commit fc360bd9cdcf875639a77f07fafec26699c546f3 upstream.
The display of the "huge" tag was accidentally removed in 29ea2f698 ("mm:
use walk_page_range() instead of custom page table walking code").
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Tested-by: Stephen Hemminger <shemminger@vyatta.com>
Reviewed-by: Stephen Wilson <wilsons@start.ca>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
commit 32ef43848f283e0ef945d3c67e851c143fea3970 upstream.
This is modeled after the smaps code.
It detects transparent hugepages and then does a single gather_stats()
for the page as a whole. This has two benifits:
1. It is more efficient since it does many pages in a single shot.
2. It does not have to break down the huge page.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
commit 3200a8aaab0c9ccdc0f59b0dac2d4a47029137fa upstream.
gather_pte_stats() does a number of checks on a target page
to see whether it should even be considered for statistics.
This breaks that code out in to a separate function so that
we can use it in the transparent hugepage case in the next
patch.
Reviewed-by: Christoph Lameter <cl@gentwo.org>
commit eb4866d0066ffd5446751c102d64feb3318d8bd1 upstream.
We need to teach the numa_maps code about transparent huge pages. The
first step is to teach gather_stats() that the pte it is dealing with
might represent more than one page.
Note that will we use this in a moment for transparent huge pages since
they have use a single pmd_t which _acts_ as a "surrogate" for a bunch
of smaller pte_t's.
I'm a _bit_ unhappy that this interface counts in hugetlbfs page sizes
for hugetlbfs pages and PAGE_SIZE for normal pages. That means that to
figure out how many _bytes_ "dirty=1" means, you must first know the
hugetlbfs page size. That's easier said than done especially if you
don't have visibility in to the mount.
But, that's probably a discussion for another day especially since it
would change behavior to fix it. But, just in case anyone wonders why
this patch only passes a '1' in the hugetlb case...
Currently, pagemap_read() has three error and/or corner case handling
mistake.
(1) If ppos parameter is wrong, mm refcount will be leak.
(2) If count parameter is 0, mm refcount will be leak too.
(3) If the current task is sleeping in kmalloc() and the system
is out of memory and oom-killer kill the proc associated task,
mm_refcount prevent the task free its memory. then system may
hang up.
<Quote Hugh's explain why we shold call kmalloc() before get_mm()>
check_mem_permission gets a reference to the mm. If we
__get_free_page after check_mem_permission, imagine what happens if the
system is out of memory, and the mm we're looking at is selected for
killing by the OOM killer: while we wait in __get_free_page for more
memory, no memory is freed from the selected mm because it cannot reach
exit_mmap while we hold that reference.
This patch fixes the above three.
Cc: Jovi Zhang <bookjovi@gmail.com>
Cc: Stephen Wilson <wilsons@start.ca>
Convert fs/proc/ from strict_strto*() to kstrto*() functions.
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor
'unsigned int'. This patch fixes such misuse.
[ Changed to use a typedef - we'll extend it to cover more cases
later, since there has been discussion about making it a 64-bit
type.. - Linus ]
In show_numa_map() we collect statistics into a numa_maps structure.
Since the number of NUMA nodes can be very large, this structure is not a
candidate for stack allocation.
Instead of going thru a kmalloc()+kfree() cycle each time show_numa_map()
is invoked, perform the allocation just once when /proc/pid/numa_maps is
opened.
Performing the allocation when numa_maps is opened, and thus before a
reference to the target tasks mm is taken, eliminates a potential
stalemate condition in the oom-killer as originally described by Hugh
Dickins:
... imagine what happens if the system is out of memory, and the mm
we're looking at is selected for killing by the OOM killer: while
we wait in __get_free_page for more memory, no memory is freed
from the selected mm because it cannot reach exit_mmap while we hold
that reference.
Signed-off-by: Stephen Wilson <wilsons@start.ca>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Moving show_numa_map() from mempolicy.c to task_mmu.c solves several
issues.
- Having the show() operation "miles away" from the corresponding
seq_file iteration operations is a maintenance burden.
- The need to export ad hoc info like struct proc_maps_private is
eliminated.
- The implementation of show_numa_map() can be improved in a simple
manner by cooperating with the other seq_file operations (start,
stop, etc) -- something that would be messy to do without this
change.
Linux kernel excludes guard page when performing mlock on a VMA with
down-growing stack. However, some architectures have up-growing stack
and locking the guard page should be excluded in this case too.
This patch fixes lvm2 on PA-RISC (and possibly other architectures with
up-growing stack). lvm2 calculates number of used pages when locking and
when unlocking and reports an internal error if the numbers mismatch.
[ Patch changed fairly extensively to also fix /proc/<pid>/maps for the
grows-up case, and to move things around a bit to clean it all up and
share the infrstructure with the /proc bits.
Tested on ia64 that has both grow-up and grow-down segments - Linus ]
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Tested-by: Tony Luck <tony.luck@gmail.com>
Cc: stable@kernel.org
When m_start returns an error, the seq_file logic will still call m_stop
with that error entry, so we'd better make sure that we check it before
using it as a vma.
Introduced by commit ec6fd8a4355c ("report errors in /proc/*/*map*
sanely"), which replaced NULL with various ERR_PTR() cases.
(On ia64, you happen to get a unaligned fault instead of a page fault,
since the address used is generally some random error code like -EPERM)
Reported-by: Anca Emanuel <anca.emanuel@gmail.com>
Reported-by: Tony Luck <tony.luck@intel.com>
Cc: Américo Wang <xiyou.wangcong@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
deal with races in /proc/*/{syscall,stack,personality}
proc: enable writing to /proc/pid/mem
proc: make check_mem_permission() return an mm_struct on success
proc: hold cred_guard_mutex in check_mem_permission()
proc: disable mem_write after exec
mm: implement access_remote_vm
mm: factor out main logic of access_process_vm
mm: use mm_struct to resolve gate vma's in __get_user_pages
mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm
mm: arch: make in_gate_area take an mm_struct instead of a task_struct
mm: arch: make get_gate_vma take an mm_struct instead of a task_struct
x86: mark associated mm when running a task in 32 bit compatibility mode
x86: add context tag to mark mm when running a task in 32-bit compatibility mode
auxv: require the target to be tracable (or yourself)
close race in /proc/*/environ
report errors in /proc/*/*map* sanely
pagemap: close races with suid execve
make sessionid permissions in /proc/*/task/* match those in /proc/*
fix leaks in path_lookupat()
Fix up trivial conflicts in fs/proc/base.c
The current code fails to print the "[heap]" marking if the heap is split
into multiple mappings.
Fix the check so that the marking is displayed in all possible cases:
1. vma matches exactly the heap
2. the heap vma is merged e.g. with bss
3. the heap vma is splitted e.g. due to locked pages
Test cases. In all cases, the process should have mapping(s) with
[heap] marking:
(1) vma matches exactly the heap
#include <stdio.h>
#include <unistd.h>
#include <sys/types.h>
int main (void)
if (sbrk(4096) != (void *)-1) {
printf("check /proc/%d/maps\n", (int)getpid());
while (1)
sleep(1);
return 0;
# ./test1
check /proc/553/maps
[1] + Stopped ./test1
# cat /proc/553/maps | head -4
00008000-00009000 r-xp 00000000 01:00 3113640 /test1
00010000-00011000 rw-p 00000000 01:00 3113640 /test1
00011000-00012000 rw-p 00000000 00:00 0 [heap]
4006f000-40070000 rw-p 00000000 00:00 0
(2) the heap vma is merged
#include <stdio.h>
#include <unistd.h>
char foo[4096] = "foo";
char bar[4096];
int main (void)
while (1)
sleep(1);
return 0;
# ./test2
check /proc/556/maps
[2] + Stopped ./test2
# cat /proc/556/maps | head -4
00008000-00009000 r-xp 00000000 01:00 3116312 /test2
00010000-00012000 rw-p 00000000 01:00 3116312 /test2
00012000-00014000 rw-p 00000000 00:00 0 [heap]
4004a000-4004b000 rw-p 00000000 00:00 0
(3) the heap vma is splitted (this fails without the patch)
#include <stdio.h>
#include <unistd.h>
#include <sys/mman.h>
int main (void)
if ((sbrk(4096) != (void *)-1) && !mlockall(MCL_FUTURE) &&
(sbrk(4096) != (void *)-1)) {
while (1)
sleep(1);
return 0;
# ./test3
check /proc/559/maps
[1] + Stopped ./test3
# cat /proc/559/maps|head -4
00008000-00009000 r-xp 00000000 01:00 3119108 /test3
00010000-00011000 rw-p 00000000 01:00 3119108 /test3
00012000-00013000 rw-p 00000000 00:00 0 [heap]
It looks like the bug has been there forever, and since it only results in
some information missing from a procfile, it does not fulfil the -stable
"critical issue" criteria.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Morally, the presence of a gate vma is more an attribute of a particular mm than
a particular task. Moreover, dropping the dependency on task_struct will help
make both existing and future operations on mm's more flexible and convenient.
Reviewed-by: Michel Lespinasse <walken@google.com>
just use mm_for_maps()
Now that the mere act of _looking_ at /proc/$pid/smaps will not destroy
transparent huge pages, tell how much of the VMA is actually mapped with
them.
This way, we can make sure that we're getting THPs where we
expect to see them.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Eric B Munson <emunson@mgebm.net>
Tested-by: Eric B Munson <emunson@mgebm.net>
Cc: Michael J Wolf <mjwolf@us.ibm.com>
Cc: Matt Mackall <mpm@selenic.com>
This adds code to explicitly detect and handle pmd_trans_huge() pmds. It
then passes HPAGE_SIZE units in to the smap_pte_entry() function instead
of PAGE_SIZE.
This means that using /proc/$pid/smaps now will no longer cause THPs to be
broken down in to small pages.
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
Add an argument to the new smaps_pte_entry() function to let it account in
things other than PAGE_SIZE units. I changed all of the PAGE_SIZE sites,
even though not all of them can be reached for transparent huge pages,
just so this will continue to work without changes as THPs are improved.
We will use smaps_pte_entry() in a moment to handle both small and
transparent large pages. But, we must break it out of smaps_pte_range()
first.
Right now, if a mm_walk has either ->pte_entry or ->pmd_entry set, it will
unconditionally split any transparent huge pages it runs in to. In
practice, that means that anyone doing a
cat /proc/$pid/smaps
will unconditionally break down every huge page in the process and depend
on khugepaged to re-collapse it later. This is fairly suboptimal.
This patch changes that behavior. It teaches each ->pmd_entry handler
(there are five) that they must break down the THPs themselves. Also, the
_generic_ code will never break down a THP unless a ->pte_entry handler is
actually set.
This means that the ->pmd_entry handlers can now choose to deal with THPs
without breaking them down.
Currently there is no way to find whether a process has locked its pages
in memory or not. And which of the memory regions are locked in memory.
Add a new field "Locked" to export this information via the smaps file.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
/proc/*/statm code needlessly truncates data from unsigned long to int.
One needs only 8+ TB of RAM to make truncation visible.
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com>
Currently one pagemap_read() call walks in PAGEMAP_WALK_SIZE bytes (== 512
pages.) But there is a corner case where walk_pmd_range() accidentally
runs over a VMA associated with a hugetlbfs file.
For example, when a process has mappings to VMAs as shown below:
# cat /proc/<pid>/maps
3a58f6d000-3a58f72000 rw-p 00000000 00:00 0
7fbd51853000-7fbd51855000 rw-p 00000000 00:00 0
7fbd5186c000-7fbd5186e000 rw-p 00000000 00:00 0
7fbd51a00000-7fbd51c00000 rw-s 00000000 00:12 8614 /hugepages/test
then pagemap_read() goes into walk_pmd_range() path and walks in the range
0x7fbd51853000-0x7fbd51a53000, but the hugetlbfs VMA should be handled by
walk_hugetlb_range(). Otherwise PMD for the hugepage is considered bad
and cleared, which causes undesirable results.
This patch fixes it by separating pagemap walk range into one PMD.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Export the number of anonymous pages in a mapping via smaps.
Even the private pages in a mapping backed by a file, would be marked as
anonymous, when they are modified. Export this information to user-space via
smaps.
Exporting this count will help gdb to make a better decision on which
areas need to be dumped in its coredump; and should be useful to others
studying the memory usage of a process.
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Currently, /proc/<pid>/smaps has wrong dirty pages accounting.
Shared_Dirty and Private_Dirty output only pte dirty pages and ignore
PG_dirty page flag. It is difference against documentation, but also
inconsistent against Referenced field. (Referenced checks both pte and
page flags)
This patch fixes it.
Test program:
large-array.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
char array[1*1024*1024*1024L];
int main(void)
memset(array, 1, sizeof(array));
pause();
return 0;
Test case:
1. run ./large-array
2. cat /proc/`pidof large-array`/smaps
3. swapoff -a
4. cat /proc/`pidof large-array`/smaps again
Test result:
<before patch>
00601000-40601000 rw-p 00000000 00:00 0
Rss: 1048576 kB
Pss: 1048576 kB
Shared_Clean: 0 kB
Shared_Dirty: 0 kB
Private_Clean: 218992 kB <-- showed pages as clean incorrectly
Private_Dirty: 829584 kB
Referenced: 388364 kB
Swap: 0 kB
KernelPageSize: 4 kB
MMUPageSize: 4 kB
<after patch>
Rss: 1048576 kB
Pss: 1048576 kB
Shared_Clean: 0 kB
Shared_Dirty: 0 kB
Private_Clean: 0 kB
Private_Dirty: 1048576 kB <-- fixed
Referenced: 388480 kB
Swap: 0 kB
MMUPageSize: 4 kB
So it can be used by all that need to check for that.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
If !CONFIG_HUGETLB_PAGE, pagemap_hugetlb_range() is never called. So put
it (and its calling function) into #ifdef block.
Acked-by: Matt Mackall <mpm@selenic.com>
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
Cc: <stable@kernel.org>
When we look into pagemap using page-types with option -p, the value of
pfn for hugepages looks wrong (see below.) This is because pte was
evaluated only once for one vma although it should be updated for each
hugepage. This patch fixes it.
$ page-types -p 3277 -Nl -b huge
voffset offset len flags
7f21e8a00 11e400 1 ___U___________H_G________________
7f21e8a01 11e401 1ff ________________TG________________
7f21e8c00 11e400 1 ___U___________H_G________________
7f21e8c01 11e401 1ff ________________TG________________
One hugepage contains 1 head page and 511 tail pages in x86_64 and each
two lines represent each hugepage. Voffset and offset mean virtual
address and physical address in the page unit, respectively. The
different hugepages should not have the same offset value.
With this patch applied:
$ page-types -p 3386 -Nl -b huge
7fec7a600 112c00 1 ___UD__________H_G________________
7fec7a601 112c01 1ff ________________TG________________
7fec7a800 113200 1 ___UD__________H_G________________
7fec7a801 113201 1ff ________________TG________________
OK
More info:
- This patch modifies walk_page_range()'s hugepage walker. But the
change only affects pagemap_read(), which is the only caller of hugepage
callback.
- Without this patch, hugetlb_entry() callback is called per vma, that
doesn't match the natural expectation from its name.
- With this patch, hugetlb_entry() is called per hugepte entry and the
callback can become much simpler.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
copy_to_user() returns the number of bytes left to be copied.
This was a typo from: d82ef020cf31 "proc: pagemap: Hold mmap_sem during
page walk".
In initial design, walk_page_range() was designed just for walking page
table and it didn't require mmap_sem. Now, find_vma() etc.. are used
in walk_page_range() and we need mmap_sem around it.
This patch adds mmap_sem around walk_page_range().
Because /proc/<pid>/pagemap's callback routine use put_user(), we have
to get rid of it to do sane fix.
Changelog: 2010/Apr/2
- fixed start_vaddr and end overflow
Changelog: 2010/Apr/1
- fixed start_vaddr calculation
- removed unnecessary cast.
- removed unnecessary change in smaps.
- use GFP_TEMPORARY instead of GFP_KERNEL
Cc: San Mehat <san@google.com>
Cc: Brian Swetland <swetland@google.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
[ Fixed kmalloc failure return code as per Matt ]
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
A frequent questions from users about memory management is what numbers of
swap ents are user for processes. And this information will give some
hints to oom-killer.
Besides we can count the number of swapents per a process by scanning
/proc/<pid>/smaps, this is very slow and not good for usual process
information handler which works like 'ps' or 'top'. (ps or top is now
enough slow..)
This patch adds a counter of swapents to mm_counter and update is at each
swap events. Information is exported via /proc/<pid>/status file as
[kamezawa@bluextal memory]$ cat /proc/self/status
State: R (running)
Tgid: 2910
Pid: 2910
PPid: 2823
TracerPid: 0
Uid: 500 500 500 500
Gid: 500 500 500 500
FDSize: 256
Groups: 500
VmPeak: 82696 kB
VmSize: 82696 kB
VmLck: 0 kB
VmHWM: 432 kB
VmRSS: 432 kB
VmData: 172 kB
VmStk: 84 kB
VmExe: 48 kB
VmLib: 1568 kB
VmPTE: 40 kB
VmSwap: 0 kB <=============== this.
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Presently, per-mm statistics counter is defined by macro in sched.h
This patch modifies it to
- defined in mm.h as inlinf functions
- use array instead of macro's name creation.
This patch is for reducing patch size in future patch to modify
implementation of per-mm counter.
A long time ago we regarded zero page as file_rss and vm_normal_page
doesn't return NULL.
But now, we reinstated ZERO_PAGE and vm_normal_page's implementation can
return NULL in case of zero page. Also we don't count it with file_rss
any more.
Then, RSS and PSS can't be matched. For consistency, Let's ignore zero
page in smaps_pte_range.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
This patch enables extraction of the pfn of a hugepage from
/proc/pid/pagemap in an architecture independent manner.
Details
My test program (leak_pagemap) works as follows:
- creat() and mmap() a file on hugetlbfs (file size is 200MB == 100 hugepages,)
- read()/write() something on it,
- call page-types with option -p,
- munmap() and unlink() the file on hugetlbfs
Without my patches
$ ./leak_pagemap
flags page-count MB symbolic-flags long-symbolic-flags
0x0000000000000000 1 0 __________________________________
0x0000000000000804 1 0 __R________M______________________ referenced,mmap
0x000000000000086c 81 0 __RU_lA____M______________________ referenced,uptodate,lru,active,mmap
0x0000000000005808 5 0 ___U_______Ma_b___________________ uptodate,mmap,anonymous,swapbacked
0x0000000000005868 12 0 ___U_lA____Ma_b___________________ uptodate,lru,active,mmap,anonymous,swapbacked
0x000000000000586c 1 0 __RU_lA____Ma_b___________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked
total 101 0
The output of page-types don't show any hugepage.
With my patches
$ ./leak_pagemap
0x0000000000030000 51100 199 ________________TG________________ compound_tail,huge
0x0000000000028018 100 0 ___UD__________H_G________________ uptodate,dirty,compound_head,huge
0x000000000000080c 1 0 __RU_______M______________________ referenced,uptodate,mmap
0x000000000000086c 80 0 __RU_lA____M______________________ referenced,uptodate,lru,active,mmap
0x0000000000005808 4 0 ___U_______Ma_b___________________ uptodate,mmap,anonymous,swapbacked
total 51300 200
The output of page-types shows 51200 pages contributing to hugepages,
containing 100 head pages and 51100 tail pages as expected.
[akpm@linux-foundation.org: build fix]
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Andy Whitcroft <apw@canonical.com>
A patch to give a better overview of the userland application stack usage,
especially for embedded linux.
Currently you are only able to dump the main process/thread stack usage
which is showed in /proc/pid/status by the "VmStk" Value. But you get no
information about the consumed stack memory of the the threads.
There is an enhancement in the /proc/<pid>/{task/*,}/*maps and which marks
the vm mapping where the thread stack pointer reside with "[thread stack
xxxxxxxx]". xxxxxxxx is the maximum size of stack. This is a value
information, because libpthread doesn't set the start of the stack to the
top of the mapped area, depending of the pthread usage.
A sample output of /proc/<pid>/task/<tid>/maps looks like:
08048000-08049000 r-xp 00000000 03:00 8312 /opt/z
08049000-0804a000 rw-p 00001000 03:00 8312 /opt/z
0804a000-0806b000 rw-p 00000000 00:00 0 [heap]
a7d12000-a7d13000 ---p 00000000 00:00 0
a7d13000-a7f13000 rw-p 00000000 00:00 0 [thread stack: 001ff4b4]
a7f13000-a7f14000 ---p 00000000 00:00 0
a7f14000-a7f36000 rw-p 00000000 00:00 0
a7f36000-a8069000 r-xp 00000000 03:00 4222 /lib/libc.so.6
a8069000-a806b000 r--p 00133000 03:00 4222 /lib/libc.so.6
a806b000-a806c000 rw-p 00135000 03:00 4222 /lib/libc.so.6
a806c000-a806f000 rw-p 00000000 00:00 0
a806f000-a8083000 r-xp 00000000 03:00 14462 /lib/libpthread.so.0
a8083000-a8084000 r--p 00013000 03:00 14462 /lib/libpthread.so.0
a8084000-a8085000 rw-p 00014000 03:00 14462 /lib/libpthread.so.0
a8085000-a8088000 rw-p 00000000 00:00 0
a8088000-a80a4000 r-xp 00000000 03:00 8317 /lib/ld-linux.so.2
a80a4000-a80a5000 r--p 0001b000 03:00 8317 /lib/ld-linux.so.2
a80a5000-a80a6000 rw-p 0001c000 03:00 8317 /lib/ld-linux.so.2
afaf5000-afb0a000 rw-p 00000000 00:00 0 [stack]
ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
Also there is a new entry "stack usage" in /proc/<pid>/{task/*,}/status
which will you give the current stack usage in kb.
A sample output of /proc/self/status looks like:
State: R (running)
Tgid: 507
Pid: 507
CapBnd: fffffffffffffeff
voluntary_ctxt_switches: 0
nonvoluntary_ctxt_switches: 0
Stack usage: 12 kB
I also fixed stack base address in /proc/<pid>/{task/*,}/stat to the base
address of the associated thread stack and not the one of the main
process. This makes more sense.
[akpm@linux-foundation.org: fs/proc/array.c now needs walk_page_range()]
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Andrew Morton pointed out similar string hacking and obfuscated check for
zero-length input at the end of the function, David Rientjes suggested to
use strict_strtol to replace simple_strtol, this patch cover above
suggestions, add removing of leading and trailing whitespace from user
input. It does not change function behavious.
Signed-off-by: Vincent Li <macli@brc.ubc.ca>
Cc: Amerigo Wang <xiyou.wangcong@gmail.com>
The patch makes the clear_refs more versatile in adding the option to
select anonymous pages or file backed pages for clearing. This addition
has a measurable impact on user space application performance as it
decreases the number of pagewalks in scenarios where one is only
interested in a specific type of page (anonymous or file mapped).
The patch adds anonymous and file backed filters to the clear_refs interface.
echo 1 > /proc/PID/clear_refs resets the bits on all pages
echo 2 > /proc/PID/clear_refs resets the bits on anonymous pages only
echo 3 > /proc/PID/clear_refs resets the bits on file backed pages only
Any other value is ignored
Signed-off-by: Moussa A. Ba <moussa.a.ba@gmail.com>
Signed-off-by: Jared E. Hulbert <jaredeh@gmail.com>
mm_for_maps() takes ->mmap_sem after security checks, this looks
strange and obfuscates the locking rules. Move this lock to its
single caller, m_start().
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
The intention of commit aae8679b0ebcaa92f99c1c3cb0cd651594a43915
("pagemap: fix bug in add_to_pagemap, require aligned-length reads of
/proc/pid/pagemap") was to force reads of /proc/pid/pagemap to be a
multiple of 8 bytes, but now it allows to read 0 bytes, which actually
puts some data to user's buffer. According to POSIX, if count is zero,
read() should return zero and has no other results.
Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com>
Cc: Thomas Tuttle <ttuttle@google.com>
Recently, it's argued that what proc/pid/maps shows is ugly when a 32bit
binary runs on 64bit host.
/proc/pid/maps outputs vma's pgoff member but vma->pgoff is of no use
information is the vma is for ANON. With this patch, /proc/pid/maps shows
just 0 if no file backing store.
[kamezawa.hiroyu@jp.fujitsu.com: coding-style fixes]
Cc: Mike Waychison <mikew@google.com>
Reported-by: Ying Han <yinghan@google.com>
Cc: Hugh Dickins <hugh@veritas.com>
fs/proc/task_mmu.c:696:12: warning: cast removes address space of expression
fs/proc/task_mmu.c:696:9: warning: incorrect type in assignment (different address spaces)
fs/proc/task_mmu.c:696:9: expected unsigned long long [noderef] [usertype] <asn:1>*out
fs/proc/task_mmu.c:696:9: got unsigned long long [usertype] *<noident>
fs/proc/task_mmu.c:697:12: warning: cast removes address space of expression
fs/proc/task_mmu.c:697:9: warning: incorrect type in assignment (different address spaces)
fs/proc/task_mmu.c:697:9: expected unsigned long long [noderef] [usertype] <asn:1>*end
fs/proc/task_mmu.c:697:9: got unsigned long long [usertype] *<noident>
fs/proc/task_mmu.c:723:12: warning: cast removes address space of expression
fs/proc/task_mmu.c:723:26: error: subtraction of different types can't work (different address spaces)
fs/proc/task_mmu.c:725:24: error: subtraction of different types can't work (different address spaces)
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
The KernelPageSize entry in /proc/pid/smaps is the pagesize used by the
kernel to back a VMA. This matches the size used by the MMU in the
majority of cases. However, one counter-example occurs on PPC64 kernels
whereby a kernel using 64K as a base pagesize may still use 4K pages for
the MMU on older processor. To distinguish, this patch reports
MMUPageSize as the pagesize used by the MMU in /proc/pid/smaps.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: "KOSAKI Motohiro" <kosaki.motohiro@jp.fujitsu.com>
It is useful to verify a hugepage-aware application is using the expected
pagesizes for its memory regions. This patch creates an entry called
KernelPageSize in /proc/pid/smaps that is the size of page used by the
kernel to back a VMA. The entry is not called PageSize as it is possible
the MMU uses a different size. This extension should not break any sensible
parser that skips lines containing unrecognised information.
Acked-by: "KOSAKI Motohiro" <kosaki.motohiro@jp.fujitsu.com>
