Turn
seq_path(..., &file->f_path, ...);
into
seq_file_path(..., file, ...);
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
As pointed by recent post[1] on exploiting DRAM physical imperfection,
/proc/PID/pagemap exposes sensitive information which can be used to do
attacks.
This disallows anybody without CAP_SYS_ADMIN to read the pagemap.
[1] http://googleprojectzero.blogspot.com/2015/03/exploiting-dram-rowhammer-bug-to-gain.html
[ Eventually we might want to do anything more finegrained, but for now
this is the simple model. - Linus ]
Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Mark Seaborn <mseaborn@chromium.org>
Cc: stable@vger.kernel.org
The output of /proc/$pid/numa_maps is in terms of number of pages like
anon=22 or dirty=54. Here's some output:
7f4680000000 default file=/hugetlb/bigfile anon=50 dirty=50 N0=50
7f7659600000 default file=/anon_hugepage\040(deleted) anon=50 dirty=50 N0=50
7fff8d425000 default stack anon=50 dirty=50 N0=50
Looks like we have a stack and a couple of anonymous hugetlbfs
areas page which both use the same amount of memory. They don't.
The 'bigfile' uses 1GB pages and takes up ~50GB of space. The
anon_hugepage uses 2MB pages and takes up ~100MB of space while the stack
uses normal 4k pages. You can go over to smaps to figure out what the
page size _really_ is with KernelPageSize or MMUPageSize. But, I think
this is a pretty nasty and counterintuitive interface as it stands.
This patch introduces 'kernelpagesize_kB' line element to
/proc/<pid>/numa_maps report file in order to help identifying the size of
pages that are backing memory areas mapped by a given task. This is
specially useful to help differentiating between HUGE and GIGANTIC page
backed VMAs.
This patch is based on Dave Hansen's proposal and reviewer's follow-ups
taken from the following dicussion threads:
* https://lkml.org/lkml/2011/9/21/454
* https://lkml.org/lkml/2014/12/20/66
Signed-off-by: Rafael Aquini <aquini@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
(peak RSS)
Peak resident size of a process can be reset back to the process's
current rss value by writing "5" to /proc/pid/clear_refs. The driving
use-case for this would be getting the peak RSS value, which can be
retrieved from the VmHWM field in /proc/pid/status, per benchmark
iteration or test scenario.
[akpm@linux-foundation.org: clarify behaviour in documentation]
Signed-off-by: Petr Cermak <petrcermak@chromium.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Primiano Tucci <primiano@chromium.org>
Cc: Petr Cermak <petrcermak@chromium.org>
Currently pagewalker splits all THP pages on any clear_refs request. It's
not necessary. We can handle this on PMD level.
One side effect is that soft dirty will potentially see more dirty memory,
since we will mark whole THP page dirty at once.
Sanity checked with CRIU test suite. More testing is required.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
walk_page_range() silently skips vma having VM_PFNMAP set, which leads to
undesirable behaviour at client end (who called walk_page_range). For
example for pagemap_read(), when no callbacks are called against VM_PFNMAP
vma, pagemap_read() may prepare pagemap data for next virtual address
range at wrong index. That could confuse and/or break userspace
applications.
This patch avoid this misbehavior caused by vma(VM_PFNMAP) like follows:
- for pagemap_read() which has its own ->pte_hole(), call the ->pte_hole()
over vma(VM_PFNMAP),
- for clear_refs and queue_pages which have their own ->tests_walk,
just return 1 and skip vma(VM_PFNMAP). This is no problem because
these are not interested in hole regions,
- for other callers, just skip the vma(VM_PFNMAP) as a default behavior.
Signed-off-by: Shiraz Hashim <shashim@codeaurora.org>
pagewalk.c can handle vma in itself, so we don't have to pass vma via
walk->private. And show_numa_map() walks pages on vma basis, so using
walk_page_vma() is preferable.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Just doing s/gather_hugetbl_stats/gather_hugetlb_stats/g, this makes code
grep-friendly.
Page table walker has the information of the current vma in mm_walk, so we
don't have to call find_vma() in each pagemap_(pte|hugetlb)_range() call
any longer. Currently pagemap_pte_range() does vma loop itself, so this
patch reduces many lines of code.
NULL-vma check is omitted because we assume that we never run these
callbacks on any address outside vma. And even if it were broken, NULL
pointer dereference would be detected, so we can get enough information
for debugging.
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
clear_refs_write() has some prechecks to determine if we really walk over
a given vma. Now we have a test_walk() callback to filter vmas, so let's
utilize it.
walk->private. And show_smap() walks pages on vma basis, so using
Lockless access to pte in pagemap_pte_range() might race with page
migration and trigger BUG_ON(!PageLocked()) in migration_entry_to_page():
CPU A (pagemap) CPU B (migration)
lock_page()
try_to_unmap(page, TTU_MIGRATION...)
make_migration_entry()
set_pte_at()
<read *pte>
pte_to_pagemap_entry()
remove_migration_ptes()
unlock_page()
if(is_migration_entry())
BUG_ON(!PageLocked(page))
Also lockless read might be non-atomic if pte is larger than wordsize.
Other pte walkers (smaps, numa_maps, clear_refs) already lock ptes.
Fixes: 052fb0d635df ("proc: report file/anon bit in /proc/pid/pagemap")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: <stable@vger.kernel.org> [3.5+]
Dave noticed that unprivileged process can allocate significant amount of
memory -- >500 MiB on x86_64 -- and stay unnoticed by oom-killer and
memory cgroup. The trick is to allocate a lot of PMD page tables. Linux
kernel doesn't account PMD tables to the process, only PTE.
The use-cases below use few tricks to allocate a lot of PMD page tables
while keeping VmRSS and VmPTE low. oom_score for the process will be 0.
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/prctl.h>
#define PUD_SIZE (1UL << 30)
#define PMD_SIZE (1UL << 21)
#define NR_PUD 130000
int main(void)
char *addr = NULL;
unsigned long i;
prctl(PR_SET_THP_DISABLE);
for (i = 0; i < NR_PUD ; i++) {
addr = mmap(addr + PUD_SIZE, PUD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE, -1, 0);
if (addr == MAP_FAILED) {
perror("mmap");
break;
*addr = 'x';
munmap(addr, PMD_SIZE);
mmap(addr, PMD_SIZE, PROT_WRITE|PROT_READ,
MAP_ANONYMOUS|MAP_PRIVATE|MAP_FIXED, -1, 0);
perror("re-mmap"), exit(1);
printf("PID %d consumed %lu KiB in PMD page tables\n",
getpid(), i * 4096 >> 10);
return pause();
The patch addresses the issue by account PMD tables to the process the
same way we account PTE.
The main place where PMD tables is accounted is __pmd_alloc() and
free_pmd_range(). But there're few corner cases:
- HugeTLB can share PMD page tables. The patch handles by accounting
the table to all processes who share it.
- x86 PAE pre-allocates few PMD tables on fork.
- Architectures with FIRST_USER_ADDRESS > 0. We need to adjust sanity
check on exit(2).
Accounting only happens on configuration where PMD page table's level is
present (PMD is not folded). As with nr_ptes we use per-mm counter. The
counter value is used to calculate baseline for badness score by
oom-killer.
Reported-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
We have to handle non-linear mappings for /proc/PID/{smaps,clear_refs}
which is unused now. Let's drop it.
As a small zero page, huge zero page should not be accounted in smaps
report as normal page.
For small pages we rely on vm_normal_page() to filter out zero page, but
vm_normal_page() is not designed to handle pmds. We only get here due
hackish cast pmd to pte in smaps_pte_range() -- pte and pmd format is not
necessary compatible on each and every architecture.
Let's add separate codepath to handle pmds. follow_trans_huge_pmd() will
detect huge zero page for us.
We would need pmd_dirty() helper to do this properly. The patch adds it
to THP-enabled architectures which don't yet have one.
[akpm@linux-foundation.org: use do_div to fix 32-bit build]
Signed-off-by: "Kirill A. Shutemov" <kirill@shutemov.name>
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Fengwei Yin <yfw.kernel@gmail.com>
MPX-enabled applications using large swaths of memory can
potentially have large numbers of bounds tables in process
address space to save bounds information. These tables can take
up huge swaths of memory (as much as 80% of the memory on the
system) even if we clean them up aggressively. In the worst-case
scenario, the tables can be 4x the size of the data structure
being tracked. IOW, a 1-page structure can require 4 bounds-table
pages.
Being this huge, our expectation is that folks using MPX are
going to be keen on figuring out how much memory is being
dedicated to it. So we need a way to track memory use for MPX.
If we want to specifically track MPX VMAs we need to be able to
distinguish them from normal VMAs, and keep them from getting
merged with normal VMAs. A new VM_ flag set only on MPX VMAs does
both of those things. With this flag, MPX bounds-table VMAs can
be distinguished from other VMAs, and userspace can also walk
/proc/$pid/smaps to get memory usage for MPX.
In addition to this flag, we also introduce a special ->vm_ops
specific to MPX VMAs (see the patch "add MPX specific mmap
interface"), but currently different ->vm_ops do not by
themselves prevent VMA merging, so we still need this flag.
We understand that VM_ flags are scarce and are open to other
options.
Signed-off-by: Qiaowei Ren <qiaowei.ren@intel.com>
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: linux-mm@kvack.org
Cc: linux-mips@linux-mips.org
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/20141114151825.565625B3@viggo.jf.intel.com
For VMAs that don't want write notifications, PTEs created for read faults
have their write bit set. If the read fault happens after VM_SOFTDIRTY is
cleared, then the PTE's softdirty bit will remain clear after subsequent
writes.
Here's a simple code snippet to demonstrate the bug:
char* m = mmap(NULL, getpagesize(), PROT_READ | PROT_WRITE,
MAP_ANONYMOUS | MAP_SHARED, -1, 0);
system("echo 4 > /proc/$PPID/clear_refs"); /* clear VM_SOFTDIRTY */
assert(*m == '\0'); /* new PTE allows write access */
assert(!soft_dirty(x));
*m = 'x'; /* should dirty the page */
assert(soft_dirty(x)); /* fails */
With this patch, write notifications are enabled when VM_SOFTDIRTY is
cleared. Furthermore, to avoid unnecessary faults, write notifications
are disabled when VM_SOFTDIRTY is set.
As a side effect of enabling and disabling write notifications with
care, this patch fixes a bug in mprotect where vm_page_prot bits set by
drivers were zapped on mprotect. An analogous bug was fixed in mmap by
commit c9d0bf241451 ("mm: uncached vma support with writenotify").
Signed-off-by: Peter Feiner <pfeiner@google.com>
Reported-by: Peter Feiner <pfeiner@google.com>
Suggested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Jamie Liu <jamieliu@google.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
If a /proc/pid/pagemap read spans a [VMA, an unmapped region, then a
VM_SOFTDIRTY VMA], the virtual pages in the unmapped region are reported
as softdirty. Here's a program to demonstrate the bug:
int main() {
const uint64_t PAGEMAP_SOFTDIRTY = 1ul << 55;
uint64_t pme[3];
int fd = open("/proc/self/pagemap", O_RDONLY);;
char *m = mmap(NULL, 3 * getpagesize(), PROT_READ,
munmap(m + getpagesize(), getpagesize());
pread(fd, pme, 24, (unsigned long) m / getpagesize() * 8);
assert(pme[0] & PAGEMAP_SOFTDIRTY); /* passes */
assert(!(pme[1] & PAGEMAP_SOFTDIRTY)); /* fails */
assert(pme[2] & PAGEMAP_SOFTDIRTY); /* passes */
return 0;
(Note that all pages in new VMAs are softdirty until cleared).
Tested:
Used the program given above. I'm going to include this code in
a selftest in the future.
[n-horiguchi@ah.jp.nec.com: prevent pagemap_pte_range() from overrunning]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
9e7814404b77 "hold task->mempolicy while numa_maps scans." fixed the
race with the exiting task but this is not enough.
The current code assumes that get_vma_policy(task) should either see
task->mempolicy == NULL or it should be equal to ->task_mempolicy saved
by hold_task_mempolicy(), so we can never race with __mpol_put(). But
this can only work if we can't race with do_set_mempolicy(), and thus
we can't race with another do_set_mempolicy() or do_exit() after that.
However, do_set_mempolicy()->down_write(mmap_sem) can not prevent this
race. This task can exec, change it's ->mm, and call do_set_mempolicy()
after that; in this case they take 2 different locks.
Change hold_task_mempolicy() to use get_task_policy(), it never returns
NULL, and change show_numa_map() to use __get_vma_policy() or fall back
to proc_priv->task_mempolicy.
Note: this is the minimal fix, we will cleanup this code later. I think
hold_task_mempolicy() and release_task_mempolicy() should die, we can
move this logic into show_numa_map(). Or we can move get_task_policy()
outside of ->mmap_sem and !CONFIG_NUMA code at least.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
- Rename vm_is_stack() to task_of_stack() and change it to return
"struct task_struct *" rather than the global (and thus wrong in
general) pid_t.
- Add the new pid_of_stack() helper which calls task_of_stack() and
uses the right namespace to report the correct pid_t.
Unfortunately we need to define this helper twice, in task_mmu.c
and in task_nommu.c. perhaps it makes sense to add fs/proc/util.c
and move at least pid_of_stack/task_of_stack there to avoid the
code duplication.
- Change show_map_vma() and show_numa_map() to use the new helper.
Cc: Greg Ungerer <gerg@uclinux.org>
m_start() can use get_proc_task() instead, and "struct inode *"
provides more potentially useful info, see the next changes.
Change the main loop in m_start() to update m->version. Mostly for
consistency, but this can help to avoid the same loop if the very
1st ->show() fails due to seq_overflow().
Add the "last_addr" optimization back. Like before, every ->show()
method checks !seq_overflow() and sets m->version = vma->vm_start.
However, it also checks that m_next_vma(vma) != NULL, otherwise it
sets m->version = -1 for the lockless "EOF" fast-path in m_start().
m_start() can simply do find_vma() + m_next_vma() if last_addr is
not zero, the code looks clear and simple and this case is clearly
separated from "scan vmas" path.
Extract the tail_vma/vm_next calculation from m_next() into the new
trivial helper, m_next_vma().
Now that m->version is gone we can cleanup m_start(). In particular,
- Remove the "unsigned long" typecast, m->index can't be negative
or exceed ->map_count. But lets use "unsigned int pos" to make
it clear that "pos < map_count" is safe.
- Remove the unnecessary "vma != NULL" check in the main loop. It
can't be NULL unless we have a vm bug.
- This also means that "pos < map_count" case can simply return the
valid vma and avoid "goto" and subsequent checks.
m_start() carefully documents, checks, and sets "m->version = -1" if
we are going to return NULL. The only problem is that we will be never
called again if m_start() returns NULL, so this is simply pointless
and misleading.
Otoh, ->show() methods m->version = 0 if vma == tail_vma and this is
just wrong, we want -1 in this case. And in fact we also want -1 if
->vm_next == NULL and ->tail_vma == NULL.
And it is not used consistently, the "scan vmas" loop in m_start()
should update last_addr too.
Finally, imo the whole "last_addr" logic in m_start() looks horrible.
find_vma(last_addr) is called unconditionally even if we are not going
to use the result. But the main problem is that this code participates
in tail_vma-or-NULL mess, and this looks simply unfixable.
Remove this optimization. We will add it back after some cleanups.
1. There is no reason to reset ->tail_vma in m_start(), if we return
IS_ERR_OR_NULL() it won't be used.
2. m_start() also clears priv->task to ensure that m_stop() won't use
the stale pointer if we fail before get_task_struct(). But this is
ugly and confusing, move this initialization in m_stop().
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
1. Kill the first "vma != NULL" check. Firstly this is not possible,
m_next() won't be called if ->start() or the previous ->next()
returns NULL.
And if it was possible the 2nd "vma != tail_vma" check is buggy,
we should not wrongly return ->tail_vma.
2. Make this function readable. The logic is very simple, we should
return check "vma != tail" once and return "vm_next || tail_vma".
m_start() drops ->mmap_sem and does mmput() if it retuns vsyscall
vma. This is because in this case m_stop()->vma_stop() obviously
can't use gate_vma->vm_mm.
Now that we have proc_maps_private->mm we can simplify this logic:
- Change m_start() to return with ->mmap_sem held unless it returns
IS_ERR_OR_NULL().
- Change vma_stop() to use priv->mm and avoid the ugly vma checks,
this makes "vm_area_struct *vma" unnecessary.
- This also allows m_start() to use vm_stop().
- Cleanup m_next() to follow the new locking rule.
Note: m_stop() looks very ugly, and this temporary uglifies it
even more. Fixed by the next change.
A simple test-case from Kirill Shutemov
cat /proc/self/maps >/dev/null
chmod +x /proc/self/net/packet
exec /proc/self/net/packet
makes lockdep unhappy, cat/exec take seq_file->lock + cred_guard_mutex in
the opposite order.
It's a false positive and probably we should not allow "chmod +x" on proc
files. Still I think that we should avoid mm_access() and cred_guard_mutex
in sys_read() paths, security checking should happen at open time. Besides,
this doesn't even look right if the task changes its ->mm between m_stop()
and m_start().
Add the new "mm_struct *mm" member into struct proc_maps_private and change
proc_maps_open() to initialize it using proc_mem_open(). Change m_start() to
use priv->mm if atomic_inc_not_zero(mm_users) succeeds or return NULL (eof)
otherwise.
The only complication is that proc_maps_open() users should additionally do
mmdrop() in fop->release(), add the new proc_map_release() helper for that.
Note: this is the user-visible change, if the task execs after open("maps")
the new ->mm won't be visible via this file. I hope this is fine, and this
matches /proc/pid/mem bahaviour.
Reported-by: "Kirill A. Shutemov" <kirill@shutemov.name>
do_maps_open() and numa_maps_open() are overcomplicated, they could use
__seq_open_private(). Plus they do the same, just sizeof(*priv)
Change them to use a new simple helper, proc_maps_open(ops, psize). This
simplifies the code and allows us to do the next changes.
get_gate_vma(priv->task->mm) looks ugly and wrong, task->mm can be NULL or
it can changed by exec right after mm_access().
And in theory this race is not harmless, the task can exec and then later
exit and free the new mm_struct. In this case get_task_mm(oldmm) can't
help, get_gate_vma(task->mm) can read the freed/unmapped memory.
I think that priv->task should simply die and hold_task_mempolicy() logic
can be simplified. tail_vma logic asks for cleanups too.
In PTE holes that contain VM_SOFTDIRTY VMAs, unmapped addresses before
VM_SOFTDIRTY VMAs are reported as softdirty by /proc/pid/pagemap. This
bug was introduced in commit 68b5a6524856 ("mm: softdirty: respect
VM_SOFTDIRTY in PTE holes"). That commit made /proc/pid/pagemap look at
VM_SOFTDIRTY in PTE holes but neglected to observe the start of VMAs
returned by find_vma.
Tested:
Wrote a selftest that creates a PMD-sized VMA then unmaps the first
page and asserts that the page is not softdirty. I'm going to send the
pagemap selftest in a later commit.
After a VMA is created with the VM_SOFTDIRTY flag set, /proc/pid/pagemap
should report that the VMA's virtual pages are soft-dirty until
VM_SOFTDIRTY is cleared (i.e., by the next write of "4" to
/proc/pid/clear_refs). However, pagemap ignores the VM_SOFTDIRTY flag
for virtual addresses that fall in PTE holes (i.e., virtual addresses
that don't have a PMD, PUD, or PGD allocated yet).
To observe this bug, use mmap to create a VMA large enough such that
there's a good chance that the VMA will occupy an unused PMD, then test
the soft-dirty bit on its pages. In practice, I found that a VMA that
covered a PMD's worth of address space was big enough.
This patch adds the necessary VMA lookup to the PTE hole callback in
/proc/pid/pagemap's page walk and sets soft-dirty according to the VMAs'
VM_SOFTDIRTY flag.
Now that 3.15 is released, this merges the 'next' branch into 'master',
bringing us to the normal situation where my 'master' branch is the
merge window.
* accumulated work in next: (6809 commits)
ufs: sb mutex merge + mutex_destroy
powerpc: update comments for generic idle conversion
cris: update comments for generic idle conversion
idle: remove cpu_idle() forward declarations
nbd: zero from and len fields in NBD_CMD_DISCONNECT.
mm: convert some level-less printks to pr_*
MAINTAINERS: adi-buildroot-devel is moderated
MAINTAINERS: add linux-api for review of API/ABI changes
mm/kmemleak-test.c: use pr_fmt for logging
fs/dlm/debug_fs.c: replace seq_printf by seq_puts
fs/dlm/lockspace.c: convert simple_str to kstr
fs/dlm/config.c: convert simple_str to kstr
mm: mark remap_file_pages() syscall as deprecated
mm: memcontrol: remove unnecessary memcg argument from soft limit functions
mm: memcontrol: clean up memcg zoneinfo lookup
mm/memblock.c: call kmemleak directly from memblock_(alloc|free)
mm/mempool.c: update the kmemleak stack trace for mempool allocations
lib/radix-tree.c: update the kmemleak stack trace for radix tree allocations
mm: introduce kmemleak_update_trace()
mm/kmemleak.c: use %u to print ->checksum
Signed-off-by: Fabian Frederick <fabf@skynet.be>
The age table walker doesn't check non-present hugetlb entry in common
path, so hugetlb_entry() callbacks must check it. The reason for this
behavior is that some callers want to handle it in its own way.
[ I think that reason is bogus, btw - it should just do what the regular
code does, which is to call the "pte_hole()" function for such hugetlb
entries - Linus]
However, some callers don't check it now, which causes unpredictable
result, for example when we have a race between migrating hugepage and
reading /proc/pid/numa_maps. This patch fixes it by adding !pte_present
checks on buggy callbacks.
This bug exists for years and got visible by introducing hugepage
migration.
ChangeLog v2:
- fix if condition (check !pte_present() instead of pte_present())
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Cc: <stable@vger.kernel.org> [3.12+]
[ Backported to 3.15. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> ]
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86 cdso updates from Peter Anvin:
"Vdso cleanups and improvements largely from Andy Lutomirski. This
makes the vdso a lot less ''special''"
* 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso, build: Make LE access macros clearer, host-safe
x86/vdso, build: Fix cross-compilation from big-endian architectures
x86/vdso, build: When vdso2c fails, unlink the output
x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET
x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls
x86, mm: Improve _install_special_mapping and fix x86 vdso naming
mm, fs: Add vm_ops->name as an alternative to arch_vma_name
x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments
x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO
x86, vdso: Move the 32-bit vdso special pages after the text
x86, vdso: Reimplement vdso.so preparation in build-time C
x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c
x86, vdso: Clean up 32-bit vs 64-bit vdso params
x86, mm: Ensure correct alignment of the fixmap
clear_soft_dirty()
clear_refs_write() is called earlier than clear_soft_dirty() and it is
more natural to clear VM_SOFTDIRTY (which belongs to VMA entry but not
PTEs) that early instead of clearing it a way deeper inside call chain.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
arch_vma_name sucks. It's a silly hack, and it's annoying to
implement correctly. In fact, AFAICS, even the straightforward x86
implementation is incorrect (I suspect that it breaks if the vdso
mapping is split or gets remapped).
This adds a new vm_ops->name operation that can replace it. The
followup patches will remove all uses of arch_vma_name on x86,
fixing a couple of annoyances in the process.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/2eee21791bb36a0a408c5c2bdb382a9e6a41ca4a.1400538962.git.luto@amacapital.net
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
All seq_printf() users are using "%n" for calculating padding size,
convert them to use seq_setwidth() / seq_pad() pair.
Cc: Joe Perches <joe@perches.com>
With split ptlock it's important to know which lock
pmd_trans_huge_lock() took. This patch adds one more parameter to the
function to return the lock.
In most places migration to new api is trivial. Exception is
move_huge_pmd(): we need to take two locks if pmd tables are different.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
With split page table lock for PMD level we can't hold mm->page_table_lock
while updating nr_ptes.
Let's convert it to atomic_long_t to avoid races.
This flag shows that the VMA is "newly created" and thus represents
"dirty" in the task's VM.
You can clear it by "echo 4 > /proc/pid/clear_refs."
Cc: Wu Fengguang <fengguang.wu@intel.com>
mpol_to_str() should not fail. Currently, it either fails because the
string buffer is too small or because a string hasn't been defined for a
mempolicy mode.
If a new mempolicy mode is introduced and no string is defined for it,
just warn and return "unknown".
If the buffer is too small, just truncate the string and return, the
same behavior as snprintf().
This also fixes a bug where there was no NULL-byte termination when doing
*p++ = '=' and *p++ ':' and maxlen has been reached.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Chen Gang <gang.chen@asianux.com>
If a page we are inspecting is in swap we may occasionally report it as
having soft dirty bit (even if it is clean). The pte_soft_dirty helper
should be called on present pte only.
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
mpol_to_str() may fail, and not fill the buffer (e.g. -EINVAL), so need
check about it, or buffer may not be zero based, and next seq_printf()
will cause issue.
The failure return need after mpol_cond_put() to match get_vma_policy().
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Pavel reported that in case if vma area get unmapped and then mapped (or
expanded) in-place, the soft dirty tracker won't be able to recognize this
situation since it works on pte level and ptes are get zapped on unmap,
loosing soft dirty bit of course.
So to resolve this situation we need to track actions on vma level, there
VM_SOFTDIRTY flag comes in. When new vma area created (or old expanded)
we set this bit, and keep it here until application calls for clearing
soft dirty bit.
Thus when user space application track memory changes now it can detect if
vma area is renewed.
Reported-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Rob Landley <rob@landley.net>
Recently we met quite a lot of random kernel panic issues after enabling
CONFIG_PROC_PAGE_MONITOR. After debuggind we found this has something
to do with following bug in pagemap:
In struct pagemapread:
struct pagemapread {
int pos, len;
pagemap_entry_t *buffer;
bool v2;
pos is number of PM_ENTRY_BYTES in buffer, but len is the size of
buffer, it is a mistake to compare pos and len in add_page_map() for
checking buffer is full or not, and this can lead to buffer overflow and
random kernel panic issue.
Correct len to be total number of PM_ENTRY_BYTES in buffer.
[akpm@linux-foundation.org: document pagemapread.pos and .len units, fix PM_ENTRY_BYTES definition]
Signed-off-by: Yonghua Zheng <younghua.zheng@gmail.com>
