commit 3ead7c52bdb0ab44f4bb1feed505a8323cc12ba7 upstream.
This function may copy the si_addr_lsb field to user mode when it hasn't
been initialized, which can leak kernel stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
seq_printf functions shouldn't really check the return value.
Checking seq_has_overflowed() occasionally is used instead.
Update vfs documentation.
Link: http://lkml.kernel.org/p/e37e6e7b76acbdcc3bb4ab2a57c8f8ca1ae11b9a.1412031505.git.joe@perches.com
[ did a few clean ups ]
This allows us to print out eventpoll target file descriptor, events and
data, the /proc/pid/fdinfo/fd consists of
| pos: 0
| flags: 02
| tfd: 5 events: 1d data: ffffffffffffffff enabled: 1
[avagin@: fix for unitialized ret variable]
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Andrey Vagin <avagin@openvz.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: James Bottomley <jbottomley@parallels.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Matthew Helsley <matt.helsley@gmail.com>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk>
signalfd_cleanup() ensures that ->signalfd_wqh is not used, but
this is not enough. eppoll_entry->whead still points to the memory
we are going to free, ep_unregister_pollwait()->remove_wait_queue()
is obviously unsafe.
Change ep_poll_callback(POLLFREE) to set eppoll_entry->whead = NULL,
change ep_unregister_pollwait() to check pwq->whead != NULL under
rcu_read_lock() before remove_wait_queue(). We add the new helper,
ep_remove_wait_queue(), for this.
This works because sighand_cachep is SLAB_DESTROY_BY_RCU and because
->signalfd_wqh is initialized in sighand_ctor(), not in copy_sighand.
ep_unregister_pollwait()->remove_wait_queue() can play with already
freed and potentially reused ->sighand, but this is fine. This memory
must have the valid ->signalfd_wqh until rcu_read_unlock().
Reported-by: Maxime Bizon <mbizon@freebox.fr>
Cc: <stable@kernel.org>
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (22 commits)
Add _addr_lsb field to ia64 siginfo
Fix migration.c compilation on s390
HWPOISON: Remove retry loop for try_to_unmap
HWPOISON: Turn addr_valid from bitfield into char
HWPOISON: Disable DEBUG by default
HWPOISON: Convert pr_debugs to pr_info
HWPOISON: Improve comments in memory-failure.c
x86: HWPOISON: Report correct address granuality for huge hwpoison faults
Encode huge page size for VM_FAULT_HWPOISON errors
Fix build error with !CONFIG_MIGRATION
hugepage: move is_hugepage_on_freelist inside ifdef to avoid warning
Clean up __page_set_anon_rmap
HWPOISON, hugetlb: fix unpoison for hugepage
HWPOISON, hugetlb: soft offlining for hugepage
HWPOSION, hugetlb: recover from free hugepage error when !MF_COUNT_INCREASED
hugetlb: move refcounting in hugepage allocation inside hugetlb_lock
HWPOISON, hugetlb: add free check to dequeue_hwpoison_huge_page()
hugetlb: hugepage migration core
hugetlb: redefine hugepage copy functions
hugetlb: add allocate function for hugepage migration
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Similar change as to signal delivery: copy out the si_addr_lsb field
to user space in signalfd
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
If signalfd is used to consume a signal generated by a POSIX interval
timer or POSIX message queue, the ssi_int field does not reflect the data
(sigevent->sigev_value) supplied to timer_create(2) or mq_notify(3). (The
ssi_ptr field, however, is filled in.)
This behavior differs from signalfd's treatment of sigqueue-generated
signals -- see the default case in signalfd_copyinfo. It also gives
results that differ from the case when a signal is handled conventionally
via a sigaction-registered handler.
So, set signalfd_siginfo->ssi_int in the remaining cases (__SI_TIMER,
__SI_MESGQ) where ssi_ptr is set.
akpm: a non-back-compatible change. Merge into -stable to minimise the
number of kernels which are in the field and which miss this feature.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
Acked-by: Davide Libenzi <davidel@xmailserver.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
It seems a couple places such as arch/ia64/kernel/perfmon.c and
drivers/infiniband/core/uverbs_main.c could use anon_inode_getfile()
instead of a private pseudo-fs + alloc_file(), if only there were a way
to get a read-only file. So provide this by having anon_inode_getfile()
create a read-only file if we pass O_RDONLY in flags.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
This patch adds test that ensure the boundary conditions for the various
constants introduced in the previous patches is met. No code is generated.
[akpm@linux-foundation.org: fix alpha]
Signed-off-by: Ulrich Drepper <drepper@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
This patch adds support for the SFD_NONBLOCK flag to signalfd4. The
additional changes needed are minimal.
The following test must be adjusted for architectures other than x86 and
x86-64 and in case the syscall numbers changed.
#include <fcntl.h>
#include <signal.h>
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#ifndef __NR_signalfd4
# ifdef __x86_64__
# define __NR_signalfd4 289
# elif defined __i386__
# define __NR_signalfd4 327
# else
# error "need __NR_signalfd4"
# endif
#endif
#define SFD_NONBLOCK O_NONBLOCK
int
main (void)
sigset_t ss;
sigemptyset (&ss);
sigaddset (&ss, SIGUSR1);
int fd = syscall (__NR_signalfd4, -1, &ss, 8, 0);
if (fd == -1)
puts ("signalfd4(0) failed");
return 1;
int fl = fcntl (fd, F_GETFL);
if (fl == -1)
puts ("fcntl failed");
return 1;
if (fl & O_NONBLOCK)
puts ("signalfd4(0) set non-blocking mode");
return 1;
close (fd);
fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_NONBLOCK);
if (fd == -1)
puts ("signalfd4(SFD_NONBLOCK) failed");
return 1;
if (fl == -1)
return 1;
if ((fl & O_NONBLOCK) == 0)
puts ("signalfd4(SFD_NONBLOCK) does not set non-blocking mode");
return 1;
close (fd);
puts ("OK");
return 0;
This patch adds the new signalfd4 syscall. It extends the old signalfd
syscall by one parameter which is meant to hold a flag value. In this
patch the only flag support is SFD_CLOEXEC which causes the close-on-exec
flag for the returned file descriptor to be set.
A new name SFD_CLOEXEC is introduced which in this implementation must
have the same value as O_CLOEXEC.
#include <fcntl.h>
#include <signal.h>
#include <stdio.h>
#include <unistd.h>
# ifdef __x86_64__
# else
# endif
#endif
#define SFD_CLOEXEC O_CLOEXEC
int
main (void)
sigset_t ss;
sigemptyset (&ss);
if (fd == -1)
return 1;
int coe = fcntl (fd, F_GETFD);
if (coe == -1)
return 1;
if (coe & FD_CLOEXEC)
puts ("signalfd4(0) set close-on-exec flag");
return 1;
close (fd);
fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_CLOEXEC);
if (fd == -1)
puts ("signalfd4(SFD_CLOEXEC) failed");
return 1;
if (coe == -1)
return 1;
if ((coe & FD_CLOEXEC) == 0)
puts ("signalfd4(SFD_CLOEXEC) does not set close-on-exec flag");
return 1;
close (fd);
puts ("OK");
return 0;
[akpm@linux-foundation.org: add sys_ni stub]
Cc: <linux-arch@vger.kernel.org>
This patch just extends the anon_inode_getfd interface to take an additional
parameter with a flag value. The flag value is passed on to
get_unused_fd_flags in anticipation for a use with the O_CLOEXEC flag.
No actual semantic changes here, the changed callers all pass 0 for now.
[akpm@linux-foundation.org: KVM fix]
a) none of the callers even looks at inode or file returned by anon_inode_getfd()
b) any caller that would try to look at those would be racy, since by the time
it returns we might have raced with close() from another thread and that
file would be pining for fjords.
Michael Kerrisk found out that signalfd was not reporting back user data
pushed using sigqueue:
http://groups.google.com/group/linux.kernel/msg/9397cab8551e3123
The following patch makes signalfd report back the ssi_ptr and ssi_int members
of the signalfd_siginfo structure.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
Acked-by: Michael Kerrisk <mtk.manpages@googlemail.com>
Every file should include the headers containing the prototypes for its global
functions (in this case sys_signalfd()).
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Davide Libenzi <davidel@xmailserver.org>
For Michael Kerrisk request, the following patch renames signalfd_siginfo
fields in order to keep them consistent with the siginfo_t ones.
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
This simplifies signalfd code, by avoiding it to remain attached to the
sighand during its lifetime.
In this way, the signalfd remain attached to the sighand only during
poll(2) (and select and epoll) and read(2). This also allows to remove
all the custom "tsk == current" checks in kernel/signal.c, since
dequeue_signal() will only be called by "current".
I think this is also what Ben was suggesting time ago.
The external effect of this, is that a thread can extract only its own
private signals and the group ones. I think this is an acceptable
behaviour, in that those are the signals the thread would be able to
fetch w/out signalfd.
With this patch any thread can dequeue its own private signals via signalfd,
even if it was created by another sub-thread.
To do so, we pass "current" to dequeue_signal() if the caller is from the same
thread group. This also fixes the scheduling of posix timers broken by the
previous patch.
If the caller doesn't belong to this thread group, we can't handle __SI_TIMER
case properly anyway. Perhaps we should forbid the cross-process signalfd usage
and convert ctx->tsk to ctx->sighand.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Roland McGrath <roland@redhat.com>
This is probably a leftover from a time when the return wasn't there yet.
Now the extra assignment is just irritating.
The new code in kernel/signal.c does not allow fetching private signals
from another task. This patch avoid spurious POLLIN returns from a
signalfd poll(2) operation.
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Gathering signals in bulk enables server applications to drain a signal
queue (almost full of realtime signals) more efficiently by reducing the
syscall and file look-up overhead.
Very similar to the sigtimedwait4() call described by Niels Provos, Chuck
Lever, and Stephen Tweedie in a paper entitled "Analyzing the Overload
Behavior of a Simple Web Server". The paper lists more details and
advantages.
Signed-off-by: Davi E. M. Arnaut <davi@haxent.com.br>
This patch series implements the new signalfd() system call.
I took part of the original Linus code (and you know how badly it can be
broken :), and I added even more breakage ;) Signals are fetched from the same
signal queue used by the process, so signalfd will compete with standard
kernel delivery in dequeue_signal(). If you want to reliably fetch signals on
the signalfd file, you need to block them with sigprocmask(SIG_BLOCK). This
seems to be working fine on my Dual Opteron machine. I made a quick test
program for it:
http://www.xmailserver.org/signafd-test.c
The signalfd() system call implements signal delivery into a file descriptor
receiver. The signalfd file descriptor if created with the following API:
int signalfd(int ufd, const sigset_t *mask, size_t masksize);
The "ufd" parameter allows to change an existing signalfd sigmask, w/out going
to close/create cycle (Linus idea). Use "ufd" == -1 if you want a brand new
signalfd file.
The "mask" allows to specify the signal mask of signals that we are interested
in. The "masksize" parameter is the size of "mask".
The signalfd fd supports the poll(2) and read(2) system calls. The poll(2)
will return POLLIN when signals are available to be dequeued. As a direct
consequence of supporting the Linux poll subsystem, the signalfd fd can use
used together with epoll(2) too.
The read(2) system call will return a "struct signalfd_siginfo" structure in
the userspace supplied buffer. The return value is the number of bytes copied
in the supplied buffer, or -1 in case of error. The read(2) call can also
return 0, in case the sighand structure to which the signalfd was attached,
has been orphaned. The O_NONBLOCK flag is also supported, and read(2) will
return -EAGAIN in case no signal is available.
If the size of the buffer passed to read(2) is lower than sizeof(struct
signalfd_siginfo), -EINVAL is returned. A read from the signalfd can also
return -ERESTARTSYS in case a signal hits the process. The format of the
struct signalfd_siginfo is, and the valid fields depends of the (->code &
__SI_MASK) value, in the same way a struct siginfo would:
struct signalfd_siginfo {
__u32 signo; /* si_signo */
__s32 err; /* si_errno */
__s32 code; /* si_code */
__u32 pid; /* si_pid */
__u32 uid; /* si_uid */
__s32 fd; /* si_fd */
__u32 tid; /* si_fd */
__u32 band; /* si_band */
__u32 overrun; /* si_overrun */
__u32 trapno; /* si_trapno */
__s32 status; /* si_status */
__s32 svint; /* si_int */
__u64 svptr; /* si_ptr */
__u64 utime; /* si_utime */
__u64 stime; /* si_stime */
__u64 addr; /* si_addr */
[akpm@linux-foundation.org: fix signalfd_copyinfo() on i386]
