[ Upstream commit 088bf2ff5d12e2e32ee52a4024fec26e582f44d3 ]
seq_read() is a nasty piece of work, not to mention buggy.
It has (I think) an old bug which allows unprivileged userspace to read
beyond the end of m->buf.
I was getting these:
BUG: KASAN: slab-out-of-bounds in seq_read+0xcd2/0x1480 at addr ffff880116889880
Read of size 2713 by task trinity-c2/1329
CPU: 2 PID: 1329 Comm: trinity-c2 Not tainted 4.8.0-rc1+ #96
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
Call Trace:
kasan_object_err+0x1c/0x80
kasan_report_error+0x2cb/0x7e0
kasan_report+0x4e/0x80
check_memory_region+0x13e/0x1a0
kasan_check_read+0x11/0x20
proc_reg_read+0x10b/0x260
do_loop_readv_writev.part.5+0x140/0x2c0
do_readv_writev+0x589/0x860
vfs_readv+0x7b/0xd0
do_readv+0xd8/0x2c0
SyS_readv+0xb/0x10
do_syscall_64+0x1b3/0x4b0
entry_SYSCALL64_slow_path+0x25/0x25
Object at ffff880116889100, in cache kmalloc-4096 size: 4096
Allocated:
PID = 1329
save_stack_trace+0x26/0x80
save_stack+0x46/0xd0
kasan_kmalloc+0xad/0xe0
__kmalloc+0x1aa/0x4a0
seq_buf_alloc+0x35/0x40
seq_read+0x7d8/0x1480
vfs_readv+0x7b/0xd0
do_readv+0xd8/0x2c0
SyS_readv+0xb/0x10
return_from_SYSCALL_64+0x0/0x6a
Freed:
PID = 0
(stack is not available)
Memory state around the buggy address:
ffff88011688a000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff88011688a080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff88011688a100: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88011688a180: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff88011688a200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Disabling lock debugging due to kernel taint
This seems to be the same thing that Dave Jones was seeing here:
https://lkml.org/lkml/2016/8/12/334
There are multiple issues here:
1) If we enter the function with a non-empty buffer, there is an attempt
to flush it. But it was not clearing m->from after doing so, which
means that if we try to do this flush twice in a row without any call
to traverse() in between, we are going to be reading from the wrong
place -- the splat above, fixed by this patch.
2) If there's a short write to userspace because of page faults, the
buffer may already contain multiple lines (i.e. pos has advanced by
more than 1), but we don't save the progress that was made so the
next call will output what we've already returned previously. Since
that is a much less serious issue (and I have a headache after
staring at seq_read() for the past 8 hours), I'll leave that for now.
Link: http://lkml.kernel.org/r/1471447270-32093-1-git-send-email-vegard.nossum@oracle.com
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Cc: <stable@vger.kernel.org>
Now that all bitmap formatting usages have been converted to
'%*pb[l]', the separate formatting functions are unnecessary. The
following functions are removed.
* bitmap_scn[list]printf()
* cpumask_scnprintf(), cpulist_scnprintf()
* [__]nodemask_scnprintf(), [__]nodelist_scnprintf()
* seq_bitmap[_list](), seq_cpumask[_list](), seq_nodemask[_list]()
* seq_buf_bitmask()
Since commit 058504edd026 ("fs/seq_file: fallback to vmalloc allocation"),
seq_buf_alloc() falls back to vmalloc() when the kmalloc() for contiguous
memory fails. This was done to address order-4 slab allocations for
reading /proc/stat on large machines and noticed because
PAGE_ALLOC_COSTLY_ORDER < 4, so there is no infinite loop in the page
allocator when allocating new slab for such high-order allocations.
Contiguous memory isn't necessary for caller of seq_buf_alloc(), however.
Other GFP_KERNEL high-order allocations that are <=
PAGE_ALLOC_COSTLY_ORDER will simply loop forever in the page allocator and
oom kill processes as a result.
We don't want to kill processes so that we can allocate contiguous memory
in situations when contiguous memory isn't necessary.
This patch does the kmalloc() allocation with __GFP_NORETRY for high-order
allocations. This still utilizes memory compaction and direct reclaim in
the allocation path, the only difference is that it will fail immediately
instead of oom kill processes when out of memory.
[akpm@linux-foundation.org: add comment]
Signed-off-by: David Rientjes <rientjes@google.com>
The return values of seq_printf/puts/putc are frequently misused.
Start down a path to remove all the return value uses of these
functions.
Move the seq_overflow() to a global inlined function called
seq_has_overflowed() that can be used by the users of seq_file() calls.
Update the documentation to not show return types for seq_printf
et al. Add a description of seq_has_overflowed().
Link: http://lkml.kernel.org/p/848ac7e3d1c31cddf638a8526fa3c59fa6fdeb8a.1412031505.git.joe@perches.com
[ Reworked the original patch from Joe ]
There are a couple of seq_files which use the single_open() interface.
This interface requires that the whole output must fit into a single
buffer.
E.g. for /proc/stat allocation failures have been observed because an
order-4 memory allocation failed due to memory fragmentation. In such
situations reading /proc/stat is not possible anymore.
Therefore change the seq_file code to fallback to vmalloc allocations
which will usually result in a couple of order-0 allocations and hence
also work if memory is fragmented.
For reference a call trace where reading from /proc/stat failed:
sadc: page allocation failure: order:4, mode:0x1040d0
CPU: 1 PID: 192063 Comm: sadc Not tainted 3.10.0-123.el7.s390x #1
Call Trace:
show_stack+0x6c/0xe8
warn_alloc_failed+0xd6/0x138
__alloc_pages_nodemask+0x9da/0xb68
__get_free_pages+0x2e/0x58
kmalloc_order_trace+0x44/0xc0
stat_open+0x5a/0xd8
proc_reg_open+0x8a/0x140
do_dentry_open+0x1bc/0x2c8
finish_open+0x46/0x60
do_last+0x382/0x10d0
path_openat+0xc8/0x4f8
do_filp_open+0x46/0xa8
do_sys_open+0x114/0x1f0
sysc_tracego+0x14/0x1a
Tested-by: David Rientjes <rientjes@google.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Thorsten Diehl <thorsten.diehl@de.ibm.com>
Cc: Andrea Righi <andrea@betterlinux.com>
Cc: Stefan Bader <stefan.bader@canonical.com>
Once we'd freed m->buf, m->count should become zero - we have no valid
contents reachable via m->buf.
Reported-by: Charley (Hao Chuan) Chu <charley.chu@broadcom.com>
There are several users who want to know bytes written by seq_*() for
alignment purpose. Currently they are using %n format for knowing it
because seq_*() returns 0 on success.
This patch introduces seq_setwidth() and seq_pad() for allowing them to
align without using %n format.
Cc: Joe Perches <joe@perches.com>
This issue was first pointed out by Jiaxing Wang several months ago, but no
further comments:
https://lkml.org/lkml/2013/6/29/41
As we know pread() does not change f_pos, so after pread(), file->f_pos
and m->read_pos become different. And seq_lseek() does not update file->f_pos
if offset equals to m->read_pos, so after pread() and seq_lseek()(lseek to
m->read_pos), then a subsequent read may read from a wrong position, the
following program produces the problem:
char str1[32] = { 0 };
char str2[32] = { 0 };
int poffset = 10;
int count = 20;
/*open any seq file*/
int fd = open("/proc/modules", O_RDONLY);
pread(fd, str1, count, poffset);
printf("pread:%s\n", str1);
/*seek to where m->read_pos is*/
lseek(fd, poffset+count, SEEK_SET);
/*supposed to read from poffset+count, but this read from position 0*/
read(fd, str2, count);
printf("read:%s\n", str2);
out put:
pread:
ck_netbios_ns 12665
read:
nf_conntrack_netbios
/proc/modules:
nf_conntrack_netbios_ns 12665 0 - Live 0xffffffffa038b000
nf_conntrack_broadcast 12589 1 nf_conntrack_netbios_ns, Live 0xffffffffa0386000
So we always update file->f_pos to offset in seq_lseek() to fix this issue.
Signed-off-by: Jiaxing Wang <hello.wjx@gmail.com>
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
When we convert the file_lock_list to a set of percpu lists, we'll need
a way to iterate over them in order to output /proc/locks info. Add
some seq_list_*_percpu helpers to handle that.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: J. Bruce Fields <bfields@fieldses.org>
Same as single_open(), but preallocates the buffer of given size.
Doesn't make any sense for sizes up to PAGE_SIZE and doesn't make
sense if output of show() exceeds PAGE_SIZE only rarely - seq_read()
will take care of growing the buffer and redoing show(). If you
_know_ that it will be large, it might make more sense to look into
saner iterator, rather than go with single-shot one. If that's
impossible, single_open_size() might be for you.
Again, don't use that without a good reason; occasionally that's really
the best way to go, but very often there are better solutions.
Pull more VFS bits from Al Viro:
"Unfortunately, it looks like xattr series will have to wait until the
next cycle ;-/
This pile contains 9p cleanups and fixes (races in v9fs_fid_add()
etc), fixup for nommu breakage in shmem.c, several cleanups and a bit
more file_inode() work"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
constify path_get/path_put and fs_struct.c stuff
fix nommu breakage in shmem.c
cache the value of file_inode() in struct file
9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry
9p: make sure ->lookup() adds fid to the right dentry
9p: untangle ->lookup() a bit
9p: double iput() in ->lookup() if d_materialise_unique() fails
9p: v9fs_fid_add() can't fail now
v9fs: get rid of v9fs_dentry
9p: turn fid->dlist into hlist
9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine
more file_inode() open-coded instances
selinux: opened file can't have NULL or negative ->f_path.dentry
(In the meantime, the hlist traversal macros have changed, so this
required a semantic conflict fixup for the newly hlistified fid->dlist)
[akpm@linux-foundation.org: checkpatch fixes]
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Fix kernel-doc warnings in fs/seq_file.c:
Warning(fs/seq_file.c:304): No description found for parameter 'whence'
Warning(fs/seq_file.c:304): Excess function parameter 'origin' description in 'seq_lseek'
But the kernel decided to call it "origin" instead. Fix most of the
sites.
struct file already has a user namespace associated with it
in file->f_cred->user_ns, unfortunately because struct
seq_file has no struct file backpointer associated with
it, it is difficult to get at the user namespace in seq_file
context. Therefore add a helper function seq_user_ns to return
the associated user namespace and a user_ns field to struct
seq_file to be used in implementing seq_user_ns.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
The existing seq_printf function is rewritten in terms of the new
seq_vprintf which is also exported to modules. This allows GFS2
(and potentially other seq_file users) to have a vprintf based
interface and to avoid an extra copy into a temporary buffer in
some cases.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
It is undocumented but a seq_file's overflow state is indicated by
m->count == m->size. Add seq_set_overflow() and seq_overflow() to
set/check overflow status explicitly.
Based on an idea from Eric Dumazet.
[akpm@linux-foundation.org: tweak code comment]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Process accounting applications as top, ps visit some files under
/proc/<pid>. With seq_put_decimal_ull(), we can optimize /proc/<pid>/stat
and /proc/<pid>/statm files.
This patch adds
- seq_put_decimal_ll() for signed values.
- allow delimiter == 0.
- convert seq_printf() to seq_put_decimal_ull/ll in /proc/stat, statm.
Test result on a system with 2000+ procs.
Before patch:
[kamezawa@bluextal test]$ top -b -n 1 | wc -l
2223
[kamezawa@bluextal test]$ time top -b -n 1 > /dev/null
real 0m0.675s
user 0m0.044s
sys 0m0.121s
[kamezawa@bluextal test]$ time ps -elf > /dev/null
real 0m0.236s
user 0m0.056s
sys 0m0.176s
After patch:
kamezawa@bluextal ~]$ time top -b -n 1 > /dev/null
real 0m0.657s
user 0m0.052s
sys 0m0.100s
[kamezawa@bluextal ~]$ time ps -elf > /dev/null
real 0m0.198s
user 0m0.050s
sys 0m0.145s
Considering top, ps tend to scan /proc periodically, this will reduce cpu
consumption by top/ps to some extent.
== stat_check.py
num = 0
with open("/proc/stat") as f:
while num < 1000 :
data = f.read()
f.seek(0, 0)
num = num + 1
perf shows
20.39% stat_check.py [kernel.kallsyms] [k] format_decode
13.41% stat_check.py [kernel.kallsyms] [k] number
12.61% stat_check.py [kernel.kallsyms] [k] vsnprintf
10.85% stat_check.py [kernel.kallsyms] [k] memcpy
4.85% stat_check.py [kernel.kallsyms] [k] radix_tree_lookup
4.43% stat_check.py [kernel.kallsyms] [k] seq_printf
This patch removes most of calls to vsnprintf() by adding num_to_str()
and seq_print_decimal_ull(), which prints decimal numbers without rich
functions provided by printf().
On my 8cpu box.
== Before patch ==
[root@bluextal test]# time ./stat_check.py
real 0m0.150s
user 0m0.026s
sys 0m0.121s
== After patch ==
real 0m0.055s
user 0m0.022s
sys 0m0.030s
[akpm@linux-foundation.org: remove incorrect comment, use less statck in num_to_str(), move comment from .h to .c, simplify seq_put_decimal_ull()]
[andrea@betterlinux.com: avoid breaking the ABI in /proc/stat]
Signed-off-by: Andrea Righi <andrea@betterlinux.com>
Cc: Glauber Costa <glommer@parallels.com>
Cc: Paul Turner <pjt@google.com>
The following program illustrates the problem:
char buf[8192];
int fd = open("/proc/self/maps", O_RDONLY);
n = pread(fd, buf, sizeof(buf), 0);
printf("%d\n", n);
/* lseek(fd, 0, SEEK_CUR); */ /* Uncomment to work around */
printf("%d\n", n);
The second printf() prints zero, but uncommenting the lseek() corrects its
behaviour.
To fix, make seq_read() mirror seq_lseek() when processing changes in
*ppos. Restore m->version first, then if required traverse and update
read_pos on success.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=11856
Signed-off-by: Earl Chew <echew@ixiacom.com>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
Cc: stable@vger.kernel.org
All callers take dcache_lock just around the call to __d_path, so
take the lock into it in preparation of getting rid of dcache_lock.
Fix kernel-doc notation in new seq-file functions and
correct spelling.
Cc: Li Zefan <lizf@cn.fujitsu.com>
Many usages of seq_file use RCU protected lists, so non RCU
iterators will not work safely.
Some places in kernel need to iterate over a hlist in seq_file,
so provide some common helpers.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Add two helpers that allow access to the seq_file's own buffer, but
hide the internal details of seq_files.
This allows easier implementation of special purpose filling
functions. It also cleans up some existing functions which duplicated
the seq_file logic.
Make these inline functions in seq_file.h, as suggested by Al.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
seq_path_root() is returning a return value of successful __d_path()
instead of returning a negative value when mangle_path() failed.
This is not a bug so far because nobody is using return value of
seq_path_root().
seq_write() can be used to construct seq_files containing arbitrary data.
Required by the gcov-profiling interface to synthesize binary profiling
data files.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Cc: Huang Ying <ying.huang@intel.com>
Cc: Li Wei <W.Li@Sun.COM>
Cc: Michael Ellerman <michaele@au1.ibm.com>
Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com>
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Jeff Dike <jdike@addtoit.com>
1) seq_bitmap_list() should take a const.
2) All the seq_bitmap should use cpumask_bits().
Currently seq_read assumes that the offset passed to it is always the
offset it passed to user space. In the case pread this assumption is
broken and we do the wrong thing when presented with pread.
To solve this I introduce an offset cache inside of struct seq_file so we
know where our logical file position is. Then in seq_read if we try to
read from another offset we reset our data structures and attempt to go to
the offset user space wanted.
[akpm@linux-foundation.org: restore FMODE_PWRITE]
[pjt@google.com: seq_open needs its fmode opened up to take advantage of this]
Signed-off-by: Eric Biederman <ebiederm@xmission.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x, 2.6.27.x, 2.6.28.x]
lseek() further than length of the file will leave stale ->index
(second-to-last during iteration). Next seq_read() will not notice
that ->f_pos is big enough to return 0, but will print last item
as if ->f_pos is pointing to it.
Introduced in commit cb510b8172602a66467f3551b4be1911f5a7c8c2
aka "seq_file: more atomicity in traverse()".
In 2.6.25 some /proc files were converted to use the seq_file
infrastructure. But seq_files do not correctly support pread(), which
broke some usersapce applications.
To handle pread correctly we can't assume that f_pos is where we left it
in seq_read. So move traverse() so that we can eventually use it in
seq_read and do thus some day support pread().
* 'cpus4096-for-linus-3' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (77 commits)
x86: setup_per_cpu_areas() cleanup
cpumask: fix compile error when CONFIG_NR_CPUS is not defined
cpumask: use alloc_cpumask_var_node where appropriate
cpumask: convert shared_cpu_map in acpi_processor* structs to cpumask_var_t
x86: use cpumask_var_t in acpi/boot.c
x86: cleanup some remaining usages of NR_CPUS where s/b nr_cpu_ids
sched: put back some stack hog changes that were undone in kernel/sched.c
x86: enable cpus display of kernel_max and offlined cpus
ia64: cpumask fix for is_affinity_mask_valid()
cpumask: convert RCU implementations, fix
xtensa: define __fls
mn10300: define __fls
m32r: define __fls
h8300: define __fls
frv: define __fls
cris: define __fls
cpumask: CONFIG_DISABLE_OBSOLETE_CPUMASK_FUNCTIONS
cpumask: zero extra bits in alloc_cpumask_var_node
cpumask: replace for_each_cpu_mask_nr with for_each_cpu in kernel/time/
cpumask: convert mm/
Explain that you really need to use the return value of d_path rather than
the buffer you passed into it.
Also fix the comment for seq_path(), the function arguments changed
recently but the comment hadn't been updated in sync.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Impact: cleanup
seq_bitmap just calls bitmap_scnprintf on the bits: that arg can be const.
Similarly, seq_cpumask just calls seq_bitmap.
mangle_path() is trivial enough to make export restrictions on it
pointless - so change the export from EXPORT_SYMBOL_GPL to EXPORT_SYMBOL.
Impact: use standard docbook tags
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Török Edwin <edwintorok@gmail.com>
Impact: expose new VFS API
make mangle_path() available, as per the suggestions of Christoph Hellwig
and Al Viro:
http://lkml.org/lkml/2008/11/4/338
seq_cpumask_list(), seq_nodemask_list() are very like seq_cpumask(),
seq_nodemask(), but they print human readable string.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Paul Menage <menage@google.com>
Cc: Paul Jackson <pj@sgi.com>
"m->count + len < m->size" is true commonly, so bitmap_scnprintf()
is commonly called. this fix saves a call to bitmap_scnprintf_len().
seq_read() has a subtle bug - we want the first loop there to go
until at least one *non-empty* record had fit entirely into buffer.
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no
good reason.
This became noticed with NR_CPUS=4096 patches, when length of printed
representation of cpumask becase 1152, but cat(1) continued to read with
1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns
1023, check returns -EINVAL.
Fix it by switching to seq_file, so handler will just fill buffer and
doesn't care about offsets, length, filling EOF and all this crap.
For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and
seq_nodemask().
Reviewed-by: Paul Jackson <pj@sgi.com>
Cc: Mike Travis <travis@sgi.com>
Add a new function:
seq_file_root()
This is similar to seq_path(), but calculates the path relative to the
given root, instead of current->fs->root. If the path was unreachable
from root, then modify the root parameter to reflect this.
[mszeredi@suse.cz] split big patch into managable chunks
Add the following functions:
dentry_path()
seq_dentry()
These are similar to d_path() and seq_path(). But instead of
calculating the path within a mount namespace, they calculate the path
from the root of the filesystem to a given dentry, ignoring mounts
completely.
Signed-off-by: Ram Pai <linuxram@us.ibm.com>
