commit 22e7478ddbcb670e33fab72d0bbe7c394c3a2c84 upstream.
Prior to commit 0e4f6a791b1e (Fix reiserfs_file_release()), reiserfs
truncates serialized on i_mutex. They mostly still do, with the exception
of reiserfs_file_release. That blocks out other writers via the tailpack
mutex and the inode openers counter adjusted in reiserfs_file_open.
However, NFS will call reiserfs_setattr without having called ->open, so
we end up with a race when nfs is calling ->setattr while another
process is releasing the file. Ultimately, it triggers the
BUG_ON(inode->i_size != new_file_size) check in maybe_indirect_to_direct.
The solution is to pull the lock into reiserfs_setattr to encompass the
truncate_setsize call as well.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 01d8885785a60ae8f4c37b0ed75bdc96d0fc6a44 upstream.
jdm-20004 reiserfs_delete_xattrs: Couldn't delete all xattrs (-2)
The -ENOENT is due to readdir calling dir_emit on the same entry twice.
If the dir_emit callback sleeps and the tree is changed underneath us,
we won't be able to trust deh_offset(deh) anymore. We need to save
next_pos before we might sleep so we can find the next entry.
This has been this way for years, and every time I stumble across it I
lose my lunch. After coming across it for the nth time in the Coverity
results, I had to overcome the bystander effect and do something about
it.
This ignores the 79 column limit in favor of making it look like C
instead of gibberish.
The correct thing to do here would be to lose some of the indentation by
breaking this function up into several smaller ones. I might do that at
some point if I have the stomach to look at this again.
(Also some of those overlong ternary operations would likely be more
readable as regular if's)
Signed-off-by: Dave Jones <davej@fedoraproject.org>
Pull vfs updates from Al Viro:
"Assorted stuff; the biggest pile here is Christoph's ACL series. Plus
assorted cleanups and fixes all over the place...
There will be another pile later this week"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits)
__dentry_path() fixes
vfs: Remove second variable named error in __dentry_path
vfs: Is mounted should be testing mnt_ns for NULL or error.
Fix race when checking i_size on direct i/o read
hfsplus: remove can_set_xattr
nfsd: use get_acl and ->set_acl
fs: remove generic_acl
nfs: use generic posix ACL infrastructure for v3 Posix ACLs
gfs2: use generic posix ACL infrastructure
jfs: use generic posix ACL infrastructure
xfs: use generic posix ACL infrastructure
reiserfs: use generic posix ACL infrastructure
ocfs2: use generic posix ACL infrastructure
jffs2: use generic posix ACL infrastructure
hfsplus: use generic posix ACL infrastructure
f2fs: use generic posix ACL infrastructure
ext2/3/4: use generic posix ACL infrastructure
btrfs: use generic posix ACL infrastructure
fs: make posix_acl_create more useful
fs: make posix_acl_chmod more useful
Also don't bother to set up a .get_acl method for symlinks as we do not
support access control (ACLs or even mode bits) for symlinks in Linux.
Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
it's never called with NULL argument...
Now that the definition is centralized in <linux/kernel.h>, the
definitions of U32_MAX (and related) elsewhere in the kernel can be
removed.
Signed-off-by: Alex Elder <elder@linaro.org>
Acked-by: Sage Weil <sage@inktank.com>
The symbol U32_MAX is defined in several spots. Change these
definitions to be conditional. This is in preparation for the next
patch, which centralizes the definition in <linux/kernel.h>.
Cc: Sage Weil <sage@inktank.com>
There are two locks involved in managing the journal lists. The general
reiserfs_write_lock and the journal->j_flush_mutex.
While flush_journal_list is sleeping to acquire the j_flush_mutex or to
submit a block for write, it will drop the write lock. This allows
another thread to acquire the write lock and ultimately call
flush_used_journal_lists to traverse the list of journal lists and
select one for flushing. It can select the journal_list that has just
had flush_journal_list called on it in the original thread and call it
again with the same journal_list.
The second thread then drops the write lock to acquire j_flush_mutex and
the first thread reacquires it and continues execution and eventually
clears and frees the journal list before dropping j_flush_mutex and
returning.
The second thread acquires j_flush_mutex and ends up operating on a
journal_list that has already been released. If the memory hasn't
been reused, we'll soon after hit a BUG_ON because the transaction id
has already been cleared. If it's been reused, we'll crash in other
fun ways.
Since flush_journal_list will synchronize on j_flush_mutex, we can fix
the race by taking a proper reference in flush_used_journal_lists
and checking to see if it's still valid after the mutex is taken. It's
safe to iterate the list of journal lists and pick a list with
just the write lock as long as a reference is taken on the journal list
before we drop the lock. We already have code to handle whether a
transaction has been flushed already so we can use that to handle the
race and get rid of the trans_id BUG_ON.
Commit a3172027 introduced test_transaction as a requirement for
flushing old lists -- but it can never return 1 unless the transaction
has already been flushed.
As a result, we have a routine that iterates the j_realblocks list but
doesn't actually do anything. Since it's been this way since 2006 and
the latency numbers were what Chris expected, let's just rip it out.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull ext3, reiserfs, udf & isofs fixes from Jan Kara:
"The contains a bunch of ext3 cleanups and minor improvements, major
reiserfs locking changes which should hopefully fix deadlocks
introduced by BKL removal, and udf/isofs changes to refuse mounting fs
rw instead of mounting it ro automatically which makes eject button
work as expected for all media (see the changelog for why userspace
should be ok with this change)"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
jbd: use a single printk for jbd_debug()
reiserfs: locking, release lock around quota operations
reiserfs: locking, handle nested locks properly
reiserfs: locking, push write lock out of xattr code
jbd: relocate assert after state lock in journal_commit_transaction()
udf: Refuse RW mount of the filesystem instead of making it RO
udf: Standardize return values in mount sequence
isofs: Refuse RW mount of the filesystem instead of making it RO
ext3: allow specifying external journal by pathname mount option
jbd: remove unneeded semicolon
Previous commits released the write lock across quota operations but
missed several places. In particular, the free operations can also
call into the file system code and take the write lock, causing
deadlocks.
This patch introduces some more helpers and uses them for quota call
sites. Without this patch applied, reiserfs + quotas runs into deadlocks
under anything more than trivial load.
The reiserfs write lock replaced the BKL and uses similar semantics.
Frederic's locking code makes a distinction between when the lock is nested
and when it's being acquired/released, but I don't think that's the right
distinction to make.
The right distinction is between the lock being released at end-of-use and
the lock being released for a schedule. The unlock should return the depth
and the lock should restore it, rather than the other way around as it is now.
This patch implements that and adds a number of places where the lock
should be dropped.
The reiserfs xattr code doesn't need the write lock and sleeps all over
the place. We can simplify the locking by releasing it and reacquiring
after the xattr call.
Since remove_proc_entry() started to wait for IO in progress (i.e.
since 2007 or so), the locking in fs/reiserfs/proc.c became wrong;
if procfs read happens between the moment when umount() locks the
victim superblock and removal of /proc/fs/reiserfs/<device>/*,
we'll get a deadlock - read will wait for s_umount (in sget(),
called by r_start()), while umount will wait in remove_proc_entry()
for that read to finish, holding s_umount all along.
Fortunately, the same change allows a much simpler race avoidance -
all we need to do is remove the procfs entries in the very beginning
of reiserfs ->kill_sb(); that'll guarantee that pointer to superblock
will remain valid for the duration for procfs IO, so we don't need
sget() to keep the sucker alive. As the matter of fact, we can
get rid of the home-grown iterator completely, and use single_open()
instead.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 update from Ted Ts'o:
"Lots of bug fixes, cleanups and optimizations. In the bug fixes
category, of note is a fix for on-line resizing file systems where the
block size is smaller than the page size (i.e., file systems 1k blocks
on x86, or more interestingly file systems with 4k blocks on Power or
ia64 systems.)
In the cleanup category, the ext4's punch hole implementation was
significantly improved by Lukas Czerner, and now supports bigalloc
file systems. In addition, Jan Kara significantly cleaned up the
write submission code path. We also improved error checking and added
a few sanity checks.
In the optimizations category, two major optimizations deserve
mention. The first is that ext4_writepages() is now used for
nodelalloc and ext3 compatibility mode. This allows writes to be
submitted much more efficiently as a single bio request, instead of
being sent as individual 4k writes into the block layer (which then
relied on the elevator code to coalesce the requests in the block
queue). Secondly, the extent cache shrink mechanism, which was
introduce in 3.9, no longer has a scalability bottleneck caused by the
i_es_lru spinlock. Other optimizations include some changes to reduce
CPU usage and to avoid issuing empty commits unnecessarily."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (86 commits)
ext4: optimize starting extent in ext4_ext_rm_leaf()
jbd2: invalidate handle if jbd2_journal_restart() fails
ext4: translate flag bits to strings in tracepoints
ext4: fix up error handling for mpage_map_and_submit_extent()
jbd2: fix theoretical race in jbd2__journal_restart
ext4: only zero partial blocks in ext4_zero_partial_blocks()
ext4: check error return from ext4_write_inline_data_end()
ext4: delete unnecessary C statements
ext3,ext4: don't mess with dir_file->f_pos in htree_dirblock_to_tree()
jbd2: move superblock checksum calculation to jbd2_write_superblock()
ext4: pass inode pointer instead of file pointer to punch hole
ext4: improve free space calculation for inline_data
ext4: reduce object size when !CONFIG_PRINTK
ext4: improve extent cache shrink mechanism to avoid to burn CPU time
ext4: implement error handling of ext4_mb_new_preallocation()
ext4: fix corruption when online resizing a fs with 1K block size
ext4: delete unused variables
ext4: return FIEMAP_EXTENT_UNKNOWN for delalloc extents
jbd2: remove debug dependency on debug_fs and update Kconfig help text
jbd2: use a single printk for jbd_debug()
... and clean the callers up a bit
... and that - only to get the superblock. Privroot is a directory
and we don't allow hardlinks to those...
Reiserfs is currently able to be deadlocked by having two NFS clients
where one has removed and recreated a file and another is accessing the
file with an open file handle.
If one client deletes and recreates a file with timing such that the
recreated file obtains the same [dirid, objectid] pair as the original
file while another client accesses the file via file handle, the create
and lookup can race and deadlock if the lookup manages to create the
in-memory inode first.
The create thread, in insert_inode_locked4, will hold the write lock
while waiting on the other inode to be unlocked. The lookup thread,
anywhere in the iget path, will release and reacquire the write lock while
it schedules. If it needs to reacquire the lock while the create thread
has it, it will never be able to make forward progress because it needs
to reacquire the lock before ultimately unlocking the inode.
This patch drops the write lock across the insert_inode_locked4 call so
that the ordering of inode_wait -> write lock is retained. Since this
would have been the case before the BKL push-down, this is safe.
reiserfs_chown_xattrs() takes the iattr struct passed into ->setattr
and uses it to iterate over all the attrs associated with a file to change
ownership of xattrs (and transfer quota associated with the xattr files).
When the setuid bit is cleared during chown, ATTR_MODE and iattr->ia_mode
are passed to all the xattrs as well. This means that the xattr directory
will have S_IFREG added to its mode bits.
This has been prevented in practice by a missing IS_PRIVATE check
in reiserfs_acl_chmod, which caused a double-lock to occur while holding
the write lock. Since the file system was completely locked up, the
writeout of the corrupted mode never happened.
This patch temporarily clears everything but ATTR_UID|ATTR_GID for the
calls to reiserfs_setattr and adds the missing IS_PRIVATE check.
After sleeping for filldir(), we check to see if the file system has
changed and research. The next_pos pointer is updated but its value
isn't pushed into the key used for the search itself. As a result,
the search returns the same item that the last cycle of the loop did
and filldir() is called multiple times with the same data.
The end result is that the buffer can contain the same name multiple
times. This can be returned to userspace or used internally in the
xattr code where it can manifest with the following warning:
reiserfs_for_each_xattr uses reiserfs_readdir_dentry to iterate over
the xattr names and ends up trying to unlink the same name twice. The
second attempt fails with -ENOENT and the error is returned. At some
point I'll need to add support into reiserfsck to remove the orphaned
directories left behind when this occurs.
The fix is to push the value into the key before researching.
->invalidatepage() aop now accepts range to invalidate so we can make
use of it in reiserfs_invalidatepage()
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Cc: reiserfs-devel@vger.kernel.org
Currently there is no way to truncate partial page where the end
truncate point is not at the end of the page. This is because it was not
needed and the functionality was enough for file system truncate
operation to work properly. However more file systems now support punch
hole feature and it can benefit from mm supporting truncating page just
up to the certain point.
Specifically, with this functionality truncate_inode_pages_range() can
be changed so it supports truncating partial page at the end of the
range (currently it will BUG_ON() if 'end' is not at the end of the
page).
This commit changes the invalidatepage() address space operation
prototype to accept range to be invalidated and update all the instances
for it.
We also change the block_invalidatepage() in the same way and actually
make a use of the new length argument implementing range invalidation.
Actual file system implementations will follow except the file systems
where the changes are really simple and should not change the behaviour
in any way .Implementation for truncate_page_range() which will be able
to accept page unaligned ranges will follow as well.
Merge more incoming from Andrew Morton:
- Various fixes which were stalled or which I picked up recently
- A large rotorooting of the AIO code. Allegedly to improve
performance but I don't really have good performance numbers (I might
have lost the email) and I can't raise Kent today. I held this out
of 3.9 and we could give it another cycle if it's all too late/scary.
I ended up taking only the first two thirds of the AIO rotorooting. I
left the percpu parts and the batch completion for later. - Linus
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (33 commits)
aio: don't include aio.h in sched.h
aio: kill ki_retry
aio: kill ki_key
aio: give shared kioctx fields their own cachelines
aio: kill struct aio_ring_info
aio: kill batch allocation
aio: change reqs_active to include unreaped completions
aio: use cancellation list lazily
aio: use flush_dcache_page()
aio: make aio_read_evt() more efficient, convert to hrtimers
wait: add wait_event_hrtimeout()
aio: refcounting cleanup
aio: make aio_put_req() lockless
aio: do fget() after aio_get_req()
aio: dprintk() -> pr_debug()
aio: move private stuff out of aio.h
aio: add kiocb_cancel()
aio: kill return value of aio_complete()
char: add aio_{read,write} to /dev/{null,zero}
aio: remove retry-based AIO
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
same story as with the previous patches - note that return
value of blkdev_close() is lost, since there's nowhere the
caller (__fput()) could return it to.
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
Don't access the proc_dir_entry in ReiserFS's r_open(), r_start() r_show()
procfs interface functions.
ReiserFS stores the ->show() method pointer in PDE->data and the super_block
pointer in PDE->parent->data. This isn't changing.
Currently, ReiserFS passes the PDE pointer into seq_file::private from
r_open() so that r_start() and r_show() can then access it. Instead, use
seq_open_private() to allocate a two-pointer struct that's passed through
seq_file::private and put the ->show() method and the sb pointers in there.
cc: reiserfs-devel@vger.kernel.org
Add proc_mkdir_data() to allow procfs directories to be created that are
annotated at the time of creation with private data rather than doing this
post-creation. This means no access is then required to the proc_dir_entry
struct to set this.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
cc: Neela Syam Kolli <megaraidlinux@lsi.com>
cc: Jerry Chuang <jerry-chuang@realtek.com>
cc: linux-scsi@vger.kernel.org
cc: devel@driverdev.osuosl.org
cc: linux-wireless@vger.kernel.org
look for file_capable() in there...
After commit 21d8a15a (lookup_one_len: don't accept . and ..) reiserfs
started failing to delete xattrs from inode. This was due to a buggy
test for '.' and '..' in fill_with_dentries() which resulted in passing
'.' and '..' entries to lookup_one_len() in some cases. That returned
error and so we failed to iterate over all xattrs of and inode.
Fix the test in fill_with_dentries() along the lines of the one in
lookup_one_len().
Reported-by: Pawel Zawora <pzawora@gmail.com>
CC: stable@vger.kernel.org
Signed-off-by: Ionut-Gabriel Radu <ihonius@gmail.com>
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Reported-by: Kees Cook <keescook@google.com>
This patch is a follow up on below patch:
[PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type
commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Vivek Trivedi <t.vivek@samsung.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Removed vmtruncate
Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com>
Calls into highlevel quota code cannot happen under the write lock. These
calls take dqio_mutex which ranks above write lock. So drop write lock
before calling back into quota code.
CC: stable@vger.kernel.org # >= 3.0
Calls into reiserfs journalling code and reiserfs_get_block() need to
be protected with write lock. We remove write lock around calls to high
level quota code in the next patch so these paths would suddently become
unprotected.
In reiserfs_quota_on() we do quite some work - for example unpacking
tail of a quota file. Thus we have to hold write lock until a moment
we call back into the quota code.
When remounting reiserfs dquot_suspend() or dquot_resume() can be called.
These functions take dqonoff_mutex which ranks above write lock so we have
to drop it before calling into quota code.
Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(),
u64 inum = fid->raw[2];
which is unhelpfully reported as at the end of shmem_alloc_inode():
BUG: unable to handle kernel paging request at ffff880061cd3000
IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40
Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Call Trace:
[<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0
[<ffffffff812d77c3>] do_handle_open+0x163/0x2c0
[<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10
[<ffffffff83a5f3f8>] tracesys+0xe1/0xe6
Right, tmpfs is being stupid to access fid->raw[2] before validating that
fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may
fall at the end of a page, and the next page not be present.
But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being
careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and
could oops in the same way: add the missing fh_len checks to those.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: stable@vger.kernel.org
Pull ext3 & udf fixes from Jan Kara:
"Shortlog pretty much says it all.
The interesting bits are UDF support for direct IO and ext3 fix for a
long standing oops in data=journal mode."
jbd: Fix assertion failure in commit code due to lacking transaction credits
UDF: Add support for O_DIRECT
ext3: Replace 0 with NULL for pointer in super.c file
udf: add writepages support for udf
ext3: don't clear orphan list on ro mount with errors
reiserfs: Make reiserfs_xattr_handlers static
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
There's no reason to call rcu_barrier() on every
deactivate_locked_super(). We only need to make sure that all delayed rcu
free inodes are flushed before we destroy related cache.
Removing rcu_barrier() from deactivate_locked_super() affects some fast
paths. E.g. on my machine exit_group() of a last process in IPC
namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
