[ Upstream commit 2acf15b94d5b8ea8392c4b6753a6ffac3135cd78 ]
Our syzcaller report a NULL pointer dereference:
BUG: kernel NULL pointer dereference, address: 0000000000000000
PGD 116e95067 P4D 116e95067 PUD 1080b5067 PMD 0
Oops: 0010 [#1] SMP KASAN
CPU: 7 PID: 592 Comm: a.out Not tainted 5.13.0-next-20210629-dirty #67
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS ?-20190727_073836-buildvm-p4
RIP: 0010:0x0
Code: Unable to access opcode bytes at RIP 0xffffffffffffffd6.
RSP: 0018:ffff888114e779b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 1ffff110229cef39 RCX: ffffffffaa67e1aa
RDX: 0000000000000000 RSI: ffff88810a58ee00 RDI: ffff8881233180b0
RBP: ffffffffac38e9c0 R08: ffffffffaa67e17e R09: 0000000000000001
R10: ffffffffb91c5557 R11: fffffbfff7238aaa R12: ffff88810a58ee00
R13: ffff888114e77aa0 R14: 0000000000000000 R15: ffff8881233180b0
FS: 00007f946163c480(0000) GS:ffff88839f1c0000(0000) knlGS:0000000000000000
CR2: ffffffffffffffd6 CR3: 00000001099c1000 CR4: 00000000000006e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
__lookup_slow+0x116/0x2d0
? page_put_link+0x120/0x120
? __d_lookup+0xfc/0x320
? d_lookup+0x49/0x90
lookup_one_len+0x13c/0x170
? __lookup_slow+0x2d0/0x2d0
? reiserfs_schedule_old_flush+0x31/0x130
reiserfs_lookup_privroot+0x64/0x150
reiserfs_fill_super+0x158c/0x1b90
? finish_unfinished+0xb10/0xb10
? bprintf+0xe0/0xe0
? __mutex_lock_slowpath+0x30/0x30
? __kasan_check_write+0x20/0x30
? up_write+0x51/0xb0
? set_blocksize+0x9f/0x1f0
mount_bdev+0x27c/0x2d0
? reiserfs_kill_sb+0x120/0x120
get_super_block+0x19/0x30
legacy_get_tree+0x76/0xf0
vfs_get_tree+0x49/0x160
? capable+0x1d/0x30
path_mount+0xacc/0x1380
? putname+0x97/0xd0
? finish_automount+0x450/0x450
? kmem_cache_free+0xf8/0x5a0
? putname+0x97/0xd0
do_mount+0xe2/0x110
? path_mount+0x1380/0x1380
? copy_mount_options+0x69/0x140
__x64_sys_mount+0xf0/0x190
do_syscall_64+0x35/0x80
entry_SYSCALL_64_after_hwframe+0x44/0xae
This is because 'root_inode' is initialized with wrong mode, and
it's i_op is set to 'reiserfs_special_inode_operations'. Thus add
check for 'root_inode' to fix the problem.
Link: https://lore.kernel.org/r/20210702040743.1918552-1-yukuai3@huawei.com
Signed-off-by: Yu Kuai <yukuai3@huawei.com>
[ Upstream commit e9d4709fcc26353df12070566970f080e651f0c9 ]
When a usrjquota or grpjquota mount option is used multiple times, we
will leak memory allocated for the file name. Make sure the last setting
is used and all the previous ones are properly freed.
Reported-by: syzbot+c9e294bbe0333a6b7640@syzkaller.appspotmail.com
[ Upstream commit 4d5c1adaf893b8aa52525d2b81995e949bcb3239 ]
When we fail to allocate string for journal device name we jump to
'error' label which tries to unlock reiserfs write lock which is not
held. Jump to 'error_unlocked' instead.
Fixes: f32485be8397 ("reiserfs: delay reiserfs lock until journal initialization")
commit 5474ca7da6f34fa95e82edc747d5faa19cbdfb5c upstream.
When a filesystem is mounted with jdev mount option, we store the
journal device name in an allocated string in superblock. However we
fail to ever free that string. Fix it.
Reported-by: syzbot+1c6756baf4b16b94d2a6@syzkaller.appspotmail.com
Fixes: c3aa077648e1 ("reiserfs: Properly display mount options in /proc/mounts")
CC: stable@vger.kernel.org
commit 60e4cf67a582d64f07713eda5fcc8ccdaf7833e6 upstream.
Since commit d0a5b995a308 (vfs: Add IOP_XATTR inode operations flag)
extended attributes haven't worked on the root directory in reiserfs.
This is due to reiserfs conditionally setting the sb->s_xattrs handler
array depending on whether it located or create the internal privroot
directory. It necessarily does this after the root inode is already
read in. The IOP_XATTR flag is set during inode initialization, so
it never gets set on the root directory.
This commit unconditionally assigns sb->s_xattrs and clears IOP_XATTR on
internal inodes. The old return values due to the conditional assignment
are handled via open_xa_root, which now returns EOPNOTSUPP as the VFS
would have done.
Link: https://lore.kernel.org/r/20191024143127.17509-1-jeffm@suse.com
Fixes: d0a5b995a308 ("vfs: Add IOP_XATTR inode operations flag")
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Fill in the appropriate limits to avoid inconsistencies
in the vfs cached inode times when timestamps are
outside the permitted range.
Even though some filesystems are read-only, fill in the
timestamps to reflect the on-disk representation.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Acked-By: Tigran Aivazian <aivazian.tigran@gmail.com>
Acked-by: Jeff Layton <jlayton@kernel.org>
Cc: aivazian.tigran@gmail.com
Cc: al@alarsen.net
Cc: coda@cs.cmu.edu
Cc: darrick.wong@oracle.com
Cc: dushistov@mail.ru
Cc: dwmw2@infradead.org
Cc: hch@infradead.org
Cc: jack@suse.com
Cc: jaharkes@cs.cmu.edu
Cc: luisbg@kernel.org
Cc: nico@fluxnic.net
Cc: phillip@squashfs.org.uk
Cc: richard@nod.at
Cc: salah.triki@gmail.com
Cc: shaggy@kernel.org
Cc: linux-xfs@vger.kernel.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: reiserfs-devel@vger.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull quota & reiserfs changes from Jan Kara:
- two error checking improvements for quota
- remove bogus i_version increase for reiserfs
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
quota: Check for register_shrinker() failure.
quota: propagate error from __dquot_initialize
reiserfs: remove unneeded i_version bump
This is a pure automated search-and-replace of the internal kernel
superblock flags.
The s_flags are now called SB_*, with the names and the values for the
moment mirroring the MS_* flags that they're equivalent to.
Note how the MS_xyz flags are the ones passed to the mount system call,
while the SB_xyz flags are what we then use in sb->s_flags.
The script to do this was:
# places to look in; re security/*: it generally should *not* be
# touched (that stuff parses mount(2) arguments directly), but
# there are two places where we really deal with superblock flags.
FILES="drivers/mtd drivers/staging/lustre fs ipc mm \
include/linux/fs.h include/uapi/linux/bfs_fs.h \
security/apparmor/apparmorfs.c security/apparmor/include/lib.h"
# the list of MS_... constants
SYMS="RDONLY NOSUID NODEV NOEXEC SYNCHRONOUS REMOUNT MANDLOCK \
DIRSYNC NOATIME NODIRATIME BIND MOVE REC VERBOSE SILENT \
POSIXACL UNBINDABLE PRIVATE SLAVE SHARED RELATIME KERNMOUNT \
I_VERSION STRICTATIME LAZYTIME SUBMOUNT NOREMOTELOCK NOSEC BORN \
ACTIVE NOUSER"
SED_PROG=
for i in $SYMS; do SED_PROG="$SED_PROG -e s/MS_$i/SB_$i/g"; done
# we want files that contain at least one of MS_...,
# with fs/namespace.c and fs/pnode.c excluded.
L=$(for i in $SYMS; do git grep -w -l MS_$i $FILES; done| sort|uniq|grep -v '^fs/namespace.c'|grep -v '^fs/pnode.c')
for f in $L; do sed -i $f $SED_PROG; done
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
The i_version field in reiserfs is not initialized and is only ever
updated here. Nothing ever views it, so just remove it.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
btrfs, debugfs, reiserfs and tracefs call save_mount_options() and reiserfs
calls replace_mount_options(), but they then implement their own
->show_options() methods and don't touch s_options, rendering the saved
options unnecessary. I'm trying to eliminate s_options to make it easier
to implement a context-based mount where the mount options can be passed
individually over a file descriptor.
Remove the calls to save/replace_mount_options() call in these cases.
cc: Chris Mason <clm@fb.com>
cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Steven Rostedt <rostedt@goodmis.org>
cc: linux-btrfs@vger.kernel.org
cc: reiserfs-devel@vger.kernel.org
Currently immutable and noatime flags on quota files are set by quota
code which requires us to copy inode->i_flags to our on disk version of
quota flags in GETFLAGS ioctl and when writing stat item. Move to
setting / clearing these on-disk flags directly to save that copying.
dquot_writeback_dquots() expects s_umount semaphore to be held to
protect it from other concurrent quota operations. reiserfs_sync_fs()
can call dquot_writeback_dquots() without holding s_umount semaphore
when called from flush_old_commits().
Fix the problem by grabbing s_umount in flush_old_commits(). However we
have to be careful and use only trylock since reiserfs_cancel_old_sync()
can be waiting for flush_old_commits() to complete while holding
s_umount semaphore. Possible postponing of sync work is not a big deal
though as that is only an opportunistic flush.
Fixes: 9d1ccbe70e0b14545caad12dc73adb3605447df0
Reported-by: Jan Beulich <jbeulich@suse.com>
Currently canceling of delayed work that flushes old data using
cancel_old_flush() does not prevent work from being requeued. Thus
in theory new work can be queued after cancel_old_flush() from
reiserfs_freeze() has run. This will become larger problem once
flush_old_commits() can requeue the work itself.
Fix the problem by recording in sbi->work_queue that flushing work is
canceled and should not be requeued.
See i_size_read() comments in include/linux/fs.h
Link: http://lkml.kernel.org/r/20170123174701.30394-1-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
CURRENT_TIME_SEC is not y2038 safe. current_time() will
be transitioned to use 64 bit time along with vfs in a
separate patch.
There is no plan to transistion CURRENT_TIME_SEC to use
y2038 safe time interfaces.
current_time() will also be extended to use superblock
range checking parameters when range checking is introduced.
This works because alloc_super() fills in the the s_time_gran
in super block to NSEC_PER_SEC.
Acked-by: Jan Kara <jack@suse.cz>
If we hold the superblock lock while calling reiserfs_quota_on_mount(), we can
deadlock our own worker - mount blocks kworker/3:2, sleeps forever more.
crash> ps|grep UN
715 2 3 ffff880220734d30 UN 0.0 0 0 [kworker/3:2]
9369 9341 2 ffff88021ffb7560 UN 1.3 493404 123184 Xorg
9665 9664 3 ffff880225b92ab0 UN 0.0 47368 812 udisks-daemon
10635 10403 3 ffff880222f22c70 UN 0.0 14904 936 mount
crash> bt ffff880220734d30
PID: 715 TASK: ffff880220734d30 CPU: 3 COMMAND: "kworker/3:2"
#0 [ffff8802244c3c20] schedule at ffffffff8144584b
#1 [ffff8802244c3cc8] __rt_mutex_slowlock at ffffffff814472b3
#2 [ffff8802244c3d28] rt_mutex_slowlock at ffffffff814473f5
#3 [ffff8802244c3dc8] reiserfs_write_lock at ffffffffa05f28fd [reiserfs]
#4 [ffff8802244c3de8] flush_async_commits at ffffffffa05ec91d [reiserfs]
#5 [ffff8802244c3e08] process_one_work at ffffffff81073726
#6 [ffff8802244c3e68] worker_thread at ffffffff81073eba
#7 [ffff8802244c3ec8] kthread at ffffffff810782e0
#8 [ffff8802244c3f48] kernel_thread_helper at ffffffff81450064
crash> rd ffff8802244c3cc8 10
ffff8802244c3cc8: ffffffff814472b3 ffff880222f23250 .rD.....P2."....
ffff8802244c3cd8: 0000000000000000 0000000000000286 ................
ffff8802244c3ce8: ffff8802244c3d30 ffff880220734d80 0=L$.....Ms ....
ffff8802244c3cf8: ffff880222e8f628 0000000000000000 (.."............
ffff8802244c3d08: 0000000000000000 0000000000000002 ................
crash> struct rt_mutex ffff880222e8f628
struct rt_mutex {
wait_lock = {
raw_lock = {
slock = 65537
wait_list = {
node_list = {
next = 0xffff8802244c3d48,
prev = 0xffff8802244c3d48
owner = 0xffff880222f22c71,
save_state = 0
crash> bt 0xffff880222f22c70
PID: 10635 TASK: ffff880222f22c70 CPU: 3 COMMAND: "mount"
#0 [ffff8802216a9868] schedule at ffffffff8144584b
#1 [ffff8802216a9910] schedule_timeout at ffffffff81446865
#2 [ffff8802216a99a0] wait_for_common at ffffffff81445f74
#3 [ffff8802216a9a30] flush_work at ffffffff810712d3
#4 [ffff8802216a9ab0] schedule_on_each_cpu at ffffffff81074463
#5 [ffff8802216a9ae0] invalidate_bdev at ffffffff81178aba
#6 [ffff8802216a9af0] vfs_load_quota_inode at ffffffff811a3632
#7 [ffff8802216a9b50] dquot_quota_on_mount at ffffffff811a375c
#8 [ffff8802216a9b80] finish_unfinished at ffffffffa05dd8b0 [reiserfs]
#9 [ffff8802216a9cc0] reiserfs_fill_super at ffffffffa05de825 [reiserfs]
RIP: 00007f7b9303997a RSP: 00007ffff443c7a8 RFLAGS: 00010202
RAX: 00000000000000a5 RBX: ffffffff8144ef12 RCX: 00007f7b932e9ee0
RDX: 00007f7b93d9a400 RSI: 00007f7b93d9a3e0 RDI: 00007f7b93d9a3c0
RBP: 00007f7b93d9a2c0 R8: 00007f7b93d9a550 R9: 0000000000000001
R10: ffffffffc0ed040e R11: 0000000000000202 R12: 000000000000040e
R13: 0000000000000000 R14: 00000000c0ed040e R15: 00007ffff443ca20
ORIG_RAX: 00000000000000a5 CS: 0033 SS: 002b
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Mike Galbraith <mgalbraith@suse.de>
Cc: <stable@vger.kernel.org>
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
This has ll_rw_block users pass in the operation and flags separately,
so ll_rw_block can setup the bio op and bi_rw flags on the bio that
is submitted.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Check out-of-memory failure of the kstrdup option. Note that the argument
"arg" may be NULL (in that case kstrup returns NULL), so out of memory
condition happened if arg was non-NULL and kstrdup returned NULL.
The patch also changes the call to replace_mount_options - if we didn't
pass any filesystem-specific options, we don't call replace_mount_options
(thus we don't erase existing reported options).
Note that to properly report options after remount, the reiserfs
filesystem should implement the show_options method. Without the
show_options method, options changed with remount replace existing
options.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Add infrastructure for supporting get_nextdqblk() callback for VFS
quotas. Translate the operation into a callback to appropriate
filesystem and consequently to quota format callback.
reiserfs_iget() returns either NULL or error code in ERR_PTR. And we
were only checking for NULL, so in case of some other error we will try
to dereference the ERR_PTR(-errno) thinking it to be a valid pointer.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
Merge second patchbomb from Andrew Morton:
- most of the rest of MM
- lots of misc things
- procfs updates
- printk feature work
- updates to get_maintainer, MAINTAINERS, checkpatch
- lib/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits)
exit,stats: /* obey this comment */
coredump: add __printf attribute to cn_*printf functions
coredump: use from_kuid/kgid when formatting corename
fs/reiserfs: remove unneeded cast
NILFS2: support NFSv2 export
fs/befs/btree.c: remove unneeded initializations
fs/minix: remove unneeded cast
init/do_mounts.c: add create_dev() failure log
kasan: remove duplicate definition of the macro KASAN_FREE_PAGE
fs/efs: femove unneeded cast
checkpatch: emit "NOTE: <types>" message only once after multiple files
checkpatch: emit an error when there's a diff in a changelog
checkpatch: validate MODULE_LICENSE content
checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY
checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()
checkpatch: fix processing of MEMSET issues
checkpatch: suggest using ether_addr_equal*()
checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files
checkpatch: remove local from codespell path
checkpatch: add --showfile to allow input via pipe to show filenames
kmem_cache_alloc() returns void*.
Signed-off-by: Firo Yang <firogm@gmail.com>
With the planned cgroup writeback support, backing-dev related
declarations will be more widely used across block and cgroup;
unfortunately, including backing-dev.h from include/linux/blkdev.h
makes cyclic include dependency quite likely.
This patch separates out backing-dev-defs.h which only has the
essential definitions and updates blkdev.h to include it. c files
which need access to more backing-dev details now include
backing-dev.h directly. This takes backing-dev.h off the common
include dependency chain making it a lot easier to use it across block
and cgroup.
v2: fs/fat build failure fixed.
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
that's the bulk of filesystem drivers dealing with inodes of their own
Create new internal interface for getting information about quota which
contains everything needed for both VFS quotas and XFS quotas. Make VFS
use this and hook it up to Q_GETINFO.
When resirefs is trying to mount a partition, it creates a commit
workqueue (sbi->commit_wq). But when mount fails later, the workqueue
is not freed.
Reported-by: auxsvr@gmail.com
Reported-by: Benoît Monin <benoit.monin@gmx.fr>
Cc: Jan Kara <jack@suse.cz>
Cc: stable@vger.kernel.org # >= 3.16
Fixes: 797d9016ceca69879bb273218810fa0beef46aac
CC: reiserfs-devel@vger.kernel.org
CC: Jeff Mahoney <jeffm@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
MAXQUOTAS value defines maximum number of quota types VFS supports.
This isn't necessarily the number of types reiserfs supports and with
addition of project quotas these two numbers stop matching. So make
reiserfs use its private definition.
Pull quota, reiserfs, UDF updates from Jan Kara:
"Scalability improvements for quota, a few reiserfs fixes, and couple
of misc cleanups (udf, ext2)"
reiserfs: Fix use after free in journal teardown
reiserfs: fix corruption introduced by balance_leaf refactor
udf: avoid redundant memcpy when writing data in ICB
fs/udf: re-use hex_asc_upper_{hi,lo} macros
fs/quota: kernel-doc warning fixes
udf: use linux/uaccess.h
fs/ext2/super.c: Drop memory allocation cast
quota: remove dqptr_sem
quota: simplify remove_inode_dquot_ref()
quota: avoid unnecessary dqget()/dqput() calls
quota: protect Q_GETFMT by dqonoff_mutex
If do_journal_release() races with do_journal_end() which requeues
delayed works for transaction flushing, we can leave work items for
flushing outstanding transactions queued while freeing them. That
results in use after free and possible crash in run_timers_softirq().
Fix the problem by not requeueing works if superblock is being shut down
(MS_ACTIVE not set) and using cancel_delayed_work_sync() in
do_journal_release().
Fix checkpatch warning
WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
Cc: Jeff Mahoney <jeffm@suse.com>
Fixes checkpatch warnings:
"WARNING: %Ld/%Lu are not-standard C, use %lld/%llu"
The hash detection code uses long ugly macros multiple times to get the same
value. This patch cleans it up to be easier to read.
[JK: Fixed up path leak in find_hash_out()]
The reiserfs code is littered with extra parens in places where the authors
may not have been certain about precedence of & vs ->. This patch cleans them
out.
journal_mark_dirty doesn't need a separate sb argument; It's provided
by the transaction handle.
journal_end doesn't need a separate sb argument; it's provided by the
transaction handle.
journal_end takes a block count argument but doesn't actually use it
for anything. We can remove it.
This patch reformats comments in the reiserfs code to fit in 80 columns and
to follow the style rules.
There is no functional change but it helps make my eyes bleed less.
This patch does a quick search and replace:
B_N_PITEM_HEAD() -> item_head()
B_N_PDELIM_KEY() -> internal_key()
B_N_PKEY() -> leaf_key()
B_N_PITEM() -> item_body()
And the item_head version:
B_I_PITEM() -> ih_item_body()
I_ENTRY_COUNT() -> ih_entry_count()
And the treepath variants:
get_ih() -> tp_item_head()
PATH_PITEM_HEAD() -> tp_item_head()
get_item() -> tp_item_body()
... which makes the code much easier on the eyes.
I've also removed a few unused macros.
Checkpatch will complain about the 80 character limit for do_balan.c.
I've addressed that in a later patchset to split up balance_leaf().
The reiserfs write lock hasn't been the BKL for some time. There's no
need to have different file systems queued up on the same workqueue.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
init_inodecache is only called by __init init_reiserfs_fs.
Acked-by: Jeff Mahoney <jeffm@suse.com>
