[ Upstream commit 073931017b49d9458aa351605b43a7e34598caef ]
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Philipp Hahn <hahn@univention.de>
[ Upstream commit 31051c85b5e2aaaf6315f74c72a732673632a905 ]
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
References: CVE-2015-1350
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream.
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull quota and udf updates from Jan Kara:
"The pull contains quota changes which complete unification of XFS and
VFS quota interfaces (so tools can use either interface to manipulate
any filesystem). There's also a patch to support project quotas in
VFS quota subsystem from Li Xi.
Finally there's a bunch of UDF fixes and cleanups and tiny cleanup in
reiserfs & ext3"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: (21 commits)
udf: Update ctime and mtime when directory is modified
udf: return correct errno for udf_update_inode()
ext3: Remove useless condition in if statement.
vfs: Add general support to enforce project quota limits
reiserfs: fix __RASSERT format string
udf: use int for allocated blocks instead of sector_t
udf: remove redundant buffer_head.h includes
udf: remove else after return in __load_block_bitmap()
udf: remove unused variable in udf_table_free_blocks()
quota: Fix maximum quota limit settings
quota: reorder flags in quota state
quota: paranoia: check quota tree root
quota: optimize i_dquot access
quota: Hook up Q_XSETQLIM for id 0 to ->set_info
xfs: Add support for Q_SETINFO
quota: Make ->set_info use structure with neccesary info to VFS and XFS
quota: Remove ->get_xstate and ->get_xstatev callbacks
gfs2: Convert to using ->get_state callback
xfs: Convert to using ->get_state callback
quota: Wire up Q_GETXSTATE and Q_GETXSTATV calls to work with ->get_state
that's the bulk of filesystem drivers dealing with inodes of their own
Now that no one is using rw, remove it completely.
Signed-off-by: Omar Sandoval <osandov@osandov.com>
The rw parameter to direct_IO is redundant with iov_iter->type, and
treated slightly differently just about everywhere it's used: some users
do rw & WRITE, and others do rw == WRITE where they should be doing a
bitwise check. Simplify this with the new iov_iter_rw() helper, which
always returns either READ or WRITE.
Most filesystems call through to these at some point, so we'll start
here.
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
struct kiocb now is a generic I/O container, so move it to fs.h.
Also do a #include diet for aio.h while we're at it.
__RASSERT format string does not use the PID argument. reiserfs_panic
arguments are therefore formatted with the wrong format specifier (for
example __LINE__ with %s). This bug was introduced when commit
c3a9c2109f84 ("reiserfs: rework reiserfs_panic") removed a
"reiserfs[%i]" prefix.
This bug is only triggered when using CONFIG_REISERFS_CHECK, otherwise
__RASSERT is never used.
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Acked-by: Jeff Mahoney <jeffm@suse.com>
Create new internal interface for getting information about quota which
contains everything needed for both VFS quotas and XFS quotas. Make VFS
use this and hook it up to Q_GETINFO.
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Fix sparse warning:
fs/reiserfs/inode.c:2769:19: warning: Using plain integer as NULL pointer
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Pull isofs and reiserfs fixes from Jan Kara:
"A reiserfs and an isofs fix. They arrived after I sent you my first
pull request and I don't want to delay them unnecessarily till rc2"
isofs: Fix infinite looping over CE entries
reiserfs: destroy allocated commit workqueue
When resirefs is trying to mount a partition, it creates a commit
workqueue (sbi->commit_wq). But when mount fails later, the workqueue
is not freed.
Reported-by: auxsvr@gmail.com
Reported-by: Benoît Monin <benoit.monin@gmx.fr>
Cc: Jan Kara <jack@suse.cz>
Cc: stable@vger.kernel.org # >= 3.16
Cc: reiserfs-devel@vger.kernel.org
Fixes: 797d9016ceca69879bb273218810fa0beef46aac
Pull trivial tree update from Jiri Kosina:
"Usual stuff: documentation updates, printk() fixes, etc"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits)
intel_ips: fix a type in error message
cpufreq: cpufreq-dt: Move newline to end of error message
ps3rom: fix error return code
treewide: fix typo in printk and Kconfig
ARM: dts: bcm63138: change "interupts" to "interrupts"
Replace mentions of "list_struct" to "list_head"
kernel: trace: fix printk message
scsi: mpt2sas: fix ioctl in comment
zbud, zswap: change module author email
clocksource: Fix 'clcoksource' typo in comment
arm: fix wording of "Crotex" in CONFIG_ARCH_EXYNOS3 help
gpio: msm-v1: make boolean argument more obvious
usb: Fix typo in usb-serial-simple.c
PCI: Fix comment typo 'COMFIG_PM_OPS'
powerpc: Fix comment typo 'CONIFG_8xx'
powerpc: Fix comment typos 'CONFiG_ALTIVEC'
clk: st: Spelling s/stucture/structure/
isci: Spelling s/stucture/structure/
usb: gadget: zero: Spelling s/infrastucture/infrastructure/
treewide: Fix company name in module descriptions
Pull VFS changes from Al Viro:
"First pile out of several (there _definitely_ will be more). Stuff in
this one:
- unification of d_splice_alias()/d_materialize_unique()
- iov_iter rewrite
- killing a bunch of ->f_path.dentry users (and f_dentry macro).
Getting that completed will make life much simpler for
unionmount/overlayfs, since then we'll be able to limit the places
sensitive to file _dentry_ to reasonably few. Which allows to have
file_inode(file) pointing to inode in a covered layer, with dentry
pointing to (negative) dentry in union one.
Still not complete, but much closer now.
- crapectomy in lustre (dead code removal, mostly)
- "let's make seq_printf return nothing" preparations
- assorted cleanups and fixes
There _definitely_ will be more piles"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
copy_from_iter_nocache()
new helper: iov_iter_kvec()
csum_and_copy_..._iter()
iov_iter.c: handle ITER_KVEC directly
iov_iter.c: convert copy_to_iter() to iterate_and_advance
iov_iter.c: convert copy_from_iter() to iterate_and_advance
iov_iter.c: get rid of bvec_copy_page_{to,from}_iter()
iov_iter.c: convert iov_iter_zero() to iterate_and_advance
iov_iter.c: convert iov_iter_get_pages_alloc() to iterate_all_kinds
iov_iter.c: convert iov_iter_get_pages() to iterate_all_kinds
iov_iter.c: convert iov_iter_npages() to iterate_all_kinds
iov_iter.c: iterate_and_advance
iov_iter.c: macros for iterating over iov_iter
kill f_dentry macro
dcache: fix kmemcheck warning in switch_names
new helper: audit_file()
nfsd_vfs_write(): use file_inode()
ncpfs: use file_inode()
kill f_dentry uses
lockd: get rid of ->f_path.dentry->d_sb
This patch fix spelling typo in printk and Kconfig within
various part of kernel sources.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
CC: reiserfs-devel@vger.kernel.org
CC: Jeff Mahoney <jeffm@suse.de>
Acked-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Merge conditional unlock/lock in the same condition to avoid sparse
warning:
fs/reiserfs/journal.c:703:36: warning: context imbalance in 'add_to_chunk' - unexpected unlock
Cc: Jeff Mahoney <jeffm@suse.com>
Pull vfs updates from Al Viro:
"The big thing in this pile is Eric's unmount-on-rmdir series; we
finally have everything we need for that. The final piece of prereqs
is delayed mntput() - now filesystem shutdown always happens on
shallow stack.
Other than that, we have several new primitives for iov_iter (Matt
Wilcox, culled from his XIP-related series) pushing the conversion to
->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c
cleanups and fixes (including the external name refcounting, which
gives consistent behaviour of d_move() wrt procfs symlinks for long
and short names alike) and assorted cleanups and fixes all over the
place.
This is just the first pile; there's a lot of stuff from various
people that ought to go in this window. Starting with
unionmount/overlayfs mess... ;-/"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits)
fs/file_table.c: Update alloc_file() comment
vfs: Deduplicate code shared by xattr system calls operating on paths
reiserfs: remove pointless forward declaration of struct nameidata
don't need that forward declaration of struct nameidata in dcache.h anymore
take dname_external() into fs/dcache.c
let path_init() failures treated the same way as subsequent link_path_walk()
fix misuses of f_count() in ppp and netlink
ncpfs: use list_for_each_entry() for d_subdirs walk
vfs: move getname() from callers to do_mount()
gfs2_atomic_open(): skip lookups on hashed dentry
[infiniband] remove pointless assignments
gadgetfs: saner API for gadgetfs_create_file()
f_fs: saner API for ffs_sb_create_file()
jfs: don't hash direct inode
[s390] remove pointless assignment of ->f_op in vmlogrdr ->open()
ecryptfs: ->f_op is never NULL
android: ->f_op is never NULL
nouveau: __iomem misannotations
missing annotation in fs/file.c
fs: namespace: suppress 'may be used uninitialized' warnings
MAXQUOTAS value defines maximum number of quota types VFS supports.
This isn't necessarily the number of types reiserfs supports and with
addition of project quotas these two numbers stop matching. So make
reiserfs use its private definition.
Pull quota, reiserfs, UDF updates from Jan Kara:
"Scalability improvements for quota, a few reiserfs fixes, and couple
of misc cleanups (udf, ext2)"
reiserfs: Fix use after free in journal teardown
reiserfs: fix corruption introduced by balance_leaf refactor
udf: avoid redundant memcpy when writing data in ICB
fs/udf: re-use hex_asc_upper_{hi,lo} macros
fs/quota: kernel-doc warning fixes
udf: use linux/uaccess.h
fs/ext2/super.c: Drop memory allocation cast
quota: remove dqptr_sem
quota: simplify remove_inode_dquot_ref()
quota: avoid unnecessary dqget()/dqput() calls
quota: protect Q_GETFMT by dqonoff_mutex
If do_journal_release() races with do_journal_end() which requeues
delayed works for transaction flushing, we can leave work items for
flushing outstanding transactions queued while freeing them. That
results in use after free and possible crash in run_timers_softirq().
Fix the problem by not requeueing works if superblock is being shut down
(MS_ACTIVE not set) and using cancel_delayed_work_sync() in
do_journal_release().
CC: stable@vger.kernel.org
Fix checkpatch warning:
WARNING: Missing a blank line after declarations
WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
Fixes checkpatch warnings:
"WARNING: %Ld/%Lu are not-standard C, use %lld/%llu"
Commits f1f007c308e (reiserfs: balance_leaf refactor, pull out
balance_leaf_insert_left) and cf22df182bf (reiserfs: balance_leaf
refactor, pull out balance_leaf_paste_left) missed that the `body'
pointer was getting repositioned. Subsequent users of the pointer
would expect it to be repositioned, and as a result, parts of the
tree would get overwritten. The most common observed corruption
is indirect block pointers being overwritten.
Since the body value isn't actually used anymore in the called routines,
we can pass back the offset it should be shifted. We constify the body
and ih pointers in the balance_leaf as a mostly-free preventative measure.
Cc: <stable@vger.kernel.org> # 3.16
Reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com>
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
"This the bunch that sat in -next + lock_parent() fix. This is the
minimal set; there's more pending stuff.
In particular, I really hope to get acct.c fixes merged this cycle -
we need that to deal sanely with delayed-mntput stuff. In the next
pile, hopefully - that series is fairly short and localized
(kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more
iov_iter work. Most of prereqs for ->splice_write with sane locking
order are there and Kent's dio rewrite would also fit nicely on top of
this pile"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits)
lock_parent: don't step on stale ->d_parent of all-but-freed one
kill generic_file_splice_write()
ceph: switch to iter_file_splice_write()
shmem: switch to iter_file_splice_write()
nfs: switch to iter_splice_write_file()
fs/splice.c: remove unneeded exports
ocfs2: switch to iter_file_splice_write()
->splice_write() via ->write_iter()
bio_vec-backed iov_iter
optimize copy_page_{to,from}_iter()
bury generic_file_aio_{read,write}
lustre: get rid of messing with iovecs
ceph: switch to ->write_iter()
ceph_sync_direct_write: stop poking into iov_iter guts
ceph_sync_read: stop poking into iov_iter guts
new helper: copy_page_from_iter()
fuse: switch to ->write_iter()
btrfs: switch to ->write_iter()
ocfs2: switch to ->write_iter()
xfs: switch to ->write_iter()
iter_file_splice_write() - a ->splice_write() instance that gathers the
pipe buffers, builds a bio_vec-based iov_iter covering those and feeds
it to ->write_iter(). A bunch of simple cases coverted to that...
[AV: fixed the braino spotted by Cyrill]
Pull reiserfs and ext3 changes from Jan Kara:
"Big reiserfs cleanup from Jeff, an ext3 deadlock fix, and some small
cleanups"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: (34 commits)
reiserfs: Fix compilation breakage with CONFIG_REISERFS_CHECK
ext3: Fix deadlock in data=journal mode when fs is frozen
reiserfs: call truncate_setsize under tailpack mutex
fs/jbd/revoke.c: replace shift loop by ilog2
reiserfs: remove obsolete __constant_cpu_to_le32
reiserfs: balance_leaf refactor, split up balance_leaf_when_delete
reiserfs: balance_leaf refactor, format balance_leaf_finish_node
reiserfs: balance_leaf refactor, format balance_leaf_new_nodes_paste
reiserfs: balance_leaf refactor, format balance_leaf_paste_right
reiserfs: balance_leaf refactor, format balance_leaf_insert_right
reiserfs: balance_leaf refactor, format balance_leaf_paste_left
reiserfs: balance_leaf refactor, format balance_leaf_insert_left
reiserfs: balance_leaf refactor, pull out balance_leaf{left, right, new_nodes, finish_node}
reiserfs: balance_leaf refactor, pull out balance_leaf_finish_node_paste
reiserfs: balance_leaf refactor pull out balance_leaf_finish_node_insert
reiserfs: balance_leaf refactor, pull out balance_leaf_new_nodes_paste
reiserfs: balance_leaf refactor, pull out balance_leaf_new_nodes_insert
reiserfs: balance_leaf refactor, pull out balance_leaf_paste_right
reiserfs: balance_leaf refactor, pull out balance_leaf_insert_right
reiserfs: balance_leaf refactor, pull out balance_leaf_paste_left
There was a bug in debug printout when CONFIG_REISERFS_CHECK was
enabled so one of the assertions in do_balan.c didn't compile. Fix it.
Fixes: 0080e9f9d3ac717537dbd6db1fc8ef72ce0b9cc1
__constant_cpu_to_le32 converted to cpu_to_le32
-Trivial code clean-up
-Fix endif }; (coccinelle warning)
Prior to commit 0e4f6a791b1e (Fix reiserfs_file_release()), reiserfs
truncates serialized on i_mutex. They mostly still do, with the exception
of reiserfs_file_release. That blocks out other writers via the tailpack
mutex and the inode openers counter adjusted in reiserfs_file_open.
However, NFS will call reiserfs_setattr without having called ->open, so
we end up with a race when nfs is calling ->setattr while another
process is releasing the file. Ultimately, it triggers the
BUG_ON(inode->i_size != new_file_size) check in maybe_indirect_to_direct.
The solution is to pull the lock into reiserfs_setattr to encompass the
truncate_setsize call as well.
Splut up balance_leaf_when_delete into:
balance_leaf_when_delete_del
balance_leaf_when_cut
balance_leaf_when_delete_left
Also reformat to adhere to CodingStyle.
Split out balance_leaf_finish_node_dirent from balance_leaf_paste_finish_node.
Break up balance_leaf_paste_new_nodes into:
balance_leaf_paste_new_nodes_shift
balance_leaf_paste_new_nodes_shift_dirent
balance_leaf_paste_new_nodes_whole
and keep balance_leaf_paste_new_nodes as a handler to select which
is appropriate.
Break up balance_leaf_paste_right into:
balance_leaf_paste_right_shift
balance_leaf_paste_right_shift_dirent
balance_leaf_paste_right_whole
and keep balance_leaf_paste_right as a handler to select which is appropriate.
Reformat balance_leaf_insert_right to adhere to CodingStyle.
Break up balance_leaf_paste_left into:
balance_leaf_paste_left_shift
balance_leaf_paste_left_shift_dirent
balance_leaf_paste_left_whole
and keep balance_leaf_paste_left as a handler to select which is appropriate.
Reformat balance_leaf_insert_left to adhere to CodingStyle.
