path: root/fs/squashfs/namei.c
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-10Squashfs: remove redundant length initialisation in squashfs_lookupPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2012-03-10Squashfs: use define instead of constantAjeet Yadav
Its better to use defined name instead of constant Signed-off-by: Ajeet Yadav <ajeet.yadav.77@gmail.com> Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20deuglify squashfs_lookup()Al Viro
d_splice_alias(NULL, dentry) is equivalent to d_add(dentry, NULL), NULL so no need for that if (inode) ... in there (or ERR_PTR(0), for that matter) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Squashfs: update email addressPhillip Lougher
My existing email address may stop working in a month or two, so update email to one that will continue working. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2011-03-16Squashfs: handle corruption of directory structurePhillip Lougher
Handle the rare case where a directory metadata block is uncompressed and corrupted, leading to a kernel oops in directory scanning (memcpy). Normally corruption is detected at the decompression stage and dealt with then, however, this will not happen if: - metadata isn't compressed (users can optionally request no metadata compression), or - the compressed metadata block was larger than the original, in which case the uncompressed version was used, or - the data was corrupt after decompression This patch fixes this by adding some sanity checks against known maximum values. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add xattr support configure optionPhillip Lougher
2010-05-17squashfs: add new extended inode typesPhillip Lougher
Add new extended inode types that store the xattr_id field. Also add the necessary code changes to make xattrs visibile. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-01-20Squashfs: factor out remaining zlib dependencies into separate wrapper filePhillip Lougher
Move zlib buffer init/destroy code into separate wrapper file. Also make zlib z_stream field a void * removing the need to include zlib.h for most files. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-01-05Squashfs: directory lookup operationsPhillip Lougher
