path: root/fs/smbfs/sock.c
2008-02-06smbfs: fix calculation of kernel_recvmsg size parameter in smb_receive()Jeff Layton
smb_receive calls kernel_recvmsg with a size that's the minimum of the amount of buffer space in the kvec passed in or req->rq_rlen (which represents the length of the response). This does not take into account any data that was read in a request earlier pass through smb_receive. If the first pass through smb_receive receives some but not all of the response, then the next pass can call kernel_recvmsg with a size field that's too big. kernel_recvmsg can overrun into the next response, throwing off the alignment and making it unrecognizable. This causes messages like this to pop up in the ring buffer: smb_get_length: Invalid NBT packet, code=69 as well as other errors indicating that the response is unrecognizable. Typically this is seen on a smbfs mount under heavy I/O. This patch changes the code to use (req->rq_rlen - req->rq_bytes_recvd) instead instead of just req->rq_rlen, since that should represent the amount of unread data in the response. I think this is correct, but an ACK or NACK from someone more familiar with this code would be appreciated... Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert smbfsJosef Sipek
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
