path: root/fs/reiserfs
2013-09-24reiserfs: fix race with flush_used_journal_lists and flush_journal_listJeff Mahoney
There are two locks involved in managing the journal lists. The general reiserfs_write_lock and the journal->j_flush_mutex. While flush_journal_list is sleeping to acquire the j_flush_mutex or to submit a block for write, it will drop the write lock. This allows another thread to acquire the write lock and ultimately call flush_used_journal_lists to traverse the list of journal lists and select one for flushing. It can select the journal_list that has just had flush_journal_list called on it in the original thread and call it again with the same journal_list. The second thread then drops the write lock to acquire j_flush_mutex and the first thread reacquires it and continues execution and eventually clears and frees the journal list before dropping j_flush_mutex and returning. The second thread acquires j_flush_mutex and ends up operating on a journal_list that has already been released. If the memory hasn't been reused, we'll soon after hit a BUG_ON because the transaction id has already been cleared. If it's been reused, we'll crash in other fun ways. Since flush_journal_list will synchronize on j_flush_mutex, we can fix the race by taking a proper reference in flush_used_journal_lists and checking to see if it's still valid after the mutex is taken. It's safe to iterate the list of journal lists and pick a list with just the write lock as long as a reference is taken on the journal list before we drop the lock. We already have code to handle whether a transaction has been flushed already so we can use that to handle the race and get rid of the trans_id BUG_ON. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-24reiserfs: remove useless flush_old_journal_listsJeff Mahoney
Commit a3172027 introduced test_transaction as a requirement for flushing old lists -- but it can never return 1 unless the transaction has already been flushed. As a result, we have a routine that iterates the j_realblocks list but doesn't actually do anything. Since it's been this way since 2006 and the latency numbers were what Chris expected, let's just rip it out. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-09-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3, reiserfs, udf & isofs fixes from Jan Kara: "The contains a bunch of ext3 cleanups and minor improvements, major reiserfs locking changes which should hopefully fix deadlocks introduced by BKL removal, and udf/isofs changes to refuse mounting fs rw instead of mounting it ro automatically which makes eject button work as expected for all media (see the changelog for why userspace should be ok with this change)" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: jbd: use a single printk for jbd_debug() reiserfs: locking, release lock around quota operations reiserfs: locking, handle nested locks properly reiserfs: locking, push write lock out of xattr code jbd: relocate assert after state lock in journal_commit_transaction() udf: Refuse RW mount of the filesystem instead of making it RO udf: Standardize return values in mount sequence isofs: Refuse RW mount of the filesystem instead of making it RO ext3: allow specifying external journal by pathname mount option jbd: remove unneeded semicolon
2013-08-08reiserfs: locking, release lock around quota operationsJeff Mahoney
Previous commits released the write lock across quota operations but missed several places. In particular, the free operations can also call into the file system code and take the write lock, causing deadlocks. This patch introduces some more helpers and uses them for quota call sites. Without this patch applied, reiserfs + quotas runs into deadlocks under anything more than trivial load. Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2013-08-08reiserfs: locking, handle nested locks properlyJeff Mahoney
The reiserfs write lock replaced the BKL and uses similar semantics. Frederic's locking code makes a distinction between when the lock is nested and when it's being acquired/released, but I don't think that's the right distinction to make. The right distinction is between the lock being released at end-of-use and the lock being released for a schedule. The unlock should return the depth and the lock should restore it, rather than the other way around as it is now. This patch implements that and adds a number of places where the lock should be dropped. Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2013-08-08reiserfs: locking, push write lock out of xattr codeJeff Mahoney
The reiserfs xattr code doesn't need the write lock and sleeps all over the place. We can simplify the locking by releasing it and reacquiring after the xattr call. Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2013-08-05reiserfs: fix deadlock in umountAl Viro
Since remove_proc_entry() started to wait for IO in progress (i.e. since 2007 or so), the locking in fs/reiserfs/proc.c became wrong; if procfs read happens between the moment when umount() locks the victim superblock and removal of /proc/fs/reiserfs/<device>/*, we'll get a deadlock - read will wait for s_umount (in sget(), called by r_start()), while umount will wait in remove_proc_entry() for that read to finish, holding s_umount all along. Fortunately, the same change allows a much simpler race avoidance - all we need to do is remove the procfs entries in the very beginning of reiserfs ->kill_sb(); that'll guarantee that pointer to superblock will remain valid for the duration for procfs IO, so we don't need sget() to keep the sucker alive. As the matter of fact, we can get rid of the home-grown iterator completely, and use single_open() instead. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 update from Ted Ts'o: "Lots of bug fixes, cleanups and optimizations. In the bug fixes category, of note is a fix for on-line resizing file systems where the block size is smaller than the page size (i.e., file systems 1k blocks on x86, or more interestingly file systems with 4k blocks on Power or ia64 systems.) In the cleanup category, the ext4's punch hole implementation was significantly improved by Lukas Czerner, and now supports bigalloc file systems. In addition, Jan Kara significantly cleaned up the write submission code path. We also improved error checking and added a few sanity checks. In the optimizations category, two major optimizations deserve mention. The first is that ext4_writepages() is now used for nodelalloc and ext3 compatibility mode. This allows writes to be submitted much more efficiently as a single bio request, instead of being sent as individual 4k writes into the block layer (which then relied on the elevator code to coalesce the requests in the block queue). Secondly, the extent cache shrink mechanism, which was introduce in 3.9, no longer has a scalability bottleneck caused by the i_es_lru spinlock. Other optimizations include some changes to reduce CPU usage and to avoid issuing empty commits unnecessarily." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits) ext4: optimize starting extent in ext4_ext_rm_leaf() jbd2: invalidate handle if jbd2_journal_restart() fails ext4: translate flag bits to strings in tracepoints ext4: fix up error handling for mpage_map_and_submit_extent() jbd2: fix theoretical race in jbd2__journal_restart ext4: only zero partial blocks in ext4_zero_partial_blocks() ext4: check error return from ext4_write_inline_data_end() ext4: delete unnecessary C statements ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree() jbd2: move superblock checksum calculation to jbd2_write_superblock() ext4: pass inode pointer instead of file pointer to punch hole ext4: improve free space calculation for inline_data ext4: reduce object size when !CONFIG_PRINTK ext4: improve extent cache shrink mechanism to avoid to burn CPU time ext4: implement error handling of ext4_mb_new_preallocation() ext4: fix corruption when online resizing a fs with 1K block size ext4: delete unused variables ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents jbd2: remove debug dependency on debug_fs and update Kconfig help text jbd2: use a single printk for jbd_debug() ...
2013-06-29reiserfs: switch reiserfs_readdir_dentry to inodeAl Viro
... and clean the callers up a bit Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29reiserfs: is_privroot_deh() needs only directory inode, actuallyAl Viro
... and that - only to get the superblock. Privroot is a directory and we don't allow hardlinks to those... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert reiserfsAl Viro
2013-05-31reiserfs: fix deadlock with nfs racing on create/lookupJeff Mahoney
Reiserfs is currently able to be deadlocked by having two NFS clients where one has removed and recreated a file and another is accessing the file with an open file handle. If one client deletes and recreates a file with timing such that the recreated file obtains the same [dirid, objectid] pair as the original file while another client accesses the file via file handle, the create and lookup can race and deadlock if the lookup manages to create the in-memory inode first. The create thread, in insert_inode_locked4, will hold the write lock while waiting on the other inode to be unlocked. The lookup thread, anywhere in the iget path, will release and reacquire the write lock while it schedules. If it needs to reacquire the lock while the create thread has it, it will never be able to make forward progress because it needs to reacquire the lock before ultimately unlocking the inode. This patch drops the write lock across the insert_inode_locked4 call so that the ordering of inode_wait -> write lock is retained. Since this would have been the case before the BKL push-down, this is safe. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-31reiserfs: fix problems with chowning setuid file w/ xattrsJeff Mahoney
reiserfs_chown_xattrs() takes the iattr struct passed into ->setattr and uses it to iterate over all the attrs associated with a file to change ownership of xattrs (and transfer quota associated with the xattr files). When the setuid bit is cleared during chown, ATTR_MODE and iattr->ia_mode are passed to all the xattrs as well. This means that the xattr directory will have S_IFREG added to its mode bits. This has been prevented in practice by a missing IS_PRIVATE check in reiserfs_acl_chmod, which caused a double-lock to occur while holding the write lock. Since the file system was completely locked up, the writeout of the corrupted mode never happened. This patch temporarily clears everything but ATTR_UID|ATTR_GID for the calls to reiserfs_setattr and adds the missing IS_PRIVATE check. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-31reiserfs: fix spurious multiple-fill in reiserfs_readdir_dentryJeff Mahoney
After sleeping for filldir(), we check to see if the file system has changed and research. The next_pos pointer is updated but its value isn't pushed into the key used for the search itself. As a result, the search returns the same item that the last cycle of the loop did and filldir() is called multiple times with the same data. The end result is that the buffer can contain the same name multiple times. This can be returned to userspace or used internally in the xattr code where it can manifest with the following warning: jdm-20004 reiserfs_delete_xattrs: Couldn't delete all xattrs (-2) reiserfs_for_each_xattr uses reiserfs_readdir_dentry to iterate over the xattr names and ends up trying to unlink the same name twice. The second attempt fails with -ENOENT and the error is returned. At some point I'll need to add support into reiserfsck to remove the orphaned directories left behind when this occurs. The fix is to push the value into the key before researching. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-05-21reiserfs: use ->invalidatepage() length argumentLukas Czerner
->invalidatepage() aop now accepts range to invalidate so we can make use of it in reiserfs_invalidatepage() Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: reiserfs-devel@vger.kernel.org
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-05-07Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge more incoming from Andrew Morton: - Various fixes which were stalled or which I picked up recently - A large rotorooting of the AIO code. Allegedly to improve performance but I don't really have good performance numbers (I might have lost the email) and I can't raise Kent today. I held this out of 3.9 and we could give it another cycle if it's all too late/scary. I ended up taking only the first two thirds of the AIO rotorooting. I left the percpu parts and the batch completion for later. - Linus * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (33 commits) aio: don't include aio.h in sched.h aio: kill ki_retry aio: kill ki_key aio: give shared kioctx fields their own cachelines aio: kill struct aio_ring_info aio: kill batch allocation aio: change reqs_active to include unreaped completions aio: use cancellation list lazily aio: use flush_dcache_page() aio: make aio_read_evt() more efficient, convert to hrtimers wait: add wait_event_hrtimeout() aio: refcounting cleanup aio: make aio_put_req() lockless aio: do fget() after aio_get_req() aio: dprintk() -> pr_debug() aio: move private stuff out of aio.h aio: add kiocb_cancel() aio: kill return value of aio_complete() char: add aio_{read,write} to /dev/{null,zero} aio: remove retry-based AIO ...
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07make blkdev_put() return voidAl Viro
same story as with the previous patches - note that return value of blkdev_close() is lost, since there's nowhere the caller (__fput()) could return it to. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-01reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()David Howells
Don't access the proc_dir_entry in ReiserFS's r_open(), r_start() r_show() procfs interface functions. ReiserFS stores the ->show() method pointer in PDE->data and the super_block pointer in PDE->parent->data. This isn't changing. Currently, ReiserFS passes the PDE pointer into seq_file::private from r_open() so that r_start() and r_show() can then access it. Instead, use seq_open_private() to allocate a two-pointer struct that's passed through seq_file::private and put the ->show() method and the sb pointers in there. Signed-off-by: David Howells <dhowells@redhat.com> cc: reiserfs-devel@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Add proc_mkdir_data()David Howells
Add proc_mkdir_data() to allow procfs directories to be created that are annotated at the time of creation with private data rather than doing this post-creation. This means no access is then required to the proc_dir_entry struct to set this. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> cc: Neela Syam Kolli <megaraidlinux@lsi.com> cc: Jerry Chuang <jerry-chuang@realtek.com> cc: linux-scsi@vger.kernel.org cc: devel@driverdev.osuosl.org cc: linux-wireless@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09reiserfs: use proc_remove_subtree()Al Viro
2013-04-09reiserfs: don't wank with EFBIG before calling do_sync_write()Al Viro
look for file_capable() in there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-29reiserfs: Fix warning and inode leak when deleting inode with xattrsJan Kara
After commit 21d8a15a (lookup_one_len: don't accept . and ..) reiserfs started failing to delete xattrs from inode. This was due to a buggy test for '.' and '..' in fill_with_dentries() which resulted in passing '.' and '..' entries to lookup_one_len() in some cases. That returned error and so we failed to iterate over all xattrs of and inode. Fix the test in fill_with_dentries() along the lines of the one in lookup_one_len(). Reported-by: Pawel Zawora <pzawora@gmail.com> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2013-03-11reiserfs: Use kstrdup instead of kmalloc/strcpyIonut-Gabriel Radu
Signed-off-by: Ionut-Gabriel Radu <ihonius@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26fs: encode_fh: return FILEID_INVALID if invalid fid_typeNamjae Jeon
This patch is a follow up on below patch: [PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63 Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Vivek Trivedi <t.vivek@samsung.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Sage Weil <sage@inktank.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-20reiserfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-19reiserfs: Move quota calls out of write lockJan Kara
Calls into highlevel quota code cannot happen under the write lock. These calls take dqio_mutex which ranks above write lock. So drop write lock before calling back into quota code. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19reiserfs: Protect reiserfs_quota_write() with write lockJan Kara
Calls into reiserfs journalling code and reiserfs_get_block() need to be protected with write lock. We remove write lock around calls to high level quota code in the next patch so these paths would suddently become unprotected. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19reiserfs: Protect reiserfs_quota_on() with write lockJan Kara
In reiserfs_quota_on() we do quite some work - for example unpacking tail of a quota file. Thus we have to hold write lock until a moment we call back into the quota code. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-11-19reiserfs: Fix lock ordering during remountJan Kara
When remounting reiserfs dquot_suspend() or dquot_resume() can be called. These functions take dqonoff_mutex which ranks above write lock so we have to drop it before calling into quota code. CC: stable@vger.kernel.org # >= 3.0 Signed-off-by: Jan Kara <jack@suse.cz>
2012-10-09tmpfs,ceph,gfs2,isofs,reiserfs,xfs: fix fh_len checkingHugh Dickins
Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(), u64 inum = fid->raw[2]; which is unhelpfully reported as at the end of shmem_alloc_inode(): BUG: unable to handle kernel paging request at ffff880061cd3000 IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Call Trace: [<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0 [<ffffffff812d77c3>] do_handle_open+0x163/0x2c0 [<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10 [<ffffffff83a5f3f8>] tracesys+0xe1/0xe6 Right, tmpfs is being stupid to access fid->raw[2] before validating that fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may fall at the end of a page, and the next page not be present. But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and could oops in the same way: add the missing fh_len checks to those. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Sage Weil <sage@inktank.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-04Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull ext3 & udf fixes from Jan Kara: "Shortlog pretty much says it all. The interesting bits are UDF support for direct IO and ext3 fix for a long standing oops in data=journal mode." * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: jbd: Fix assertion failure in commit code due to lacking transaction credits UDF: Add support for O_DIRECT ext3: Replace 0 with NULL for pointer in super.c file udf: add writepages support for udf ext3: don't clear orphan list on ro mount with errors reiserfs: Make reiserfs_xattr_handlers static
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert reiserfs to use kuid and kgid where appropriateEric W. Biederman
Cc: reiserfs-devel@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-18userns: Pass a userns parameter into posix_acl_to_xattr and posix_acl_from_xattrEric W. Biederman
- Pass the user namespace the uid and gid values in the xattr are stored in into posix_acl_from_xattr. - Pass the user namespace kuid and kgid values should be converted into when storing uid and gid values in an xattr in posix_acl_to_xattr. - Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to pass in &init_user_ns. In the short term this change is not strictly needed but it makes the code clearer. In the longer term this change is necessary to be able to mount filesystems outside of the initial user namespace that natively store posix acls in the linux xattr format. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-09-04reiserfs: Make reiserfs_xattr_handlers staticSachin Kamat
Silences the following sparse warning: fs/reiserfs/xattr.c:899:28: warning: symbol 'reiserfs_xattr_handlers' was not declared. Should it be static? Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Jan Kara <jack@suse.cz>
2012-08-15reiserfs: fix deadlocks with quotasJeff Mahoney
The BKL push-down for reiserfs made lock recursion a special case that needs to be handled explicitly. One of the cases that was unhandled is dropping the quota during inode eviction. Both reiserfs_evict_inode and reiserfs_write_dquot take the write lock, but when the journal lock is taken it only drops one the references. The locking rules are that the journal lock be acquired before the write lock so leaving the reference open leads to a ABBA deadlock. This patch pushes the unlock up before clear_inode and avoids the recursive locking. Another ABBA situation can occur when the write lock is dropped while reading the bitmap buffer while in the quota code. When the lock is reacquired, it will deadlock against dquot->dq_lock and dqopt->dqio_mutex in the dquot_acquire path. It's safe to retain the lock across the read and should be cached under write load. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-07-23don't expose I_NEW inodes via dentry->d_inodeAl Viro
d_instantiate(dentry, inode); unlock_new_inode(inode); is a bad idea; do it the other way round... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22quota: Move quota syncing to ->sync_fs methodJan Kara
Since the moment writes to quota files are using block device page cache and space for quota structures is reserved at the moment they are first accessed we have no reason to sync quota before inode writeback. In fact this order is now only harmful since quota information can easily change during inode writeback (either because conversion of delayed-allocated extents or simply because of allocation of new blocks for simple filesystems not using page_mkwrite). So move syncing of quota information after writeback of inodes into ->sync_fs method. This way we do not have to use ->quota_sync callback which is primarily intended for use by quotactl syscall anyway and we get rid of calling ->sync_fs() twice unnecessarily. We skip quota syncing for OCFS2 since it does proper quota journalling in all cases (unlike ext3, ext4, and reiserfs which also support legacy non-journalled quotas) and thus there are no dirty quota structures. CC: "Theodore Ts'o" <tytso@mit.edu> CC: Joel Becker <jlbec@evilplan.org> CC: reiserfs-devel@vger.kernel.org Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Dave Kleikamp <shaggy@kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01reiserfs: get rid of resierfs_sync_superArtem Bityutskiy
This patch stops reiserfs using the VFS 'write_super()' method along with the s_dirt flag, because they are on their way out. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblock using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
