[ Upstream commit 30696378f68a9e3dad6bfe55938b112e72af00c2 ]
The ramoops backend currently calls persistent_ram_save_old() even
if a buffer is empty. While this appears to work, it is does not seem
like the right thing to do and could lead to future bugs so lets avoid
that. It also prevents misleading prints in the logs which claim the
buffer is valid.
I got something like:
found existing buffer, size 0, start 0
When I was expecting:
no valid data in buffer (sig = ...)
This bails out early (and reports with pr_debug()), since it's an
acceptable state.
Signed-off-by: Joel Fernandes (Google) <joel@joelfernandes.org>
Co-developed-by: Kees Cook <keescook@chromium.org>
commit 831b624df1b420c8f9281ed1307a8db23afb72df upstream.
persistent_ram_vmap() returns the page start vaddr.
persistent_ram_iomap() supports non-page-aligned mapping.
persistent_ram_buffer_map() always adds offset-in-page to the vaddr
returned from these two functions, which causes incorrect mapping of
non-page-aligned persistent ram buffer.
By default ftrace_size is 4096 and max_ftrace_cnt is nr_cpu_ids. Without
this patch, the zone_sz in ramoops_init_przs() is 4096/nr_cpu_ids which
might not be page aligned. If the offset-in-page > 2048, the vaddr will be
in next page. If the next page is not mapped, it will cause kernel panic:
[ 0.074231] BUG: unable to handle kernel paging request at ffffa19e0081b000
[ 0.075000] RIP: 0010:persistent_ram_new+0x1f8/0x39f
[ 0.075000] Call Trace:
[ 0.075000] ramoops_init_przs.part.10.constprop.15+0x105/0x260
[ 0.075000] ramoops_probe+0x232/0x3a0
[ 0.075000] platform_drv_probe+0x3e/0xa0
[ 0.075000] driver_probe_device+0x2cd/0x400
[ 0.075000] __driver_attach+0xe4/0x110
[ 0.075000] ? driver_probe_device+0x400/0x400
[ 0.075000] bus_for_each_dev+0x70/0xa0
[ 0.075000] driver_attach+0x1e/0x20
[ 0.075000] bus_add_driver+0x159/0x230
[ 0.075000] ? do_early_param+0x95/0x95
[ 0.075000] driver_register+0x70/0xc0
[ 0.075000] ? init_pstore_fs+0x4d/0x4d
[ 0.075000] __platform_driver_register+0x36/0x40
[ 0.075000] ramoops_init+0x12f/0x131
[ 0.075000] do_one_initcall+0x4d/0x12c
[ 0.075000] kernel_init_freeable+0x19b/0x222
[ 0.075000] ? rest_init+0xbb/0xbb
[ 0.075000] kernel_init+0xe/0xfc
[ 0.075000] ret_from_fork+0x3a/0x50
Signed-off-by: Bin Yang <bin.yang@intel.com>
[kees: add comments describing the mapping differences, updated commit log]
Fixes: 24c3d2f342ed ("staging: android: persistent_ram: Make it possible to use memory outside of bootmem")
Cc: stable@vger.kernel.org
The per-prz spinlock should be using the dynamic initializer so that
lockdep can correctly track it. Without this, under lockdep, we get a
warning at boot that the lock is in non-static memory.
Fixes: 109704492ef6 ("pstore: Make spinlock per zone instead of global")
Fixes: 76d5692a5803 ("pstore: Correctly initialize spinlock and flags")
The ram backend wasn't always initializing its spinlock correctly. Since
it was coming from kzalloc memory, though, it was harmless on
architectures that initialize unlocked spinlocks to 0 (at least x86 and
ARM). This also fixes a possibly ignored flag setting too.
When running under CONFIG_DEBUG_SPINLOCK, the following Oops was visible:
[ 0.760836] persistent_ram: found existing buffer, size 29988, start 29988
[ 0.765112] persistent_ram: found existing buffer, size 30105, start 30105
[ 0.769435] persistent_ram: found existing buffer, size 118542, start 118542
[ 0.785960] persistent_ram: found existing buffer, size 0, start 0
[ 0.786098] persistent_ram: found existing buffer, size 0, start 0
[ 0.786131] pstore: using zlib compression
[ 0.790716] BUG: spinlock bad magic on CPU#0, swapper/0/1
[ 0.790729] lock: 0xffffffc0d1ca9bb0, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
[ 0.790742] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.10.0-rc2+ #913
[ 0.790747] Hardware name: Google Kevin (DT)
[ 0.790750] Call trace:
[ 0.790768] [<ffffff900808ae88>] dump_backtrace+0x0/0x2bc
[ 0.790780] [<ffffff900808b164>] show_stack+0x20/0x28
[ 0.790794] [<ffffff9008460ee0>] dump_stack+0xa4/0xcc
[ 0.790809] [<ffffff9008113cfc>] spin_dump+0xe0/0xf0
[ 0.790821] [<ffffff9008113d3c>] spin_bug+0x30/0x3c
[ 0.790834] [<ffffff9008113e28>] do_raw_spin_lock+0x50/0x1b8
[ 0.790846] [<ffffff9008a2d2ec>] _raw_spin_lock_irqsave+0x54/0x6c
[ 0.790862] [<ffffff90083ac3b4>] buffer_size_add+0x48/0xcc
[ 0.790875] [<ffffff90083acb34>] persistent_ram_write+0x60/0x11c
[ 0.790888] [<ffffff90083aab1c>] ramoops_pstore_write_buf+0xd4/0x2a4
[ 0.790900] [<ffffff90083a9d3c>] pstore_console_write+0xf0/0x134
[ 0.790912] [<ffffff900811c304>] console_unlock+0x48c/0x5e8
[ 0.790923] [<ffffff900811da18>] register_console+0x3b0/0x4d4
[ 0.790935] [<ffffff90083aa7d0>] pstore_register+0x1a8/0x234
[ 0.790947] [<ffffff90083ac250>] ramoops_probe+0x6b8/0x7d4
[ 0.790961] [<ffffff90085ca548>] platform_drv_probe+0x7c/0xd0
[ 0.790972] [<ffffff90085c76ac>] driver_probe_device+0x1b4/0x3bc
[ 0.790982] [<ffffff90085c7ac8>] __device_attach_driver+0xc8/0xf4
[ 0.790996] [<ffffff90085c4bfc>] bus_for_each_drv+0xb4/0xe4
[ 0.791006] [<ffffff90085c7414>] __device_attach+0xd0/0x158
[ 0.791016] [<ffffff90085c7b18>] device_initial_probe+0x24/0x30
[ 0.791026] [<ffffff90085c648c>] bus_probe_device+0x50/0xe4
[ 0.791038] [<ffffff90085c35b8>] device_add+0x3a4/0x76c
[ 0.791051] [<ffffff90087d0e84>] of_device_add+0x74/0x84
[ 0.791062] [<ffffff90087d19b8>] of_platform_device_create_pdata+0xc0/0x100
[ 0.791073] [<ffffff90087d1a2c>] of_platform_device_create+0x34/0x40
[ 0.791086] [<ffffff900903c910>] of_platform_default_populate_init+0x58/0x78
[ 0.791097] [<ffffff90080831fc>] do_one_initcall+0x88/0x160
[ 0.791109] [<ffffff90090010ac>] kernel_init_freeable+0x264/0x31c
[ 0.791123] [<ffffff9008a25bd0>] kernel_init+0x18/0x11c
[ 0.791133] [<ffffff9008082ec0>] ret_from_fork+0x10/0x50
[ 0.793717] console [pstore-1] enabled
[ 0.797845] pstore: Registered ramoops as persistent store backend
[ 0.804647] ramoops: attached 0x100000@0xf7edc000, ecc: 0/0
Fixes: 663deb47880f ("pstore: Allow prz to control need for locking")
Reported-by: Brian Norris <briannorris@chromium.org>
In preparation of not locking at all for certain buffers depending on if
there's contention, make locking optional depending on the initialization
of the prz.
Signed-off-by: Joel Fernandes <joelaf@google.com>
[kees: moved locking flag into prz instead of via caller arguments]
Currently pstore has a global spinlock for all zones. Since the zones
are independent and modify different areas of memory, there's no need
to have a global lock, so we should use a per-zone lock as introduced
here. Also, when ramoops's ftrace use-case has a FTRACE_PER_CPU flag
introduced later, which splits the ftrace memory area into a single zone
per CPU, it will eliminate the need for locking. In preparation for this,
make the locking optional.
[kees: updated commit message]
The ramoops buffer may be mapped as either I/O memory or uncached
memory. On ARM64, this results in a device-type (strongly-ordered)
mapping. Since unnaligned accesses to device-type memory will
generate an alignment fault (regardless of whether or not strict
alignment checking is enabled), it is not safe to use memcpy().
memcpy_fromio() is guaranteed to only use aligned accesses, so use
that instead.
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Signed-off-by: Enric Balletbo Serra <enric.balletbo@collabora.com>
Reviewed-by: Puneet Kumar <puneetster@chromium.org>
persistent_ram_update uses vmap / iomap based on whether the buffer is in
memory region or reserved region. However, both map it as non-cacheable
memory. For armv8 specifically, non-cacheable mapping requests use a
memory type that has to be accessed aligned to the request size. memcpy()
doesn't guarantee that.
Signed-off-by: Furquan Shaikh <furquan@google.com>
Reviewed-by: Aaron Durbin <adurbin@chromium.org>
Reviewed-by: Olof Johansson <olofj@chromium.org>
Tested-by: Furquan Shaikh <furquan@chromium.org>
Removing a bounce buffer copy operation in the pmsg driver path is
always better. We also gain in overall performance by not requesting
a vmalloc on every write as this can cause precious RT tasks, such
as user facing media operation, to stall while memory is being
reclaimed. Added a write_buf_user to the pstore functions, a backup
platform write_buf_user that uses the small buffer that is part of
the instance, and implemented a ramoops write_buf_user that only
supports PSTORE_TYPE_PMSG.
Signed-off-by: Mark Salyzyn <salyzyn@android.com>
I have here a FPGA behind PCIe which exports SRAM which I use for
pstore. Now it seems that the FPGA no longer supports cmpxchg based
updates and writes back 0xff…ff and returns the same. This leads to
crash during crash rendering pstore useless.
Since I doubt that there is much benefit from using cmpxchg() here, I am
dropping this atomic access and use the spinlock based version.
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Rabin Vincent <rabinv@axis.com>
Tested-by: Rabin Vincent <rabinv@axis.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
[kees: remove "_locked" suffix since it's the only option now]
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Currently trying to use pstore on at least ARMs can hang as we're
mapping the peristent RAM with pgprot_noncached().
On ARMs, pgprot_noncached() will actually make the memory strongly
ordered, and as the atomic operations pstore uses are implementation
defined for strongly ordered memory, they may not work. So basically
atomic operations have undefined behavior on ARM for device or strongly
ordered memory types.
Let's fix the issue by using write-combine variants for mappings. This
corresponds to normal, non-cacheable memory on ARM. For many other
architectures, this change does not change the mapping type as by
default we have:
#define pgprot_writecombine pgprot_noncached
The reason why pgprot_noncached() was originaly used for pstore
is because Colin Cross <ccross@android.com> had observed lost
debug prints right before a device hanging write operation on some
systems. For the platforms supporting pgprot_noncached(), we can
add a an optional configuration option to support that. But let's
get pstore working first before adding new features.
Cc: Anton Vorontsov <cbouatmailru@gmail.com>
[tony@atomide.com: updated description]
kmalloc_array manages count*sizeof overflow.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
- Define pr_fmt in plateform.c and ram_core.c for global prefix.
- Coalesce format fragments.
- Separate format/arguments on lines > 80 characters.
Note: Some pr_foo() were initially declared without prefix and therefore
this could break existing log analyzer.
[akpm@linux-foundation.org: missed a couple of prefix removals]
Cc: Joe Perches <joe@perches.com>
In case new offset is equal to prz->buffer_size, it won't wrap at this
time and will return old(overflow) value next time.
Signed-off-by: Liu ShuoX <shuox.liu@intel.com>
For persistent RAM outside of main memory, the memory may have limitations
on supported accesses. For internal RAM on highbank platform exclusive
accesses are not supported and will hang the system. So atomic_cmpxchg
cannot be used. This commit uses spinlock protection for buffer size and
start updates on ioremapped regions instead.
Acked-by: Anton Vorontsov <anton@enomsg.org>
This was lost when proc/last_kmsg moved to pstore/console-ramoops.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Signed-off-by: Anton Vorontsov <anton@enomsg.org>
Allow specifying ecc parameters in platform data
[jstultz: Tweaked commit subject & add commit message]
Wastes less memory and allows using more memory for ecc than data.
[jstultz: Tweaked commit subject]
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit from the pstore filesystem.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Decoding the binary trace w/ a different kernel might be troublesome
since we convert addresses to symbols. For kernels with minimal changes,
the mappings would probably match, but it's not guaranteed at all.
(But still we could convert the addresses by hand, since we do print
raw addresses.)
If we use modules, the symbols could be loaded at different addresses
from the previously booted kernel, and so this would also fail, but
there's nothing we can do about it.
Also, the binary data format that pstore/ram is using in its ringbuffer
may change between the kernels, so here we too must ensure that we're
running the same kernel.
So, there are two questions really:
1. How to compute the unique kernel tag;
2. Where to store it.
In this patch we're using LINUX_VERSION_CODE, just as hibernation
(suspend-to-disk) does. This way we are protecting from the kernel
version mismatch, making sure that we're running the same kernel
version and patch level. We could use CRC of a symbol table (as
suggested by Tony Luck), but for now let's not be that strict.
And as for storing, we are using a small trick here. Instead of
allocating a dedicated buffer for the tag (i.e. another prz), or
hacking ram_core routines to "reserve" some control data in the
buffer, we are just encoding the tag into the buffer signature
(and XOR'ing it with the actual signature value, so that buffers
not needing a tag can just pass zero, which will result into the
plain old PRZ signature).
Suggested-by: Steven Rostedt <rostedt@goodmis.org>
Suggested-by: Tony Luck <tony.luck@intel.com>
Suggested-by: Colin Cross <ccross@android.com>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
Nowadays we can use prz->ecc_size as a flag, no need for the special
member in the prz struct.
This is now pretty straightforward: instead of using bool, just pass
an integer. For backwards compatibility ramoops.ecc=1 means 16 bytes
ECC (using 1 byte for ECC isn't much of use anyway).
Suggested-by: Arve Hjønnevåg <arve@android.com>
The struct members were never used anywhere outside of
persistent_ram_init_ecc(), so there's actually no need for them
to be in the struct.
If we ever want to make polynomial or symbol size configurable,
it would make more sense to just pass initialized rs_decoder
to the persistent_ram init functions.
- Instead of exploiting unsigned overflows (which doesn't work for all
sizes), use straightforward checking for ECC total size not exceeding
initial buffer size;
- Printing overflowed buffer_size is not informative. Instead, print
ecc_size and buffer_size;
- No need for buffer_size argument in persistent_ram_init_ecc(),
we can address prz->buffer_size directly.
We will implement variable-sized ECC buffers soon, so post_init routine
might fail much more likely, so we'd better check for its errors.
To make error handling simple, modify persistent_ram_free() to it be safe
at all times.
Registering the platform driver before module_init allows us to log oopses
that happen during device probing.
This requires changing module_init to postcore_initcall, and switching
from platform_driver_probe to platform_driver_register because the
platform device is not registered when the platform driver is registered;
and because we use driver_register, now can't use create_bundle() (since
it will try to register the same driver once again), so we have to switch
to platform_device_register_data().
Also, some __init -> __devinit changes were needed.
Overall, the registration logic is now much clearer, since we have only
one driver registration point, and just an optional dummy device, which
is created from the module parameters.
The code tried to maintain the global list of persistent ram zones,
which isn't a great idea overall, plus since Android's ram_console
is no longer there, we can remove some unused functions.
Acked-by: Colin Cross <ccross@android.com>
Since we use multiple regions, the messages are somewhat annoying.
We do print total mapped memory already, so no need to print the
information for each region in the library routines.
A handy function that we will use outside of ram_core soon. But
so far just factor it out and start using it in post_init().
Otherwise, the files will survive just one reboot, and on a subsequent
boot they will disappear.
Without the update, we'll only see the new dmesg buffer after the
reboot, but previously we could see it right away. Making an oops
visible in pstore filesystem before reboot is a somewhat dubious
feature, but removing it wasn't an intentional change, so let's
restore it.
For this we have to make persistent_ram_save_old() safe for calling
multiple times, and also extern it.
This is a first step for adding ECC support for pstore RAM backend: we
will use the persistent_ram routines, kindly provided by Google.
Basically, persistent_ram is a set of helper routines to deal with the
[optionally] ECC-protected persistent ram regions.
A bit of Makefile, Kconfig and header files adjustments were needed
because of the move.
