path: root/fs/reiserfs
2012-01-12reiserfs: Force inode evictions before umount to avoid crashJeff Mahoney
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream. This patch fixes a crash in reiserfs_delete_xattrs during umount. When shrink_dcache_for_umount clears the dcache from generic_shutdown_super, delayed evictions are forced to disk. If an evicted inode has extended attributes associated with it, it will need to walk the xattr tree to locate and remove them. But since shrink_dcache_for_umount will BUG if it encounters active dentries, the xattr tree must be released before it's called or it will crash during every umount. This patch forces the evictions to occur before generic_shutdown_super by calling shrink_dcache_sb first. The additional evictions caused by the removal of each associated xattr file and dir will be automatically handled as they're added to the LRU list. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12reiserfs: Fix quota mount option parsingJan Kara
commit a06d789b424190e9f59da391681f908486db2554 upstream. When jqfmt mount option is not specified on remount, we mistakenly clear s_jquota_fmt value stored in superblock. Fix the problem. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-20reiserfs_permission() doesn't need to bail out in RCU modeAl Viro
nothing blocking other than generic_permission() (and check_acl callback does bail out in RCU mode). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28reiserfs: remove unnecessary dentry_unhash from rmdir, dir renameSage Weil
Reiserfs does not have problems with references to unlinked directories. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27fs: pass exact type of data dirties to ->dirty_inodeChristoph Hellwig
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or anything else, so that the filesystem can track internally if it needs to push out a transaction for fdatasync or not. This is just the prototype change with no user for it yet. I plan to push large XFS changes for the next merge window, and getting this trivial infrastructure in this window would help a lot to avoid tree interdependencies. Also remove incorrect comments that ->dirty_inode can't block. That has been changed a long time ago, and many implementations rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: remove dget() from dentry_unhash()Sage Weil
This serves no useful purpose that I can discern. All callers (rename, rmdir) hold their own reference to the dentry. A quick audit of all file systems showed no relevant checks on the value of d_count in vfs_rmdir/vfs_rename_dir paths. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-16Merge branch 'next' into for-linusJames Morris
2011-03-15fs: Remove i_nlink check from file system link callbackAneesh Kumar K.V
Now that VFS check for inode->i_nlink == 0 and returns proper error, remove similar check from file system Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10reiserfs xattr ->d_revalidate() shouldn't care about RCUAl Viro
... it returns an error unconditionally Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-03fix reiserfs mkdir() breakageAl Viro
if directory has so many subdirectories that its link count is set to 1 (i.e. "can't tell accurately") and reiserfs_new_inode() fails, we shouldn't decrement the parent's link count in cleanup path; that's what DEC_DIR_INODE_NLINK() is for. As it is, we end up with parent suddenly getting zero i_nlink, with very unpleasant effects. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-02-01reiserfs: make commit_wq use the default concurrency levelTejun Heo
The maximum number of concurrent work items queued on commit_wq is bound by the number of active journals. Convert to alloc_workqueue() and use the default concurrency level so that they can be processed in parallel. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: reiserfs-devel@vger.kernel.org
2011-01-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Fix deadlock during path resolution
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-13reiserfs: make sure va_end() is always called after va_start().Jesper Juhl
A call to va_start() must always be followed by a call to va_end() in the same function. In fs/reiserfs/prints.c::print_block() this is not always the case. If 'bh' is NULL we'll return without calling va_end(). One could add a call to va_end() before the 'return' statement, but it's nicer to just move the call to va_start() after the test for 'bh' being NULL. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12quota: Fix deadlock during path resolutionJan Kara
As Al Viro pointed out path resolution during Q_QUOTAON calls to quotactl is prone to deadlocks. We hold s_umount semaphore for reading during the path resolution and resolution itself may need to acquire the semaphore for writing when e. g. autofs mountpoint is passed. Solve the problem by performing the resolution before we get hold of the superblock (and thus s_umount semaphore). The whole thing is complicated by the fact that some filesystems (OCFS2) ignore the path argument. So to distinguish between filesystem which want the path and which do not we introduce new .quota_on_meta callback which does not get the path. OCFS2 then uses this callback instead of old .quota_on. CC: Al Viro <viro@ZenIV.linux.org.uk> CC: Christoph Hellwig <hch@lst.de> CC: Ted Ts'o <tytso@mit.edu> CC: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-02reiserfs: don't acquire lock recursively in reiserfs_acl_chmodFrederic Weisbecker
reiserfs_acl_chmod() can be called by reiserfs_set_attr() and then take the reiserfs lock a second time. Thereafter it may call journal_begin() that definitely requires the lock not to be nested in order to release it before taking the journal mutex because the reiserfs lock depends on the journal mutex already. So, aviod nesting the lock in reiserfs_acl_chmod(). Reported-by: Pawel Zawora <pzawora@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Pawel Zawora <pzawora@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: <stable@kernel.org> [2.6.32.x+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-25reiserfs: fix inode mutex - reiserfs lock misorderingFrederic Weisbecker
reiserfs_unpack() locks the inode mutex with reiserfs_mutex_lock_safe() to protect against reiserfs lock dependency. However this protection requires to have the reiserfs lock to be locked. This is the case if reiserfs_unpack() is called by reiserfs_ioctl but not from reiserfs_quota_on() when it tries to unpack tails of quota files. Fix the ordering of the two locks in reiserfs_unpack() to fix this issue. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: Markus Gapp <markus.gapp@gmx.net> Reported-by: Jan Kara <jack@suse.cz> Cc: Jeff Mahoney <jeffm@suse.com> Cc: <stable@kernel.org> [2.6.36.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-13block: clean up blkdev_get() wrappers and their usersTejun Heo
After recent blkdev_get() modifications, open_by_devnum() and open_bdev_exclusive() are simple wrappers around blkdev_get(). Replace them with blkdev_get_by_dev() and blkdev_get_by_path(). blkdev_get_by_dev() is identical to open_by_devnum(). blkdev_get_by_path() is slightly different in that it doesn't automatically add %FMODE_EXCL to @mode. All users are converted. Most conversions are mechanical and don't introduce any behavior difference. There are several exceptions. * btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no reason to OR it explicitly on blkdev_put(). * gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in sb->s_mode. * With the above changes, sb->s_mode now always should contain FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect errors. The new blkdev_get_*() functions are with proper docbook comments. While at it, add function description to blkdev_get() too. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Philipp Reisner <philipp.reisner@linbit.com> Cc: Neil Brown <neilb@suse.de> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Joern Engel <joern@lazybastard.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jan Kara <jack@suse.cz> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: reiserfs-devel@vger.kernel.org Cc: xfs-masters@oss.sgi.com Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2010-11-13block: make blkdev_get/put() handle exclusive accessTejun Heo
Over time, block layer has accumulated a set of APIs dealing with bdev open, close, claim and release. * blkdev_get/put() are the primary open and close functions. * bd_claim/release() deal with exclusive open. * open/close_bdev_exclusive() are combination of open and claim and the other way around, respectively. * bd_link/unlink_disk_holder() to create and remove holder/slave symlinks. * open_by_devnum() wraps bdget() + blkdev_get(). The interface is a bit confusing and the decoupling of open and claim makes it impossible to properly guarantee exclusive access as in-kernel open + claim sequence can disturb the existing exclusive open even before the block layer knows the current open if for another exclusive access. Reorganize the interface such that, * blkdev_get() is extended to include exclusive access management. @holder argument is added and, if is @FMODE_EXCL specified, it will gain exclusive access atomically w.r.t. other exclusive accesses. * blkdev_put() is similarly extended. It now takes @mode argument and if @FMODE_EXCL is set, it releases an exclusive access. Also, when the last exclusive claim is released, the holder/slave symlinks are removed automatically. * bd_claim/release() and close_bdev_exclusive() are no longer necessary and either made static or removed. * bd_link_disk_holder() remains the same but bd_unlink_disk_holder() is no longer necessary and removed. * open_bdev_exclusive() becomes a simple wrapper around lookup_bdev() and blkdev_get(). It also has an unexpected extra bdev_read_only() test which probably should be moved into blkdev_get(). * open_by_devnum() is modified to take @holder argument and pass it to blkdev_get(). Most of bdev open/close operations are unified into blkdev_get/put() and most exclusive accesses are tested atomically at the open time (as it should). This cleans up code and removes some, both valid and invalid, but unnecessary all the same, corner cases. open_bdev_exclusive() and open_by_devnum() can use further cleanup - rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop special features. Well, let's leave them for another day. Most conversions are straight-forward. drbd conversion is a bit more involved as there was some reordering, but the logic should stay the same. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Brown <neilb@suse.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Philipp Reisner <philipp.reisner@linbit.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jan Kara <jack@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Alex Elder <aelder@sgi.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: dm-devel@redhat.com Cc: drbd-dev@lists.linbit.com Cc: Leo Chen <leochen@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Joern Engel <joern@logfs.org> Cc: reiserfs-devel@vger.kernel.org Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25new helper: inode_unhashed()Al Viro
note: for race-free uses you inode_lock held Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-19Merge branch 'v2.6.36-rc8' into for-2.6.37/barrierJens Axboe
Conflicts: block/blk-core.c drivers/block/loop.c mm/swapfile.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-01reiserfs: fix unwanted reiserfs lock recursionFrederic Weisbecker
Prevent from recursively locking the reiserfs lock in reiserfs_unpack() because we may call journal_begin() that requires the lock to be taken only once, otherwise it won't be able to release the lock while taking other mutexes, ending up in inverted dependencies between the journal mutex and the reiserfs lock for example. This fixes: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.35.4.4a #3 ------------------------------------------------------- lilo/1620 is trying to acquire lock: (&journal->j_mutex){+.+...}, at: [<d0325bff>] do_journal_begin_r+0x7f/0x340 [reiserfs] but task is already holding lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a278>] reiserfs_write_lock+0x28/0x40 [reiserfs] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&REISERFS_SB(s)->lock){+.+.+.}: [<c10562b7>] lock_acquire+0x67/0x80 [<c12facad>] __mutex_lock_common+0x4d/0x410 [<c12fb0c8>] mutex_lock_nested+0x18/0x20 [<d032a278>] reiserfs_write_lock+0x28/0x40 [reiserfs] [<d0325c06>] do_journal_begin_r+0x86/0x340 [reiserfs] [<d0325f77>] journal_begin+0x77/0x140 [reiserfs] [<d0315be4>] reiserfs_remount+0x224/0x530 [reiserfs] [<c10b6a20>] do_remount_sb+0x60/0x110 [<c10cee25>] do_mount+0x625/0x790 [<c10cf014>] sys_mount+0x84/0xb0 [<c12fca3d>] syscall_call+0x7/0xb -> #0 (&journal->j_mutex){+.+...}: [<c10560f6>] __lock_acquire+0x1026/0x1180 [<c10562b7>] lock_acquire+0x67/0x80 [<c12facad>] __mutex_lock_common+0x4d/0x410 [<c12fb0c8>] mutex_lock_nested+0x18/0x20 [<d0325bff>] do_journal_begin_r+0x7f/0x340 [reiserfs] [<d0325f77>] journal_begin+0x77/0x140 [reiserfs] [<d0326271>] reiserfs_persistent_transaction+0x41/0x90 [reiserfs] [<d030d06c>] reiserfs_get_block+0x22c/0x1530 [reiserfs] [<c10db9db>] __block_prepare_write+0x1bb/0x3a0 [<c10dbbe6>] block_prepare_write+0x26/0x40 [<d030b738>] reiserfs_prepare_write+0x88/0x170 [reiserfs] [<d03294d6>] reiserfs_unpack+0xe6/0x120 [reiserfs] [<d0329782>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3188>] vfs_ioctl+0x28/0xa0 [<c10c3bbd>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3eb3>] sys_ioctl+0x63/0x70 [<c12fca3d>] syscall_call+0x7/0xb other info that might help us debug this: 2 locks held by lilo/1620: #0: (&sb->s_type->i_mutex_key#8){+.+.+.}, at: [<d032945a>] reiserfs_unpack+0x6a/0x120 [reiserfs] #1: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a278>] reiserfs_write_lock+0x28/0x40 [reiserfs] stack backtrace: Pid: 1620, comm: lilo Not tainted 2.6.35.4.4a #3 Call Trace: [<c10560f6>] __lock_acquire+0x1026/0x1180 [<c10562b7>] lock_acquire+0x67/0x80 [<c12facad>] __mutex_lock_common+0x4d/0x410 [<c12fb0c8>] mutex_lock_nested+0x18/0x20 [<d0325bff>] do_journal_begin_r+0x7f/0x340 [reiserfs] [<d0325f77>] journal_begin+0x77/0x140 [reiserfs] [<d0326271>] reiserfs_persistent_transaction+0x41/0x90 [reiserfs] [<d030d06c>] reiserfs_get_block+0x22c/0x1530 [reiserfs] [<c10db9db>] __block_prepare_write+0x1bb/0x3a0 [<c10dbbe6>] block_prepare_write+0x26/0x40 [<d030b738>] reiserfs_prepare_write+0x88/0x170 [reiserfs] [<d03294d6>] reiserfs_unpack+0xe6/0x120 [reiserfs] [<d0329782>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3188>] vfs_ioctl+0x28/0xa0 [<c10c3bbd>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3eb3>] sys_ioctl+0x63/0x70 [<c12fca3d>] syscall_call+0x7/0xb Reported-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: All since 2.6.32 <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-01reiserfs: fix dependency inversion between inode and reiserfs mutexesFrederic Weisbecker
The reiserfs mutex already depends on the inode mutex, so we can't lock the inode mutex in reiserfs_unpack() without using the safe locking API, because reiserfs_unpack() is always called with the reiserfs mutex locked. This fixes: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.35c #13 ------------------------------------------------------- lilo/1606 is trying to acquire lock: (&sb->s_type->i_mutex_key#8){+.+.+.}, at: [<d0329450>] reiserfs_unpack+0x60/0x110 [reiserfs] but task is already holding lock: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a268>] reiserfs_write_lock+0x28/0x40 [reiserfs] which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&REISERFS_SB(s)->lock){+.+.+.}: [<c1056347>] lock_acquire+0x67/0x80 [<c12f083d>] __mutex_lock_common+0x4d/0x410 [<c12f0c58>] mutex_lock_nested+0x18/0x20 [<d032a268>] reiserfs_write_lock+0x28/0x40 [reiserfs] [<d0329e9a>] reiserfs_lookup_privroot+0x2a/0x90 [reiserfs] [<d0316b81>] reiserfs_fill_super+0x941/0xe60 [reiserfs] [<c10b7d17>] get_sb_bdev+0x117/0x170 [<d0313e21>] get_super_block+0x21/0x30 [reiserfs] [<c10b74ba>] vfs_kern_mount+0x6a/0x1b0 [<c10b7659>] do_kern_mount+0x39/0xe0 [<c10cebe0>] do_mount+0x340/0x790 [<c10cf0b4>] sys_mount+0x84/0xb0 [<c12f25cd>] syscall_call+0x7/0xb -> #0 (&sb->s_type->i_mutex_key#8){+.+.+.}: [<c1056186>] __lock_acquire+0x1026/0x1180 [<c1056347>] lock_acquire+0x67/0x80 [<c12f083d>] __mutex_lock_common+0x4d/0x410 [<c12f0c58>] mutex_lock_nested+0x18/0x20 [<d0329450>] reiserfs_unpack+0x60/0x110 [reiserfs] [<d0329772>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3228>] vfs_ioctl+0x28/0xa0 [<c10c3c5d>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3f53>] sys_ioctl+0x63/0x70 [<c12f25cd>] syscall_call+0x7/0xb other info that might help us debug this: 1 lock held by lilo/1606: #0: (&REISERFS_SB(s)->lock){+.+.+.}, at: [<d032a268>] reiserfs_write_lock+0x28/0x40 [reiserfs] stack backtrace: Pid: 1606, comm: lilo Not tainted 2.6.35c #13 Call Trace: [<c1056186>] __lock_acquire+0x1026/0x1180 [<c1056347>] lock_acquire+0x67/0x80 [<c12f083d>] __mutex_lock_common+0x4d/0x410 [<c12f0c58>] mutex_lock_nested+0x18/0x20 [<d0329450>] reiserfs_unpack+0x60/0x110 [reiserfs] [<d0329772>] reiserfs_ioctl+0x272/0x320 [reiserfs] [<c10c3228>] vfs_ioctl+0x28/0xa0 [<c10c3c5d>] do_vfs_ioctl+0x32d/0x5c0 [<c10c3f53>] sys_ioctl+0x63/0x70 [<c12f25cd>] syscall_call+0x7/0xb Reported-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: <stable@kernel.org> [2.6.32 and later] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10reiserfs: replace barriers with explicit flush / FUA usageChristoph Hellwig
Switch to the WRITE_FLUSH_FUA flag for log writes and remove the EOPNOTSUPP detection for barriers. Note that reiserfs had a fairly different code path for barriers before as it wa the only filesystem actually making use of them. The new code always uses the old non-barrier codepath and just sets the WRITE_FLUSH_FUA explicitly for the journal commits. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
