path: root/fs/ramfs
2017-09-06mm: make pagevec_lookup() update indexJan Kara
Make pagevec_lookup() (and underlying find_get_pages()) update index to the next page where iteration should continue. Most callers want this and also pagevec_lookup_tag() already does this. Link: http://lkml.kernel.org/r/20170726114704.7626-3-jack@suse.cz Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-07-06ramfs: Implement show_optionsDavid Howells
Implement the show_options superblock op for ramfs as part of a bid to get rid of s_options and generic_show_options() to make it easier to implement a context-based mount where the mount options can be passed individually over a file descriptor. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-10-08Merge remote-tracking branch 'jk/vfs' into work.miscAl Viro
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27libfs: support RENAME_NOREPLACE in simple_rename()Miklos Szeredi
This is trivial to do: - add flags argument to simple_rename() - check if flags doesn't have any other than RENAME_NOREPLACE - assign simple_rename() to .rename2 instead of .rename Filesystems converted: hugetlbfs, ramfs, bpf. Debugfs uses simple_rename() to implement debugfs_rename(), which is for debugfs instances to rename files internally, not for userspace filesystem access. For this case pass zero flags to simple_rename(). Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Alexei Starovoitov <ast@kernel.org>
2016-09-22fs: Give dentry to inode_change_ok() instead of inodeJan Kara
inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2016-09-19ipc/shm: fix crash if CONFIG_SHMEM is not setKirill A. Shutemov
Commit c01d5b300774 ("shmem: get_unmapped_area align huge page") makes use of shm_get_unmapped_area() in shm_file_operations() unconditional to CONFIG_MMU. As Tony Battersby pointed this can lead NULL-pointer dereference on machine with CONFIG_MMU=y and CONFIG_SHMEM=n. In this case ipc/shm is backed by ramfs which doesn't provide f_op->get_unmapped_area for configurations with MMU. The solution is to provide dummy f_op->get_unmapped_area for ramfs when CONFIG_MMU=y, which just call current->mm->get_unmapped_area(). Fixes: c01d5b300774 ("shmem: get_unmapped_area align huge page") Link: http://lkml.kernel.org/r/20160912102704.140442-1-kirill.shutemov@linux.intel.com Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Reported-by: Tony Battersby <tonyb@cybernetics.com> Tested-by: Tony Battersby <tonyb@cybernetics.com> Cc: Hugh Dickins <hughd@google.com> Cc: <stable@vger.kernel.org> [4.7.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-20tmpfs/ramfs: fix VM_MAYSHARE mappings for NOMMURich Felker
The nommu do_mmap expects f_op->get_unmapped_area to either succeed or return -ENOSYS for VM_MAYSHARE (e.g. private read-only) mappings. Returning addr in the non-MAP_SHARED case was completely wrong, and only happened to work because addr was 0. However, it prevented VM_MAYSHARE mappings from sharing backing with the fs cache, and forced such mappings (including shareable program text) to be copied whenever the number of mappings transitioned from 0 to 1, impacting performance and memory usage. Subsequent mappings beyond the first still correctly shared memory with the first. Instead, treat VM_MAYSHARE identically to VM_SHARED at the file ops level; do_mmap already handles the semantic differences between them. Signed-off-by: Rich Felker <dalias@libc.org> Cc: Michal Hocko <mhocko@suse.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-10-16mm, fs: obey gfp_mapping for add_to_page_cache()Michal Hocko
Commit 6afdb859b710 ("mm: do not ignore mapping_gfp_mask in page cache allocation paths") has caught some users of hardcoded GFP_KERNEL used in the page cache allocation paths. This, however, wasn't complete and there were others which went unnoticed. Dave Chinner has reported the following deadlock for xfs on loop device: : With the recent merge of the loop device changes, I'm now seeing : XFS deadlock on my single CPU, 1GB RAM VM running xfs/073. : : The deadlocked is as follows: : : kloopd1: loop_queue_read_work : xfs_file_iter_read : lock XFS inode XFS_IOLOCK_SHARED (on image file) : page cache read (GFP_KERNEL) : radix tree alloc : memory reclaim : reclaim XFS inodes : log force to unpin inodes : <wait for log IO completion> : : xfs-cil/loop1: <does log force IO work> : xlog_cil_push : xlog_write : <loop issuing log writes> : xlog_state_get_iclog_space() : <blocks due to all log buffers under write io> : <waits for IO completion> : : kloopd1: loop_queue_write_work : xfs_file_write_iter : lock XFS inode XFS_IOLOCK_EXCL (on image file) : <wait for inode to be unlocked> : : i.e. the kloopd, with it's split read and write work queues, has : introduced a dependency through memory reclaim. i.e. that writes : need to be able to progress for reads make progress. : : The problem, fundamentally, is that mpage_readpages() does a : GFP_KERNEL allocation, rather than paying attention to the inode's : mapping gfp mask, which is set to GFP_NOFS. : : The didn't used to happen, because the loop device used to issue : reads through the splice path and that does: : : error = add_to_page_cache_lru(page, mapping, index, : GFP_KERNEL & mapping_gfp_mask(mapping)); This has changed by commit aa4d86163e4 ("block: loop: switch to VFS ITER_BVEC"). This patch changes mpage_readpage{s} to follow gfp mask set for the mapping. There are, however, other places which are doing basically the same. lustre:ll_dir_filler is doing GFP_KERNEL from the function which apparently uses GFP_NOFS for other allocations so let's make this consistent. cifs:readpages_get_pages is called from cifs_readpages and __cifs_readpages_from_fscache called from the same path obeys mapping gfp. ramfs_nommu_expand_for_mapping is hardcoding GFP_KERNEL as well regardless it uses mapping_gfp_mask for the page allocation. ext4_mpage_readpages is the called from the page cache allocation path same as read_pages and read_cache_pages As I've noticed in my previous post I cannot say I would be happy about sprinkling mapping_gfp_mask all over the place and it sounds like we should drop gfp_mask argument altogether and use it internally in __add_to_page_cache_locked that would require all the filesystems to use mapping gfp consistently which I am not sure is the case here. From a quick glance it seems that some file system use it all the time while others are selective. Signed-off-by: Michal Hocko <mhocko@suse.com> Reported-by: Dave Chinner <david@fromorbit.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Ming Lei <ming.lei@canonical.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-20fs: introduce f_op->mmap_capabilities for nommu mmap supportChristoph Hellwig
Since "BDI: Provide backing device capability information [try #3]" the backing_dev_info structure also provides flags for the kind of mmap operation available in a nommu environment, which is entirely unrelated to it's original purpose. Introduce a new nommu-only file operation to provide this information to the nommu mmap code instead. Splitting this from the backing_dev_info structure allows to remove lots of backing_dev_info instance that aren't otherwise needed, and entirely gets rid of the concept of providing a backing_dev_info for a character device. It also removes the need for the mtd_inodefs filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-08-08fs/ramfs/file-nommu.c: replace count*size kzalloc by kcallocFabian Frederick
Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Axel Lin <axel.lin@ingics.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-12->splice_write() via ->write_iter()Al Viro
iter_file_splice_write() - a ->splice_write() instance that gathers the pipe buffers, builds a bio_vec-based iov_iter covering those and feeds it to ->write_iter(). A bunch of simple cases coverted to that... [AV: fixed the braino spotted by Cyrill] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-01-23fs/ramfs: move ramfs_aops to inode.cAxel Lin
ramfs_aops is identical in file-mmu.c and file-nommu.c. Thus move it to fs/ramfs/inode.c and make it static. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-23fs/ramfs/file-nommu.c: make ramfs_nommu_get_unmapped_area() and ↵Axel Lin
ramfs_nommu_mmap() static Since commit 853ac43ab194 ("shmem: unify regular and tiny shmem"), ramfs_nommu_get_unmapped_area() and ramfs_nommu_mmap() are not directly referenced outside of file-nommu.c. Thus make them static. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-21fs/ramfs: don't use module_init for non-modular core codePaul Gortmaker
The ramfs is always built in. It will never be modular, so using module_init as an alias for __initcall is rather misleading. Fix this up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of fs_initcall (which makes sense for fs code) will thus change this registration from level 6-device to level 5-fs (i.e. slightly earlier). However no observable impact of that small difference has been observed during testing, or is expected. Also note that this change uncovers a missing semicolon bug in the registration of the initcall. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11initmpfs: move rootfs code from fs/ramfs/ to init/Rob Landley
When the rootfs code was a wrapper around ramfs, having them in the same file made sense. Now that it can wrap another filesystem type, move it in with the init code instead. This also allows a subsequent patch to access rootfstype= command line arg. Signed-off-by: Rob Landley <rob@landley.net> Cc: Jeff Layton <jlayton@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Warren <swarren@nvidia.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11initmpfs: move bdi setup from init_rootfs to init_ramfsRob Landley
Even though ramfs hasn't got a backing device, commit e0bf68ddec4f ("mm: bdi init hooks") added one anyway, and put the initialization in init_rootfs() since that's the first user, leaving it out of init_ramfs() to avoid duplication. But initmpfs uses init_tmpfs() instead, so move the init into the filesystem's init function, add a "once" guard to prevent duplicate initialization, and call the filesystem init from rootfs init. This goes part of the way to allowing ramfs to be built as a module. [akpm@linux-foundation.org; using bit 1 was odd] Signed-off-by: Rob Landley <rob@landley.net> Cc: Jeff Layton <jlayton@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Warren <swarren@nvidia.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-11initmpfs: replace MS_NOUSER in initramfsRob Landley
Mounting MS_NOUSER prevents --bind mounts from rootfs. Prevent new rootfs mounts with a different mechanism that doesn't affect bind mounts. Signed-off-by: Rob Landley <rob@landley.net> Cc: Jeff Layton <jlayton@redhat.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Stephen Warren <swarren@nvidia.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jim Cromie <jim.cromie@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-01-26userns: Allow the userns root to mount ramfs.Eric W. Biederman
There is no backing store to ramfs and file creation rules are the same as for any other filesystem so it is semantically safe to allow unprivileged users to mount it. The memory control group successfully limits how much memory ramfs can consume on any system that cares about a user namespace root using ramfs to exhaust memory the memory control group can be deployed. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-11fs: ramfs: file-nommu: add SetPageUptodate()Bob Liu
There is a bug in the below scenario for !CONFIG_MMU: 1. create a new file 2. mmap the file and write to it 3. read the file can't get the correct value Because sys_read() -> generic_file_aio_read() -> simple_readpage() -> clear_page() which causes the page to be zeroed. Add SetPageUptodate() to ramfs_nommu_expand_for_mapping() so that generic_file_aio_read() do not call simple_readpage(). Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Hugh Dickins <hughd@google.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20tidy up after d_make_root() conversionAl Viro
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-03pohmelfs: propagate umode_tAl Viro
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02ramfs: remove module leftoversRichard Weinberger
Since ramfs is hard-selected to "y", the module leftovers make no sense. Signed-off-by: Richard Weinberger <richard@nod.at> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14ramfs: fix memleak on no-mmu archBob Liu
On no-mmu arch, there is a memleak during shmem test. The cause of this memleak is ramfs_nommu_expand_for_mapping() added page refcount to 2 which makes iput() can't free that pages. The simple test file is like this: int main(void) { int i; key_t k = ftok("/etc", 42); for ( i=0; i<100; ++i) { int id = shmget(k, 10000, 0644|IPC_CREAT); if (id == -1) { printf("shmget error\n"); } if(shmctl(id, IPC_RMID, NULL ) == -1) { printf("shm rm error\n"); return -1; } } printf("run ok...\n"); return 0; } And the result: root:/> free total used free shared buffers Mem: 60320 17912 42408 0 0 -/+ buffers: 17912 42408 root:/> shmem run ok... root:/> free total used free shared buffers Mem: 60320 19096 41224 0 0 -/+ buffers: 19096 41224 root:/> shmem run ok... root:/> free total used free shared buffers Mem: 60320 20296 40024 0 0 -/+ buffers: 20296 40024 ... After this patch the test result is:(no memleak anymore) root:/> free total used free shared buffers Mem: 60320 16668 43652 0 0 -/+ buffers: 16668 43652 root:/> shmem run ok... root:/> free total used free shared buffers Mem: 60320 16668 43652 0 0 -/+ buffers: 16668 43652 Signed-off-by: Bob Liu <lliubbo@gmail.com> Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: convert simple fs to new truncateNick Piggin
Convert simple filesystems: ramfs, configfs, sysfs, block_dev to new truncate sequence. Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21ramfs: replace inode uid,gid,mode initialization with helper functionDmitry Monakhov
- seems what ramfs_get_inode is only locally, make it static. [AV: the hell it is; it's used by shmem, so shmem needed conversion too and no, that function can't be made static] Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21devtmpfs: support !CONFIG_TMPFSPeter Korsgaard
Make devtmpfs available on (embedded) configurations without SHMEM/TMPFS, using ramfs instead. Saves ~15KB. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
