path: root/fs/squashfs
2010-10-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: fix function prototype Squashfs: fix use of __le64 annotated variable
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-28Squashfs: fix function prototypePhillip Lougher
The fourth argument should be unsigned. Also add missing include so that the function prototype is defined in xattr_id.c This fixes a couple of sparse warnings. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-10-28Squashfs: fix use of __le64 annotated variablePhillip Lougher
This fixes a sparse with endian checking warning. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-10-04BKL: Remove BKL from squashfsArnd Bergmann
The BKL is only used in put_super and fill_super, which are both protected by the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL entirely. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-08Squashfs: fix checkpatch.pl warningsPhillip Lougher
Checkpatch.pl in 2.6.34 added a check for spaces between tabs. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-08-05Squashfs: fix filename typoPhillip Lougher
2010-08-05Squashfs: update Kconfig and documentation for LZOPhillip Lougher
Update compression types supported and add some help text for the LZO Kconfig option. Also add missing "default n" line and make some trivial whitespace cleanups too. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-08-05Squashfs: fix block size use in LZO decompressorPhillip Lougher
Sizing the buffer using block size alone is incorrect leading to a potential buffer over-run on 4K block size file systems (because the metadata block size is always 8K). Srclength is set to the maximum expected size of the decompressed block and it is block_size or 8K depending on whether a data or metadata block is being decompressed. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-08-05Squashfs: Add LZO compression supportChan Jeong
Signed-off-by: Chan Jeong <chan.jeong@lge.com> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-31squashfs: fix filename in header commentPhillip Lougher
2010-05-31Squashfs: Make XATTR config name consistent with other file systemsPhillip Lougher
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-31squashfs: fix compiler inline warningPhillip Lougher
Fix compiler warning where inline conflicts with non-inline prototype. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-23squashfs: fix name reading in squashfs_xattr_getPhillip Lougher
Only read potentially matching names into the target buffer, all obviously non matching names don't need to be read into the target buffer. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-23squashfs: constify xattr handlersPhillip Lougher
2010-05-17squashfs: xattr fix sparse warningsStephen Hemminger
Sparse does not like inline function declared without body, because it is not part of the standard kernel practice. The xattr_handler tables can be declared static. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: xattr_lookup sparse fixStephen Hemminger
Sparse detected that unsigned pointer was being passed as int pointer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> [fixed up to deal with code refactoring] Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add xattr support configure optionPhillip Lougher
2010-05-17squashfs: add new extended inode typesPhillip Lougher
Add new extended inode types that store the xattr_id field. Also add the necessary code changes to make xattrs visibile. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add support for xattr readingPhillip Lougher
Add support for listxattr and getxattr. Also add xattr definitions. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add xattr id supportPhillip Lougher
This patch adds support for mapping xattr ids (stored in inodes) into the on-disk location of the xattrs themselves. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-04-25squashfs: fix potential buffer over-run on 4K block file systemsPhillip Lougher
Sizing the buffer based on block size is incorrect, leading to a potential buffer over-run on 4K block size file systems (because the metadata block size is always 8K). This bug doesn't seem have triggered because 4K block size file systems are not default, and also because metadata blocks after compression tend to be less than 4K. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-04-25squashfs: add missing buffer freePhillip Lougher
2010-04-25squashfs: fix warn_on when root inode is corruptedPhillip Lougher
Fix warn_on triggered by mounting a fsfuzzer corrupted file system, where the root inode has been corrupted. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Reported-by: Steve Grubb <sgrubb@redhat.com>
2010-04-23squashfs: fix locking bug in zlib wrapperPhillip Lougher
Fix locking bug in zlib wrapper introduced by recent decompressor changes. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05Squashfs: get rid of obsolete definition in header filePhillip Lougher
2010-03-05Squashfs: get rid of obsolete variable in struct squashfs_sb_infoPhillip Lougher
2010-01-20Squashfs: add decompressor entries for lzma and lzoPhillip Lougher
Add knowledge of lzma/lzo compression formats to the decompressor framework. For now these are added as unsupported. Without these entries lzma/lzo compressed filesystems will be flagged as having unknown compression which is undesirable. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-01-20Squashfs: add a decompressor frameworkPhillip Lougher
This adds a decompressor framework which allows multiple compression algorithms to be cleanly supported. Also update zlib wrapper and other code to use the new framework. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-01-20Squashfs: factor out remaining zlib dependencies into separate wrapper filePhillip Lougher
Move zlib buffer init/destroy code into separate wrapper file. Also make zlib z_stream field a void * removing the need to include zlib.h for most files. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-01-20Squashfs: move zlib decompression wrapper code into a separate filePhillip Lougher
2009-09-22const: mark remaining super_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-13Squashfs: cody tidying, remove commented out line in MakefilePhillip Lougher
2009-05-13Squashfs: check page size is not larger than the filesystem block sizePhillip Lougher
Normally the block size (by default 128K) will be larger than the page size, unless a non-standard block size has been specified in Mksquashfs, and the page size is larger than 4K. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-05-13Squashfs: fix breakage when page size > metadata block sizeDoug Chapman
Squashfs is broken on any system where the page size is larger than the metadata size (8192). This is easily fixed by ensuring cache->pages is always > 0. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Doug Chapman <doug.chapman@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-04-06Merge branch 'kmemtrace-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: kmemtrace: trace kfree() calls with NULL or zero-length objects kmemtrace: small cleanups kmemtrace: restore original tracing data binary format, improve ABI kmemtrace: kmemtrace_alloc() must fill type_id kmemtrace: use tracepoints kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints kmemtrace, rcu: fix rcupreempt.c data structure dependencies kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c kmemtrace, squashfs: fix slab.h dependency problem in squasfs kmemtrace, befs: fix slab.h dependency problem kmemtrace, security: fix linux/key.h header file dependencies kmemtrace, fs: fix linux/fdtable.h header file dependencies kmemtrace, fs: uninline simple_transaction_set() kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
2009-04-03kmemtrace, squashfs: fix slab.h dependency problem in squasfsPekka Enberg
Impact: cleanup fs/squashfs/export.c depends on slab.h without including it: CC fs/squashfs/export.o fs/squashfs/export.c: In function ‘squashfs_read_inode_lookup_table’: fs/squashfs/export.c:133: error: implicit declaration of function ‘kmalloc’ fs/squashfs/export.c:133: warning: assignment makes pointer from integer without a cast fs/squashfs/export.c:143: error: implicit declaration of function ‘kfree’ make[1]: *** [fs/squashfs/export.o] Error 1 make: *** [fs/squashfs/] Error 2 It gets included implicitly currently - but this will not be the case with upcoming kmemtrace changes. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> LKML-Reference: <1237884999.25315.41.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-02fs/squashfs: return f_fsid for statfs(2)Coly Li
Make squashfs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12Squashfs: Valid filesystems are flagged as bad by the corrupted fs patchPhillip Lougher
The corrupted filesystem patch added a check against zlib trying to output too much data in the presence of data corruption. This check triggered if zlib_inflate asked to be called again (Z_OK) with avail_out == 0 and no more output buffers available. This check proves to be rather dumb, as it incorrectly catches the case where zlib has generated all the output, but there are still input bytes to be processed. This patch does a number of things. It removes the original check and replaces it with code to not move to the next output buffer if there are no more output buffers available, relying on zlib to error if it wants an extra output buffer in the case of data corruption. It also replaces the Z_NO_FLUSH flag with the more correct Z_SYNC_FLUSH flag, and makes the error messages more understandable to non-technical users. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk> Reported-by: Stefan Lippers-Hollmann <s.L-H@gmx.de>
2009-03-05Squashfs: frag_size should be signed, as it can hold an error resultRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-03-05Squashfs: Fix oops when reading fsfuzzer corrupted filesystemsPhillip Lougher
This fixes a code regression caused by the recent mainlining changes. The recent code changes call zlib_inflate repeatedly, decompressing into separate 4K buffers, this code didn't check for the possibility that zlib_inflate might ask for too many buffers when decompressing corrupted data. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2009-01-22fs/Kconfig: move squashfs outAlexey Dobriyan
2009-01-15btrfs & squashfs: Move btrfs and squashfsto's magic number to <linux/magic.h>Qinghuang Feng
Use the standard magic.h for btrfs and squashfs. Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com> Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05Squashfs: MakefilesPhillip Lougher
