path: root/fs/select.c
2012-08-09posix_types.h: Cleanup stale __NFDBITS and related definitionsJosh Boyer
commit 8ded2bbc1845e19c771eb55209aab166ef011243 upstream. Recently, glibc made a change to suppress sign-conversion warnings in FD_SET (glibc commit ceb9e56b3d1). This uncovered an issue with the kernel's definition of __NFDBITS if applications #include <linux/types.h> after including <sys/select.h>. A build failure would be seen when passing the -Werror=sign-compare and -D_FORTIFY_SOURCE=2 flags to gcc. It was suggested that the kernel should either match the glibc definition of __NFDBITS or remove that entirely. The current in-kernel uses of __NFDBITS can be replaced with BITS_PER_LONG, and there are no uses of the related __FDELT and __FDMASK defines. Given that, we'll continue the cleanup that was started with commit 8b3d1cda4f5f ("posix_types: Remove fd_set macros") and drop the remaining unused macros. Additionally, linux/time.h has similar macros defined that expand to nothing so we'll remove those at the same time. Reported-by: Jeff Law <law@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Boyer <jwboyer@redhat.com> [ .. and fix up whitespace as per akpm ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-23poll: add poll_requested_events() and poll_does_not_wait() functionsHans Verkuil
In some cases the poll() implementation in a driver has to do different things depending on the events the caller wants to poll for. An example is when a driver needs to start a DMA engine if the caller polls for POLLIN, but doesn't want to do that if POLLIN is not requested but instead only POLLOUT or POLLPRI is requested. This is something that can happen in the video4linux subsystem among others. Unfortunately, the current epoll/poll/select implementation doesn't provide that information reliably. The poll_table_struct does have it: it has a key field with the event mask. But once a poll() call matches one or more bits of that mask any following poll() calls are passed a NULL poll_table pointer. Also, the eventpoll implementation always left the key field at ~0 instead of using the requested events mask. This was changed in eventpoll.c so the key field now contains the actual events that should be polled for as set by the caller. The solution to the NULL poll_table pointer is to set the qproc field to NULL in poll_table once poll() matches the events, not the poll_table pointer itself. That way drivers can obtain the mask through a new poll_requested_events inline. The poll_table_struct can still be NULL since some kernel code calls it internally (netfs_state_poll() in ./drivers/staging/pohmelfs/netfs.h). In that case poll_requested_events() returns ~0 (i.e. all events). Very rarely drivers might want to know whether poll_wait will actually wait. If another earlier file descriptor in the set already matched the events the caller wanted to wait for, then the kernel will return from the select() call without waiting. This might be useful information in order to avoid doing expensive work. A new helper function poll_does_not_wait() is added that drivers can use to detect this situation. This is now used in sock_poll_wait() in include/net/sock.h. This was the only place in the kernel that needed this information. Drivers should no longer access any of the poll_table internals, but use the poll_requested_events() and poll_does_not_wait() access functions instead. In order to enforce that the poll_table fields are now prepended with an underscore and a comment was added warning against using them directly. This required a change in unix_dgram_poll() in unix/af_unix.c which used the key field to get the requested events. It's been replaced by a call to poll_requested_events(). For qproc it was especially important to change its name since the behavior of that field changes with this patch since this function pointer can now be NULL when that wasn't possible in the past. Any driver accessing the qproc or key fields directly will now fail to compile. Some notes regarding the correctness of this patch: the driver's poll() function is called with a 'struct poll_table_struct *wait' argument. This pointer may or may not be NULL, drivers can never rely on it being one or the other as that depends on whether or not an earlier file descriptor in the select()'s fdset matched the requested events. There are only three things a driver can do with the wait argument: 1) obtain the key field: events = wait ? wait->key : ~0; This will still work although it should be replaced with the new poll_requested_events() function (which does exactly the same). This will now even work better, since wait is no longer set to NULL unnecessarily. 2) use the qproc callback. This could be deadly since qproc can now be NULL. Renaming qproc should prevent this from happening. There are no kernel drivers that actually access this callback directly, BTW. 3) test whether wait == NULL to determine whether poll would return without waiting. This is no longer sufficient as the correct test is now wait == NULL || wait->_qproc == NULL. However, the worst that can happen here is a slight performance hit in the case where wait != NULL and wait->_qproc == NULL. In that case the driver will assume that poll_wait() will actually add the fd to the set of waiting file descriptors. Of course, poll_wait() will not do that since it tests for wait->_qproc. This will not break anything, though. There is only one place in the whole kernel where this happens (sock_poll_wait() in include/net/sock.h) and that code will be replaced by a call to poll_does_not_wait() in the next patch. Note that even if wait->_qproc != NULL drivers cannot rely on poll_wait() actually waiting. The next file descriptor from the set might match the event mask and thus any possible waits will never happen. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Reviewed-by: Jonathan Corbet <corbet@lwn.net> Reviewed-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-21sys_poll: fix incorrect type for 'timeout' parameterLinus Torvalds
The 'poll()' system call timeout parameter is supposed to be 'int', not 'long'. Now, the reason this matters is that right now 32-bit compat mode is broken on at least x86-64, because the 32-bit code just calls 'sys_poll()' directly on x86-64, and the 32-bit argument will have been zero-extended, turning a signed 'int' into a large unsigned 'long' value. We could just introduce a 'compat_sys_poll()' function for this, and that may eventually be what we have to do, but since the actual standard poll() semantics is *supposed* to be 'int', and since at least on x86-64 glibc sign-extends the argument before invocing the system call (so nobody can actually use a 64-bit timeout value in user space _anyway_, even in 64-bit binaries), the simpler solution would seem to be to just fix the definition of the system call to match what it should have been from the very start. If it turns out that somebody somehow circumvents the user-level libc 64-bit sign extension and actually uses a large unsigned 64-bit timeout despite that not being how poll() is supposed to work, we will need to do the compat_sys_poll() approach. Reported-by: Thomas Meyer <thomas@m3y3r.de> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-19Replace the fd_sets in struct fdtable with an array of unsigned longsDavid Howells
Replace the fd_sets in struct fdtable with an array of unsigned longs and then use the standard non-atomic bit operations rather than the FD_* macros. This: (1) Removes the abuses of struct fd_set: (a) Since we don't want to allocate a full fd_set the vast majority of the time, we actually, in effect, just allocate a just-big-enough array of unsigned longs and cast it to an fd_set type - so why bother with the fd_set at all? (b) Some places outside of the core fdtable handling code (such as SELinux) want to look inside the array of unsigned longs hidden inside the fd_set struct for more efficient iteration over the entire set. (2) Eliminates the use of FD_*() macros in the kernel completely. (3) Permits the __FD_*() macros to be deleted entirely where not exposed to userspace. Signed-off-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20120216174954.23314.48147.stgit@warthog.procyon.org.uk Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk>
2011-03-21select: remove unused MAX_SELECT_SECONDSNamhyung Kim
Remove the leftover from the commit 8ff3e8e85fa6 ("select: switch select() and poll() over to hrtimers"). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13fs/select.c: fix information leak to userspaceVasiliy Kulikov
On some architectures __kernel_suseconds_t is int. On these archs struct timeval has padding bytes at the end. This struct is copied to userspace with these padding bytes uninitialized. This leads to leaking of contents of kernel stack memory. This bug was added with v2.6.27-rc5-286-gb773ad4. [akpm@linux-foundation.org: avoid the memset on architectures which don't need it] Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27epoll: make epoll_wait() use the hrtimer range featureShawn Bohrer
This make epoll use hrtimers for the timeout value which prevents epoll_wait() from timing out up to a millisecond early. This mirrors the behavior of select() and poll(). Signed-off-by: Shawn Bohrer <shawn.bohrer@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27select: rename estimate_accuracy() to select_estimate_accuracy()Andrew Morton
Make it a subsystem-specific identifier because we wish to amke it non-static in the next patch ("epoll: make epoll_wait() use the hrtimer range feature"). Cc: Shawn Bohrer <shawn.bohrer@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12Add generic sys_old_select()Christoph Hellwig
Add a generic implementation of the old select() syscall, which expects its argument in a memory block and switch all architectures over to use it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Reviewed-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Acked-by: Andreas Schwab <schwab@linux-m68k.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06fs: use rlimit helpersJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23poll/select: avoid arithmetic overflow in __estimate_accuracy()Guillaume Knispel
__estimate_accuracy() was prone to integer overflow, for example if *tv == {2147, 483648000} on a 32 bit computer (or even for delays as small as {429, 500000000} if the task is niced). Because the result was already forced between 0 and 100ms, the effect of the overflow was not too problematic, but the use of the hrtimer range feature was not optimal in overflow cases. This patch ensures that there can not be an integer overflow in this function. Signed-off-by: Guillaume Knispel <gknispel@proformatique.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-15poll/select: initialize triggered field of struct poll_wqueuesGuillaume Knispel
The triggered field of struct poll_wqueues introduced in commit 5f820f648c92a5ecc771a96b3c29aa6e90013bba ("poll: allow f_op->poll to sleep"). It was first set to 1 in pollwake() (now __pollwake() ), tested and later set to 0 in poll_schedule_timeout(), but not initialized before. As a result when the process needs to sleep, triggered was likely to be non-zero even if pollwake() is not called before the first poll_schedule_timeout(), meaning schedule_hrtimeout_range() would not be called and an extra loop calling all ->poll() would be done. This patch initialize triggered to 0 in poll_initwait() so the ->poll() are not called twice before the process goes to sleep when it needs to. Signed-off-by: Guillaume Knispel <gknispel@proformatique.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Tejun Heo <tj@kernel.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16poll: avoid extra wakeups in select/pollEric Dumazet
After introduction of keyed wakeups Davide Libenzi did on epoll, we are able to avoid spurious wakeups in poll()/select() code too. For example, typical use of poll()/select() is to wait for incoming network frames on many sockets. But TX completion for UDP/TCP frames call sock_wfree() which in turn schedules thread. When scheduled, thread does a full scan of all polled fds and can sleep again, because nothing is really available. If number of fds is large, this cause significant load. This patch makes select()/poll() aware of keyed wakeups and useless wakeups are avoided. This reduces number of context switches by about 50% on some setups, and work performed by sofirq handlers. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Andi Kleen <ak@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 32Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 23Heiko Carstens
2009-01-14[CVE-2009-0029] Make sys_pselect7 staticHeiko Carstens
Not a single architecture has wired up sys_pselect7 plus it is the only system call with seven parameters. Just make it static and rename it to do_pselect which will do the work for sys_pselect6. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-13Fix timeouts in sys_pselect7Bernd Schmidt
Since we (Analog Devices) updated our Blackfin kernel to 2.6.28, we've seen occasional 5-second hangs from telnet. telnetd calls select with a NULL timeout, but with the new kernel, the system call occasionally returns 0, which causes telnet to call sleep (5). This did not happen with earlier kernels. The code in sys_pselect7 looks a bit strange, in particular the variable "to" is initialized to NULL, then changed if a non-null timeout was passed in, but not used further. It needs to be passed to core_sys_select instead of &end_time. This bug was introduced by 8ff3e8e85fa6c312051134b3953e397feb639f51 ("select: switch select() and poll() over to hrtimers"). Signed-off-by: Bernd Schmidt <bernd.schmidt@analog.com> Reviewed-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06poll: allow f_op->poll to sleepTejun Heo
f_op->poll is the only vfs operation which is not allowed to sleep. It's because poll and select implementation used task state to synchronize against wake ups, which doesn't have to be the case anymore as wait/wake interface can now use custom wake up functions. The non-sleep restriction can be a bit tricky because ->poll is not called from an atomic context and the result of accidentally sleeping in ->poll only shows up as temporary busy looping when the timing is right or rather wrong. This patch converts poll/select to use custom wake up function and use separate triggered variable to synchronize against wake up events. The only added overhead is an extra function call during wake up and negligible. This patch removes the one non-sleep exception from vfs locking rules and is beneficial to userland filesystem implementations like FUSE, 9p or peculiar fs like spufs as it's very difficult for those to implement non-sleeping poll method. While at it, make the following cosmetic changes to make poll.h and select.c checkpatch friendly. * s/type * symbol/type *symbol/ : three places in poll.h * remove blank line before EXPORT_SYMBOL() : two places in select.c Oleg: spotted missing barrier in poll_schedule_timeout() Davide: spotted missing write barrier in pollwake() Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Brad Boyer <flar@allandria.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Roland McGrath <roland@redhat.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-26select: deal with math overflow from borderline valid userland dataArjan van de Ven
Some userland apps seem to pass in a "0" for the seconds, and several seconds worth of usecs to select(). The old kernels accepted this just fine, so the new kernels must too. However, due to the upscaling of the microseconds to nanoseconds we had some cases where we got math overflow, and depending on the GCC version (due to inlining decisions) that actually resulted in an -EINVAL return. This patch fixes this by adding the excess microseconds to the seconds field. Also with thanks to Marcin Slusarz for spotting some implementation bugs in the diagnostics patches. Reported-by: Carlos R. Mafra <crmafra2@gmail.com> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-07hrtimer: fix signed/unsigned bug in slack estimatorArjan van de Ven
the slack estimator used unsigned math; however for very short delay it's possible that by the time you calculate the timeout, it's already passed and you get a negative time/slack... in an unsigned variable... which then gets turned into a 100 msec delay rather than zero. This patch fixes this by using a signed typee in the right places. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-07hrtimer: incorporate feedback from Peter ZijlstraArjan van de Ven
(based on lkml review) * use rt_task() * task_nice() has a sign Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-05hrtimer: make select() and poll() use the hrtimer range featureArjan van de Ven
This patch makes the select() and poll() hrtimers use the new range feature and settings from the task struct. In addition, this includes the estimate_accuracy() function that Linus posted to lkml, but changed entirely based on other peoples lkml feedback. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-05select: switch select() and poll() over to hrtimersArjan van de Ven
With lots of help, input and cleanups from Thomas Gleixner This patch switches select() and poll() over to hrtimers. The core of the patch is replacing the "s64 timeout" with a "struct timespec end_time" in all the plumbing. But most of the diffstat comes from using the just introduced helpers: poll_select_set_timeout poll_select_copy_remaining timespec_add_safe which make manipulating the timespec easier and less error-prone. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-05select: add poll_select_set_timeout() and poll_select_copy_remaining() helpersThomas Gleixner
This patch adds 2 helpers that will be used for the hrtimer based select/poll: poll_select_set_timeout() is a helper that takes a timeout (as a second, nanosecond pair) and turns that into a "struct timespec" that represents the absolute end time. This is a common operation in the many select() and poll() variants and needs various, common, sanity checks. poll_select_copy_remaining() is a helper that takes care of copying the remaining time to userspace, as select(), pselect() and ppoll() do. This function comes in both a natural and a compat implementation (due to datastructure differences). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-06-22Fix performance regression on lmbench select benchmarkLinus Torvalds
Christian Borntraeger reported that reinstating cond_resched() with CONFIG_PREEMPT caused a performance regression on lmbench: For example select file 500: 23 microseconds 32 microseconds and that's really because we totally unnecessarily do the cond_resched() in the innermost loop of select(), which is just silly. This moves it out from the innermost loop (which only ever loops ove the bits in a single "unsigned long" anyway), which makes the performance regression go away. Reported-and-tested-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-01[PATCH] make osf_select() use core_sys_select()Al Viro
... instead of open-coding it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-30signals: use HAVE_SET_RESTORE_SIGMASKRoland McGrath
Change all the #ifdef TIF_RESTORE_SIGMASK conditionals in non-arch code to #ifdef HAVE_SET_RESTORE_SIGMASK. If arch code defines it first, the generic set_restore_sigmask() using TIF_RESTORE_SIGMASK is not defined. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30signals: add set_restore_sigmaskRoland McGrath
This adds the set_restore_sigmask() inline in <linux/thread_info.h> and replaces every set_thread_flag(TIF_RESTORE_SIGMASK) with a call to it. No change, but abstracts the details of the flag protocol from all the calls. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21trivial: small cleanupsPavel Machek
These are small cleanups all over the tree. Trivial style and comment changes to fs/select.c, kernel/signal.c, kernel/stop_machine.c & mm/pdflush.c Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-02-06make sys_poll() wait at least timeout msKarsten Wiese
schedule_timeout(jiffies) waits for at least jiffies - 1. Add 1 jiffie to the timeout_jiffies calculated in sys_poll() to wait at least timeout_msecs, like poll() manpage says. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19fs/select, remove unused macrosJiri Slaby
fs/select, remove unused macros this is due to preparation for global BIT macro Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Use ERESTART_RESTARTBLOCK if poll() is interrupted by a signalChris Wright
Lomesh reported poll returning EINTR during suspend/resume cycle. This is caused by the STOP/CONT cycle that the freezer uses, generating a pending signal for what in effect is an ignored signal. In general poll is a little eager in returning EINTR, when it could try not bother userspace and simply restart the syscall. Both select and ppoll do use ERESTARTNOHAND to restart the syscall. Oleg points out that simply using ERESTARTNOHAND will cause poll to restart with original timeout value. which could ultimately lead to process never returning to userspace. Instead use ERESTART_RESTARTBLOCK, and restart poll with updated timeout value. Inspired by Manfred's use ERESTARTNOHAND in poll patch. [bunk@kernel.org: do_restart_poll() can become static] Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Agarwal, Lomesh" <lomesh.agarwal@intel.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17do_poll: return -EINTR when signalledOleg Nesterov
do_poll() checks signal_pending() but returns 0 when interrupted. This means the caller has to check signal_pending() again. Change it to return -EINTR when signal_pending() and count == 0. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Andi Kleen <ak@suse.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Vadim Lobanov <vlobanov@speakeasy.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17do_sys_poll: simplify playing with on-stack dataOleg Nesterov
Cleanup. Lessens both the source and compiled code (100 bytes) and imho makes the code much more understandable. With this patch "struct poll_list *head" always points to on-stack stack_pps, so we can remove all "is it on-stack" and "was it initialized" checks. Also, move poll_initwait/poll_freewait and -EINTR detection closer to the do_poll()'s callsite. [akpm@linux-foundation.org: fix warning (size_t != uint)] Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Looks-good-to: Andi Kleen <ak@suse.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Vadim Lobanov <vlobanov@speakeasy.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11Fix select on /proc files without ->pollAlexey Dobriyan
Taneli Vähäkangas <vahakang@cs.helsinki.fi> reported that commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba aka "Fix rmmod/read/write races in /proc entries" broke SBCL + SLIME combo. The old code in do_select() used DEFAULT_POLLMASK, if couldn't find ->poll handler. The new code makes ->poll always there and returns 0 by default, which is not correct. Return DEFAULT_POLLMASK instead. Steps to reproduce: install emacs, SBCL, SLIME emacs M-x slime in *inferior-lisp* buffer [watch it doing "Connecting to Swank on port X.."] Please, apply before 2.6.23. P.S.: why SBCL can't just read(2) /proc/cpuinfo is a mystery. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: T Taneli Vahakangas <vahakang@cs.helsinki.fi> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Style fix in fs/select.cWANG Cong
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08ROUND_UP macro cleanup in fs/(select|compat|readdir).cMilind Arun Choudhary
ROUND_UP macro cleanup use,ALIGN or DIV_ROUND_UP where ever appropriate. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] enforce RLIMIT_NOFILE in poll()Chris Snook
POSIX states that poll() shall fail with EINVAL if nfds > OPEN_MAX. In this context, POSIX is referring to sysconf(OPEN_MAX), which is the value of current->signal->rlim[RLIMIT_NOFILE].rlim_cur in the linux kernel, not the compile-time constant which happens to also be named OPEN_MAX. In the current code, an application may poll up to max_fdset file descriptors, even if this exceeds RLIMIT_NOFILE. The current code also breaks applications which poll more than max_fdset descriptors, which worked circa 2.4.18 when the check was against NR_OPEN, which is 1024*1024. This patch enforces the limit precisely as POSIX defines, even if RLIMIT_NOFILE has been changed at run time with ulimit -n. To elaborate on the rationale for this, there are three cases: 1) RLIMIT_NOFILE is at the default value of 1024 In this (default) case, the patch changes nothing. Calls with nfds > 1024 fail with EINVAL both before and after the patch, and calls with nfds <= 1024 pass the check both before and after the patch, since 1024 is the initial value of max_fdset. 2) RLIMIT_NOFILE has been raised above the default In this case, poll() becomes more permissive, allowing polling up to RLIMIT_NOFILE file descriptors even if less than 1024 have been opened. The patch won't introduce new errors here. If an application somehow depends on poll() failing when it polls with duplicate or invalid file descriptors, it's already broken, since this is already allowed below 1024, and will also work above 1024 if enough file descriptors have been open at some point to cause max_fdset to have been increased above nfds. 3) RLIMIT_NOFILE has been lowered below the default In this case, the system administrator or the user has gone out of their way to protect the system from inefficient (or malicious) applications wasting kernel memory. The current code allows polling up to 1024 file descriptors even if RLIMIT_NOFILE is much lower, which is not what the user or administrator intended. Well-written applications which only poll valid, unique file descriptors will never notice the difference, because they'll hit the limit on open() first. If an application gets broken because of the patch in this case, then it was already poorly/maliciously designed, and allowing it to work in the past was a violation of POSIX and a DoS risk on low-resource systems. With this patch, poll() will permit exactly what POSIX suggests, no more, no less, and for any run-time value set with ulimit -n, not just 256 or 1024. There are existing apps which which poll a large number of file descriptors, some of which may be invalid, and if those numbers stradle 1024, they currently fail with or without the patch in -mm, though they worked fine under 2.4.18. Signed-off-by: Chris Snook <csnook@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fs: sys_poll with timeout -1 bug fixFrode Isaksen
If you do a poll() call with timeout -1, the wait will be a big number (depending on HZ) instead of infinite wait, since -1 is passed to the msecs_to_jiffies function. Signed-off-by: Frode Isaksen <frode.isaksen@gmail.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] Poll cleanups/microoptimizationsVadim Lobanov
The "count" and "pt" variables are declared and modified by do_poll(), as well as accessed and written indirectly in the do_pollfd() subroutine. This patch pulls all handling of these variables into the do_poll() function, thereby eliminating the odd use of indirection in do_pollfd(). This is done by pulling the "struct pollfd" traversal loop from do_pollfd() into its only caller do_poll(). As an added bonus, the patch saves a few clock cycles, and also adds comments to make the code easier to follow. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] select: don't overflow if (SELECT_STACK_ALLOC % sizeof(long) != 0)Mitchell Blank Jr
If SELECT_STACK_ALLOC is not a multiple of sizeof(long) then stack_fds[] would be shorter than SELECT_STACK_ALLOC bytes and could overflow later in the function. Fixed by simply rearranging the test later to work on sizeof(stack_fds) Currently SELECT_STACK_ALLOC is 256 so this doesn't happen, but it's nasty to have things like this hidden in the code. What if later someone decides to change SELECT_STACK_ALLOC to 300? Signed-off-by: Mitchell Blank Jr <mitch@sfgoth.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] select() warning fixesAndrew Morton
fs/select.c: In function `core_sys_select': fs/select.c:339: warning: assignment from incompatible pointer type fs/select.c:376: warning: comparison of distinct pointer types lacks a cast By using a void* we can remove lots of casts rather than adding more. Cc: Jes Sorensen <jes@trained-monkey.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] avoid unaligned access when accessing poll stackJes Sorensen
Commit 70674f95c0a2ea694d5c39f4e514f538a09be36f: [PATCH] Optimize select/poll by putting small data sets on the stack resulted in the poll stack being 4-byte aligned on 64-bit architectures, causing misaligned accesses to elements in the array. This patch fixes it by declaring the stack in terms of 'long' instead of 'char'. Force alignment of poll and select stacks to long to avoid unaligned access on 64 bit architectures. Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
