commit 44cff8a9ee8a974f9e931df910688e7fc1f0b0f9 upstream.
Handle the rare case where a directory metadata block is uncompressed and
corrupted, leading to a kernel oops in directory scanning (memcpy).
Normally corruption is detected at the decompression stage and dealt with
then, however, this will not happen if:
- metadata isn't compressed (users can optionally request no metadata
compression), or
- the compressed metadata block was larger than the original, in which
case the uncompressed version was used, or
- the data was corrupt after decompression
This patch fixes this by adding some sanity checks against known maximum
values.
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
Normally the block size (by default 128K) will be larger than the
page size, unless a non-standard block size has been specified in
Mksquashfs, and the page size is larger than 4K.
Squashfs is broken on any system where the page size is larger than
the metadata size (8192). This is easily fixed by ensuring cache->pages
is always > 0.
Signed-off-by: Doug Chapman <doug.chapman@hp.com>
* 'kmemtrace-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
kmemtrace: trace kfree() calls with NULL or zero-length objects
kmemtrace: small cleanups
kmemtrace: restore original tracing data binary format, improve ABI
kmemtrace: kmemtrace_alloc() must fill type_id
kmemtrace: use tracepoints
kmemtrace, rcu: don't include unnecessary headers, allow kmemtrace w/ tracepoints
kmemtrace, rcu: fix rcupreempt.c data structure dependencies
kmemtrace, rcu: fix rcu_tree_trace.c data structure dependencies
kmemtrace, rcu: fix linux/rcutree.h and linux/rcuclassic.h dependencies
kmemtrace, mm: fix slab.h dependency problem in mm/failslab.c
kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_unlzma.c
kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_bunzip2.c
kmemtrace, kbuild: fix slab.h dependency problem in lib/decompress_inflate.c
kmemtrace, squashfs: fix slab.h dependency problem in squasfs
kmemtrace, befs: fix slab.h dependency problem
kmemtrace, security: fix linux/key.h header file dependencies
kmemtrace, fs: fix linux/fdtable.h header file dependencies
kmemtrace, fs: uninline simple_transaction_set()
kmemtrace, fs, security: move alloc_secdata() and free_secdata() to linux/security.h
Impact: cleanup
fs/squashfs/export.c depends on slab.h without including it:
CC fs/squashfs/export.o
fs/squashfs/export.c: In function ‘squashfs_read_inode_lookup_table’:
fs/squashfs/export.c:133: error: implicit declaration of function ‘kmalloc’
fs/squashfs/export.c:133: warning: assignment makes pointer from integer without a cast
fs/squashfs/export.c:143: error: implicit declaration of function ‘kfree’
make[1]: *** [fs/squashfs/export.o] Error 1
make: *** [fs/squashfs/] Error 2
It gets included implicitly currently - but this will not be the
case with upcoming kmemtrace changes.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro>
LKML-Reference: <1237884999.25315.41.camel@penberg-laptop>
Make squashfs return f_fsid info for statfs(2).
Signed-off-by: Coly Li <coly.li@suse.de>
Cc: Phillip Lougher <phillip@lougher.demon.co.uk>
The corrupted filesystem patch added a check against zlib trying to
output too much data in the presence of data corruption. This check
triggered if zlib_inflate asked to be called again (Z_OK) with
avail_out == 0 and no more output buffers available. This check proves
to be rather dumb, as it incorrectly catches the case where zlib has
generated all the output, but there are still input bytes to be processed.
This patch does a number of things. It removes the original check and
replaces it with code to not move to the next output buffer if there
are no more output buffers available, relying on zlib to error if it
wants an extra output buffer in the case of data corruption. It
also replaces the Z_NO_FLUSH flag with the more correct Z_SYNC_FLUSH
flag, and makes the error messages more understandable to
non-technical users.
Reported-by: Stefan Lippers-Hollmann <s.L-H@gmx.de>
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
This fixes a code regression caused by the recent mainlining changes.
The recent code changes call zlib_inflate repeatedly, decompressing into
separate 4K buffers, this code didn't check for the possibility that
zlib_inflate might ask for too many buffers when decompressing corrupted
data.
Use the standard magic.h for btrfs and squashfs.
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
Cc: Chris Mason <chris.mason@oracle.com>
