path: root/fs/reiserfs/do_balan.c
2014-08-13Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull quota, reiserfs, UDF updates from Jan Kara: "Scalability improvements for quota, a few reiserfs fixes, and couple of misc cleanups (udf, ext2)" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: reiserfs: Fix use after free in journal teardown reiserfs: fix corruption introduced by balance_leaf refactor udf: avoid redundant memcpy when writing data in ICB fs/udf: re-use hex_asc_upper_{hi,lo} macros fs/quota: kernel-doc warning fixes udf: use linux/uaccess.h fs/ext2/super.c: Drop memory allocation cast quota: remove dqptr_sem quota: simplify remove_inode_dquot_ref() quota: avoid unnecessary dqget()/dqput() calls quota: protect Q_GETFMT by dqonoff_mutex
2014-08-08fs/reiserfs: use linux/uaccess.hFabian Frederick
Fix checkpatch warning WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-05reiserfs: fix corruption introduced by balance_leaf refactorJeff Mahoney
Commits f1f007c308e (reiserfs: balance_leaf refactor, pull out balance_leaf_insert_left) and cf22df182bf (reiserfs: balance_leaf refactor, pull out balance_leaf_paste_left) missed that the `body' pointer was getting repositioned. Subsequent users of the pointer would expect it to be repositioned, and as a result, parts of the tree would get overwritten. The most common observed corruption is indirect block pointers being overwritten. Since the body value isn't actually used anymore in the called routines, we can pass back the offset it should be shifted. We constify the body and ih pointers in the balance_leaf as a mostly-free preventative measure. Cc: <stable@vger.kernel.org> # 3.16 Reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-06-11reiserfs: Fix compilation breakage with CONFIG_REISERFS_CHECKJan Kara
There was a bug in debug printout when CONFIG_REISERFS_CHECK was enabled so one of the assertions in do_balan.c didn't compile. Fix it. Fixes: 0080e9f9d3ac717537dbd6db1fc8ef72ce0b9cc1 Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-13reiserfs: balance_leaf refactor, split up balance_leaf_when_deleteJeff Mahoney
Splut up balance_leaf_when_delete into: balance_leaf_when_delete_del balance_leaf_when_cut balance_leaf_when_delete_left Also reformat to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-13reiserfs: balance_leaf refactor, format balance_leaf_finish_nodeJeff Mahoney
Split out balance_leaf_finish_node_dirent from balance_leaf_paste_finish_node. Also reformat to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-13reiserfs: balance_leaf refactor, format balance_leaf_new_nodes_pasteJeff Mahoney
Break up balance_leaf_paste_new_nodes into: balance_leaf_paste_new_nodes_shift balance_leaf_paste_new_nodes_shift_dirent balance_leaf_paste_new_nodes_whole and keep balance_leaf_paste_new_nodes as a handler to select which is appropriate. Also reformat to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, format balance_leaf_paste_rightJeff Mahoney
Break up balance_leaf_paste_right into: balance_leaf_paste_right_shift balance_leaf_paste_right_shift_dirent balance_leaf_paste_right_whole and keep balance_leaf_paste_right as a handler to select which is appropriate. Also reformat to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, format balance_leaf_insert_rightJeff Mahoney
Reformat balance_leaf_insert_right to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, format balance_leaf_paste_leftJeff Mahoney
Break up balance_leaf_paste_left into: balance_leaf_paste_left_shift balance_leaf_paste_left_shift_dirent balance_leaf_paste_left_whole and keep balance_leaf_paste_left as a handler to select which is appropriate. Also reformat to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, format balance_leaf_insert_leftJeff Mahoney
Reformat balance_leaf_insert_left to adhere to CodingStyle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf{left, right, ↵Jeff Mahoney
new_nodes, finish_node} Break out the code that splits paste/insert for each phase. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_finish_node_pasteJeff Mahoney
This patch factors out a new balance_leaf_finish_node_paste from the code in balance_leaf responsible for pasting new content into existing items held in S[0]. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor pull out balance_leaf_finish_node_insertJeff Mahoney
This patch factors out a new balance_leaf_finish_node_insert from the code in balance_leaf responsible for inserting new items into S[0] It has not been reformatted yet. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_new_nodes_pasteJeff Mahoney
This patch factors out a new balance_leaf_new_nodes_insert from the code in balance_leaf responsible for pasting new content into existing items that may have been shifted into new nodes in the tree. It has not been reformatted yet. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_new_nodes_insertJeff Mahoney
This patch factors out a new balance_leaf_new_nodes_insert from the code in balance_leaf responsible for inserting new items into new nodes in the tree. It has not been reformatted yet. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_paste_rightJeff Mahoney
This patch factors out a new balance_leaf_paste_right from the code in balance_leaf responsible for pasting new contents into an existing item located in the node to the right of S[0] in the tree. It has not been reformatted yet. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_insert_rightJeff Mahoney
This patch factors out a new balance_leaf_insert_right from the code in balance_leaf responsible for inserting new items into the node to the right of S[0] in the tree. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_paste_leftJeff Mahoney
This patch factors out a new balance_leaf_paste_left from the code in balance_leaf responsible for pasting new content into an existing item located in the node to the left of S[0] in the tree. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, pull out balance_leaf_insert_leftJeff Mahoney
This patch factors out a new balance_leaf_insert_left from the code in balance_leaf responsible for inserting new items into the node to the left of S[0] in the tree. It is not yet formatted correctly. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, move state variables into tree_balanceJeff Mahoney
This patch pushes the rest of the state variables in balance_leaf into the tree_balance structure so we can use them when we split balance_leaf into separate functions. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-07reiserfs: balance_leaf refactor, reformat balance_leaf commentsJeff Mahoney
The comments in balance_leaf are as bad as the code. This patch shifts them around to fit in 80 columns and be easier to read. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-06reiserfs: cleanup, remove unnecessary parensJeff Mahoney
The reiserfs code is littered with extra parens in places where the authors may not have been certain about precedence of & vs ->. This patch cleans them out. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-06reiserfs: cleanup, remove sb argument from journal_mark_dirtyJeff Mahoney
journal_mark_dirty doesn't need a separate sb argument; It's provided by the transaction handle. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-06reiserfs: cleanup, reformat comments to normal kernel styleJeff Mahoney
This patch reformats comments in the reiserfs code to fit in 80 columns and to follow the style rules. There is no functional change but it helps make my eyes bleed less. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-05-06reiserfs: cleanup, rename key and item accessors to more friendly namesJeff Mahoney
This patch does a quick search and replace: B_N_PITEM_HEAD() -> item_head() B_N_PDELIM_KEY() -> internal_key() B_N_PKEY() -> leaf_key() B_N_PITEM() -> item_body() And the item_head version: B_I_PITEM() -> ih_item_body() I_ENTRY_COUNT() -> ih_entry_count() And the treepath variants: get_ih() -> tp_item_head() PATH_PITEM_HEAD() -> tp_item_head() get_item() -> tp_item_body() ... which makes the code much easier on the eyes. I've also removed a few unused macros. Checkpatch will complain about the 80 character limit for do_balan.c. I've addressed that in a later patchset to split up balance_leaf(). Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2014-02-17reiserfs: fix utterly brain-damaged indentation.Dave Jones
This has been this way for years, and every time I stumble across it I lose my lunch. After coming across it for the nth time in the Coverity results, I had to overcome the bystander effect and do something about it. This ignores the 79 column limit in favor of making it look like C instead of gibberish. The correct thing to do here would be to lose some of the indentation by breaking this function up into several smaller ones. I might do that at some point if I have the stomach to look at this again. (Also some of those overlong ternary operations would likely be more readable as regular if's) Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20move private bits of reiserfs_fs.h to fs/reiserfs/reiserfs.hAl Viro
2009-09-14kill-the-bkl/reiserfs: move the concurrent tree accesses checks per superblockFrederic Weisbecker
When do_balance() balances the tree, a trick is performed to provide the ability for other tree writers/readers to check whether do_balance() is executing concurrently (requires CONFIG_REISERFS_CHECK). This is done to protect concurrent accesses to the tree. The trick is the following: When do_balance is called, a unique global variable called cur_tb takes a pointer to the current tree to be rebalanced. Once do_balance finishes its work, cur_tb takes the NULL value. Then, concurrent tree readers/writers just have to check the value of cur_tb to ensure do_balance isn't executing concurrently. If it is, then it proves that schedule() occured on do_balance(), which then relaxed the bkl that protected the tree. Now that the bkl has be turned into a mutex, this check is still fine even though do_balance() becomes preemptible: the write lock will not be automatically released on schedule(), so the tree is still protected. But this is only fine if we have a single reiserfs mountpoint. Indeed, because the bkl is a global lock, it didn't allowed concurrent executions between a tree reader/writer in a mount point and a do_balance() on another tree from another mountpoint. So assuming all these readers/writers weren't supposed to be reentrant, the current check now sometimes detect false positives with the current per-superblock mutex which allows this reentrancy. This patch keeps the concurrent tree accesses check but moves it per superblock, so that only trees from a same mount point are checked to be not accessed concurrently. [ Impact: fix spurious panic while running several reiserfs mount-points ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-06-18reiserfs: fix warnings with gcc 4.4Jeff Mahoney
Several code paths in reiserfs have a construct like: if (is_direntry_le_ih(ih = B_N_PITEM_HEAD(src, item_num))) ... which, in addition to being ugly, end up causing compiler warnings with gcc 4.4.0. Previous compilers didn't issue a warning. fs/reiserfs/do_balan.c:1273: warning: operation on `aux_ih' may be undefined fs/reiserfs/lbalance.c:393: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:421: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:777: warning: operation on `ih' may be undefined I believe this is due to the ih being passed to macros which evaluate the argument more than once. This is old code and we haven't seen any problems with it, but this patch eliminates the warnings. It converts the multiple evaluation macros to static inlines and does a preassignment for the cases that were causing the warnings because that code is just ugly. Reported-by: Chris Mason <mason@oracle.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: strip trailing whitespaceJeff Mahoney
This patch strips trailing whitespace from the reiserfs code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: factor out buffer_info initializationJeff Mahoney
This is the first in a series of patches to make balance_leaf() not quite so insane. This patch factors out the open coded initializations of buffer_info structures and defines a few initializers for the 4 cases they're used. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_panicJeff Mahoney
ReiserFS panics can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_warningJeff Mahoney
ReiserFS warnings can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use buffer_info for leaf_paste_entriesJeff Mahoney
This patch makes leaf_paste_entries more consistent with respect to the other leaf operations. Using buffer_info instead of buffer_head directly allows us to get a superblock pointer for use in error handling. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28reiserfs: fix more sparse warnings in do_balan.cHarvey Harrison
fs/reiserfs/do_balan.c:1467:10: warning: symbol 'ret_val' shadows an earlier one fs/reiserfs/do_balan.c:275:6: originally declared here fs/reiserfs/do_balan.c:1471:23: warning: symbol 'ih' shadows an earlier one fs/reiserfs/do_balan.c:249:67: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-30NULL noise: fs/*, mm/*, kernel/*Al Viro
2007-02-12[PATCH] reiserfs: Use ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
