path: root/fs/quota
2011-01-10quota: Use %pV and __attribute__((format (printf in __quota_error and fix ↵Joe Perches
fallout Use %pV in __quota_error so a single printk can not be interleaved with other logging messages. Add __attribute__((format (printf, 3, 4))) so format and arguments can be verified by compiler. Make sure printk formats and arguments match. Block # needed a pointer dereference. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28quota: Fix possible oops in __dquot_initialize()Jan Kara
When quotaon(8) races with __dquot_initialize() or dqget() fails because of EIO, ENOSPC, or similar error, we could possibly dereference NULL pointer in inode->i_dquot[cnt]. Add proper checking. Reported-by: Dmitry Monakhov <dmonakhov@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28quota: Fix issuing of warnings from dquot_transferJan Kara
__dquot_transfer accidentally called flush_warnings for a wrong set of dquots which could result in quota warnings being issued with a wrong identification. Also when operation fails because of EDQUOT, there's no need check for issuing information message about user getting below limits (no transfer has actually happened). Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28quota: fix dquot_disable vs dquot_transfer race v2Dmitry
I've got following lockup: dquot_disable dquot_transfer ->dqget() sb_has_quota_active dqopt->flags &= ~dquot_state_flag(f, cnt) atomic_inc(dq->dq_count) ->drop_dquot_ref(sb, cnt); down_write(dqptr_sem) inode->i_dquot[cnt] = NULL ->__dquot_transfer invalidate_dquots(sb, cnt); down_write(&dqptr_sem) ->wait for dq_wait_unused inode->i_dquot = new_dquot /* wait forever */ ^^^^New quota user^^^^^^ We cannot allow new references to dquots from inodes after drop_dquot_ref() has removed them. We have to recheck quota state under dqptr_sem and before assignment, as we do it in dquot_initialize(). Signed-off-by: Dmitry Monakhov <dmonakhov@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-05quota: Make QUOTACTL config be selected by its usersJan Kara
Remove "depends on" line from QUOTACTL config option and rather select the option explicitely from config options which need it. It makes more sense this way and also fixes Kconfig warning due to GFS2 selecting QUOTACTL but QUOTACTL not depending on it. Signed-off-by: Jan Kara <jack@suse.cz>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09simplify checks for I_CLEAR/I_FREEINGAl Viro
add I_CLEAR instead of replacing I_FREEING with it. I_CLEAR is equivalent to I_FREEING for almost all code looking at either; it's there to keep track of having called clear_inode() exactly once per inode lifetime, at some point after having set I_FREEING. I_CLEAR and I_FREEING never get set at the same time with the current code, so we can switch to setting i_flags to I_FREEING | I_CLEAR instead of I_CLEAR without loss of information. As the result of such change, checks become simpler and the amount of code that needs to know about I_CLEAR shrinks a lot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-07Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Fix dirtying of journalled buffers in data=journal mode ext3: default to ordered mode quota: Use mark_inode_dirty_sync instead of mark_inode_dirty quota: Change quota error message to print out disk and function name MAINTAINERS: Update entries of ext2 and ext3 MAINTAINERS: Update address of Andreas Dilger ext3: Avoid filesystem corruption after a crash under heavy delete load ext3: remove vestiges of nobh support ext3: Fix set but unused variables quota: clean up quota active checks quota: Clean up the namespace in dqblk_xfs.h quota: check quota reservation on remove_dquot_ref
2010-07-23quota: Use mark_inode_dirty_sync instead of mark_inode_dirtyJan Kara
Quota code never touches file data. It just modifies i_blocks + i_bytes of inodes and inode flags of quota files. So use mark_inode_dirty_sync instead of mark_inode_dirty. Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21quota: Change quota error message to print out disk and function nameJiaying Zhang
The current quota error message doesn't always print the disk name, so it is hard to identify the "bad" disk when quota error happens. This patch changes the standardized quota error message to print out disk name and function name. It also uses a combination of cpp macro and inline function to provide better type checking and to lower the text size of the message. [Jan Kara: Export __quota_error] Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21quota: clean up quota active checksChristoph Hellwig
The various quota operations check for any quota beeing active on a superblock, and the inode not having the noquota flag. Merge these two checks into a dquot_active check and move that into dquot.c as that's the only place where it's needed. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21quota: Clean up the namespace in dqblk_xfs.hChristoph Hellwig
Almost all identifiers use the FS_* namespace, so rename the missing few XFS_* ones to FS_* as well. Without this some people might get upset about having too many XFS names in generic code. Acked-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21quota: check quota reservation on remove_dquot_refDmitry Monakhov
Reserved space must being claimed before remove_dquot_ref() for a given inode. Filesystem is responsible for performing force blocks allocation in case of dealloc in ->quota_off. Let's add sanity check for that case. Do it similar to add_dquot_ref(). Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-19mm: add context argument to shrinker callbackDave Chinner
The current shrinker implementation requires the registered callback to have global state to work from. This makes it difficult to shrink caches that are not global (e.g. per-filesystem caches). Pass the shrinker structure to the callback so that users can embed the shrinker structure in the context the shrinker needs to operate on and get back to it in the callback via container_of(). Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de>
2010-05-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert quota statistics to generic percpu_counter ext3 uses rb_node = NULL; to zero rb_root. quota: Fixup dquot_transfer reiserfs: Fix resuming of quotas on remount read-write pohmelfs: Remove dead quota code ufs: Remove dead quota code udf: Remove dead quota code quota: rename default quotactl methods to dquot_ quota: explicitly set ->dq_op and ->s_qcop quota: drop remount argument to ->quota_on and ->quota_off quota: move unmount handling into the filesystem quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers quota: move remount handling into the filesystem ocfs2: Fix use after free on remount read-only Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
2010-05-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits) ext4: Make fsync sync new parent directories in no-journal mode ext4: Drop whitespace at end of lines ext4: Fix compat EXT4_IOC_ADD_GROUP ext4: Conditionally define compat ioctl numbers tracing: Convert more ext4 events to DEFINE_EVENT ext4: Add new tracepoints to track mballoc's buddy bitmap loads ext4: Add a missing trace hook ext4: restart ext4_ext_remove_space() after transaction restart ext4: Clear the EXT4_EOFBLOCKS_FL flag only when warranted ext4: Avoid crashing on NULL ptr dereference on a filesystem error ext4: Use bitops to read/modify i_flags in struct ext4_inode_info ext4: Convert calls of ext4_error() to EXT4_ERROR_INODE() ext4: Convert callers of ext4_get_blocks() to use ext4_map_blocks() ext4: Add new abstraction ext4_map_blocks() underneath ext4_get_blocks() ext4: Use our own write_cache_pages() ext4: Show journal_checksum option ext4: Fix for ext4_mb_collect_stats() ext4: check for a good block group before loading buddy pages ext4: Prevent creation of files larger than RLIMIT_FSIZE using fallocate ext4: Remove extraneous newlines in ext4_msg() calls ... Fixed up trivial conflict in fs/ext4/fsync.c
2010-05-27quota: Convert quota statistics to generic percpu_counterDmitry Monakhov
Generic per-cpu counter has some memory overhead but it is negligible for modern systems and embedded systems compile without quota support. And code reuse is a good thing. This patch should fix complain from preemptive kernels which was introduced by dde9588853b1bde. [Jan Kara: Fixed patch to work on 32-bit archs as well] Reported-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-27quota: Fixup dquot_transferJan Kara
Commit bc8e5f07392f05c47c8bdeff4f7098db440d065c had a typo which caused quota miscomputation when changing owner group of a file. Linus will hate me. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: rename default quotactl methods to dquot_Christoph Hellwig
Follow the dquot_* style used elsewhere in dquot.c. [Jan Kara: Fixed up missing conversion of ext2] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: explicitly set ->dq_op and ->s_qcopChristoph Hellwig
Only set the quota operation vectors if the filesystem actually supports quota instead of doing it for all filesystems in alloc_super(). [Jan Kara: Export dquot_operations and vfs_quotactl_ops] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: drop remount argument to ->quota_on and ->quota_offChristoph Hellwig
Remount handling has fully moved into the filesystem, so all this is superflous now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappersChristoph Hellwig
Instead of having wrappers in the VFS namespace export the dquot_suspend and dquot_resume helpers directly. Also rename vfs_quota_disable to dquot_disable while we're at it. [Jan Kara: Moved dquot_suspend to quotaops.h and made it inline] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21new helper: iterate_supers()Al Viro
... and switch the simple "loop over superblocks and do something" loops to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Bury __put_super_and_need_restart()Al Viro
2010-05-21Convert simple loops over superblocks to list_for_each_entry_safeAl Viro
2010-05-21Leave superblocks on s_list until the endAl Viro
We used to remove from s_list and s_instances at the same time. So let's *not* do the former and skip superblocks that have empty s_instances in the loops over s_list. The next step, of course, will be to get rid of rescan logics in those loops. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21dquot: Detect partial write error to quota file in write_blk() and add ↵Jiaying Zhang
printk_ratelimit for quota error messages This patch changes quota_tree.c:write_blk() to detect error caused by partial write to quota file and add a macro to limit control printed quota error messages so we won't fill up dmesg with a corrupted quota file. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: Refactor dquot_transfer code so that OCFS2 can pass in its referencesJan Kara
Currently, __dquot_transfer() acquires its own references of dquot structures that will be put into inode. But for OCFS2, this creates a lock inversion between dq_lock (waited on in dqget) and transaction start (started in ocfs2_setattr). Currently, deadlock is impossible because dq_lock is acquired only during dquot_acquire and dquot_release and we already hold a reference to dquot structures in ocfs2_setattr so neither of these functions can be called while we call dquot_transfer. But this is rather subtle and it is hard to teach lockdep about it. So provide __dquot_transfer function that can be passed dquot references directly. OCFS2 can then pass acquired dquot references directly to __dquot_transfer with proper locking. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: unify quota init condition in setattrDmitry Monakhov
Quota must being initialized if size or uid/git changes requested. But initialization performed in two different places: in case of i_size file system is responsible for dquot init , but in case of uid/gid init will be called internally in dquot_transfer(). This ambiguity makes code harder to understand. Let's move this logic to one common helper function. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: remove sb_has_quota_active in get/set_infoChristoph Hellwig
The methods already do these checks, so remove them in the quotactl implementation to allow non-VFS quota implementations to also support these calls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: unify ->set_dqblkChristoph Hellwig
Pass the larger struct fs_disk_quota to the ->set_dqblk operation so that the Q_SETQUOTA and Q_XSETQUOTA operations can be implemented with a single filesystem operation and we can retire the ->set_xquota operation. The additional information (RT-subvolume accounting and warn counts) are left zero for the VFS quota implementation. Add new fieldmask values for setting the numer of blocks and inodes values which is required for the VFS quota, but wasn't for XFS. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: unify ->get_dqblkChristoph Hellwig
Pass the larger struct fs_disk_quota to the ->get_dqblk operation so that the Q_GETQUOTA and Q_XGETQUOTA operations can be implemented with a single filesystem operation and we can retire the ->get_xquota operation. The additional information (RT-subvolume accounting and warn counts) are left zero for the VFS quota implementation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: Make quota stat accounting lockless.Dmitry Monakhov
Quota stats is mostly writable data structure. Let's alloc percpu bucket for each value. NOTE: dqstats_read() function is racy against dqstats_{inc,dec} and may return inconsistent value. But this is ok since absolute accuracy is not required. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21suppress warning: "quotatypes" defined but not usedSergey Senozhatsky
Suppress compilation warning: "quotatypes" defined but not used. quotatypes is used only when CONFIG_QUOTA_DEBUG or CONFIG_PRINT_QUOTA_WARNING is/are defined. Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21quota: optimize mark_dirty logicDmitry Monakhov
- Skip locking if quota is dirty already. - Return old quota state to help fs-specciffic implementation to optimize case where quota was dirty already. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-16quota: add the option to not fail with EDQUOT in blockEric Sandeen
To simplify metadata tracking for delalloc writes, ext4 will simply claim metadata blocks at allocation time, without first speculatively reserving the worst case and then freeing what was not used. To do this, we need a mechanism to track allocations in the quota subsystem, but potentially allow that allocation to actually go over quota. This patch adds a DQUOT_SPACE_NOFAIL flag and function variants for this purpose. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-05-16quota: use flags interface for dquot alloc/free spaceEric Sandeen
Switch __dquot_alloc_space and __dquot_free_space to take flags to indicate whether to warn and/or to reserve (or free reserve). This is slightly more readable at the callpoints, and makes it cleaner to add a "nofail" option in the next patch. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-04-20quota: Convert __DQUOT_PARANOIA symbol to standard config optionJan Kara
Make __DQUOT_PARANOIA define from the old days a standard config option and turn it off by default. This gets rid of a quota warning about writes before quota is turned on for systems with ext4 root filesystem. Currently there's no way to legally solve this because /etc/mtab has to be written before quota is turned on on most systems. Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-12quota: Fix possible dq_flags corruptionAndrew Perepechko
dq_flags are modified non-atomically in do_set_dqblk via __set_bit calls and atomically for example in mark_dquot_dirty or clear_dquot_dirty. Hence a change done by an atomic operation can be overwritten by a change done by a non-atomic one. Fix the problem by using atomic bitops even in do_set_dqblk. Signed-off-by: Andrew Perepechko <andrew.perepechko@sun.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-12quota: Hide warnings about writes to the filesystem before quota was turned onJan Kara
For a root filesystem write to the filesystem before quota is turned on happens regularly and there's no way around it because of writes to syslog, /etc/mtab, and similar. So the warning is rather pointless for ordinary users. It's still useful during development so we just hide the warning behind __DQUOT_PARANOIA config option. Signed-off-by: Jan Kara <jack@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05quota: stop using QUOTA_OK / NO_QUOTAChristoph Hellwig
Just use 0 / -EDQUOT directly - that's what it translates to anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot initialize routineChristoph Hellwig
Get rid of the initialize dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_initialize helper to __dquot_initialize and vfs_dq_init to dquot_initialize to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot drop routineChristoph Hellwig
Get rid of the drop dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_drop helper to __dquot_drop and vfs_dq_drop to dquot_drop to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot transfer routineChristoph Hellwig
Get rid of the transfer dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_transfer helper to __dquot_transfer and vfs_dq_transfer to dquot_transfer to have a consistent namespace, and make the new dquot_transfer return a normal negative errno value which all callers expect. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup inode allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_inode and free_inode dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Also get rid of the vfs_dq_alloc/vfs_dq_free wrappers and always call the lowlevel dquot_alloc_inode / dqout_free_inode routines directly, which now lose the number argument which is always 1. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup space allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_space, free_space, reserve_space, claim_space and release_rsv dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Move shared logic into the common __dquot_alloc_space, dquot_claim_space_nodirty and __dquot_free_space low-level methods, and rationalize the wrappers around it to move as much as possible code into the common block for CONFIG_QUOTA vs not. Also rename all these helpers to be named dquot_* instead of vfs_dq_*. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05quota: Properly invalidate caches even for filesystems with blocksize < pagesizeJan Kara
Sometimes invalidate_bdev() can fail to invalidate a part of block device cache because of dirty data. If the filesystem has blocksize smaller than page size, this can happen even for pages containing quota files and thus kernel would operate on stale data. Fix the issue by syncing the filesystem before invalidating the cache. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05quota: generalize quota transfer interfaceDmitry Monakhov
Current quota transfer interface support only uid/gid. This patch extend interface in order to support various quotas types The goal is accomplished without changes in most frequently used vfs_dq_transfer() func. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
