Now that sys_sysctl is a generic wrapper around /proc/sys .ctl_name
and .strategy members of sysctl tables are dead code. Remove them.
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
Commit d01730d74d2b0155da50d44555001706294014f7 didn't completely fix
the problem since we still take dqio_mutex and i_mutex in the wrong
order. Move taking of i_mutex further down (luckily it's needed only
for updating inode flags) below where dqio_mutex is taken.
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
The following test script triggers a deadlock on ext2 filesystem:
while true; do quotaon /dev/hda >&/dev/null; usleep $RANDOM; done &
while true; do quotaoff /dev/hda >&/dev/null; usleep $RANDOM; done &
I found there is a potential deadlock between quotaon and quotaoff (or
quotasync). Basically, all of quotactl operations need to be protected by
dqonoff_mutex. vfs_quota_off and vfs_quota_sync also call sb->s_op->quota_write
that needs to grab the i_mutex of the quota file. But in vfs_quota_on_inode
(called from quotaon operation), the current code tries to grab the i_mutex of
the quota file first before getting quonoff_mutex.
Reverse the order in which we take locks in vfs_quota_on_inode().
Jan Kara: Changed changelog to be more readable, made lockdep happy with
I_MUTEX_QUOTA.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
clear_inode() will switch inode state from I_FREEING to I_CLEAR, and do so
_outside_ of inode_lock. So any I_FREEING testing is incomplete without a
coupled testing of I_CLEAR.
So add I_CLEAR tests to drop_pagecache_sb(), generic_sync_sb_inodes() and
add_dquot_ref().
Masayoshi MIZUMA discovered the bug in drop_pagecache_sb() and Jan Kara
reminds fixing the other two cases.
Masayoshi MIZUMA has a nice panic flow:
[process A] | [process B]
| prune_icache() | drop_pagecache()
| spin_lock(&inode_lock) | drop_pagecache_sb()
| inode->i_state |= I_FREEING; | |
| spin_unlock(&inode_lock) | V
| V | |
| dispose_list() | |
| list_del() | |
| clear_inode() | |
| inode->i_state = I_CLEAR | |
| | | V
| | | if (inode->i_state & (I_FREEING|I_WILL_FREE))
| | | continue; <==== NOT MATCH
| | | (DANGER from here on! Accessing disposing inode!)
| | | __iget()
| | | list_move() <===== PANIC on poisoned list !!
V V |
(time)
Reported-by: Masayoshi MIZUMA <m.mizuma@jp.fujitsu.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: <stable@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits)
fs: avoid I_NEW inodes
Merge code for single and multiple-instance mounts
Remove get_init_pts_sb()
Move common mknod_ptmx() calls into caller
Parse mount options just once and copy them to super block
Unroll essentials of do_remount_sb() into devpts
vfs: simple_set_mnt() should return void
fs: move bdev code out of buffer.c
constify dentry_operations: rest
constify dentry_operations: configfs
constify dentry_operations: sysfs
constify dentry_operations: JFS
constify dentry_operations: OCFS2
constify dentry_operations: GFS2
constify dentry_operations: FAT
constify dentry_operations: FUSE
constify dentry_operations: procfs
constify dentry_operations: ecryptfs
constify dentry_operations: CIFS
constify dentry_operations: AFS
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-quota-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-quota-2.6: (27 commits)
ext2: Zero our b_size in ext2_quota_read()
trivial: fix typos/grammar errors in fs/Kconfig
quota: Coding style fixes
quota: Remove superfluous inlines
quota: Remove uppercase aliases for quota functions.
nfsd: Use lowercase names of quota functions
jfs: Use lowercase names of quota functions
udf: Use lowercase names of quota functions
ufs: Use lowercase names of quota functions
reiserfs: Use lowercase names of quota functions
ext4: Use lowercase names of quota functions
ext3: Use lowercase names of quota functions
ext2: Use lowercase names of quota functions
ramfs: Remove quota call
vfs: Use lowercase names of quota functions
quota: Remove dqbuf_t and other cleanups
quota: Remove NODQUOT macro
quota: Make global quota locks cacheline aligned
quota: Move quota files into separate directory
ext4: quota reservation for delayed allocation
Wrap long lines, remove assignments from conditions, rewrite two
overcomplicated for loops.
Remove inlines of large functions to decrease code size (saved 1543
bytes).
Remove this macro which is just a definition of NULL. Fix a few coding style
issues along the way.
Andrew Morton has suggested that three global quota locks can end up in the
same cacheline which can result in bad cacheline ping-pong on SMP machines.
Make locks cacheline aligned so that we avoid this problem (thanks goes to
Andrew for the idea).
CC: Andrew Morton <akpm@linux-foundation.org>
Quota subsystem has more and more files. It's time to create a dir for it.
