path: root/fs/quota_v2.c
2006-02-03[PATCH] quota_v2: printk warning fixesAndrew Morton
fs/quota_v2.c: In function `v2_check_quota_file': fs/quota_v2.c:39: warning: int format, different type arg (arg 2) fs/quota_v2.c:39: warning: int format, different type arg (arg 3) Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] quota: make useless quota error message informativeValdis.Kletnieks@vt.edu
fs/quota_v2.c can, under some conditions, issue a kernel message that says, in totality, 'failed read'. This patch does the following: 1) Gives a hint who issued the error message, so people reading the logs don't have to go grepping the entire kernel tree (with 11 false positives). 2) Say what amount of data we expected, and actually got. Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] quota: possible bug in quota format v2 supportNiu YaWei
Don't put root block of quota tree to the free list (when quota file is completely empty). That should not actually happen anyway (somebody should get accounted for the filesystem root and so quota file should never be empty) but better prevent it here than solve magical quota file corruption. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
