commit fc46820b27a2d9a46f7e90c9ceb4a64a1bc5fab8 upstream.
In generic_file_llseek_size, return -ENXIO for negative offsets as well
as offsets beyond EOF. This affects filesystems which don't implement
SEEK_HOLE / SEEK_DATA internally, possibly because they don't support
holes.
Fixes xfstest generic/448.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
That allows ->write_iter() instances much more convenient life wrt
iocb->ki_pos (and fixes several filesystems with borderline POSIX
violations when zero-length write succeeds and changes the current
position).
no remaining users
all remaining instances of aio_{read,write} (all 4 of them) have explicit
->read and ->write resp.; do_sync_read/do_sync_write is never called by
__vfs_read/__vfs_write anymore and no other users had been left.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
get it closer to matching {compat_,}rw_copy_check_uvector().
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
The AIO interface is fairly complex because it tries to allow
filesystems to always work async and then wakeup a synchronous
caller through aio_complete. It turns out that basically no one
was doing this to avoid the complexity and context switches,
and we've already fixed up the remaining users and can now
get rid of this case.
There is no need to pass the total request length in the kiocb, as
we already get passed in through the iov_iter argument.
Pull iov_iter updates from Al Viro:
"More iov_iter work - missing counterpart of iov_iter_init() for
bvec-backed ones and vfs_read_iter()/vfs_write_iter() - wrappers for
sync calls of ->read_iter()/->write_iter()"
* 'iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: add vfs_iter_{read,write} helpers
new helper: iov_iter_bvec()
Simple helpers that pass an arbitrary iov_iter to filesystems.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
Acked-by: Christoph Hellwig <hch@lst.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security layer updates from James Morris:
"In terms of changes, there's general maintenance to the Smack,
SELinux, and integrity code.
The IMA code adds a new kconfig option, IMA_APPRAISE_SIGNED_INIT,
which allows IMA appraisal to require signatures. Support for reading
keys from rootfs before init is call is also added"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (23 commits)
selinux: Remove security_ops extern
security: smack: fix out-of-bounds access in smk_parse_smack()
VFS: refactor vfs_read()
ima: require signature based appraisal
integrity: provide a hook to load keys when rootfs is ready
ima: load x509 certificate from the kernel
integrity: provide a function to load x509 certificate from the kernel
integrity: define a new function integrity_read_file()
Security: smack: replace kzalloc with kmem_cache for inode_smack
Smack: Lock mode for the floor and hat labels
ima: added support for new kernel cmdline parameter ima_template_fmt
ima: allocate field pointers array on demand in template_desc_init_fields()
ima: don't allocate a copy of template_fmt in template_desc_init_fields()
ima: display template format in meas. list if template name length is zero
ima: added error messages to template-related functions
ima: use atomic bit operations to protect policy update interface
ima: ignore empty and with whitespaces policy lines
ima: no need to allocate entry for comment
ima: report policy load status
ima: use path names cache
integrity_kernel_read() duplicates the file read operations code
in vfs_read(). This patch refactors vfs_read() code creating a
helper function __vfs_read(). It is used by both vfs_read() and
integrity_kernel_read().
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Beginning to introduce those. Just the callers for now, and it's
clumsier than it'll eventually become; once we finish converting
aio_read and aio_write instances, the things will get nicer.
For now, these guys are in parallel to ->aio_read() and ->aio_write();
they take iocb and iov_iter, with everything in iov_iter already
validated. File offset is passed in iocb->ki_pos, iov/nr_segs -
in iov_iter.
Main concerns in that series are stack footprint and ability to
split the damn thing cleanly.
[fix from Peter Ujfalusi <peter.ujfalusi@ti.com> folded]
Since we are about to introduce new methods (read_iter/write_iter), the
tests in a bunch of places would have to grow inconveniently. Check
once (at open() time) and store results in ->f_mode as FMODE_CAN_READ
and FMODE_CAN_WRITE resp. It might end up being a temporary measure -
once everything switches from ->aio_{read,write} to ->{read,write}_iter
it might make sense to return to open-coded checks. We'll see...
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 compat wrapper rework from Heiko Carstens:
"S390 compat system call wrapper simplification work.
The intention of this work is to get rid of all hand written assembly
compat system call wrappers on s390, which perform proper sign or zero
extension, or pointer conversion of compat system call parameters.
Instead all of this should be done with C code eg by using Al's
COMPAT_SYSCALL_DEFINEx() macro.
Therefore all common code and s390 specific compat system calls have
been converted to the COMPAT_SYSCALL_DEFINEx() macro.
In order to generate correct code all compat system calls may only
have eg compat_ulong_t parameters, but no unsigned long parameters.
Those patches which change parameter types from unsigned long to
compat_ulong_t parameters are separate in this series, but shouldn't
cause any harm.
The only compat system calls which intentionally have 64 bit
parameters (preadv64 and pwritev64) in support of the x86/32 ABI
haven't been changed, but are now only available if an architecture
defines __ARCH_WANT_COMPAT_SYS_PREADV64/PWRITEV64.
System calls which do not have a compat variant but still need proper
zero extension on s390, like eg "long sys_brk(unsigned long brk)" will
get a proper wrapper function with the new s390 specific
COMPAT_SYSCALL_WRAPx() macro:
COMPAT_SYSCALL_WRAP1(brk, unsigned long, brk);
which generates the following code (simplified):
asmlinkage long sys_brk(unsigned long brk);
asmlinkage long compat_sys_brk(long brk)
return sys_brk((u32)brk);
Given that the C file which contains all the COMPAT_SYSCALL_WRAP lines
includes both linux/syscall.h and linux/compat.h, it will generate
build errors, if the declaration of sys_brk() doesn't match, or if
there exists a non-matching compat_sys_brk() declaration.
In addition this will intentionally result in a link error if
somewhere else a compat_sys_brk() function exists, which probably
should have been used instead. Two more BUILD_BUG_ONs make sure the
size and type of each compat syscall parameter can be handled
correctly with the s390 specific macros.
I converted the compat system calls step by step to verify the
generated code is correct and matches the previous code. In fact it
did not always match, however that was always a bug in the hand
written asm code.
In result we get less code, less bugs, and much more sanity checking"
* 'compat' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (44 commits)
s390/compat: add copyright statement
compat: include linux/unistd.h within linux/compat.h
s390/compat: get rid of compat wrapper assembly code
s390/compat: build error for large compat syscall args
mm/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
kexec/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
net/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
ipc/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter types
security/compat: convert to COMPAT_SYSCALL_DEFINE
kernel/compat: convert to COMPAT_SYSCALL_DEFINE
fs/compat: optional preadv64/pwrite64 compat system calls
ipc/compat_sys_msgrcv: change msgtyp type from long to compat_long_t
s390/compat: partial parameter conversion within syscall wrappers
s390/compat: automatic zero, sign and pointer conversion of syscalls
s390/compat: add sync_file_range and fallocate compat syscalls
Commit 9c225f2655e36a4 ("vfs: atomic f_pos accesses as per POSIX") changed
several system calls to use fdget_pos() instead of fdget(), but missed
sys_llseek(). Fix it.
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
instead of returning the flags by reference, we can just have the
low-level primitive return those in lower bits of unsigned long,
with struct file * derived from the rest.
Our write() system call has always been atomic in the sense that you get
the expected thread-safe contiguous write, but we haven't actually
guaranteed that concurrent writes are serialized wrt f_pos accesses, so
threads (or processes) that share a file descriptor and use "write()"
concurrently would quite likely overwrite each others data.
This violates POSIX.1-2008/SUSv4 Section XSI 2.9.7 that says:
"2.9.7 Thread Interactions with Regular File Operations
All of the following functions shall be atomic with respect to each
other in the effects specified in POSIX.1-2008 when they operate on
regular files or symbolic links: [...]"
and one of the effects is the file position update.
This unprotected file position behavior is not new behavior, and nobody
has ever cared. Until now. Yongzhi Pan reported unexpected behavior to
Michael Kerrisk that was due to this.
This resolves the issue with a f_pos-specific lock that is taken by
read/write/lseek on file descriptors that may be shared across threads
or processes.
Reported-by: Yongzhi Pan <panyongzhi@gmail.com>
Reported-by: Michael Kerrisk <mtk.manpages@gmail.com>
The preadv64/pwrite64 have been implemented for the x32 ABI, in order
to allow passing 64 bit arguments from user space without splitting
them into two 32 bit parameters, like it would be necessary for usual
compat tasks.
Howevert these two system calls are only being used for the x32 ABI,
so add __ARCH_WANT_COMPAT defines for these two compat syscalls and
make these two only visible for x86.
We got a report that the pwritev syscall does not work correctly in
compat mode on s390.
It turned out that with commit 72ec35163f9f ("switch compat readv/writev
variants to COMPAT_SYSCALL_DEFINE") we lost the zero extension of a
couple of syscall parameters because the some parameter types haven't
been converted from unsigned long to compat_ulong_t.
This is needed for architectures where the ABI requires that the caller
of a function performed zero and/or sign extension to 64 bit of all
parameters.
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: <stable@vger.kernel.org> [v3.10+]
The compat_do_readv_writev() function was doing a verify_area on the
incoming iov, but the nr_segs value is not checked. If someone passes
in a -1 for nr_segs, for instance, the function should return an EINVAL.
However, it returns a EFAULT because the verify_area fails because it is
checking an array of size MAX_UINT. The check is bogus, anyway, because
the next check, compat_rw_copy_check_uvector(), will do all the
necessary checking, anyway. The non-compat do_readv_writev() function
doesn't do this check, so I think it's safe to just remove the code.
Signed-off-by: Corey Minyard <cminyard@mvista.com>
This code doesn't serve any purpose anymore, since the aio retry
infrastructure has been removed.
This change should be safe because aio_read/write are also used for
synchronous IO, and called from do_sync_read()/do_sync_write() - and
there's no looping done in the sync case (the read and write syscalls).
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
For those file systems(btrfs/ext4/ocfs2/tmpfs) that support
SEEK_DATA/SEEK_HOLE functions, we end up handling the similar
matter in lseek_execute() to update the current file offset
to the desired offset if it is valid, ceph also does the
simliar things at ceph_llseek().
To reduce the duplications, this patch make lseek_execute()
public accessible so that we can call it directly from the
underlying file systems.
Thanks Dave Chinner for this suggestion.
[AV: call it vfs_setpos(), don't bring the removed 'inode' argument back]
v2->v1:
- Add kernel-doc comments for lseek_execute()
- Call lseek_execute() in ceph->llseek()
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Cc: Dave Chinner <dchinner@redhat.com>
Cc: Chris Mason <chris.mason@fusionio.com>
Cc: Josef Bacik <jbacik@fusionio.com>
Cc: Ben Myers <bpm@sgi.com>
Cc: Ted Tso <tytso@mit.edu>
Cc: Sage Weil <sage@inktank.com>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
This removes the retry-based AIO infrastructure now that nothing in tree
is using it.
We want to remove retry-based AIO because it is fundemantally unsafe.
It retries IO submission from a kernel thread that has only assumed the
mm of the submitting task. All other task_struct references in the IO
submission path will see the kernel thread, not the submitting task.
This design flaw means that nothing of any meaningful complexity can use
retry-based AIO.
This removes all the code and data associated with the retry machinery.
The most significant benefit of this is the removal of the locking
around the unused run list in the submission path.
Signed-off-by: Zach Brown <zab@redhat.com>
Acked-by: Jeff Moyer <jmoyer@redhat.com>
fs/compat.c doesn't need it anymore, so let's just move the remaining
contents (two typedefs) into fs/read_write.c
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
Commit ef3d0fd27e90 ("vfs: do (nearly) lockless generic_file_llseek")
has removed i_mutex from generic_file_llseek, so update the comment
accordingly.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
... and take to fs/read_write.c
Commit 06ae43f34bcc ("Don't bother with redoing rw_verify_area() from
default_file_splice_from()") lost the checks to test existence of the
write/aio_write methods. My apologies ;-/
Eventually, we want that in fs/splice.c side of things (no point
repeating it for every buffer, after all), but for now this is the
obvious minimal fix.
Reported-by: Dave Jones <davej@redhat.com>
default_file_splice_from() ends up calling vfs_write() (via very convoluted
callchain). It's an overkill, since we already have done rw_verify_area()
in the caller by the time we call vfs_write() we are under set_fs(KERNEL_DS),
so access_ok() is also pointless. Add a new helper (__kernel_write()),
use it instead of kernel_write() in there.
... and convert a bunch of SYSCALL_DEFINE ones to SYSCALL_DEFINE<n>,
killing the boilerplate crap around them.
