path: root/fs/select.c
2011-01-13fs/select.c: fix information leak to userspaceVasiliy Kulikov
On some architectures __kernel_suseconds_t is int. On these archs struct timeval has padding bytes at the end. This struct is copied to userspace with these padding bytes uninitialized. This leads to leaking of contents of kernel stack memory. This bug was added with v2.6.27-rc5-286-gb773ad4. [akpm@linux-foundation.org: avoid the memset on architectures which don't need it] Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27epoll: make epoll_wait() use the hrtimer range featureShawn Bohrer
This make epoll use hrtimers for the timeout value which prevents epoll_wait() from timing out up to a millisecond early. This mirrors the behavior of select() and poll(). Signed-off-by: Shawn Bohrer <shawn.bohrer@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27select: rename estimate_accuracy() to select_estimate_accuracy()Andrew Morton
Make it a subsystem-specific identifier because we wish to amke it non-static in the next patch ("epoll: make epoll_wait() use the hrtimer range feature"). Cc: Shawn Bohrer <shawn.bohrer@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06fs: use rlimit helpersJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23poll/select: avoid arithmetic overflow in __estimate_accuracy()Guillaume Knispel
__estimate_accuracy() was prone to integer overflow, for example if *tv == {2147, 483648000} on a 32 bit computer (or even for delays as small as {429, 500000000} if the task is niced). Because the result was already forced between 0 and 100ms, the effect of the overflow was not too problematic, but the use of the hrtimer range feature was not optimal in overflow cases. This patch ensures that there can not be an integer overflow in this function. Signed-off-by: Guillaume Knispel <gknispel@proformatique.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-15poll/select: initialize triggered field of struct poll_wqueuesGuillaume Knispel
The triggered field of struct poll_wqueues introduced in commit 5f820f648c92a5ecc771a96b3c29aa6e90013bba ("poll: allow f_op->poll to sleep"). It was first set to 1 in pollwake() (now __pollwake() ), tested and later set to 0 in poll_schedule_timeout(), but not initialized before. As a result when the process needs to sleep, triggered was likely to be non-zero even if pollwake() is not called before the first poll_schedule_timeout(), meaning schedule_hrtimeout_range() would not be called and an extra loop calling all ->poll() would be done. This patch initialize triggered to 0 in poll_initwait() so the ->poll() are not called twice before the process goes to sleep when it needs to. Signed-off-by: Guillaume Knispel <gknispel@proformatique.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16poll: avoid extra wakeups in select/pollEric Dumazet
After introduction of keyed wakeups Davide Libenzi did on epoll, we are able to avoid spurious wakeups in poll()/select() code too. For example, typical use of poll()/select() is to wait for incoming network frames on many sockets. But TX completion for UDP/TCP frames call sock_wfree() which in turn schedules thread. When scheduled, thread does a full scan of all polled fds and can sleep again, because nothing is really available. If number of fds is large, this cause significant load. This patch makes select()/poll() aware of keyed wakeups and useless wakeups are avoided. This reduces number of context switches by about 50% on some setups, and work performed by sofirq handlers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 32Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 23Heiko Carstens
2009-01-14[CVE-2009-0029] Make sys_pselect7 staticHeiko Carstens
Not a single architecture has wired up sys_pselect7 plus it is the only system call with seven parameters. Just make it static and rename it to do_pselect which will do the work for sys_pselect6. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-13Fix timeouts in sys_pselect7Bernd Schmidt
Since we (Analog Devices) updated our Blackfin kernel to 2.6.28, we've seen occasional 5-second hangs from telnet. telnetd calls select with a NULL timeout, but with the new kernel, the system call occasionally returns 0, which causes telnet to call sleep (5). This did not happen with earlier kernels. The code in sys_pselect7 looks a bit strange, in particular the variable "to" is initialized to NULL, then changed if a non-null timeout was passed in, but not used further. It needs to be passed to core_sys_select instead of &end_time. This bug was introduced by 8ff3e8e85fa6c312051134b3953e397feb639f51 ("select: switch select() and poll() over to hrtimers"). Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Reviewed-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06poll: allow f_op->poll to sleepTejun Heo
f_op->poll is the only vfs operation which is not allowed to sleep. It's because poll and select implementation used task state to synchronize against wake ups, which doesn't have to be the case anymore as wait/wake interface can now use custom wake up functions. The non-sleep restriction can be a bit tricky because ->poll is not called from an atomic context and the result of accidentally sleeping in ->poll only shows up as temporary busy looping when the timing is right or rather wrong. This patch converts poll/select to use custom wake up function and use separate triggered variable to synchronize against wake up events. The only added overhead is an extra function call during wake up and negligible. This patch removes the one non-sleep exception from vfs locking rules and is beneficial to userland filesystem implementations like FUSE, 9p or peculiar fs like spufs as it's very difficult for those to implement non-sleeping poll method. While at it, make the following cosmetic changes to make poll.h and select.c checkpatch friendly. * s/type * symbol/type *symbol/ : three places in poll.h * remove blank line before EXPORT_SYMBOL() : two places in select.c Oleg: spotted missing barrier in poll_schedule_timeout() Davide: spotted missing write barrier in pollwake() Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Brad Boyer <flar@allandria.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Roland McGrath <roland@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26select: deal with math overflow from borderline valid userland dataArjan van de Ven
Some userland apps seem to pass in a "0" for the seconds, and several seconds worth of usecs to select(). The old kernels accepted this just fine, so the new kernels must too. However, due to the upscaling of the microseconds to nanoseconds we had some cases where we got math overflow, and depending on the GCC version (due to inlining decisions) that actually resulted in an -EINVAL return. This patch fixes this by adding the excess microseconds to the seconds field. Also with thanks to Marcin Slusarz for spotting some implementation bugs in the diagnostics patches. Reported-by: Carlos R. Mafra <crmafra2@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-07hrtimer: fix signed/unsigned bug in slack estimatorArjan van de Ven
the slack estimator used unsigned math; however for very short delay it's possible that by the time you calculate the timeout, it's already passed and you get a negative time/slack... in an unsigned variable... which then gets turned into a 100 msec delay rather than zero. This patch fixes this by using a signed typee in the right places. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-07hrtimer: incorporate feedback from Peter ZijlstraArjan van de Ven
(based on lkml review) * use rt_task() * task_nice() has a sign Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-05hrtimer: make select() and poll() use the hrtimer range featureArjan van de Ven
This patch makes the select() and poll() hrtimers use the new range feature and settings from the task struct. In addition, this includes the estimate_accuracy() function that Linus posted to lkml, but changed entirely based on other peoples lkml feedback. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-05select: switch select() and poll() over to hrtimersArjan van de Ven
With lots of help, input and cleanups from Thomas Gleixner This patch switches select() and poll() over to hrtimers. The core of the patch is replacing the "s64 timeout" with a "struct timespec end_time" in all the plumbing. But most of the diffstat comes from using the just introduced helpers: poll_select_set_timeout poll_select_copy_remaining timespec_add_safe which make manipulating the timespec easier and less error-prone. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-05select: add poll_select_set_timeout() and poll_select_copy_remaining() helpersThomas Gleixner
This patch adds 2 helpers that will be used for the hrtimer based select/poll: poll_select_set_timeout() is a helper that takes a timeout (as a second, nanosecond pair) and turns that into a "struct timespec" that represents the absolute end time. This is a common operation in the many select() and poll() variants and needs various, common, sanity checks. poll_select_copy_remaining() is a helper that takes care of copying the remaining time to userspace, as select(), pselect() and ppoll() do. This function comes in both a natural and a compat implementation (due to datastructure differences). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-06-22Fix performance regression on lmbench select benchmarkLinus Torvalds
Christian Borntraeger reported that reinstating cond_resched() with CONFIG_PREEMPT caused a performance regression on lmbench: For example select file 500: 23 microseconds 32 microseconds and that's really because we totally unnecessarily do the cond_resched() in the innermost loop of select(), which is just silly. This moves it out from the innermost loop (which only ever loops ove the bits in a single "unsigned long" anyway), which makes the performance regression go away. Reported-and-tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] make osf_select() use core_sys_select()Al Viro
... instead of open-coding it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30signals: use HAVE_SET_RESTORE_SIGMASKRoland McGrath
Change all the #ifdef TIF_RESTORE_SIGMASK conditionals in non-arch code to #ifdef HAVE_SET_RESTORE_SIGMASK. If arch code defines it first, the generic set_restore_sigmask() using TIF_RESTORE_SIGMASK is not defined. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30signals: add set_restore_sigmaskRoland McGrath
This adds the set_restore_sigmask() inline in <linux/thread_info.h> and replaces every set_thread_flag(TIF_RESTORE_SIGMASK) with a call to it. No change, but abstracts the details of the flag protocol from all the calls. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21trivial: small cleanupsPavel Machek
These are small cleanups all over the tree. Trivial style and comment changes to fs/select.c, kernel/signal.c, kernel/stop_machine.c & mm/pdflush.c Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-02-06make sys_poll() wait at least timeout msKarsten Wiese
schedule_timeout(jiffies) waits for at least jiffies - 1. Add 1 jiffie to the timeout_jiffies calculated in sys_poll() to wait at least timeout_msecs, like poll() manpage says. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19fs/select, remove unused macrosJiri Slaby
fs/select, remove unused macros this is due to preparation for global BIT macro Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Use ERESTART_RESTARTBLOCK if poll() is interrupted by a signalChris Wright
Lomesh reported poll returning EINTR during suspend/resume cycle. This is caused by the STOP/CONT cycle that the freezer uses, generating a pending signal for what in effect is an ignored signal. In general poll is a little eager in returning EINTR, when it could try not bother userspace and simply restart the syscall. Both select and ppoll do use ERESTARTNOHAND to restart the syscall. Oleg points out that simply using ERESTARTNOHAND will cause poll to restart with original timeout value. which could ultimately lead to process never returning to userspace. Instead use ERESTART_RESTARTBLOCK, and restart poll with updated timeout value. Inspired by Manfred's use ERESTARTNOHAND in poll patch. [bunk@kernel.org: do_restart_poll() can become static] Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Agarwal, Lomesh" <lomesh.agarwal@intel.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17do_poll: return -EINTR when signalledOleg Nesterov
do_poll() checks signal_pending() but returns 0 when interrupted. This means the caller has to check signal_pending() again. Change it to return -EINTR when signal_pending() and count == 0. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Andi Kleen <ak@suse.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Vadim Lobanov <vlobanov@speakeasy.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17do_sys_poll: simplify playing with on-stack dataOleg Nesterov
Cleanup. Lessens both the source and compiled code (100 bytes) and imho makes the code much more understandable. With this patch "struct poll_list *head" always points to on-stack stack_pps, so we can remove all "is it on-stack" and "was it initialized" checks. Also, move poll_initwait/poll_freewait and -EINTR detection closer to the do_poll()'s callsite. [akpm@linux-foundation.org: fix warning (size_t != uint)] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Looks-good-to: Andi Kleen <ak@suse.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Vadim Lobanov <vlobanov@speakeasy.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11Fix select on /proc files without ->pollAlexey Dobriyan
Taneli Vähäkangas <vahakang@cs.helsinki.fi> reported that commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba aka "Fix rmmod/read/write races in /proc entries" broke SBCL + SLIME combo. The old code in do_select() used DEFAULT_POLLMASK, if couldn't find ->poll handler. The new code makes ->poll always there and returns 0 by default, which is not correct. Return DEFAULT_POLLMASK instead. Steps to reproduce: install emacs, SBCL, SLIME emacs M-x slime in *inferior-lisp* buffer [watch it doing "Connecting to Swank on port X.."] Please, apply before 2.6.23. P.S.: why SBCL can't just read(2) /proc/cpuinfo is a mystery. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: T Taneli Vahakangas <vahakang@cs.helsinki.fi> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Style fix in fs/select.cWANG Cong
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08ROUND_UP macro cleanup in fs/(select|compat|readdir).cMilind Arun Choudhary
ROUND_UP macro cleanup use,ALIGN or DIV_ROUND_UP where ever appropriate. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] enforce RLIMIT_NOFILE in poll()Chris Snook
POSIX states that poll() shall fail with EINVAL if nfds > OPEN_MAX. In this context, POSIX is referring to sysconf(OPEN_MAX), which is the value of current->signal->rlim[RLIMIT_NOFILE].rlim_cur in the linux kernel, not the compile-time constant which happens to also be named OPEN_MAX. In the current code, an application may poll up to max_fdset file descriptors, even if this exceeds RLIMIT_NOFILE. The current code also breaks applications which poll more than max_fdset descriptors, which worked circa 2.4.18 when the check was against NR_OPEN, which is 1024*1024. This patch enforces the limit precisely as POSIX defines, even if RLIMIT_NOFILE has been changed at run time with ulimit -n. To elaborate on the rationale for this, there are three cases: 1) RLIMIT_NOFILE is at the default value of 1024 In this (default) case, the patch changes nothing. Calls with nfds > 1024 fail with EINVAL both before and after the patch, and calls with nfds <= 1024 pass the check both before and after the patch, since 1024 is the initial value of max_fdset. 2) RLIMIT_NOFILE has been raised above the default In this case, poll() becomes more permissive, allowing polling up to RLIMIT_NOFILE file descriptors even if less than 1024 have been opened. The patch won't introduce new errors here. If an application somehow depends on poll() failing when it polls with duplicate or invalid file descriptors, it's already broken, since this is already allowed below 1024, and will also work above 1024 if enough file descriptors have been open at some point to cause max_fdset to have been increased above nfds. 3) RLIMIT_NOFILE has been lowered below the default In this case, the system administrator or the user has gone out of their way to protect the system from inefficient (or malicious) applications wasting kernel memory. The current code allows polling up to 1024 file descriptors even if RLIMIT_NOFILE is much lower, which is not what the user or administrator intended. Well-written applications which only poll valid, unique file descriptors will never notice the difference, because they'll hit the limit on open() first. If an application gets broken because of the patch in this case, then it was already poorly/maliciously designed, and allowing it to work in the past was a violation of POSIX and a DoS risk on low-resource systems. With this patch, poll() will permit exactly what POSIX suggests, no more, no less, and for any run-time value set with ulimit -n, not just 256 or 1024. There are existing apps which which poll a large number of file descriptors, some of which may be invalid, and if those numbers stradle 1024, they currently fail with or without the patch in -mm, though they worked fine under 2.4.18. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fs: sys_poll with timeout -1 bug fixFrode Isaksen
If you do a poll() call with timeout -1, the wait will be a big number (depending on HZ) instead of infinite wait, since -1 is passed to the msecs_to_jiffies function. Signed-off-by: Frode Isaksen <frode.isaksen@gmail.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Poll cleanups/microoptimizationsVadim Lobanov
The "count" and "pt" variables are declared and modified by do_poll(), as well as accessed and written indirectly in the do_pollfd() subroutine. This patch pulls all handling of these variables into the do_poll() function, thereby eliminating the odd use of indirection in do_pollfd(). This is done by pulling the "struct pollfd" traversal loop from do_pollfd() into its only caller do_poll(). As an added bonus, the patch saves a few clock cycles, and also adds comments to make the code easier to follow. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] select: don't overflow if (SELECT_STACK_ALLOC % sizeof(long) != 0)Mitchell Blank Jr
If SELECT_STACK_ALLOC is not a multiple of sizeof(long) then stack_fds[] would be shorter than SELECT_STACK_ALLOC bytes and could overflow later in the function. Fixed by simply rearranging the test later to work on sizeof(stack_fds) Currently SELECT_STACK_ALLOC is 256 so this doesn't happen, but it's nasty to have things like this hidden in the code. What if later someone decides to change SELECT_STACK_ALLOC to 300? Signed-off-by: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] select() warning fixesAndrew Morton
fs/select.c: In function `core_sys_select': fs/select.c:339: warning: assignment from incompatible pointer type fs/select.c:376: warning: comparison of distinct pointer types lacks a cast By using a void* we can remove lots of casts rather than adding more. Cc: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] avoid unaligned access when accessing poll stackJes Sorensen
Commit 70674f95c0a2ea694d5c39f4e514f538a09be36f: [PATCH] Optimize select/poll by putting small data sets on the stack resulted in the poll stack being 4-byte aligned on 64-bit architectures, causing misaligned accesses to elements in the array. This patch fixes it by declaring the stack in terms of 'long' instead of 'char'. Force alignment of poll and select stacks to long to avoid unaligned access on 64 bit architectures. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] mark f_ops const in the inodeArjan van de Ven
Mark the f_ops members of inodes as const, as well as fix the ripple-through this causes by places that copy this f_ops and then "do stuff" with it. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] use fget_light() in select/pollEric Dumazet
Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Optimize select/poll by putting small data sets on the stackAndi Kleen
Optimize select and poll by a using stack space for small fd sets This brings back an old optimization from Linux 2.0. Using the stack is faster than kmalloc. On a Intel P4 system it speeds up a select of a single pty fd by about 13% (~4000 cycles -> ~3500) It also saves memory because a daemon hanging in select or poll will usually save one or two less pages. This can add up - e.g. if you have 10 daemons blocking in poll/select you save 40KB of memory. I did a patch for this long ago, but it was never applied. This version is a reimplementation of the old patch that tries to be less intrusive. I only did the minimal changes needed for the stack allocation. The cut off point before external memory is allocated is currently at 832bytes. The system calls always allocate this much memory on the stack. These 832 bytes are divided into 256 bytes frontend data (for the select bitmaps of the pollfds) and the rest of the space for the wait queues used by the low level drivers. There are some extreme cases where this won't work out for select and it falls back to allocating memory too early - especially with very sparse large select bitmaps - but the majority of processes who only have a small number of file descriptors should be ok. [TBD: 832/256 might not be the best split for select or poll] I suspect more optimizations might be possible, but they would be more complicated. One way would be to cache the select/poll context over multiple system calls because typically the input values should be similar. Problem is when to flush the file descriptors out though. Signed-off-by: Andi Kleen <ak@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] select: time comparison fixesAndrew Morton
I got all of these backwards. We want to return min(input timeout, new timeout) to userspace to prevent increasing the time-remaining value. Thanks to Ernst Herzberg <earny@net4u.de> for reporting and diagnosing. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-11[PATCH] select: fix returned timevalAndrew Morton
With David Woodhouse <dwmw2@infradead.org> select() presently has a habit of increasing the value of the user's `timeout' argument on return. We were writing back a timeout larger than the original. We _deliberately_ round up, since we know we must wait at _least_ as long as the caller asks us to. The patch adds a couple of helper functions for magnitude comparison of timespecs and of timevals, and uses them to prevent the various poll and select functions from returning a timeout which is larger than the one which was passed in. The patch also fixes a bug in compat_sys_pselect7(): it was adding the new timeout value to the old one and was returning that. It should just return the new timeout value. (We have various handy timespec/timeval-to-from-nsec conversion functions in time.h. But this code open-codes it all). Cc: "David S. Miller" <davem@davemloft.net> Cc: Andi Kleen <ak@muc.de> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: george anzinger <george@mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] fix __user annotations in fs/select.cAl Viro
2006-01-18[PATCH] Add pselect/ppoll system call implementationDavid Woodhouse
The following implementation of ppoll() and pselect() system calls depends on the architecture providing a TIF_RESTORE_SIGMASK flag in the thread_info. These system calls have to change the signal mask during their operation, and signal handlers must be invoked using the new, temporary signal mask. The old signal mask must be restored either upon successful exit from the system call, or upon returning from the invoked signal handler if the system call is interrupted. We can't simply restore the original signal mask and return to userspace, since the restored signal mask may actually block the signal which interrupted the system call. The TIF_RESTORE_SIGMASK flag deals with this by causing the syscall exit path to trap into do_signal() just as TIF_SIGPENDING does, and by causing do_signal() to use the saved signal mask instead of the current signal mask when setting up the stack frame for the signal handler -- or by causing do_signal() to simply restore the saved signal mask in the case where there is no handler to be invoked. The first patch implements the sys_pselect() and sys_ppoll() system calls, which are present only if TIF_RESTORE_SIGMASK is defined. That #ifdef should go away in time when all architectures have implemented it. The second patch implements TIF_RESTORE_SIGMASK for the PowerPC kernel (in the -mm tree), and the third patch then removes the arch-specific implementations of sys_rt_sigsuspend() and replaces them with generic versions using the same trick. The fourth and fifth patches, provided by David Howells, implement TIF_RESTORE_SIGMASK for FR-V and i386 respectively, and the sixth patch adds the syscalls to the i386 syscall table. This patch: Add the pselect() and ppoll() system calls, providing core routines usable by the original select() and poll() system calls and also the new calls (with their semantics w.r.t timeouts). Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] files: lock-free fd look-upDipankar Sarma
With the use of RCU in files structure, the look-up of files using fds can now be lock-free. The lookup is protected by rcu_read_lock()/rcu_read_unlock(). This patch changes the readers to use lock-free lookup. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Ravikiran Thirumalai <kiran_th@gmail.com> Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
