path: root/fs/proc/array.c
2008-05-31capabilities: remain source compatible with 32-bit raw legacy capability ↵Andrew G. Morgan
support. Source code out there hard-codes a notion of what the _LINUX_CAPABILITY_VERSION #define means in terms of the semantics of the raw capability system calls capget() and capset(). Its unfortunate, but true. Since the confusing header file has been in a released kernel, there is software that is erroneously using 64-bit capabilities with the semantics of 32-bit compatibilities. These recently compiled programs may suffer corruption of their memory when sys_getcap() overwrites more memory than they are coded to expect, and the raising of added capabilities when using sys_capset(). As such, this patch does a number of things to clean up the situation for all. It 1. forces the _LINUX_CAPABILITY_VERSION define to always retain its legacy value. 2. adopts a new #define strategy for the kernel's internal implementation of the preferred magic. 3. deprecates v2 capability magic in favor of a new (v3) magic number. The functionality of v3 is entirely equivalent to v2, the only difference being that the v2 magic causes the kernel to log a "deprecated" warning so the admin can find applications that may be using v2 inappropriately. [User space code continues to be encouraged to use the libcap API which protects the application from details like this. libcap-2.10 is the first to support v3 capabilities.] Fixes issue reported in https://bugzilla.redhat.com/show_bug.cgi?id=447518. Thanks to Bojan Smojver for the report. [akpm@linux-foundation.org: s/depreciate/deprecate/g] [akpm@linux-foundation.org: be robust about put_user size] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: Bojan Smojver <bojan@rexursive.com> Cc: stable@kernel.org Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org>
2008-05-13capabilities: add bounding set to /proc/self/statusSerge E. Hallyn
There is currently no way to query the bounding set of another task. As there appears to be no security reason not to, and as Michael Kerrisk points out the following valid reasons to do so exist: * consistency (I can see all of the other per-thread/process sets in /proc/.../status) * debugging -- I could imagine that it would make the job of debugging an application that uses capabilities a little simpler. this patch adds the bounding set to /proc/self/status right after the effective set. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Andrew G. Morgan <morgan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30tty_io: fix remaining pid struct lockingAlan Cox
This fixes the last couple of pid struct locking failures I know about. [oleg@tv-sign.ru: clean up do_task_stat()] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30do_task_stat: don't take rcu_read_lock()Oleg Nesterov
lock_task_sighand() was changed, and do_task_stat() doesn't need rcu_read_lock any longer. sighand->siglock protects all "interesting" fields. Except: it doesn't protect ->tty->pgrp, but neither does rcu_read_lock(), this should be fixed. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Pavel Emelyanov <xemul@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: seqfile convert proc_pid_status to properly handle pid namespacesEric W. Biederman
Currently we possibly lookup the pid in the wrong pid namespace. So seq_file convert proc_pid_status which ensures the proper pid namespaces is passed in. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: another build fix] [akpm@linux-foundation.org: s390 build fix] [akpm@linux-foundation.org: fix task_name() output] [akpm@linux-foundation.org: fix nommu build] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Andrew Morgan <morgan@kernel.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08seqfile convert proc_pid_statmEric W. Biederman
This conversion is just for code cleanliness, uniformity, and general safety. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08proc: rewrite do_task_stat to correctly handle pid namespaces.Eric W. Biederman
Currently (as pointed out by Oleg) do_task_stat has a race when calling task_pid_nr_ns with the task exiting. In addition do_task_stat is not currently displaying information in the context of the pid namespace that mounted the /proc filesystem. So "cut -d' ' -f 1 /proc/<pid>/stat" may not equal <pid>. This patch fixes the problem by converting to a single_open seq_file show method. Getting the pid namespace from the filesystem superblock instead of current, and simply using the the struct pid from the inode instead of attempting to get that same pid from the task. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Add 64-bit capability support to the kernelAndrew Morgan
The patch supports legacy (32-bit) capability userspace, and where possible translates 32-bit capabilities to/from userspace and the VFS to 64-bit kernel space capabilities. If a capability set cannot be compressed into 32-bits for consumption by user space, the system call fails, with -ERANGE. FWIW libcap-2.00 supports this change (and earlier capability formats) http://www.kernel.org/pub/linux/libs/security/linux-privs/kernel-2.6/ [akpm@linux-foundation.org: coding-syle fixes] [akpm@linux-foundation.org: use get_task_comm()] [ezk@cs.sunysb.edu: build fix] [akpm@linux-foundation.org: do not initialise statics to 0 or NULL] [akpm@linux-foundation.org: unused var] [serue@us.ibm.com: export __cap_ symbols] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Chris Wright <chrisw@sous-sol.org> Cc: James Morris <jmorris@namei.org> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-01Merge branch 'task_killable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits) Remove commented-out code copied from NFS NFS: Switch from intr mount option to TASK_KILLABLE Add wait_for_completion_killable Add wait_event_killable Add schedule_timeout_killable Use mutex_lock_killable in vfs_readdir Add mutex_lock_killable Use lock_page_killable Add lock_page_killable Add fatal_signal_pending Add TASK_WAKEKILL exit: Use task_is_* signal: Use task_is_* sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL ptrace: Use task_is_* power: Use task_is_* wait: Use TASK_NORMAL proc/base.c: Use task_is_* proc/array.c: Use TASK_REPORT perfmon: Use task_is_* ... Fixed up conflicts in NFS/sunrpc manually..
2008-01-14fix the "remove task_ppid_nr_ns" commitOleg Nesterov
Commit 84427eaef1fb91704c7112bdb598c810003b99f3 (remove task_ppid_nr_ns) moved the task_tgid_nr_ns(task->real_parent) outside of lock_task_sighand(). This is wrong, ->real_parent could be freed/reused. Both ->parent/real_parent point to nothing after __exit_signal() because we remove the child from ->children list, and thus the child can't be reparented when its parent exits. rcu_read_lock() protects ->parent/real_parent, but _only_ if we know it was valid before we take rcu lock. Revert this part of the patch. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-13remove task_ppid_nr_nsRoland McGrath
task_ppid_nr_ns is called in three places. One of these should never have called it. In the other two, using it broke the existing semantics. This was presumably accidental. If the function had not been there, it would have been much more obvious to the eye that those patches were changing the behavior. We don't need this function. In task_state, the pid of the ptracer is not the ppid of the ptracer. In do_task_stat, ppid is the tgid of the real_parent, not its pid. I also moved the call outside of lock_task_sighand, since it doesn't need it. In sys_getppid, ppid is the tgid of the real_parent, not its pid. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-06proc/array.c: Use TASK_REPORTMatthew Wilcox
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-11-26sched: fix prev_stime calculationIngo Molnar
Srivatsa Vaddagiri noticed occasionally incorrect CPU usage values in top and tracked it down to stime going below 0 in task_stime(). Negative values are possible there due to the sampled nature of stime/utime. Fix suggested by Balbir Singh. Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Reviewed-by: Balbir Singh <balbir@linux.vnet.ibm.com>
2007-10-30sched: fix /proc/<PID>/stat stime/utime monotonicity, part 2Balbir Singh
Extend Peter's patch to fix accounting issues, by keeping stime monotonic too. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Tested-by: Frans Pop <elendil@planet.nl>
2007-10-29sched: keep utime/stime monotonicPeter Zijlstra
keep utime/stime monotonic. cpustats use utime/stime as a ratio against sum_exec_runtime, as a consequence it can happen - when the ratio changes faster than time accumulates - that either can be appear to go backwards. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: fix guest time accounting going faster than user time accounting
2007-10-19Fix tsk->exit_state usageEugene Teo
tsk->exit_state can only be 0, EXIT_ZOMBIE, or EXIT_DEAD. A non-zero test is the same as tsk->exit_state & (EXIT_ZOMBIE | EXIT_DEAD), so just testing tsk->exit_state is sufficient. Signed-off-by: Eugene Teo <eugeneteo@kernel.sg> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: round up the APIPavel Emelianov
The set of functions process_session, task_session, process_group and task_pgrp is confusing, as the names can be mixed with each other when looking at the code for a long time. The proposals are to * equip the functions that return the integer with _nr suffix to represent that fact, * and to make all functions work with task (not process) by making the common prefix of the same name. For monotony the routines signal_session() and set_signal_session() are replaced with task_session_nr() and set_task_session(), especially since they are only used with the explicit task->signal dereference. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19sched: fix guest time accounting going faster than user time accountingChristian Borntraeger
cputime_add already adds, dont do it twice. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: guest CPU accounting: add guest-CPU /proc/<pid>/stat fieldsLaurent Vivier
like for cpustat, introduce the "gtime" (guest time of the task) and "cgtime" (guest time of the task children) fields for the tasks. Modify signal_struct and task_struct. Modify /proc/<pid>/stat to display these new fields. Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-08-23sched: accounting regression since rc1Christian Borntraeger
Fix the accounting regression for CONFIG_VIRT_CPU_ACCOUNTING. It reverts parts of commit b27f03d4bdc145a09fb7b0c0e004b29f1ee555fa by converting fs/proc/array.c back to cputime_t. The new functions task_utime and task_stime now return cputime_t instead of clock_t. If CONFIG_VIRT_CPU_ACCOUTING is set, task->utime and task->stime are returned directly instead of using sum_exec_runtime. Patch is tested on s390x with and without VIRT_CPU_ACCOUTING as well as on i386. [ mingo@elte.hu: cleanups, comments. ] Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: [PATCH] sched: fix up fs/proc/array.c whitespace problems [PATCH] sched: prettify prio_to_wmult[] [PATCH] sched: document prio_to_wmult[] [PATCH] sched: improve weight-array comments [PATCH] sched: remove dead code from task_stime() Fixed up trivial conflict in fs/proc/array.c
2007-07-16taskstats: add context-switch countersMaxim Uvarov
Make available to the user the following task and process performance statistics: * Involuntary Context Switches (task_struct->nivcsw) * Voluntary Context Switches (task_struct->nvcsw) Statistics information is available from: 1. taskstats interface (Documentation/accounting/) 2. /proc/PID/status (task only). This data is useful for detecting hyperactivity patterns between processes. [akpm@linux-foundation.org: cleanup] Signed-off-by: Maxim Uvarov <muvarov@ru.mvista.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Jonathan Lim <jlim@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use boot based time for process start time and boot time in /procTomas Janousek
Commit 411187fb05cd11676b0979d9fbf3291db69dbce2 caused boot time to move and process start times to become invalid after suspend. Using boot based time for those restores the old behaviour and fixes the issue. [akpm@linux-foundation.org: little cleanup] Signed-off-by: Tomas Janousek <tjanouse@redhat.com> Cc: Tomas Smetana <tsmetana@redhat.com> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16[PATCH] sched: fix up fs/proc/array.c whitespace problemsIngo Molnar
while changing task_stime() i noticed a whitespace style problem in array.c - fix it. While at it, fix all the other style problems too, most of them in the scheduler-stats related portions of array.c. There is no change in functionality: text data bss dec hex filename 4356 28 0 4384 1120 array.o-before 4356 28 0 4384 1120 array.o-after Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-16[PATCH] sched: remove dead code from task_stime()Ingo Molnar
Alexey Dobriyan noticed that task_stime() contains a piece of dead code. (which is a remnant of earlier versions of this code) Remove that code. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-09sched: make use of precise accounting for /proc task statsIngo Molnar
make use of CFS's precise accounting to drive /proc/<pid>/stat statistics. this code was co-authored by: Balbir Singh <balbir@linux.vnet.ibm.com> Dmitry Adamushko <dmitry.adamushko@gmail.com> Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
2007-07-09sched: remove the SleepAVG fieldIngo Molnar
remove the SleepAVG field from /proc/<pid>/status, as with the removal of the sleep-average code this value no longer makes sense. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-05-08reduce size of task_struct on 64-bit machinesWilliam Cohen
This past week I was playing around with that pahole tool (http://oops.ghostprotocols.net:81/acme/dwarves/) and looking at the size of various struct in the kernel. I was surprised by the size of the task_struct on x86_64, approaching 4K. I looked through the fields in task_struct and found that a number of them were declared as "unsigned long" rather than "unsigned int" despite them appearing okay as 32-bit sized fields. On x86_64 "unsigned long" ends up being 8 bytes in size and forces 8 byte alignment. Is there a reason there a reason they are "unsigned long"? The patch below drops the size of the struct from 3808 bytes (60 64-byte cachelines) to 3760 bytes (59 64-byte cachelines). A couple other fields in the task struct take a signficant amount of space: struct thread_struct thread; 688 struct held_lock held_locks[30]; 1680 CONFIG_LOCKDEP is turned on in the .config [akpm@linux-foundation.org: fix printk warnings] Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] tty: update the tty layer to work with struct pidEric W. Biederman
Of kernel subsystems that work with pids the tty layer is probably the largest consumer. But it has the nice virtue that the assiation with a session only lasts until the session leader exits. Which means that no reference counting is required. So using struct pid winds up being a simple optimization to avoid hash table lookups. In the long term the use of pid_nr also ensures that when we have multiple pid spaces mixed everything will work correctly. Signed-off-by: Eric W. Biederman <eric@maxwell.lnxi.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] add process_session() helper routine: deprecate old fieldCedric Le Goater
Add an anonymous union and ((deprecated)) to catch direct usage of the session field. [akpm@osdl.org: fix various missed conversions] [jdike@addtoit.com: fix UML bug] Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] do_task_stat(): don't take tty_mutexOleg Nesterov
->signal->tty is protected by ->siglock, no need to take the global tty_mutex. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] proc: drop tasklist lock in task_state()Oleg Nesterov
task_state() needs tasklist_lock to protect ->parent/->real_parent. However task->parent points to nowhere only when the actions below happen in order 1) release_task(task) 2) release_task(task->parent) 3) a grace period passed But 3) implies that the memory ops from 1) should be finished, so pid_alive() can't be true in such a case. Otherwise, we don't care if ->parent/->real_parent changes under us. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] proc: convert do_task_stat() to use lock_task_sighand()Oleg Nesterov
Drop tasklist_lock. ->siglock protects almost all interesting data (including sub-threads traversal) except: ->signal->tty protected by tty_mutex ->real_parent the task can't be unhashed while we are holding ->siglock, so ->real_parent can change from under us but we can safely dereference it under rcu_read_lock() ->pgrp/->session we can get inconsistent numbers if the task does sys_setsid/daemonize at the same time. I hope this is acceptable. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] proc: convert task_sig() to use lock_task_sighand()Oleg Nesterov
lock_task_sighand() can take ->siglock without holding tasklist_lock. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] tty: stop the tty vanishing under procfs accessAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] per-task-delay-accounting: /proc export of aggregated block I/O delaysShailabh Nagar
Export I/O delays seen by a task through /proc/<tgid>/stats for use in top etc. Note that delays for I/O done for swapping in pages (swapin I/O) is clubbed together with all other I/O here (this is not the case in the netlink interface where the swapin I/O is kept distinct) [akpm@osdl.org: printk warning fix] Signed-off-by: Shailabh Nagar <nagar@watson.ibm.com> Signed-off-by: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Peter Chubb <peterc@gelato.unsw.edu.au> Cc: Erich Focht <efocht@ess.nec.de> Cc: Levent Serinol <lserinol@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] hrtimers: remove it_real_value calculation from proc/*/statRoman Zippel
Remove the it_real_value from /proc/*/stat, during 1.2.x was the last time it returned useful data (as it was directly maintained by the scheduler), now it's only a waste of time to calculate it. Return 0 instead. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] hrtimer: switch itimers to hrtimerThomas Gleixner
switch itimers to a hrtimers-based implementation Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] s390: cleanup KconfigMartin Schwidefsky
Sanitize some s390 Kconfig options. We have ARCH_S390, ARCH_S390X, ARCH_S390_31, 64BIT, S390_SUPPORT and COMPAT. Replace these 6 options by S390, 64BIT and COMPAT. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: rss = file_rss + anon_rssHugh Dickins
I was lazy when we added anon_rss, and chose to change as few places as possible. So currently each anonymous page has to be counted twice, in rss and in anon_rss. Which won't be so good if those are atomic counts in some configurations. Change that around: keep file_rss and anon_rss separately, and add them together (with get_mm_rss macro) when the total is needed - reading two atomics is much cheaper than updating two atomics. And update anon_rss upfront, typically in memory.c, not tucked away in page_add_anon_rmap. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-17[PATCH] files: fix preemption issuesDipankar Sarma
With the new fdtable locking rules, you have to protect fdtable with either ->file_lock or rcu_read_lock/unlock(). There are some places where we aren't doing either. This patch fixes those places. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: break up files structDipankar Sarma
In order for the RCU to work, the file table array, sets and their sizes must be updated atomically. Instead of ensuring this through too many memory barriers, we put the arrays and their sizes in a separate structure. This patch takes the first step of putting the file table elements in a separate structure fdtable that is embedded withing files_struct. It also changes all the users to refer to the file table using files_fdtable() macro. Subsequent applciation of RCU becomes easier after this. Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
