path: root/fs/read_write.c
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-28vfs: add generic_file_llseek_sizeAndi Kleen
Add a generic_file_llseek variant to the VFS that allows passing in the maximum file size of the file system, instead of always using maxbytes from the superblock. This can be used to eliminate some cut'n'paste seek code in ext4. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-28vfs: do (nearly) lockless generic_file_llseekAndi Kleen
The i_mutex lock use of generic _file_llseek hurts. Independent processes accessing the same file synchronize over a single lock, even though they have no need for synchronization at all. Under high utilization this can cause llseek to scale very poorly on larger systems. This patch does some rethinking of the llseek locking model: First the 64bit f_pos is not necessarily atomic without locks on 32bit systems. This can already cause races with read() today. This was discussed on linux-kernel in the past and deemed acceptable. The patch does not change that. Let's look at the different seek variants: SEEK_SET: Doesn't really need any locking. If there's a race one writer wins, the other loses. For 32bit the non atomic update races against read() stay the same. Without a lock they can also happen against write() now. The read() race was deemed acceptable in past discussions, and I think if it's ok for read it's ok for write too. => Don't need a lock. SEEK_END: This behaves like SEEK_SET plus it reads the maximum size too. Reading the maximum size would have the 32bit atomic problem. But luckily we already have a way to read the maximum size without locking (i_size_read), so we can just use that instead. Without i_mutex there is no synchronization with write() anymore, however since the write() update is atomic on 64bit it just behaves like another racy SEEK_SET. On non atomic 32bit it's the same as SEEK_SET. => Don't need a lock, but need to use i_size_read() SEEK_CUR: This has a read-modify-write race window on the same file. One could argue that any application doing unsynchronized seeks on the same file is already broken. But for the sake of not adding a regression here I'm using the file->f_lock to synchronize this. Using this lock is much better than the inode mutex because it doesn't synchronize between processes. => So still need a lock, but can use a f_lock. This patch implements this new scheme in generic_file_llseek. I dropped generic_file_llseek_unlocked and changed all callers. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-26fs: add missing unlock in default_llseek()Dan Carpenter
A recent change in linux-next, 982d816581 "fs: add SEEK_HOLE and SEEK_DATA flags" added some direct returns on error, but it should have been a goto out. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: add SEEK_HOLE and SEEK_DATA flagsJosef Bacik
This just gets us ready to support the SEEK_HOLE and SEEK_DATA flags. Turns out using fiemap in things like cp cause more problems than it solves, so lets try and give userspace an interface that doesn't suck. We need to match solaris here, and the definitions are *o* If /whence/ is SEEK_HOLE, the offset of the start of the next hole greater than or equal to the supplied offset is returned. The definition of a hole is provided near the end of the DESCRIPTION. *o* If /whence/ is SEEK_DATA, the file pointer is set to the start of the next non-hole file region greater than or equal to the supplied offset. So in the generic case the entire file is data and there is a virtual hole at the end. That means we will just return i_size for SEEK_HOLE and will return the same offset for SEEK_DATA. This is how Solaris does it so we have to do it the same way. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12fix signedness mess in rw_verify_area() on 64bit architecturesAl Viro
... and clean the unsigned-f_pos code, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29readv/writev: do the same MAX_RW_COUNT truncation that read/write doesLinus Torvalds
We used to protect against overflow, but rather than return an error, do what read/write does, namely to limit the total size to MAX_RW_COUNT. This is not only more consistent, but it also means that any broken low-level read/write routine that still keeps counts in 'int' can't break. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25vfs: introduce FMODE_UNSIGNED_OFFSET for allowing negative f_posKAMEZAWA Hiroyuki
Now, rw_verify_area() checsk f_pos is negative or not. And if negative, returns -EINVAL. But, some special files as /dev/(k)mem and /proc/<pid>/mem etc.. has negative offsets. And we can't do any access via read/write to the file(device). So introduce FMODE_UNSIGNED_OFFSET to allow negative file offsets. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-15vfs: make no_llseek the defaultArnd Bergmann
All file operations now have an explicit .llseek operation pointer, so we can change the default action for future code. This makes changes the default from default_llseek to no_llseek, which always returns -ESPIPE if a user tries to seek on a file without a .llseek operation. The name of the default_llseek function remains unchanged, if anyone thinks we should change it, please speak up. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org
2010-10-15vfs: don't use BKL in default_llseekArnd Bergmann
There are currently 191 users of default_llseek. Nine of these are in device drivers that use the big kernel lock. None of these ever touch file->f_pos outside of llseek or file_pos_write. Consequently, we never rely on the BKL in the default_llseek function and can replace that with i_mutex, which is also used in generic_file_llseek. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-07-28fsnotify: pass a file instead of an inode to open, read, and writeEric Paris
fanotify, the upcoming notification system actually needs a struct path so it can do opens in the context of listeners, and it needs a file so it can get f_flags from the original process. Close was the only operation that already was passing a struct file to the notification hook. This patch passes a file for access, modify, and open as well as they are easily available to these hooks. Signed-off-by: Eric Paris <eparis@redhat.com>
2010-05-27vfs: introduce noop_llseek()jan Blunck
This is an implementation of ->llseek useable for the rare special case when userspace expects the seek to succeed but the (device) file is actually not able to perform the seek. In this case you use noop_llseek() instead of falling back to the default implementation of ->llseek. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-24do_sync_read/write() should set kiocb.ki_nbytes to be consistentDavid Howells
do_sync_read/write() should set kiocb.ki_nbytes to be consistent with do_sync_readv_writev(). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-04sendfile(): check f_op.splice_write() rather than f_op.sendpage()Changli Gao
sendfile(2) was reworked with the splice infrastructure, but it still checks f_op.sendpage() instead of f_op.splice_write() wrongly. Although if f_op.sendpage() exists, f_op.splice_write() always exists at the same time currently, the assumption will be broken in future silently. This patch also brings a side effect: sendfile(2) can work with any output file. Some security checks related to f_op are added too. Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-24vfs: remove redundant position check in do_sendfileJeff Layton
As Johannes Weiner pointed out, one of the range checks in do_sendfile is redundant and is already checked in rw_verify_area. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Robert Love <rlove@google.com> Cc: Mandeep Singh Baines <msb@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-11splice: implement default splice_read methodMiklos Szeredi
If f_op->splice_read() is not implemented, fall back to a plain read. Use vfs_readv() to read into previously allocated pages. This will allow splice and functions using splice, such as the loop device, to work on all filesystems. This includes "direct_io" files in fuse which bypass the page cache. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-04Make non-compat preadv/pwritev use native register sizeLinus Torvalds
Instead of always splitting the file offset into 32-bit 'high' and 'low' parts, just split them into the largest natural word-size - which in C terms is 'unsigned long'. This allows 64-bit architectures to avoid the unnecessary 32-bit shifting and masking for native format (while the compat interfaces will obviously always have to do it). This also changes the order of 'high' and 'low' to be "low first". Why? Because when we have it like this, the 64-bit system calls now don't use the "pos_high" argument at all, and it makes more sense for the native system call to simply match the user-mode prototype. This results in a much more natural calling convention, and allows the compiler to generate much more straightforward code. On x86-64, we now generate testq %rcx, %rcx # pos_l js .L122 #, movq %rcx, -48(%rbp) # pos_l, pos from the C source loff_t pos = pos_from_hilo(pos_h, pos_l); ... if (pos < 0) return -EINVAL; and the 'pos_h' register isn't even touched. It used to generate code like mov %r8d, %r8d # pos_low, pos_low salq $32, %rcx #, tmp71 movq %r8, %rax # pos_low, pos.386 orq %rcx, %rax # tmp71, pos.386 js .L122 #, movq %rax, -48(%rbp) # pos.386, pos which isn't _that_ horrible, but it does show how the natural word size is just a more sensible interface (same arguments will hold in the user level glibc wrapper function, of course, so the kernel side is just half of the equation!) Note: in all cases the user code wrapper can again be the same. You can just do #define HALF_BITS (sizeof(unsigned long)*4) __syscall(PWRITEV, fd, iov, count, offset, (offset >> HALF_BITS) >> HALF_BITS); or something like that. That way the user mode wrapper will also be nicely passing in a zero (it won't actually have to do the shifts, the compiler will understand what is going on) for the last argument. And that is a good idea, even if nobody will necessarily ever care: if we ever do move to a 128-bit lloff_t, this particular system call might be left alone. Of course, that will be the least of our worries if we really ever need to care, so this may not be worth really caring about. [ Fixed for lost 'loff_t' cast noticed by Andrew Morton ] Acked-by: Gerd Hoffmann <kraxel@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-api@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: Ingo Molnar <mingo@elte.hu> Cc: Ralf Baechle <ralf@linux-mips.org>> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02preadv/pwritev: Add preadv and pwritev system calls.Gerd Hoffmann
This patch adds preadv and pwritev system calls. These syscalls are a pretty straightforward combination of pread and readv (same for write). They are quite useful for doing vectored I/O in threaded applications. Using lseek+readv instead opens race windows you'll have to plug with locking. Other systems have such system calls too, for example NetBSD, check here: http://www.daemon-systems.org/man/preadv.2.html The application-visible interface provided by glibc should look like this to be compatible to the existing implementations in the *BSD family: ssize_t preadv(int d, const struct iovec *iov, int iovcnt, off_t offset); ssize_t pwritev(int d, const struct iovec *iov, int iovcnt, off_t offset); This prototype has one problem though: On 32bit archs is the (64bit) offset argument unaligned, which the syscall ABI of several archs doesn't allow to do. At least s390 needs a wrapper in glibc to handle this. As we'll need a wrappers in glibc anyway I've decided to push problem to glibc entriely and use a syscall prototype which works without arch-specific wrappers inside the kernel: The offset argument is explicitly splitted into two 32bit values. The patch sports the actual system call implementation and the windup in the x86 system call tables. Other archs follow as separate patches. Signed-off-by: Gerd Hoffmann <kraxel@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 20Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 19Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 16Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrapper special casesHeiko Carstens
System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-05vfs: lseek(fd, 0, SEEK_CUR) race conditionAlain Knaff
This patch fixes a race condition in lseek. While it is expected that unpredictable behaviour may result while repositioning the offset of a file descriptor concurrently with reading/writing to the same file descriptor, this should not happen when merely *reading* the file descriptor's offset. Unfortunately, the only portable way in Unix to read a file descriptor's offset is lseek(fd, 0, SEEK_CUR); however executing this concurrently with read/write may mess up the position. [with fixes from akpm] Signed-off-by: Alain Knaff <alain@knaff.lu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] generic_file_llseek tidyupsChristoph Hellwig
Add kerneldoc for generic_file_llseek and generic_file_llseek_unlocked, use sane variable names and unclutter the code. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-02Remove BKL from remote_llseek v2Andi Kleen
- Replace remote_llseek with generic_file_llseek_unlocked (to force compilation failures in all users) - Change all users to either use generic_file_llseek_unlocked directly or take the BKL around. I changed the file systems who don't use the BKL for anything (CIFS, GFS) to call it directly. NCPFS and SMBFS and NFS take the BKL, but explicitely in their own source now. I moved them all over in a single patch to avoid unbisectable sections. Open problem: 32bit kernels can corrupt fpos because its modification is not atomic, but they can do that anyways because there's other paths who modify it without BKL. Do we need a special lock for the pos/f_version = 0 checks? Trond says the NFS BKL is likely not needed, but keep it for now until his full audit. v2: Use generic_file_llseek_unlocked instead of remote_llseek_unlocked and factor duplicated code (suggested by hch) Cc: Trond.Myklebust@netapp.com Cc: swhiteho@redhat.com Cc: sfrench@samba.org Cc: vandrove@vc.cvut.cz Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-22fs: use loff_t type instead of long longDavid Sterba
Use offset type consistently. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08remove the unused exports of sys_open/sys_readArjan van de Ven
These exports (which aren't used and which are in fact dangerous to use because they pretty much form a security hole to use) have been marked _UNUSED since 2.6.24 with removal in 2.6.25. This patch is their final departure from the Linux kernel tree. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28ext4: export iov_shorten from kernel for ext4's useEric Sandeen
Export iov_shorten() from kernel so that ext4 can truncate too-large writes to bitmapped files. Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2008-01-25security: call security_file_permission from rw_verify_areaJames Morris
All instances of rw_verify_area() are followed by a call to security_file_permission(), so just call the latter from the former. Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2007-11-14mark sys_open/sys_read exports unusedArjan van de Ven
sys_open / sys_read were used in the early 1.2 days to load firmware from disk inside drivers. Since 2.0 or so this was deprecated behavior, but several drivers still were using this. Since a few years we have a request_firmware() API that implements this in a nice, consistent way. Only some old ISA sound drivers (pre-ALSA) still straggled along for some time.... however with commit c2b1239a9f22f19c53543b460b24507d0e21ea0c the last user is now gone. This is a good thing, since using sys_open / sys_read etc for firmware is a very buggy to dangerous thing to do; these operations put an fd in the process file descriptor table.... which then can be tampered with from other threads for example. For those who don't want the firmware loader, filp_open()/vfs_read are the better APIs to use, without this security issue. The patch below marks sys_open and sys_read unused now that they're really not used anymore, and for deletion in the 2.6.25 timeframe. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09Cleanup macros for distinguishing mandatory locksPavel Emelyanov
The combination of S_ISGID bit set and S_IXGRP bit unset is used to mark the inode as "mandatory lockable" and there's a macro for this check called MANDATORY_LOCK(inode). However, fs/locks.c and some filesystems still perform the explicit i_mode checking. Besides, Andrew pointed out, that this macro is buggy itself, as it dereferences the inode arg twice. Convert this macro into static inline function and switch its users to it, making the code shorter and more readable. The __mandatory_lock() helper is to be used in places where the IS_MANDLOCK() for superblock is already known to be true. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: David Howells <dhowells@redhat.com> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-07-10Remove remnants of sendfile()Jens Axboe
There are now zero users of .sendfile() in the kernel, so kill it from the file_operations structure and in do_sendfile(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10splice: divorce the splice structure/function definitions from the pipe headerJens Axboe
We need to move even more stuff into the header so that folks can use the splice_to_pipe() implementation instead of open-coding a lot of pipe knowledge (see relay implementation), so move to our own header file finally. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10sys_sendfile: switch to using ->splice_read, if availableJens Axboe
This patch makes sendfile prefer to use ->splice_read(), if it's available in the file_operations structure. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-08use use SEEK_MAX to validate user lseek argumentsChris Snook
Add SEEK_MAX and use it to validate lseek arguments from userspace. Signed-off-by: Chris Snook <csnook@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08use symbolic constants in generic lseek codeChris Snook
Convert magic numbers to SEEK_* values from fs.h Signed-off-by: Chris Snook <csnook@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] FS: speed up rw_verify_area()Eric Dumazet
oprofile hunting showed a stall in rw_verify_area(), because of triple indirection and potential cache misses. (file->f_path.dentry->d_inode->i_flock) By moving initialization of 'struct inode' pointer before the pos/count sanity tests, we allow the compiler and processor to perform two loads by anticipation, reducing stall, without prefetch() hints. Even x86 arch has enough registers to not use temporary variables and not increase text size. I validated this patch running a bench and studied oprofile changes, and absolute perf of the test program. Results of my epoll_pipe_bench (source available on request) on a Pentium-M 1.6 GHz machine Before : # ./epoll_pipe_bench -l 30 -t 20 Avg: 436089 evts/sec read_count=8843037 write_count=8843040 21.218390 samples per call (best value out of 10 runs) After : # ./epoll_pipe_bench -l 30 -t 20 Avg: 470980 evts/sec read_count=9549871 write_count=9549894 21.216694 samples per call (best value out of 10 runs) oprofile CPU_CLK_UNHALTED events gave a reduction from 5.3401 % to 2.5851 % for the rw_verify_area() function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] ifdef ->rchar, ->wchar, ->syscr, ->syscw from task_structAlexey Dobriyan
They are fat: 4x8 bytes in task_struct. They are uncoditionally updated in every fork, read, write and sendfile. They are used only if you have some "extended acct fields feature". And please, please, please, read(2) knows about bytes, not characters, why it is called "rchar"? Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] one more EXPORT_UNUSED_SYMBOL removalAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Add vector AIO supportBadari Pulavarty
This work is initially done by Zach Brown to add support for vectored aio. These are the core changes for AIO to support IOCB_CMD_PREADV/IOCB_CMD_PWRITEV. [akpm@osdl.org: huge build fix] Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] fs/read_write.c: EXPORT_UNUSED_SYMBOLAdrian Bunk
This patch marks an unused export as EXPORT_UNUSED_SYMBOL. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] splice: unlikely() optimizationsJens Axboe
Also corrects a few comments. Patch mainly from Ingo, changes by me. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] remove needless check in fs/read_write.cCarsten Otte
nr_segs is unsigned long and thus cannot be negative. We checked against 0 few lines before. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
