commit 35e5cbc0af240778e61113286c019837e06aeec6 upstream.
After commit 21d8a15a (lookup_one_len: don't accept . and ..) reiserfs
started failing to delete xattrs from inode. This was due to a buggy
test for '.' and '..' in fill_with_dentries() which resulted in passing
'.' and '..' entries to lookup_one_len() in some cases. That returned
error and so we failed to iterate over all xattrs of and inode.
Fix the test in fill_with_dentries() along the lines of the one in
lookup_one_len().
Reported-by: Pawel Zawora <pzawora@gmail.com>
commit 7af11686933726e99af22901d622f9e161404e6b upstream.
Calls into highlevel quota code cannot happen under the write lock. These
calls take dqio_mutex which ranks above write lock. So drop write lock
before calling back into quota code.
commit 361d94a338a3fd0cee6a4ea32bbc427ba228e628 upstream.
Calls into reiserfs journalling code and reiserfs_get_block() need to
be protected with write lock. We remove write lock around calls to high
level quota code in the next patch so these paths would suddently become
unprotected.
commit b9e06ef2e8706fe669b51f4364e3aeed58639eb2 upstream.
In reiserfs_quota_on() we do quite some work - for example unpacking
tail of a quota file. Thus we have to hold write lock until a moment
we call back into the quota code.
[bwh: Backported to 3.2: there is no distinction between USRQUOTA and
GRPQUOTA mount options here]
commit 3bb3e1fc47aca554e7e2cc4deeddc24750987ac2 upstream.
When remounting reiserfs dquot_suspend() or dquot_resume() can be called.
These functions take dqonoff_mutex which ranks above write lock so we have
to drop it before calling into quota code.
[bwh: Backported to 3.2: adjust context]
commit 35c2a7f4908d404c9124c2efc6ada4640ca4d5d5 upstream.
Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(),
u64 inum = fid->raw[2];
which is unhelpfully reported as at the end of shmem_alloc_inode():
BUG: unable to handle kernel paging request at ffff880061cd3000
IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Call Trace:
[<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0
[<ffffffff812d77c3>] do_handle_open+0x163/0x2c0
[<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10
[<ffffffff83a5f3f8>] tracesys+0xe1/0xe6
Right, tmpfs is being stupid to access fid->raw[2] before validating that
fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may
fall at the end of a page, and the next page not be present.
But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being
careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and
could oops in the same way: add the missing fh_len checks to those.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream.
This patch fixes a crash in reiserfs_delete_xattrs during umount.
When shrink_dcache_for_umount clears the dcache from
generic_shutdown_super, delayed evictions are forced to disk. If an
evicted inode has extended attributes associated with it, it will
need to walk the xattr tree to locate and remove them.
But since shrink_dcache_for_umount will BUG if it encounters active
dentries, the xattr tree must be released before it's called or it will
crash during every umount.
This patch forces the evictions to occur before generic_shutdown_super
by calling shrink_dcache_sb first. The additional evictions caused
by the removal of each associated xattr file and dir will be automatically
handled as they're added to the LRU list.
CC: reiserfs-devel@vger.kernel.org
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit a06d789b424190e9f59da391681f908486db2554 upstream.
When jqfmt mount option is not specified on remount, we mistakenly clear
s_jquota_fmt value stored in superblock. Fix the problem.
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits)
MAINTAINERS: linux-m32r is moderated for non-subscribers
linux@lists.openrisc.net is moderated for non-subscribers
Drop default from "DM365 codec select" choice
parisc: Kconfig: cleanup Kernel page size default
Kconfig: remove redundant CONFIG_ prefix on two symbols
cris: remove arch/cris/arch-v32/lib/nand_init.S
microblaze: add missing CONFIG_ prefixes
h8300: drop puzzling Kconfig dependencies
MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers
tty: drop superfluous dependency in Kconfig
ARM: mxc: fix Kconfig typo 'i.MX51'
Fix file references in Kconfig files
aic7xxx: fix Kconfig references to READMEs
Fix file references in drivers/ide/
thinkpad_acpi: Fix printk typo 'bluestooth'
bcmring: drop commented out line in Kconfig
btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888'
doc: raw1394: Trivial typo fix
CIFS: Don't free volume_info->UNC until we are entirely done with it.
treewide: Correct spelling of successfully in comments
Fast-forward merge with Linus to be able to merge patches
based on more recent version of the tree.
Acked-by: Alex Elder <aelder@sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/ima-2.6 into next
fs/attr.c
Resolve conflict manually.
Signed-off-by: James Morris <jmorris@namei.org>
... so that &inode->i_mode could be passed to it
so we can pass &inode->i_mode to it
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
Use hweight_long() to count free bits in the bitmap.
Using __test_and_{set,clear}_bit_le() with ignoring its return value can
be replaced with __{set,clear}_bit_le().
This introduces reiserfs_{set,clear}_le_bit for __{set,clear}_bit_le and
does the above change with them.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: take the ACL checks to common code
bury posix_acl_..._masq() variants
kill boilerplates around posix_acl_create_masq()
generic_acl: no need to clone acl just to push it to set_cached_acl()
kill boilerplate around posix_acl_chmod_masq()
reiserfs: cache negative ACLs for v1 stat format
xfs: cache negative ACLs if there is no attribute fork
9p: do no return 0 from ->check_acl without actually checking
vfs: move ACL cache lookup into generic code
CIFS: Fix oops while mounting with prefixpath
xfs: Fix wrong return value of xfs_file_aio_write
fix devtmpfs race
caam: don't pass bogus S_IFCHR to debugfs_create_...()
get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose
asus-wmi: ->is_visible() can't return negative
fix jffs2 ACLs on big-endian with 16bit mode_t
9p: close ACL leaks
ocfs2_init_acl(): fix a leak
VFS : mount lock scalability for internal mounts
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with
modified clone, on failure releases acl and replaces with NULL.
Returns 0 or -ve on error. All callers of posix_acl_create_masq()
switched.
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified
clone or with NULL if that has failed; returns 0 or -ve on error. All
callers of posix_acl_chmod_masq() switched to that - they'd been doing
exactly the same thing.
Always set up a negative ACL cache entry if the inode can't have ACLs.
That behaves much better than doing this check inside ->check_acl.
Also remove the left over MAY_NOT_BLOCK check.
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits)
block: strict rq_affinity
backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu
block: fix patch import error in max_discard_sectors check
block: reorder request_queue to remove 64 bit alignment padding
CFQ: add think time check for group
CFQ: add think time check for service tree
CFQ: move think time check variables to a separate struct
fixlet: Remove fs_excl from struct task.
cfq: Remove special treatment for metadata rqs.
block: document blk_plug list access
block: avoid building too big plug list
compat_ioctl: fix make headers_check regression
block: eliminate potential for infinite loop in blkdev_issue_discard
compat_ioctl: fix warning caused by qemu
block: flush MEDIA_CHANGE from drivers on close(2)
blk-throttle: Make total_nr_queued unsigned
block: Add __attribute__((format(printf...) and fix fallout
fs/partitions/check.c: make local symbols static
block:remove some spare spaces in genhd.c
block:fix the comment error in blkdev.h
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
Change the default reiserfs mount option to barrier=flush. Based on a patch
from Jeff Mahoney in the SuSE tree.
Simple filesystems always pass inode->i_sb_bdev as the block device
argument, and never need a end_io handler. Let's simply things for
them and for my grepping activity by dropping these arguments. The
only thing not falling into that scheme is ext4, which passes and
end_io handler without needing special flags (yet), but given how
messy the direct I/O code there is use of __blockdev_direct_IO
in one instead of two out of three cases isn't going to make a large
difference anyway.
Let filesystems handle waiting for direct I/O requests themselves instead
of doing it beforehand. This means filesystem-specific locks to prevent
new dio referenes from appearing can be held. This is important to allow
generalizing i_dio_count to non-DIO_LOCKING filesystems.
i_alloc_sem is a rather special rw_semaphore. It's the last one that may
be released by a non-owner, and it's write side is always mirrored by
real exclusion. It's intended use it to wait for all pending direct I/O
requests to finish before starting a truncate.
Replace it with a hand-grown construct:
- exclusion for truncates is already guaranteed by i_mutex, so it can
simply fall way
- the reader side is replaced by an i_dio_count member in struct inode
that counts the number of pending direct I/O requests. Truncate can't
proceed as long as it's non-zero
- when i_dio_count reaches non-zero we wake up a pending truncate using
wake_up_bit on a new bit in i_flags
- new references to i_dio_count can't appear while we are waiting for
it to read zero because the direct I/O count always needs i_mutex
(or an equivalent like XFS's i_iolock) for starting a new operation.
This scheme is much simpler, and saves the space of a spinlock_t and a
struct list_head in struct inode (typically 160 bits on a non-debug 64-bit
system).
not used by the instances anymore.
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of
them removes that bit.
not used in the instances anymore.
its value depends only on inode and does not change; we might as
well store it in ->i_op->check_acl and be done with that.
This patch changes the security_inode_init_security API by adding a
filesystem specific callback to write security extended attributes.
This change is in preparation for supporting the initialization of
multiple LSM xattrs and the EVM xattr. Initially the callback function
walks an array of xattrs, writing each xattr separately, but could be
optimized to write multiple xattrs at once.
For existing security_inode_init_security() calls, which have not yet
been converted to use the new callback function, such as those in
reiserfs and ocfs2, this patch defines security_old_inode_init_security().
Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
fs_excl is a poor man's priority inheritance for filesystems to hint to
the block layer that an operation is important. It was never clearly
specified, not widely adopted, and will not prevent starvation in many
cases (like across cgroups).
fs_excl was introduced with the time sliced CFQ IO scheduler, to
indicate when a process held FS exclusive resources and thus needed
a boost.
It doesn't cover all file systems, and it was never fully complete.
Lets kill it.
Signed-off-by: Justin TerAvest <teravest@google.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
nothing blocking other than generic_permission() (and
check_acl callback does bail out in RCU mode).
Reiserfs does not have problems with references to unlinked directories.
Signed-off-by: Sage Weil <sage@newdream.net>
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or
anything else, so that the filesystem can track internally if it
needs to push out a transaction for fdatasync or not.
This is just the prototype change with no user for it yet. I plan
to push large XFS changes for the next merge window, and getting
this trivial infrastructure in this window would help a lot to avoid
tree interdependencies.
Also remove incorrect comments that ->dirty_inode can't block. That
has been changed a long time ago, and many implementations rely on it.
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
This serves no useful purpose that I can discern. All callers (rename,
rmdir) hold their own reference to the dentry.
A quick audit of all file systems showed no relevant checks on the value
of d_count in vfs_rmdir/vfs_rename_dir paths.
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits)
video: change to new flag variable
scsi: change to new flag variable
rtc: change to new flag variable
rapidio: change to new flag variable
pps: change to new flag variable
net: change to new flag variable
misc: change to new flag variable
message: change to new flag variable
memstick: change to new flag variable
isdn: change to new flag variable
ieee802154: change to new flag variable
ide: change to new flag variable
hwmon: change to new flag variable
dma: change to new flag variable
char: change to new flag variable
fs: change to new flag variable
xtensa: change to new flag variable
um: change to new flag variables
s390: change to new flag variable
mips: change to new flag variable
Fix up trivial conflict in drivers/hwmon/Makefile
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y
for cleaner conditional inclusion.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits)
AppArmor: kill unused macros in lsm.c
AppArmor: cleanup generated files correctly
KEYS: Add an iovec version of KEYCTL_INSTANTIATE
KEYS: Add a new keyctl op to reject a key with a specified error code
KEYS: Add a key type op to permit the key description to be vetted
KEYS: Add an RCU payload dereference macro
AppArmor: Cleanup make file to remove cruft and make it easier to read
SELinux: implement the new sb_remount LSM hook
LSM: Pass -o remount options to the LSM
SELinux: Compute SID for the newly created socket
SELinux: Socket retains creator role and MLS attribute
SELinux: Auto-generate security_is_socket_class
TOMOYO: Fix memory leak upon file open.
Revert "selinux: simplify ioctl checking"
selinux: drop unused packet flow permissions
selinux: Fix packet forwarding checks on postrouting
selinux: Fix wrong checks for selinux_policycap_netpeer
selinux: Fix check for xfrm selinux context algorithm
ima: remove unnecessary call to ima_must_measure
IMA: remove IMA imbalance checking
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: fix build failure introduced by s/freezeable/freezable/
workqueue: add system_freezeable_wq
rds/ib: use system_wq instead of rds_ib_fmr_wq
net/9p: replace p9_poll_task with a work
net/9p: use system_wq instead of p9_mux_wq
xfs: convert to alloc_workqueue()
reiserfs: make commit_wq use the default concurrency level
ocfs2: use system_wq instead of ocfs2_quota_wq
ext4: convert to alloc_workqueue()
scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path
scsi/be2iscsi,qla2xxx: convert to alloc_workqueue()
misc/iwmc3200top: use system_wq instead of dedicated workqueues
i2o: use alloc_workqueue() instead of create_workqueue()
acpi: kacpi*_wq don't need WQ_MEM_RECLAIM
fs/aio: aio_wq isn't used in memory reclaim path
input/tps6507x-ts: use system_wq instead of dedicated workqueue
cpufreq: use system_wq instead of dedicated workqueues
wireless/ipw2x00: use system_wq instead of dedicated workqueues
arm/omap: use system_wq in mailbox
workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
