in posix_acl_valid().
User namespaces allow to arbitrary map user and group identifiers which
can cause the ACL_USER and ACL_GROUP entry order to differ between user
space and the kernel; posix_acl_valid() would then fail.
Work around this by allowing ACL_USER and ACL_GROUP entries to be in any
order in the kernel. The effect is only minor: file permission checks
will pick the first matching ACL_USER entry, and check all matching
ACL_GROUP entries.
(The libacl user-space library and getfacl / setfacl tools will not create
ACLs with duplicate user or group idenfifiers; they will handle ACLs with
entries in an arbitrary order correctly.)
Signed-off-by: Andreas Gruenbacher <agruen@linbit.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Theodore Tso <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jan Kara <jack@suse.cz>
Uninline vast tracts of nested inline functions in
This reduces the text+data+bss size of x86_64 allyesconfig vmlinux by
8026 bytes.
The patch also regularises the positioning of the EXPORT_SYMBOLs in
posix_acl.c.
Cc: J. Bruce Fields <bfields@fieldses.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Tested-by: Benny Halevy <bhalevy@primarydata.com>
Cc: Benny Halevy <bhalevy@panasas.com>
Cc: Andreas Gruenbacher <agruen@suse.de>
- In setxattr if we are setting a posix acl convert uids and gids from
the current user namespace into the initial user namespace, before
the xattrs are passed to the underlying filesystem.
Untranslatable uids and gids are represented as -1 which
posix_acl_from_xattr will represent as INVALID_UID or INVALID_GID.
posix_acl_valid will fail if an acl from userspace has any
INVALID_UID or INVALID_GID values. In net this guarantees that
untranslatable posix acls will not be stored by filesystems.
- In getxattr if we are reading a posix acl convert uids and gids from
the initial user namespace into the current user namespace.
Uids and gids that can not be tranlsated into the current user namespace
will be represented as -1.
- Replace e_id in struct posix_acl_entry with an anymouns union of
e_uid and e_gid. For the short term retain the e_id field
until all of the users are converted.
- Don't set struct posix_acl.e_id in the cases where the acl type
does not use e_id. Greatly reducing the use of ACL_UNDEFINED_ID.
- Rework the ordering checks in posix_acl_valid so that I use kuid_t
and kgid_t types throughout the code, and so that I don't need
arithmetic on uid and gid types.
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
Acked-by: J. Bruce Fields <bfields@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruen@kernel.org>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
again, that's what all callers pass to it
... seeing that this is what all callers pass to it anyway.
... so that &inode->i_mode could be passed to it
so we can pass &inode->i_mode to it
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
made static; no callers left outside of posix_acl.c. posix_acl_clone() also
has lost all external callers and became static...
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with
modified clone, on failure releases acl and replaces with NULL.
Returns 0 or -ve on error. All callers of posix_acl_create_masq()
switched.
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified
clone or with NULL if that has failed; returns 0 or -ve on error. All
callers of posix_acl_chmod_masq() switched to that - they'd been doing
exactly the same thing.
nfsacl_encode() allocates memory in certain cases. This of course
is not guaranteed to work.
Since commit 9f06c719 "SUNRPC: New xdr_streams XDR encoder API", the
kernel's XDR encoders can't return a result indicating possibly a
failure, so a memory allocation failure in nfsacl_encode() has become
fatal (ie, the XDR code Oopses) in some cases.
However, the allocated memory is a tiny fixed amount, on the order
of 40-50 bytes. We can easily use a stack-allocated buffer for
this, with only a wee bit of nose-holding.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
- added typedef unsigned int __nocast gfp_t;
- replaced __nocast uses for gfp flags with gfp_t - it gives exactly
the same warnings as far as sparse is concerned, doesn't change
generated code (from gcc point of view we replaced unsigned int with
typedef) and documents what's going on far better.
infrastructure for it.
Let it rip!
