path: root/fs/romfs
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-30Merge tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6Linus Torvalds
Pull MTD changes from David Woodhouse: - Artem's cleanup of the MTD API continues apace. - Fixes and improvements for ST FSMC and SuperH FLCTL NAND, amongst others. - More work on DiskOnChip G3, new driver for DiskOnChip G4. - Clean up debug/warning printks in JFFS2 to use pr_<level>. Fix up various trivial conflicts, largely due to changes in calling conventions for things like dmaengine_prep_slave_sg() (new inline wrapper to hide new parameter, clashing with rewrite of previously last parameter that used to be an 'append' flag, and is now a bitmap of 'unsigned long flags'). (Also some header file fallout - like so many merges this merge window - and silly conflicts with sparse fixes) * tag 'for-linus-3.4' of git://git.infradead.org/mtd-2.6: (120 commits) mtd: docg3 add protection against concurrency mtd: docg3 refactor cascade floors structure mtd: docg3 increase write/erase timeout mtd: docg3 fix inbound calculations mtd: nand: gpmi: fix function annotations mtd: phram: fix section mismatch for phram_setup mtd: unify initialization of erase_info->fail_addr mtd: support ONFI multi lun NAND mtd: sm_ftl: fix typo in major number. mtd: add device-tree support to spear_smi mtd: spear_smi: Remove default partition information from driver mtd: Add device-tree support to fsmc_nand mtd: fix section mismatch for doc_probe_device mtd: nand/fsmc: Remove sparse warnings and errors mtd: nand/fsmc: Add DMA support mtd: nand/fsmc: Access the NAND device word by word whenever possible mtd: nand/fsmc: Use dev_err to report error scenario mtd: nand/fsmc: Use devm routines mtd: nand/fsmc: Modify fsmc driver to accept nand timing parameters via platform mtd: fsmc_nand: add pm callbacks to support hibernation ...
2012-03-27romfs: switch to new MTD APIArtem Bityutskiy
We have changed the MTD API and now ROMFS should use 'mtd_read()' instead of mtd->read(). Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-10Merge tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6Linus Torvalds
MTD pull for 3.3 * tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6: (113 commits) mtd: Fix dependency for MTD_DOC200x mtd: do not use mtd->block_markbad directly logfs: do not use 'mtd->block_isbad' directly mtd: introduce mtd_can_have_bb helper mtd: do not use mtd->suspend and mtd->resume directly mtd: do not use mtd->lock, unlock and is_locked directly mtd: do not use mtd->sync directly mtd: harmonize mtd_writev usage mtd: do not use mtd->lock_user_prot_reg directly mtd: mtd->write_user_prot_reg directly mtd: do not use mtd->read_*_prot_reg directly mtd: do not use mtd->get_*_prot_info directly mtd: do not use mtd->read_oob directly mtd: mtdoops: do not use mtd->panic_write directly romfs: do not use mtd->get_unmapped_area directly mtd: do not use mtd->get_unmapped_area directly mtd: do use mtd->point directly mtd: introduce mtd_has_oob helper mtd: mtdcore: export symbols cleanup mtd: clean-up the default_mtd_writev function ... Fix up trivial edit/remove conflict in drivers/staging/spectra/lld_mtd.c
2012-01-09romfs: do not use mtd->get_unmapped_area directlyArtem Bityutskiy
Remove direct usage of mtd->get_unmapped_area. Instead, just call 'mtd_get_unmapped_area()' which will return -EOPNOTSUPP if the function is not implemented, and then test for this code. We also translate -EOPNOTSUPP to -ENOSYS because this return code is probably part of the kernel ABI which we do not want to break. Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2012-01-09mtd: introduce mtd_get_unmapped_area interfaceArtem Bityutskiy
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-06-27romfs: fix romfs_get_unmapped_area() argument checkBob Liu
romfs_get_unmapped_area() checks argument `len' without considering PAGE_ALIGN which will cause do_mmap_pgoff() return -EINVAL error after commit f67d9b1576c ("nommu: add page_align to mmap"). Fix the check by changing it in same way ramfs_nommu_get_unmapped_area() was changed in ramfs/file-nommu.c. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_mtd() users to ->mount()Al Viro
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-01-26fix leak in romfs_fill_super()Al Viro
2009-10-11ROMFS: fix length used with romfs_dev_strnlen() functionBernd Schmidt
An interestingly corrupted romfs file system exposed a problem with the romfs_dev_strnlen function: it's passing the wrong value to its helpers. Rather than limit the string to the length passed in by the callers, it uses the size of the device as the limit. Signed-off-by: Bernd Schmidt <bernds_cb1@t-online.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24fs/romfs: correct error-handling codeJulia Lawall
romfs_iget returns an ERR_PTR value in an error case instead of NULL. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @match exists@ expression x, E; statement S1, S2; @@ x = romfs_iget(...) ... when != x = E ( * if (x == NULL || ...) S1 else S2 | * if (x == NULL && ...) S1 else S2 ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining inode_operations as constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-09ROMFS: romfs_dev_read() error ignoredRoel Kluin
romfs_dev_read() may return -EIO, but ret is unsigned, so the errorpath isn't taken. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-24ROMFS: Advance destination buffer pointer when reading from a blockdevDavid Howells
RomFS should advance the destination buffer pointer when reading data from a blockdev source (the data may be split over multiple blocks, each requiring its own sb_read() call). Without this, all the data is copied to the beginning of the output buffer. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24ROMFS: romfs_lookup() shouldn't be doing a partial name comparisonDavid Howells
romfs_lookup() should be using a routine akin to strcmp() on the backing store, rather than one akin to strncmp(). If it uses the latter, it's liable to match /bin/shutdown when looking up /bin/sh. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07fs/romfs: return f_fsid for statfs(2)Coly Li
Make romfs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24NOMMU: Fix the RomFS Kconfig to ensure at least one backing store is selectedDavid Howells
Fix the configuration of the RomFS to make sure that at least one backing store method is always selected. This is done by rendering it down to a choice item that selects between Block, MTD and both. This also works correctly in the case that CONFIG_MTD=m: MTD cannot be selected as a backing store unless CONFIG_ROMFS_FS is also 'm'. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-24NOMMU: Make it possible for RomFS to use MTD devices directlyDavid Howells
Change RomFS so that it can use MTD devices directly - without the intercession of the block layer - as well as using block devices. This permits RomFS: (1) to use the MTD direct mapping facility available under NOMMU conditions if the underlying device is directly accessible by the CPU (including XIP); (2) and thus to be used when the block layer is disabled. RomFS can be configured with support just for MTD devices, just for Block devices or for both. If RomFS is configured for both, then it will treat mtdblock device files as MTD backing stores, not block layer backing stores. I tested this using a CONFIG_MMU=n CONFIG_BLOCK=n kernel running on my FRV board with a RomFS image installed on the mtdram test device. I see my test program being run XIP: # cat /proc/maps ... c0c000b0-c0c01f8c r-xs 00000000 1f:00 144 /mnt/doshm ... GDB on the kernel can be used to show that these addresses are within the set-aside RAM space. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-22fs/Kconfig: move romfs outAlexey Dobriyan
2009-01-08romfs: romfs_iget() - unsigned ino >= 0 is always trueroel kluin
romfs_strnlen() returns int unsigned X >= 0 is always true [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: roel kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-30romfs_readpage: don't report errors for pages beyond i_sizeLinus Torvalds
We zero-fill them like we are supposed to, and that's all fine. It's only an error if the 'romfs_copyfrom()' routine isn't able to fill the data that is supposed to be there. Most of the patch is really just re-organizing the code a bit, and using separate variables for the error value and for how much of the page we actually filled from the filesystem. Reported-and-tested-by: Chris Fester <cfester@wms.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Matt Waddel <matt.waddel@freescale.com> Cc: Greg Ungerer <gerg@snapgear.com> Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19ROMFS: Fix up an error in iget removalDavid Howells
Fix up an error in iget removal in which romfs_lookup() making a successful call to romfs_iget() continues through the negative/error handling (previously the successful case jumped around the negative/error handling case): (1) inode is initialised to NULL at the top of the function, eliminating the need for specific negative-inode handling. This means the positive success handling now flows straight through. (2) Rename the labels to be clearer about what they mean. Also make romfs_lookup()'s result variable of type long so as to avoid 32-bit/64-bit conversions with PTR_ERR() and friends. Based upon a report and patch from Adam Richter. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Adam J. Richter" <adam@yggdrasil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop ROMFS from using iget() and read_inode()David Howells
Stop the ROMFS filesystem from using iget() and read_inode(). Replace romfs_read_inode() with romfs_iget(), and call that instead of iget(). romfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. romfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/romfs/inode.c: trivial improvementsWANG Cong
- There are no lists in fs/romfs/inode.c, so using list_entry is a bit confusing. Replace it with container_of. - It is unnecessary to cast the return value of kmem_cache_alloc, since it returns a void* pointer. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-12-08[PATCH] struct path: convert romfsJosef Sipek
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix possible PAGE_CACHE_SHIFT overflowsAndrew Morton
We've had two instances recently of overflows when doing 64_bit_value = (32_bit_value << PAGE_CACHE_SHIFT) I did a tree-wide grep of `<<.*PAGE_CACHE_SHIFT' and this is the result. - afs_rxfs_fetch_descriptor.offset is of type off_t, which seems broken. - jfs and jffs are limited to 4GB anyway. - reiserfs map_block_for_writepage() takes an unsigned long for the block - it should take sector_t. (It'll fail for huge filesystems with blocksize<PAGE_CACHE_SIZE) - cramfs_read() needs to use sector_t (I think cramsfs is busted on large filesystems anyway) - affs is limited in file size anyway. - I generally didn't fix 32-bit overflows in directory operations. - arm's __flush_dcache_page() is peculiar. What if the page lies beyond 4G? - gss_wrap_req_priv() needs checking (snd_buf->page_base) Cc: Oleg Drokin <green@linuxhacker.ru> Cc: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: <reiserfs-dev@namesys.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-fsdevel@vger.kernel.org> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
