commit 60e4cf67a582d64f07713eda5fcc8ccdaf7833e6 upstream.
Since commit d0a5b995a308 (vfs: Add IOP_XATTR inode operations flag)
extended attributes haven't worked on the root directory in reiserfs.
This is due to reiserfs conditionally setting the sb->s_xattrs handler
array depending on whether it located or create the internal privroot
directory. It necessarily does this after the root inode is already
read in. The IOP_XATTR flag is set during inode initialization, so
it never gets set on the root directory.
This commit unconditionally assigns sb->s_xattrs and clears IOP_XATTR on
internal inodes. The old return values due to the conditional assignment
are handled via open_xa_root, which now returns EOPNOTSUPP as the VFS
would have done.
Link: https://lore.kernel.org/r/20191024143127.17509-1-jeffm@suse.com
CC: stable@vger.kernel.org
Fixes: d0a5b995a308 ("vfs: Add IOP_XATTR inode operations flag")
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
vfs-timespec64
Pull the timespec64 conversion from Deepa Dinamani:
"The series aims to switch vfs timestamps to use
struct timespec64. Currently vfs uses struct timespec,
which is not y2038 safe.
The flag patch applies cleanly. I've not seen the timestamps
update logic change often. The series applies cleanly on 4.17-rc6
and linux-next tip (top commit: next-20180517).
I'm not sure how to merge this kind of a series with a flag patch.
We are targeting 4.18 for this.
Let me know if you have other suggestions.
The series involves the following:
1. Add vfs helper functions for supporting struct timepec64 timestamps.
2. Cast prints of vfs timestamps to avoid warnings after the switch.
3. Simplify code using vfs timestamps so that the actual
replacement becomes easy.
4. Convert vfs timestamps to use struct timespec64 using a script.
This is a flag day patch.
I've tried to keep the conversions with the script simple, to
aid in the reviews. I've kept all the internal filesystem data
structures and function signatures the same.
Next steps:
1. Convert APIs that can handle timespec64, instead of converting
timestamps at the boundaries.
2. Update internal data structures to avoid timestamp conversions."
I've pulled it into a branch based on top of the NFS changes that
are now in mainline, so I could resolve the non-obvious conflict
between the two while merging.
struct timespec is not y2038 safe. Transition vfs to use
y2038 safe struct timespec64 instead.
The change was made with the help of the following cocinelle
script. This catches about 80% of the changes.
All the header file and logic changes are included in the
first 5 rules. The rest are trivial substitutions.
I avoid changing any of the function signatures or any other
filesystem specific data structures to keep the patch simple
for review.
The script can be a little shorter by combining different cases.
But, this version was sufficient for my usecase.
virtual patch
@ depends on patch @
identifier now;
- struct timespec
+ struct timespec64
current_time ( ... )
- struct timespec now = current_kernel_time();
+ struct timespec64 now = current_kernel_time64();
- return timespec_trunc(
+ return timespec64_trunc(
identifier xtime;
struct \( iattr \| inode \| kstat \) {
- struct timespec xtime;
+ struct timespec64 xtime;
identifier t;
struct inode_operations {
int (*update_time) (...,
- struct timespec t,
+ struct timespec64 t,
identifier t;
identifier fn_update_time =~ "update_time$";
fn_update_time (...,
- struct timespec *t,
+ struct timespec64 *t,
identifier t;
lease_get_mtime( ... ,
@te depends on patch forall@
identifier ts;
local idexpression struct inode *inode_node;
identifier i_xtime =~ "^i_[acm]time$";
identifier ia_xtime =~ "^ia_[acm]time$";
identifier fn;
expression e, E3;
local idexpression struct inode *node1;
local idexpression struct inode *node2;
local idexpression struct iattr *attr1;
local idexpression struct iattr *attr2;
local idexpression struct iattr attr;
identifier i_xtime1 =~ "^i_[acm]time$";
identifier i_xtime2 =~ "^i_[acm]time$";
identifier ia_xtime1 =~ "^ia_[acm]time$";
identifier ia_xtime2 =~ "^ia_[acm]time$";
- struct timespec ts;
+ struct timespec64 ts;
- struct timespec ts = current_time(inode_node);
+ struct timespec64 ts = current_time(inode_node);
<+... when != ts
- timespec_equal(&inode_node->i_xtime, &ts)
+ timespec64_equal(&inode_node->i_xtime, &ts)
- timespec_equal(&ts, &inode_node->i_xtime)
+ timespec64_equal(&ts, &inode_node->i_xtime)
- timespec_compare(&inode_node->i_xtime, &ts)
+ timespec64_compare(&inode_node->i_xtime, &ts)
- timespec_compare(&ts, &inode_node->i_xtime)
+ timespec64_compare(&ts, &inode_node->i_xtime)
ts = current_time(e)
fn_update_time(..., &ts,...)
inode_node->i_xtime = ts
node1->i_xtime = ts
ts = inode_node->i_xtime
<+... attr1->ia_xtime ...+> = ts
ts = attr1->ia_xtime
ts.tv_sec
ts.tv_nsec
btrfs_set_stack_timespec_sec(..., ts.tv_sec)
btrfs_set_stack_timespec_nsec(..., ts.tv_nsec)
- ts = timespec64_to_timespec(
+ ts =
- ts = ktime_to_timespec(
+ ts = ktime_to_timespec64(
- ts = E3
+ ts = timespec_to_timespec64(E3)
- ktime_get_real_ts(&ts)
+ ktime_get_real_ts64(&ts)
fn(...,
- ts
+ timespec64_to_timespec(ts)
<... when != ts
- return ts;
+ return timespec64_to_timespec(ts);
- timespec_equal(&node1->i_xtime1, &node2->i_xtime2)
+ timespec64_equal(&node1->i_xtime2, &node2->i_xtime2)
- timespec_equal(&node1->i_xtime1, &attr2->ia_xtime2)
+ timespec64_equal(&node1->i_xtime2, &attr2->ia_xtime2)
- timespec_compare(&node1->i_xtime1, &node2->i_xtime2)
+ timespec64_compare(&node1->i_xtime1, &node2->i_xtime2)
node1->i_xtime1 =
- timespec_trunc(attr1->ia_xtime1,
+ timespec64_trunc(attr1->ia_xtime1,
- attr1->ia_xtime1 = timespec_trunc(attr2->ia_xtime2,
+ attr1->ia_xtime1 = timespec64_trunc(attr2->ia_xtime2,
- ktime_get_real_ts(&attr1->ia_xtime1)
+ ktime_get_real_ts64(&attr1->ia_xtime1)
- ktime_get_real_ts(&attr.ia_xtime1)
+ ktime_get_real_ts64(&attr.ia_xtime1)
struct inode *node;
struct iattr *attr;
identifier fn;
expression e;
- fn(node->i_xtime);
+ fn(timespec64_to_timespec(node->i_xtime));
fn(...,
- node->i_xtime);
+ timespec64_to_timespec(node->i_xtime));
- e = fn(attr->ia_xtime);
+ e = fn(timespec64_to_timespec(attr->ia_xtime));
@ depends on patch forall @
struct inode *node;
struct iattr *attr;
identifier fn;
+ struct timespec ts;
+ ts = timespec64_to_timespec(node->i_xtime);
fn (...,
- &node->i_xtime,
+ &ts,
+ ts = timespec64_to_timespec(attr->ia_xtime);
fn (...,
- &attr->ia_xtime,
+ &ts,
struct inode *node;
struct iattr *attr;
struct kstat *stat;
identifier xtime =~ "^[acm]time$";
identifier fn, ret;
ret = fn (...,
- &node->i_xtime,
+ &ts,
ret = fn (...,
- &node->i_xtime);
+ &ts);
ret = fn (...,
- &attr->ia_xtime,
+ &ts,
ret = fn (...,
- &attr->ia_xtime);
+ &ts);
+ ts = timespec64_to_timespec(stat->xtime);
ret = fn (...,
- &stat->xtime);
+ &ts);
struct inode *node;
identifier i_xtime3 =~ "^i_[acm]time$";
struct iattr *attrp;
struct iattr *attrp2;
struct iattr attr ;
struct kstat *stat;
struct kstat stat1;
identifier xtime =~ "^[acmb]time$";
expression e;
( node->i_xtime2 \| attrp->ia_xtime2 \| attr.ia_xtime2 \) = node->i_xtime1 ;
node->i_xtime2 = \( node2->i_xtime1 \| timespec64_trunc(...) \);
node->i_xtime2 = node->i_xtime1 = node->i_xtime3 = \(ts \| current_time(...) \);
stat->xtime = node2->i_xtime1;
stat1.xtime = node2->i_xtime1;
( node->i_xtime2 \| attrp->ia_xtime2 \) = attrp->ia_xtime1 ;
( attrp->ia_xtime1 \| attr.ia_xtime1 \) = attrp2->ia_xtime2;
- e = node->i_xtime1;
+ e = timespec64_to_timespec( node->i_xtime1 );
- e = attrp->ia_xtime1;
+ e = timespec64_to_timespec( attrp->ia_xtime1 );
node->i_xtime1 = current_time(...);
- e;
+ timespec_to_timespec64(e);
- e;
- node->i_xtime1 = e;
+ node->i_xtime1 = timespec_to_timespec64(e);
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Cc: <anton@tuxera.com>
Cc: <balbi@kernel.org>
Cc: <bfields@fieldses.org>
Cc: <darrick.wong@oracle.com>
Cc: <dhowells@redhat.com>
Cc: <dsterba@suse.com>
Cc: <dwmw2@infradead.org>
Cc: <hch@lst.de>
Cc: <hirofumi@mail.parknet.co.jp>
Cc: <hubcap@omnibond.com>
Cc: <jack@suse.com>
Cc: <jaegeuk@kernel.org>
Cc: <jaharkes@cs.cmu.edu>
Cc: <jslaby@suse.com>
Cc: <keescook@chromium.org>
Cc: <mark@fasheh.com>
Cc: <miklos@szeredi.hu>
Cc: <nico@linaro.org>
Cc: <reiserfs-devel@vger.kernel.org>
Cc: <richard@nod.at>
Cc: <sage@redhat.com>
Cc: <sfrench@samba.org>
Cc: <swhiteho@redhat.com>
Cc: <tj@kernel.org>
Cc: <trond.myklebust@primarydata.com>
Cc: <tytso@mit.edu>
Cc: <viro@zeniv.linux.org.uk>
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
If .readlink == NULL implies generic_readlink().
Generated by:
to_del="\.readlink.*=.*generic_readlink"
for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
These inode operations are no longer used; remove them.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
CURRENT_TIME_SEC is not y2038 safe. current_time() will
be transitioned to use 64 bit time along with vfs in a
separate patch.
There is no plan to transistion CURRENT_TIME_SEC to use
y2038 safe time interfaces.
current_time() will also be extended to use superblock
range checking parameters when range checking is introduced.
This works because alloc_super() fills in the the s_time_gran
in super block to NSEC_PER_SEC.
Acked-by: Jan Kara <jack@suse.cz>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
This is trivial to do:
- add flags argument to foo_rename()
- check if flags doesn't have any other than RENAME_NOREPLACE
- assign foo_rename() to .rename2 instead of .rename
Filesystems converted:
affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos,
nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat.
Acked-by: Boaz Harrosh <ooo@electrozaur.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: Bob Copeland <me@bobcopeland.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
reiserfs_xattr_[sg]et() will fail with -EOPNOTSUPP for V1 inodes anyway,
and all reiserfs instances of ->[sg]et() call it and so does ->set_acl().
Checks for name length in the instances had been bogus; they should've
been "bugger off if it's _exactly_ the prefix" (as generic would
do on its own) and not "bugger off if it's shorter than the prefix" -
that can't happen.
xattr_full_name() is needed to adjust for the fact that generic instances
will skip the prefix in the name passed to ->[gs]et(); reiserfs homegrown
analogues didn't.
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
kmap() in page_follow_link_light() needed to go - allowing to hold
an arbitrary number of kmaps for long is a great way to deadlocking
the system.
new helper (inode_nohighmem(inode)) needs to be used for pagecache
symlinks inodes; done for all in-tree cases. page_follow_link_light()
instrumented to yell about anything missed.
new_valid_dev() always returns 1, so the !new_valid_dev() check is not
needed. Remove it.
Signed-off-by: Yaowei Bai <bywxiaobai@163.com>
dquot_initialize() can now return error. Handle it where possible.
Signed-off-by: Jan Kara <jack@suse.com>
that's the bulk of filesystem drivers dealing with inodes of their own
The reiserfs code is littered with extra parens in places where the authors
may not have been certain about precedence of & vs ->. This patch cleans them
out.
This patch moves reiserfs closer to adhering to the style rules by
removing leading whitespace from labels.
journal_mark_dirty doesn't need a separate sb argument; It's provided
by the transaction handle.
journal_end doesn't need a separate sb argument; it's provided by the
transaction handle.
journal_end takes a block count argument but doesn't actually use it
for anything. We can remove it.
This patch reformats comments in the reiserfs code to fit in 80 columns and
to follow the style rules.
There is no functional change but it helps make my eyes bleed less.
This patch does a quick search and replace:
B_N_PITEM_HEAD() -> item_head()
B_N_PDELIM_KEY() -> internal_key()
B_N_PKEY() -> leaf_key()
B_N_PITEM() -> item_body()
And the item_head version:
B_I_PITEM() -> ih_item_body()
I_ENTRY_COUNT() -> ih_entry_count()
And the treepath variants:
get_ih() -> tp_item_head()
PATH_PITEM_HEAD() -> tp_item_head()
get_item() -> tp_item_body()
... which makes the code much easier on the eyes.
I've also removed a few unused macros.
Checkpatch will complain about the 80 character limit for do_balan.c.
I've addressed that in a later patchset to split up balance_leaf().
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux.
The reiserfs write lock replaced the BKL and uses similar semantics.
Frederic's locking code makes a distinction between when the lock is nested
and when it's being acquired/released, but I don't think that's the right
distinction to make.
The right distinction is between the lock being released at end-of-use and
the lock being released for a schedule. The unlock should return the depth
and the lock should restore it, rather than the other way around as it is now.
This patch implements that and adds a number of places where the lock
should be dropped.
d_instantiate(dentry, inode);
unlock_new_inode(inode);
is a bad idea; do it the other way round...
boolean "does it have to be exclusive?" flag is passed instead;
Local filesystem should just ignore it - the object is guaranteed
not to be there yet.
Just the flags; only NFS cares even about that, but there are
legitimate uses for such argument. And getting rid of that
completely would require splitting ->lookup() into a couple
of methods (at least), so let's leave that alone for now...
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
its value depends only on inode and does not change; we might as
well store it in ->i_op->check_acl and be done with that.
Reiserfs does not have problems with references to unlinked directories.
CC: reiserfs-devel@vger.kernel.org
Signed-off-by: Sage Weil <sage@newdream.net>
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits)
AppArmor: kill unused macros in lsm.c
AppArmor: cleanup generated files correctly
KEYS: Add an iovec version of KEYCTL_INSTANTIATE
KEYS: Add a new keyctl op to reject a key with a specified error code
KEYS: Add a key type op to permit the key description to be vetted
KEYS: Add an RCU payload dereference macro
AppArmor: Cleanup make file to remove cruft and make it easier to read
SELinux: implement the new sb_remount LSM hook
LSM: Pass -o remount options to the LSM
SELinux: Compute SID for the newly created socket
SELinux: Socket retains creator role and MLS attribute
SELinux: Auto-generate security_is_socket_class
TOMOYO: Fix memory leak upon file open.
Revert "selinux: simplify ioctl checking"
selinux: drop unused packet flow permissions
selinux: Fix packet forwarding checks on postrouting
selinux: Fix wrong checks for selinux_policycap_netpeer
selinux: Fix check for xfrm selinux context algorithm
ima: remove unnecessary call to ima_must_measure
IMA: remove IMA imbalance checking
Now that VFS check for inode->i_nlink == 0 and returns proper
error, remove similar check from file system
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
if directory has so many subdirectories that its link count is set
to 1 (i.e. "can't tell accurately") and reiserfs_new_inode() fails,
we shouldn't decrement the parent's link count in cleanup path;
that's what DEC_DIR_INODE_NLINK() is for. As it is, we end up
with parent suddenly getting zero i_nlink, with very unpleasant
effects.
SELinux would like to implement a new labeling behavior of newly created
inodes. We currently label new inodes based on the parent and the creating
process. This new behavior would also take into account the name of the
new object when deciding the new label. This is not the (supposed) full path,
just the last component of the path.
This is very useful because creating /etc/shadow is different than creating
/etc/passwd but the kernel hooks are unable to differentiate these
operations. We currently require that userspace realize it is doing some
difficult operation like that and than userspace jumps through SELinux hoops
to get things set up correctly. This patch does not implement new
behavior, that is obviously contained in a seperate SELinux patch, but it
does pass the needed name down to the correct LSM hook. If no such name
exists it is fine to pass NULL.
Signed-off-by: Eric Paris <eparis@redhat.com>
Clones an existing reference to inode; caller must already hold one.
