path: root/fs/reiserfs/xattr.c
2010-05-21reiserfs: constify xattr_handlerStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-04-24reiserfs: fix corruption during shrinking of xattrsJeff Mahoney
Commit 48b32a3553a54740d236b79a90f20147a25875e3 ("reiserfs: use generic xattr handlers") introduced a problem that causes corruption when extended attributes are replaced with a smaller value. The issue is that the reiserfs_setattr to shrink the xattr file was moved from before the write to after the write. The root issue has always been in the reiserfs xattr code, but was papered over by the fact that in the shrink case, the file would just be expanded again while the xattr was written. The end result is that the last 8 bytes of xattr data are lost. This patch fixes it to use new_size. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=14826 Signed-off-by: Jeff Mahoney <jeffm@suse.com> Reported-by: Christian Kujau <lists@nerdbynature.de> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jethro Beekman <kernel@jbeekman.nl> Cc: Greg Surbey <gregsurbey@hotmail.com> Cc: Marco Gatti <marco.gatti@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-24reiserfs: fix permissions on .reiserfs_privJeff Mahoney
Commit 677c9b2e393a0cd203bd54e9c18b012b2c73305a ("reiserfs: remove privroot hiding in lookup") removed the magic from the lookup code to hide the .reiserfs_priv directory since it was getting loaded at mount-time instead. The intent was that the entry would be hidden from the user via a poisoned d_compare, but this was faulty. This introduced a security issue where unprivileged users could access and modify extended attributes or ACLs belonging to other users, including root. This patch resolves the issue by properly hiding .reiserfs_priv. This was the intent of the xattr poisoning code, but it appears to have never worked as expected. This is fixed by using d_revalidate instead of d_compare. This patch makes -oexpose_privroot a no-op. I'm fine leaving it this way. The effort involved in working out the corner cases wrt permissions and caching outweigh the benefit of the feature. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Acked-by: Edward Shishkin <edward.shishkin@gmail.com> Reported-by: Matt McCutchen <matt@mattmccutchen.net> Tested-by: Matt McCutchen <matt@mattmccutchen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-01-08Merge branch 'reiserfs/kill-bkl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'reiserfs/kill-bkl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: reiserfs: Relax reiserfs_xattr_set_handle() while acquiring xattr locks reiserfs: Fix unreachable statement reiserfs: Don't call reiserfs_get_acl() with the reiserfs lock reiserfs: Relax lock on xattr removing reiserfs: Relax the lock before truncating pages reiserfs: Fix recursive lock on lchown reiserfs: Fix mistake in down_write() conversion
2010-01-07reiserfs: Relax reiserfs_xattr_set_handle() while acquiring xattr locksFrederic Weisbecker
Fix remaining xattr locks acquired in reiserfs_xattr_set_handle() while we are holding the reiserfs lock to avoid lock inversions. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-05reiserfs: Relax lock on xattr removingFrederic Weisbecker
When we remove an xattr, we call lookup_and_delete_xattr() that takes some private xattr inodes mutexes. But we hold the reiserfs lock at this time, which leads to dependency inversions. We can safely call lookup_and_delete_xattr() without the reiserfs lock, where xattr inodes lookups only need the xattr inodes mutexes. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-03reiserfs: Fix mistake in down_write() conversionFrederic Weisbecker
Fix a mistake in commit 0719d3434747889b314a1e8add776418c4148bcf (reiserfs: Fix reiserfs lock <-> i_xattr_sem dependency inversion) that has converted a down_write() into a down_read() accidentally. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02Merge branch 'reiserfs/kill-bkl' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing * 'reiserfs/kill-bkl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing: reiserfs: Safely acquire i_mutex from xattr_rmdir reiserfs: Safely acquire i_mutex from reiserfs_for_each_xattr reiserfs: Fix journal mutex <-> inode mutex lock inversion reiserfs: Fix unwanted recursive reiserfs lock in reiserfs_unlink() reiserfs: Relax lock before open xattr dir in reiserfs_xattr_set_handle() reiserfs: Relax reiserfs lock while freeing the journal reiserfs: Fix reiserfs lock <-> i_mutex dependency inversion on xattr reiserfs: Warn on lock relax if taken recursively reiserfs: Fix reiserfs lock <-> i_xattr_sem dependency inversion reiserfs: Fix remaining in-reclaim-fs <-> reclaim-fs-on locking inversion reiserfs: Fix reiserfs lock <-> inode mutex dependency inversion reiserfs: Fix reiserfs lock and journal lock inversion dependency reiserfs: Fix possible recursive lock
2010-01-02reiserfs: Safely acquire i_mutex from xattr_rmdirFrederic Weisbecker
Relax the reiserfs lock before taking the inode mutex from xattr_rmdir() to avoid the usual reiserfs lock <-> inode mutex bad dependency. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02reiserfs: Safely acquire i_mutex from reiserfs_for_each_xattrFrederic Weisbecker
Relax the reiserfs lock before taking the inode mutex from reiserfs_for_each_xattr() to avoid the usual bad dependencies: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-atom #179 ------------------------------------------------------- rm/3242 is trying to acquire lock: (&sb->s_type->i_mutex_key#4/3){+.+.+.}, at: [<c11428ef>] reiserfs_for_each_xattr+0x23f/0x290 but task is already holding lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<c1143389>] reiserfs_write_lock+0x29/0x40 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&REISERFS_SB(s)->lock){+.+.+.}: [<c105ea7f>] __lock_acquire+0x11ff/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401aab>] mutex_lock_nested+0x5b/0x340 [<c1143339>] reiserfs_write_lock_once+0x29/0x50 [<c1117022>] reiserfs_lookup+0x62/0x140 [<c10bd85f>] __lookup_hash+0xef/0x110 [<c10bf21d>] lookup_one_len+0x8d/0xc0 [<c1141e3a>] open_xa_dir+0xea/0x1b0 [<c1142720>] reiserfs_for_each_xattr+0x70/0x290 [<c11429ba>] reiserfs_delete_xattrs+0x1a/0x60 [<c111ea2f>] reiserfs_delete_inode+0x9f/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10c0b13>] sys_unlinkat+0x23/0x40 [<c1002ec4>] sysenter_do_call+0x12/0x32 -> #0 (&sb->s_type->i_mutex_key#4/3){+.+.+.}: [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401aab>] mutex_lock_nested+0x5b/0x340 [<c11428ef>] reiserfs_for_each_xattr+0x23f/0x290 [<c11429ba>] reiserfs_delete_xattrs+0x1a/0x60 [<c111ea2f>] reiserfs_delete_inode+0x9f/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10c0b13>] sys_unlinkat+0x23/0x40 [<c1002ec4>] sysenter_do_call+0x12/0x32 other info that might help us debug this: 1 lock held by rm/3242: #0: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<c1143389>] reiserfs_write_lock+0x29/0x40 stack backtrace: Pid: 3242, comm: rm Not tainted 2.6.32-atom #179 Call Trace: [<c13ffa13>] ? printk+0x18/0x1a [<c105d33a>] print_circular_bug+0xca/0xd0 [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105c932>] ? mark_held_locks+0x62/0x80 [<c105cc3b>] ? trace_hardirqs_on+0xb/0x10 [<c1401098>] ? mutex_unlock+0x8/0x10 [<c105f2c8>] lock_acquire+0x68/0x90 [<c11428ef>] ? reiserfs_for_each_xattr+0x23f/0x290 [<c11428ef>] ? reiserfs_for_each_xattr+0x23f/0x290 [<c1401aab>] mutex_lock_nested+0x5b/0x340 [<c11428ef>] ? reiserfs_for_each_xattr+0x23f/0x290 [<c11428ef>] reiserfs_for_each_xattr+0x23f/0x290 [<c1143180>] ? delete_one_xattr+0x0/0x100 [<c11429ba>] reiserfs_delete_xattrs+0x1a/0x60 [<c1143339>] ? reiserfs_write_lock_once+0x29/0x50 [<c111ea2f>] reiserfs_delete_inode+0x9f/0x150 [<c11b0d4f>] ? _atomic_dec_and_lock+0x4f/0x70 [<c111e990>] ? reiserfs_delete_inode+0x0/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c1401098>] ? mutex_unlock+0x8/0x10 [<c10c3e0d>] ? vfs_readdir+0x7d/0xb0 [<c10c3af0>] ? filldir64+0x0/0xf0 [<c1002ef3>] ? sysenter_exit+0xf/0x16 [<c105cbe4>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10c0b13>] sys_unlinkat+0x23/0x40 [<c1002ec4>] sysenter_do_call+0x12/0x32 Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02reiserfs: Fix journal mutex <-> inode mutex lock inversionFrederic Weisbecker
We need to relax the reiserfs lock before locking the inode mutex from xattr_unlink(), otherwise we'll face the usual bad dependencies: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-atom #178 ------------------------------------------------------- rm/3202 is trying to acquire lock: (&journal->j_mutex){+.+...}, at: [<c113c234>] do_journal_begin_r+0x94/0x360 but task is already holding lock: (&sb->s_type->i_mutex_key#4/2){+.+...}, at: [<c1142a67>] xattr_unlink+0x57/0xb0 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #2 (&sb->s_type->i_mutex_key#4/2){+.+...}: [<c105ea7f>] __lock_acquire+0x11ff/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a7b>] mutex_lock_nested+0x5b/0x340 [<c1142a67>] xattr_unlink+0x57/0xb0 [<c1143179>] delete_one_xattr+0x29/0x100 [<c11427bb>] reiserfs_for_each_xattr+0x10b/0x290 [<c11429ba>] reiserfs_delete_xattrs+0x1a/0x60 [<c111ea2f>] reiserfs_delete_inode+0x9f/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10c0b13>] sys_unlinkat+0x23/0x40 [<c1002ec4>] sysenter_do_call+0x12/0x32 -> #1 (&REISERFS_SB(s)->lock){+.+.+.}: [<c105ea7f>] __lock_acquire+0x11ff/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a7b>] mutex_lock_nested+0x5b/0x340 [<c1143359>] reiserfs_write_lock+0x29/0x40 [<c113c23c>] do_journal_begin_r+0x9c/0x360 [<c113c680>] journal_begin+0x80/0x130 [<c1127363>] reiserfs_remount+0x223/0x4e0 [<c10b6dd6>] do_remount_sb+0xa6/0x140 [<c10ce6a0>] do_mount+0x560/0x750 [<c10ce914>] sys_mount+0x84/0xb0 [<c1002ec4>] sysenter_do_call+0x12/0x32 -> #0 (&journal->j_mutex){+.+...}: [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a7b>] mutex_lock_nested+0x5b/0x340 [<c113c234>] do_journal_begin_r+0x94/0x360 [<c113c680>] journal_begin+0x80/0x130 [<c1116d63>] reiserfs_unlink+0x83/0x2e0 [<c1142a74>] xattr_unlink+0x64/0xb0 [<c1143179>] delete_one_xattr+0x29/0x100 [<c11427bb>] reiserfs_for_each_xattr+0x10b/0x290 [<c11429ba>] reiserfs_delete_xattrs+0x1a/0x60 [<c111ea2f>] reiserfs_delete_inode+0x9f/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10c0b13>] sys_unlinkat+0x23/0x40 [<c1002ec4>] sysenter_do_call+0x12/0x32 other info that might help us debug this: 2 locks held by rm/3202: #0: (&sb->s_type->i_mutex_key#4/3){+.+.+.}, at: [<c114274b>] reiserfs_for_each_xattr+0x9b/0x290 #1: (&sb->s_type->i_mutex_key#4/2){+.+...}, at: [<c1142a67>] xattr_unlink+0x57/0xb0 stack backtrace: Pid: 3202, comm: rm Not tainted 2.6.32-atom #178 Call Trace: [<c13ff9e3>] ? printk+0x18/0x1a [<c105d33a>] print_circular_bug+0xca/0xd0 [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c1142a67>] ? xattr_unlink+0x57/0xb0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c113c234>] ? do_journal_begin_r+0x94/0x360 [<c113c234>] ? do_journal_begin_r+0x94/0x360 [<c1401a7b>] mutex_lock_nested+0x5b/0x340 [<c113c234>] ? do_journal_begin_r+0x94/0x360 [<c113c234>] do_journal_begin_r+0x94/0x360 [<c10411b6>] ? run_timer_softirq+0x1a6/0x220 [<c103cb00>] ? __do_softirq+0x50/0x140 [<c113c680>] journal_begin+0x80/0x130 [<c103cba2>] ? __do_softirq+0xf2/0x140 [<c104f72f>] ? hrtimer_interrupt+0xdf/0x220 [<c1116d63>] reiserfs_unlink+0x83/0x2e0 [<c105c932>] ? mark_held_locks+0x62/0x80 [<c11b8d08>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c1002fd8>] ? restore_all_notrace+0x0/0x18 [<c1142a67>] ? xattr_unlink+0x57/0xb0 [<c1142a74>] xattr_unlink+0x64/0xb0 [<c1143179>] delete_one_xattr+0x29/0x100 [<c11427bb>] reiserfs_for_each_xattr+0x10b/0x290 [<c1143150>] ? delete_one_xattr+0x0/0x100 [<c1401cb9>] ? mutex_lock_nested+0x299/0x340 [<c11429ba>] reiserfs_delete_xattrs+0x1a/0x60 [<c1143309>] ? reiserfs_write_lock_once+0x29/0x50 [<c111ea2f>] reiserfs_delete_inode+0x9f/0x150 [<c11b0d1f>] ? _atomic_dec_and_lock+0x4f/0x70 [<c111e990>] ? reiserfs_delete_inode+0x0/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c1401068>] ? mutex_unlock+0x8/0x10 [<c10c3e0d>] ? vfs_readdir+0x7d/0xb0 [<c10c3af0>] ? filldir64+0x0/0xf0 [<c1002ef3>] ? sysenter_exit+0xf/0x16 [<c105cbe4>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10c0b13>] sys_unlinkat+0x23/0x40 [<c1002ec4>] sysenter_do_call+0x12/0x32 Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02reiserfs: Relax lock before open xattr dir in reiserfs_xattr_set_handle()Frederic Weisbecker
We call xattr_lookup() from reiserfs_xattr_get(). We then hold the reiserfs lock when we grab the i_mutex. But later, we may relax the reiserfs lock, creating dependency inversion between both locks. The lookups and creation jobs ar already protected by the inode mutex, so we can safely relax the reiserfs lock, dropping the unwanted reiserfs lock -> i_mutex dependency, as shown in the following lockdep report: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-atom #173 ------------------------------------------------------- cp/3204 is trying to acquire lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<c11432b9>] reiserfs_write_lock_once+0x29/0x50 but task is already holding lock: (&sb->s_type->i_mutex_key#4/3){+.+.+.}, at: [<c1141e18>] open_xa_dir+0xd8/0x1b0 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#4/3){+.+.+.}: [<c105ea7f>] __lock_acquire+0x11ff/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a2b>] mutex_lock_nested+0x5b/0x340 [<c1141d83>] open_xa_dir+0x43/0x1b0 [<c1142722>] reiserfs_for_each_xattr+0x62/0x260 [<c114299a>] reiserfs_delete_xattrs+0x1a/0x60 [<c111ea1f>] reiserfs_delete_inode+0x9f/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10c0a00>] sys_unlink+0x10/0x20 [<c1002ec4>] sysenter_do_call+0x12/0x32 -> #0 (&REISERFS_SB(s)->lock){+.+.+.}: [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a2b>] mutex_lock_nested+0x5b/0x340 [<c11432b9>] reiserfs_write_lock_once+0x29/0x50 [<c1117012>] reiserfs_lookup+0x62/0x140 [<c10bd85f>] __lookup_hash+0xef/0x110 [<c10bf21d>] lookup_one_len+0x8d/0xc0 [<c1141e2a>] open_xa_dir+0xea/0x1b0 [<c1141fe5>] xattr_lookup+0x15/0x160 [<c1142476>] reiserfs_xattr_get+0x56/0x2a0 [<c1144042>] reiserfs_get_acl+0xa2/0x360 [<c114461a>] reiserfs_cache_default_acl+0x3a/0x160 [<c111789c>] reiserfs_mkdir+0x6c/0x2c0 [<c10bea96>] vfs_mkdir+0xd6/0x180 [<c10c0c10>] sys_mkdirat+0xc0/0xd0 [<c10c0c40>] sys_mkdir+0x20/0x30 [<c1002ec4>] sysenter_do_call+0x12/0x32 other info that might help us debug this: 2 locks held by cp/3204: #0: (&sb->s_type->i_mutex_key#4/1){+.+.+.}, at: [<c10bd8d6>] lookup_create+0x26/0xa0 #1: (&sb->s_type->i_mutex_key#4/3){+.+.+.}, at: [<c1141e18>] open_xa_dir+0xd8/0x1b0 stack backtrace: Pid: 3204, comm: cp Not tainted 2.6.32-atom #173 Call Trace: [<c13ff993>] ? printk+0x18/0x1a [<c105d33a>] print_circular_bug+0xca/0xd0 [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105d3aa>] ? check_usage+0x6a/0x460 [<c105f2c8>] lock_acquire+0x68/0x90 [<c11432b9>] ? reiserfs_write_lock_once+0x29/0x50 [<c11432b9>] ? reiserfs_write_lock_once+0x29/0x50 [<c1401a2b>] mutex_lock_nested+0x5b/0x340 [<c11432b9>] ? reiserfs_write_lock_once+0x29/0x50 [<c11432b9>] reiserfs_write_lock_once+0x29/0x50 [<c1117012>] reiserfs_lookup+0x62/0x140 [<c105ccca>] ? debug_check_no_locks_freed+0x8a/0x140 [<c105cbe4>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10bd85f>] __lookup_hash+0xef/0x110 [<c10bf21d>] lookup_one_len+0x8d/0xc0 [<c1141e2a>] open_xa_dir+0xea/0x1b0 [<c1141fe5>] xattr_lookup+0x15/0x160 [<c1142476>] reiserfs_xattr_get+0x56/0x2a0 [<c1144042>] reiserfs_get_acl+0xa2/0x360 [<c10ca2e7>] ? new_inode+0x27/0xa0 [<c114461a>] reiserfs_cache_default_acl+0x3a/0x160 [<c1402eb7>] ? _spin_unlock+0x27/0x40 [<c111789c>] reiserfs_mkdir+0x6c/0x2c0 [<c10c7cb8>] ? __d_lookup+0x108/0x190 [<c105c932>] ? mark_held_locks+0x62/0x80 [<c1401c8d>] ? mutex_lock_nested+0x2bd/0x340 [<c10bd17a>] ? generic_permission+0x1a/0xa0 [<c11788fe>] ? security_inode_permission+0x1e/0x20 [<c10bea96>] vfs_mkdir+0xd6/0x180 [<c10c0c10>] sys_mkdirat+0xc0/0xd0 [<c10505c6>] ? up_read+0x16/0x30 [<c1002fd8>] ? restore_all_notrace+0x0/0x18 [<c10c0c40>] sys_mkdir+0x20/0x30 [<c1002ec4>] sysenter_do_call+0x12/0x32 Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02reiserfs: Fix reiserfs lock <-> i_mutex dependency inversion on xattrFrederic Weisbecker
While deleting the xattrs of an inode, we hold the reiserfs lock and grab the inode->i_mutex of the targeted inode and the root private xattr directory. Later on, we may relax the reiserfs lock for various reasons, this creates inverted dependencies. We can remove the reiserfs lock -> i_mutex dependency by relaxing the former before calling open_xa_dir(). This is fine because the lookup and creation of xattr private directories done in open_xa_dir() are covered by the targeted inode mutexes. And deeper operations in the tree are still done under the write lock. This fixes the following lockdep report: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-atom #173 ------------------------------------------------------- cp/3204 is trying to acquire lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<c11432b9>] reiserfs_write_lock_once+0x29/0x50 but task is already holding lock: (&sb->s_type->i_mutex_key#4/3){+.+.+.}, at: [<c1141e18>] open_xa_dir+0xd8/0x1b0 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#4/3){+.+.+.}: [<c105ea7f>] __lock_acquire+0x11ff/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a2b>] mutex_lock_nested+0x5b/0x340 [<c1141d83>] open_xa_dir+0x43/0x1b0 [<c1142722>] reiserfs_for_each_xattr+0x62/0x260 [<c114299a>] reiserfs_delete_xattrs+0x1a/0x60 [<c111ea1f>] reiserfs_delete_inode+0x9f/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10c0a00>] sys_unlink+0x10/0x20 [<c1002ec4>] sysenter_do_call+0x12/0x32 -> #0 (&REISERFS_SB(s)->lock){+.+.+.}: [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105f2c8>] lock_acquire+0x68/0x90 [<c1401a2b>] mutex_lock_nested+0x5b/0x340 [<c11432b9>] reiserfs_write_lock_once+0x29/0x50 [<c1117012>] reiserfs_lookup+0x62/0x140 [<c10bd85f>] __lookup_hash+0xef/0x110 [<c10bf21d>] lookup_one_len+0x8d/0xc0 [<c1141e2a>] open_xa_dir+0xea/0x1b0 [<c1141fe5>] xattr_lookup+0x15/0x160 [<c1142476>] reiserfs_xattr_get+0x56/0x2a0 [<c1144042>] reiserfs_get_acl+0xa2/0x360 [<c114461a>] reiserfs_cache_default_acl+0x3a/0x160 [<c111789c>] reiserfs_mkdir+0x6c/0x2c0 [<c10bea96>] vfs_mkdir+0xd6/0x180 [<c10c0c10>] sys_mkdirat+0xc0/0xd0 [<c10c0c40>] sys_mkdir+0x20/0x30 [<c1002ec4>] sysenter_do_call+0x12/0x32 other info that might help us debug this: 2 locks held by cp/3204: #0: (&sb->s_type->i_mutex_key#4/1){+.+.+.}, at: [<c10bd8d6>] lookup_create+0x26/0xa0 #1: (&sb->s_type->i_mutex_key#4/3){+.+.+.}, at: [<c1141e18>] open_xa_dir+0xd8/0x1b0 stack backtrace: Pid: 3204, comm: cp Not tainted 2.6.32-atom #173 Call Trace: [<c13ff993>] ? printk+0x18/0x1a [<c105d33a>] print_circular_bug+0xca/0xd0 [<c105f176>] __lock_acquire+0x18f6/0x19e0 [<c105d3aa>] ? check_usage+0x6a/0x460 [<c105f2c8>] lock_acquire+0x68/0x90 [<c11432b9>] ? reiserfs_write_lock_once+0x29/0x50 [<c11432b9>] ? reiserfs_write_lock_once+0x29/0x50 [<c1401a2b>] mutex_lock_nested+0x5b/0x340 [<c11432b9>] ? reiserfs_write_lock_once+0x29/0x50 [<c11432b9>] reiserfs_write_lock_once+0x29/0x50 [<c1117012>] reiserfs_lookup+0x62/0x140 [<c105ccca>] ? debug_check_no_locks_freed+0x8a/0x140 [<c105cbe4>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10bd85f>] __lookup_hash+0xef/0x110 [<c10bf21d>] lookup_one_len+0x8d/0xc0 [<c1141e2a>] open_xa_dir+0xea/0x1b0 [<c1141fe5>] xattr_lookup+0x15/0x160 [<c1142476>] reiserfs_xattr_get+0x56/0x2a0 [<c1144042>] reiserfs_get_acl+0xa2/0x360 [<c10ca2e7>] ? new_inode+0x27/0xa0 [<c114461a>] reiserfs_cache_default_acl+0x3a/0x160 [<c1402eb7>] ? _spin_unlock+0x27/0x40 [<c111789c>] reiserfs_mkdir+0x6c/0x2c0 [<c10c7cb8>] ? __d_lookup+0x108/0x190 [<c105c932>] ? mark_held_locks+0x62/0x80 [<c1401c8d>] ? mutex_lock_nested+0x2bd/0x340 [<c10bd17a>] ? generic_permission+0x1a/0xa0 [<c11788fe>] ? security_inode_permission+0x1e/0x20 [<c10bea96>] vfs_mkdir+0xd6/0x180 [<c10c0c10>] sys_mkdirat+0xc0/0xd0 [<c10505c6>] ? up_read+0x16/0x30 [<c1002fd8>] ? restore_all_notrace+0x0/0x18 [<c10c0c40>] sys_mkdir+0x20/0x30 [<c1002ec4>] sysenter_do_call+0x12/0x32 v2: Don't drop reiserfs_mutex_lock_nested_safe() as we'll still need it later Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2010-01-02reiserfs: Fix reiserfs lock <-> i_xattr_sem dependency inversionFrederic Weisbecker
i_xattr_sem depends on the reiserfs lock. But after we grab i_xattr_sem, we may relax/relock the reiserfs lock while waiting on a freezed filesystem, creating a dependency inversion between the two locks. In order to avoid the i_xattr_sem -> reiserfs lock dependency, let's create a reiserfs_down_read_safe() that acts like reiserfs_mutex_lock_safe(): relax the reiserfs lock while grabbing another lock to avoid undesired dependencies induced by the heivyweight reiserfs lock. This fixes the following warning: [ 990.005931] ======================================================= [ 990.012373] [ INFO: possible circular locking dependency detected ] [ 990.013233] 2.6.33-rc1 #1 [ 990.013233] ------------------------------------------------------- [ 990.013233] dbench/1891 is trying to acquire lock: [ 990.013233] (&REISERFS_SB(s)->lock){+.+.+.}, at: [<ffffffff81159505>] reiserfs_write_lock+0x35/0x50 [ 990.013233] [ 990.013233] but task is already holding lock: [ 990.013233] (&REISERFS_I(inode)->i_xattr_sem){+.+.+.}, at: [<ffffffff8115899a>] reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [ 990.013233] which lock already depends on the new lock. [ 990.013233] [ 990.013233] [ 990.013233] the existing dependency chain (in reverse order) is: [ 990.013233] [ 990.013233] -> #1 (&REISERFS_I(inode)->i_xattr_sem){+.+.+.}: [ 990.013233] [<ffffffff81063afc>] __lock_acquire+0xf9c/0x1560 [ 990.013233] [<ffffffff8106414f>] lock_acquire+0x8f/0xb0 [ 990.013233] [<ffffffff814ac194>] down_write+0x44/0x80 [ 990.013233] [<ffffffff8115899a>] reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [<ffffffff81158e30>] reiserfs_xattr_set+0xb0/0x150 [ 990.013233] [<ffffffff8115a6aa>] user_set+0x8a/0x90 [ 990.013233] [<ffffffff8115901a>] reiserfs_setxattr+0xaa/0xb0 [ 990.013233] [<ffffffff810e2596>] __vfs_setxattr_noperm+0x36/0xa0 [ 990.013233] [<ffffffff810e26bc>] vfs_setxattr+0xbc/0xc0 [ 990.013233] [<ffffffff810e2780>] setxattr+0xc0/0x150 [ 990.013233] [<ffffffff810e289d>] sys_fsetxattr+0x8d/0xa0 [ 990.013233] [<ffffffff81002dab>] system_call_fastpath+0x16/0x1b [ 990.013233] [ 990.013233] -> #0 (&REISERFS_SB(s)->lock){+.+.+.}: [ 990.013233] [<ffffffff81063e30>] __lock_acquire+0x12d0/0x1560 [ 990.013233] [<ffffffff8106414f>] lock_acquire+0x8f/0xb0 [ 990.013233] [<ffffffff814aba77>] __mutex_lock_common+0x47/0x3b0 [ 990.013233] [<ffffffff814abebe>] mutex_lock_nested+0x3e/0x50 [ 990.013233] [<ffffffff81159505>] reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff811340e5>] reiserfs_prepare_write+0x45/0x180 [ 990.013233] [<ffffffff81158bb6>] reiserfs_xattr_set_handle+0x2a6/0x470 [ 990.013233] [<ffffffff81158e30>] reiserfs_xattr_set+0xb0/0x150 [ 990.013233] [<ffffffff8115a6aa>] user_set+0x8a/0x90 [ 990.013233] [<ffffffff8115901a>] reiserfs_setxattr+0xaa/0xb0 [ 990.013233] [<ffffffff810e2596>] __vfs_setxattr_noperm+0x36/0xa0 [ 990.013233] [<ffffffff810e26bc>] vfs_setxattr+0xbc/0xc0 [ 990.013233] [<ffffffff810e2780>] setxattr+0xc0/0x150 [ 990.013233] [<ffffffff810e289d>] sys_fsetxattr+0x8d/0xa0 [ 990.013233] [<ffffffff81002dab>] system_call_fastpath+0x16/0x1b [ 990.013233] [ 990.013233] other info that might help us debug this: [ 990.013233] [ 990.013233] 2 locks held by dbench/1891: [ 990.013233] #0: (&sb->s_type->i_mutex_key#12){+.+.+.}, at: [<ffffffff810e2678>] vfs_setxattr+0x78/0xc0 [ 990.013233] #1: (&REISERFS_I(inode)->i_xattr_sem){+.+.+.}, at: [<ffffffff8115899a>] reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [ 990.013233] stack backtrace: [ 990.013233] Pid: 1891, comm: dbench Not tainted 2.6.33-rc1 #1 [ 990.013233] Call Trace: [ 990.013233] [<ffffffff81061639>] print_circular_bug+0xe9/0xf0 [ 990.013233] [<ffffffff81063e30>] __lock_acquire+0x12d0/0x1560 [ 990.013233] [<ffffffff8115899a>] ? reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [<ffffffff8106414f>] lock_acquire+0x8f/0xb0 [ 990.013233] [<ffffffff81159505>] ? reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff8115899a>] ? reiserfs_xattr_set_handle+0x8a/0x470 [ 990.013233] [<ffffffff814aba77>] __mutex_lock_common+0x47/0x3b0 [ 990.013233] [<ffffffff81159505>] ? reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff81159505>] ? reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff81062592>] ? mark_held_locks+0x72/0xa0 [ 990.013233] [<ffffffff814ab81d>] ? __mutex_unlock_slowpath+0xbd/0x140 [ 990.013233] [<ffffffff810628ad>] ? trace_hardirqs_on_caller+0x14d/0x1a0 [ 990.013233] [<ffffffff814abebe>] mutex_lock_nested+0x3e/0x50 [ 990.013233] [<ffffffff81159505>] reiserfs_write_lock+0x35/0x50 [ 990.013233] [<ffffffff811340e5>] reiserfs_prepare_write+0x45/0x180 [ 990.013233] [<ffffffff81158bb6>] reiserfs_xattr_set_handle+0x2a6/0x470 [ 990.013233] [<ffffffff81158e30>] reiserfs_xattr_set+0xb0/0x150 [ 990.013233] [<ffffffff814abcb4>] ? __mutex_lock_common+0x284/0x3b0 [ 990.013233] [<ffffffff8115a6aa>] user_set+0x8a/0x90 [ 990.013233] [<ffffffff8115901a>] reiserfs_setxattr+0xaa/0xb0 [ 990.013233] [<ffffffff810e2596>] __vfs_setxattr_noperm+0x36/0xa0 [ 990.013233] [<ffffffff810e26bc>] vfs_setxattr+0xbc/0xc0 [ 990.013233] [<ffffffff810e2780>] setxattr+0xc0/0x150 [ 990.013233] [<ffffffff81056018>] ? sched_clock_cpu+0xb8/0x100 [ 990.013233] [<ffffffff8105eded>] ? trace_hardirqs_off+0xd/0x10 [ 990.013233] [<ffffffff810560a3>] ? cpu_clock+0x43/0x50 [ 990.013233] [<ffffffff810c6820>] ? fget+0xb0/0x110 [ 990.013233] [<ffffffff810c6770>] ? fget+0x0/0x110 [ 990.013233] [<ffffffff81002ddc>] ? sysret_check+0x27/0x62 [ 990.013233] [<ffffffff810e289d>] sys_fsetxattr+0x8d/0xa0 [ 990.013233] [<ffffffff81002dab>] system_call_fastpath+0x16/0x1b Reported-and-tested-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2009-12-16reiserfs: Fix reiserfs lock <-> inode mutex dependency inversionFrederic Weisbecker
The reiserfs lock -> inode mutex dependency gets inverted when we relax the lock while walking to the tree. To fix this, use a specialized version of reiserfs_mutex_lock_safe that takes care of mutex subclasses. Then we can grab the inode mutex with I_MUTEX_XATTR subclass without any reiserfs lock dependency. This fixes the following report: [ INFO: possible circular locking dependency detected ] 2.6.32-06793-gf405425-dirty #2 ------------------------------------------------------- mv/18566 is trying to acquire lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<c1110708>] reiserfs_write_lock+0x28= /0x40 but task is already holding lock: (&sb->s_type->i_mutex_key#5/3){+.+.+.}, at: [<c111033c>] reiserfs_for_each_xattr+0x10c/0x380 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&sb->s_type->i_mutex_key#5/3){+.+.+.}: [<c104f723>] validate_chain+0xa23/0xf70 [<c1050155>] __lock_acquire+0x4e5/0xa70 [<c105075a>] lock_acquire+0x7a/0xa0 [<c134c76f>] mutex_lock_nested+0x5f/0x2b0 [<c11102b4>] reiserfs_for_each_xattr+0x84/0x380 [<c1110615>] reiserfs_delete_xattrs+0x15/0x50 [<c10ef57f>] reiserfs_delete_inode+0x8f/0x140 [<c10a565c>] generic_delete_inode+0x9c/0x150 [<c10a574d>] generic_drop_inode+0x3d/0x60 [<c10a4667>] iput+0x47/0x50 [<c109cc0b>] do_unlinkat+0xdb/0x160 [<c109cca0>] sys_unlink+0x10/0x20 [<c1002c50>] sysenter_do_call+0x12/0x36 -> #0 (&REISERFS_SB(s)->lock){+.+.+.}: [<c104fc68>] validate_chain+0xf68/0xf70 [<c1050155>] __lock_acquire+0x4e5/0xa70 [<c105075a>] lock_acquire+0x7a/0xa0 [<c134c76f>] mutex_lock_nested+0x5f/0x2b0 [<c1110708>] reiserfs_write_lock+0x28/0x40 [<c1103d6b>] search_by_key+0x1f7b/0x21b0 [<c10e73ef>] search_by_entry_key+0x1f/0x3b0 [<c10e77f7>] reiserfs_find_entry+0x77/0x400 [<c10e81e5>] reiserfs_lookup+0x85/0x130 [<c109a144>] __lookup_hash+0xb4/0x110 [<c109b763>] lookup_one_len+0xb3/0x100 [<c1110350>] reiserfs_for_each_xattr+0x120/0x380 [<c1110615>] reiserfs_delete_xattrs+0x15/0x50 [<c10ef57f>] reiserfs_delete_inode+0x8f/0x140 [<c10a565c>] generic_delete_inode+0x9c/0x150 [<c10a574d>] generic_drop_inode+0x3d/0x60 [<c10a4667>] iput+0x47/0x50 [<c10a1c4f>] dentry_iput+0x6f/0xf0 [<c10a1d74>] d_kill+0x24/0x50 [<c10a396b>] dput+0x5b/0x120 [<c109ca89>] sys_renameat+0x1b9/0x230 [<c109cb28>] sys_rename+0x28/0x30 [<c1002c50>] sysenter_do_call+0x12/0x36 other info that might help us debug this: 2 locks held by mv/18566: #0: (&sb->s_type->i_mutex_key#5/1){+.+.+.}, at: [<c109b6ac>] lock_rename+0xcc/0xd0 #1: (&sb->s_type->i_mutex_key#5/3){+.+.+.}, at: [<c111033c>] reiserfs_for_each_xattr+0x10c/0x380 stack backtrace: Pid: 18566, comm: mv Tainted: G C 2.6.32-06793-gf405425-dirty #2 Call Trace: [<c134b252>] ? printk+0x18/0x1e [<c104e790>] print_circular_bug+0xc0/0xd0 [<c104fc68>] validate_chain+0xf68/0xf70 [<c104c8cb>] ? trace_hardirqs_off+0xb/0x10 [<c1050155>] __lock_acquire+0x4e5/0xa70 [<c105075a>] lock_acquire+0x7a/0xa0 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c134c76f>] mutex_lock_nested+0x5f/0x2b0 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c134b60a>] ? schedule+0x27a/0x440 [<c1110708>] reiserfs_write_lock+0x28/0x40 [<c1103d6b>] search_by_key+0x1f7b/0x21b0 [<c1050176>] ? __lock_acquire+0x506/0xa70 [<c1051267>] ? lock_release_non_nested+0x1e7/0x340 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c104e354>] ? trace_hardirqs_on_caller+0x124/0x170 [<c104e3ab>] ? trace_hardirqs_on+0xb/0x10 [<c1042a55>] ? T.316+0x15/0x1a0 [<c1042d2d>] ? sched_clock_cpu+0x9d/0x100 [<c10e73ef>] search_by_entry_key+0x1f/0x3b0 [<c134bf2a>] ? __mutex_unlock_slowpath+0x9a/0x120 [<c104e354>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10e77f7>] reiserfs_find_entry+0x77/0x400 [<c10e81e5>] reiserfs_lookup+0x85/0x130 [<c1042d2d>] ? sched_clock_cpu+0x9d/0x100 [<c109a144>] __lookup_hash+0xb4/0x110 [<c109b763>] lookup_one_len+0xb3/0x100 [<c1110350>] reiserfs_for_each_xattr+0x120/0x380 [<c110ffe0>] ? delete_one_xattr+0x0/0x1c0 [<c1003342>] ? math_error+0x22/0x150 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c1110615>] reiserfs_delete_xattrs+0x15/0x50 [<c1110708>] ? reiserfs_write_lock+0x28/0x40 [<c10ef57f>] reiserfs_delete_inode+0x8f/0x140 [<c10a561f>] ? generic_delete_inode+0x5f/0x150 [<c10ef4f0>] ? reiserfs_delete_inode+0x0/0x140 [<c10a565c>] generic_delete_inode+0x9c/0x150 [<c10a574d>] generic_drop_inode+0x3d/0x60 [<c10a4667>] iput+0x47/0x50 [<c10a1c4f>] dentry_iput+0x6f/0xf0 [<c10a1d74>] d_kill+0x24/0x50 [<c10a396b>] dput+0x5b/0x120 [<c109ca89>] sys_renameat+0x1b9/0x230 [<c1042d2d>] ? sched_clock_cpu+0x9d/0x100 [<c104c8cb>] ? trace_hardirqs_off+0xb/0x10 [<c1042dde>] ? cpu_clock+0x4e/0x60 [<c1350825>] ? do_page_fault+0x155/0x370 [<c1041816>] ? up_read+0x16/0x30 [<c1350825>] ? do_page_fault+0x155/0x370 [<c109cb28>] sys_rename+0x28/0x30 [<c1002c50>] sysenter_do_call+0x12/0x36 Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de>
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-14kill-the-bkl/reiserfs: fix "reiserfs lock" / "inode mutex" lock inversion ↵Frederic Weisbecker
dependency reiserfs_xattr_init is called with the reiserfs write lock held, but if the ".reiserfs_priv" entry is not created, we take the superblock root directory inode mutex until .reiserfs_priv is created. This creates a lock dependency inversion against other sites such as reiserfs_file_release() which takes an inode mutex and the reiserfs lock after. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Laurent Riffard <laurent.riffard@free.fr>
2009-09-14kill-the-bkl/reiserfs: acquire the inode mutex safelyFrederic Weisbecker
While searching a pathname, an inode mutex can be acquired in do_lookup() which calls reiserfs_lookup() which in turn acquires the write lock. On the other side reiserfs_fill_super() can acquire the write_lock and then call reiserfs_lookup_privroot() which can acquire an inode mutex (the root of the mount point). So we theoretically risk an AB - BA lock inversion that could lead to a deadlock. As for other lock dependencies found since the bkl to mutex conversion, the fix is to use reiserfs_mutex_lock_safe() which drops the lock dependency to the write lock. [ Impact: fix a possible deadlock with reiserfs ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11reiserfs: allow exposing privroot w/ xattrs enabledJeff Mahoney
This patch adds an -oexpose_privroot option to allow access to the privroot. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-17reiserfs: fixup perms when xattrs are disabledJeff Mahoney
This adds CONFIG_REISERFS_FS_XATTR protection from reiserfs_permission. This is needed to avoid warnings during file deletions and chowns with xattrs disabled. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-17reiserfs: deal with NULL xattr root w/ xattrs disabledJeff Mahoney
This avoids an Oops in open_xa_root that can occur when deleting a file with xattrs disabled. It assumes that the xattr root will be there, and that is not guaranteed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-17reiserfs: clean up ifdefsJeff Mahoney
With xattr cleanup even with xattrs disabled, much of the initial setup is still performed. Some #ifdefs are just not needed since the options they protect wouldn't be available anyway. This cleans those up. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-09reiserfs: remove privroot hiding in lookupJeff Mahoney
With Al Viro's patch to move privroot lookup to fs mount, there's no need to have special code to hide the privroot in reiserfs_lookup. I've also cleaned up the privroot hiding in reiserfs_readdir_dentry and removed the last user of reiserfs_xattrs(). Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: fixup xattr_root cachingJeff Mahoney
The xattr_root caching was broken from my previous patch set. It wouldn't cause corruption, but could cause decreased performance due to allocating a larger chunk of the journal (~ 27 blocks) than it would actually use. This patch loads the xattr root dentry at xattr initialization and creates it on-demand. Since we're using the cached dentry, there's no point in keeping lookup_or_create_dir around, so that's removed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Always lookup priv_root on reiserfs mount and keep itAl Viro
... even if it's a negative dentry. That way we can set ->d_op on root before anyone could race with us. Simplify d_compare(), while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: Expand i_mutex to enclose lookup_one_lenJeff Mahoney
2.6.30-rc3 introduced some sanity checks in the VFS code to avoid NFS bugs by ensuring that lookup_one_len is always called under i_mutex. This patch expands the i_mutex locking to enclose lookup_one_len. This was always required, but not not enforced in the reiserfs code since it does locking around the xattr interactions with the xattr_sem. This is obvious enough, and it survived an overnight 50 thread ACL test. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-30reiserfs: xattr_create is unused with xattrs disabledJeff Mahoney
This patch ifdefs xattr_create when xattrs aren't enabled. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Merge branch 'reiserfs-updates' from Jeff MahoneyLinus Torvalds
* reiserfs-updates: (35 commits) reiserfs: rename [cn]_* variables reiserfs: rename p_._ variables reiserfs: rename p_s_tb to tb reiserfs: rename p_s_inode to inode reiserfs: rename p_s_bh to bh reiserfs: rename p_s_sb to sb reiserfs: strip trailing whitespace reiserfs: cleanup path functions reiserfs: factor out buffer_info initialization reiserfs: add atomic addition of selinux attributes during inode creation reiserfs: use generic readdir for operations across all xattrs reiserfs: journaled xattrs reiserfs: use generic xattr handlers reiserfs: remove i_has_xattr_dir reiserfs: make per-inode xattr locking more fine grained reiserfs: eliminate per-super xattr lock reiserfs: simplify xattr internal file lookups/opens reiserfs: Clean up xattrs when REISERFS_FS_XATTR is unset reiserfs: remove IS_PRIVATE helpers reiserfs: remove link detection code ... Fixed up conflicts manually due to: - quota name cleanups vs variable naming changes: fs/reiserfs/inode.c fs/reiserfs/namei.c fs/reiserfs/stree.c fs/reiserfs/xattr.c - exported include header cleanups include/linux/reiserfs_fs.h
2009-03-30reiserfs: use generic readdir for operations across all xattrsJeff Mahoney
The current reiserfs xattr implementation open codes reiserfs_readdir and frees the path before calling the filldir function. Typically, the filldir function is something that modifies the file system, such as a chown or an inode deletion that also require reading of an inode associated with each direntry. Since the file system is modified, the path retained becomes invalid for the next run. In addition, it runs backwards in attempt to minimize activity. This is clearly suboptimal from a code cleanliness perspective as well as performance-wise. This patch implements a generic reiserfs_for_each_xattr that uses the generic readdir and a specific filldir routine that simply populates an array of dentries and then performs a specific operation on them. When all files have been operated on, it then calls the operation on the directory itself. The result is a noticable code reduction and better performance. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: journaled xattrsJeff Mahoney
Deadlocks are possible in the xattr code between the journal lock and the xattr sems. This patch implements journalling for xattr operations. The benefit is twofold: * It gets rid of the deadlock possibility by always ensuring that xattr write operations are initiated inside a transaction. * It corrects the problem where xattr backing files aren't considered any differently than normal files, despite the fact they are metadata. I discussed the added journal load with Chris Mason, and we decided that since xattrs (versus other journal activity) is fairly rare, the introduction of larger transactions to support journaled xattrs wouldn't be too big a deal. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use generic xattr handlersJeff Mahoney
Christoph Hellwig had asked me quite some time ago to port the reiserfs xattrs to the generic xattr interface. This patch replaces the reiserfs-specific xattr handling code with the generic struct xattr_handler. However, since reiserfs doesn't split the prefix and name when accessing xattrs, it can't leverage generic_{set,get,list,remove}xattr without needlessly reconstructing the name on the back end. Update 7/26/07: Added missing dput() to deletion path. Update 8/30/07: Added missing mark_inode_dirty when i_mode is used to represent an ACL and no previous ACL existed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove i_has_xattr_dirJeff Mahoney
With the changes to xattr root locking, the i_has_xattr_dir flag is no longer needed. This patch removes it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: make per-inode xattr locking more fine grainedJeff Mahoney
The per-inode locking can be made more fine-grained to surround just the interaction with the filesystem itself. This really only applies to protecting reads during a write, since concurrent writes are barred with inode->i_mutex at the vfs level. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: eliminate per-super xattr lockJeff Mahoney
With the switch to using inode->i_mutex locking during lookups/creation in the xattr root, the per-super xattr lock is no longer needed. This patch removes it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: simplify xattr internal file lookups/opensJeff Mahoney
The xattr file open/lookup code is needlessly complex. We can use vfs-level operations to perform the same work, and also simplify the locking constraints. The locking advantages will be exploited in future patches. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: Clean up xattrs when REISERFS_FS_XATTR is unsetJeff Mahoney
The current reiserfs xattr implementation will not clean up old xattr files if files are deleted when REISERFS_FS_XATTR is unset. This results in inaccessible lost files, wasting space. This patch compiles in basic xattr knowledge, such as how to delete them and change ownership for quota tracking. If the file system has never used xattrs, then the operation is quite fast: it returns immediately when it sees there is no .reiserfs_priv directory. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove IS_PRIVATE helpersJeff Mahoney
There are a number of helper functions for marking a reiserfs inode private that were leftover from reiserfs did its own thing wrt to private inodes. S_PRIVATE has been in the kernel for some time, so this patch removes the helpers and uses IS_PRIVATE instead. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove link detection codeJeff Mahoney
Early in the reiserfs xattr development, there was a plan to use hardlinks to save disk space for identical xattrs. That code never materialized and isn't going to, so this patch removes the detection code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: xattr reiserfs_get_page takes offset instead of indexJeff Mahoney
This patch changes reiserfs_get_page to take an offset rather than an index since no callers calculate the index differently. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: small variable cleanupJeff Mahoney
This patch removes the xinode and mapping variables from reiserfs_xattr_{get,set}. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use reiserfs_error()Jeff Mahoney
This patch makes many paths that are currently using warnings to handle the error. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_warningJeff Mahoney
ReiserFS warnings can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: make some warnings informationalJeff Mahoney
In several places, reiserfs_warning is used when there is no warning, just a notice. This patch changes some of them to indicate that the message is merely informational. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2008-10-16fs/reiserfs: use an IS_ERR test rather than a NULL testJulien Brunel
In case of error, the function open_xa_dir returns an ERR pointer, but never returns a NULL pointer. So a NULL test that comes after an IS_ERR test should be deleted. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @match_bad_null_test@ expression x, E; statement S1,S2; @@ x = open_xa_dir(...) ... when != x = E ( * if (x == NULL && ...) S1 else S2 | * if (x == NULL || ...) S1 else S2 ) // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-18fs: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
