path: root/fs/stat.c
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-01Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 support from Catalin Marinas: "Linux support for the 64-bit ARM architecture (AArch64) Features currently supported: - 39-bit address space for user and kernel (each) - 4KB and 64KB page configurations - Compat (32-bit) user applications (ARMv7, EABI only) - Flattened Device Tree (mandated for all AArch64 platforms) - ARM generic timers" * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (35 commits) arm64: ptrace: remove obsolete ptrace request numbers from user headers arm64: Do not set the SMP/nAMP processor bit arm64: MAINTAINERS update arm64: Build infrastructure arm64: Miscellaneous header files arm64: Generic timers support arm64: Loadable modules arm64: Miscellaneous library functions arm64: Performance counters support arm64: Add support for /proc/sys/debug/exception-trace arm64: Debugging support arm64: Floating point and SIMD arm64: 32-bit (compat) applications support arm64: User access library functions arm64: Signal handling support arm64: VDSO support arm64: System calls handling arm64: ELF definitions arm64: SMP support arm64: DMA mapping API ...
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-09-14vfs: make O_PATH file descriptors usable for 'fstat()'Linus Torvalds
We already use them for openat() and friends, but fstat() also wants to be able to use O_PATH file descriptors. This should make it more directly comparable to the O_SEARCH of Solaris. Note that you could already do the same thing with "fstatat()" and an empty path, but just doing "fstat()" directly is simpler and faster, so there is no reason not to just allow it directly. See also commit 332a2e1244bd, which did the same thing for fchdir, for the same reasons. Reported-by: ольга крыжановская <olga.kryzhanovska@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org # O_PATH introduced in 3.0+ Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-14fs: Build sys_stat64() and friends if __ARCH_WANT_COMPAT_STAT64Catalin Marinas
On AArch64 Linux, we want the sys_stat64() and related functions for compat support but do not need the generic struct stat64, enabled automatically if __ARCH_WANT_STAT64. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace enhancements from Eric Biederman: "This is a course correction for the user namespace, so that we can reach an inexpensive, maintainable, and reasonably complete implementation. Highlights: - Config guards make it impossible to enable the user namespace and code that has not been converted to be user namespace safe. - Use of the new kuid_t type ensures the if you somehow get past the config guards the kernel will encounter type errors if you enable user namespaces and attempt to compile in code whose permission checks have not been updated to be user namespace safe. - All uids from child user namespaces are mapped into the initial user namespace before they are processed. Removing the need to add an additional check to see if the user namespace of the compared uids remains the same. - With the user namespaces compiled out the performance is as good or better than it is today. - For most operations absolutely nothing changes performance or operationally with the user namespace enabled. - The worst case performance I could come up with was timing 1 billion cache cold stat operations with the user namespace code enabled. This went from 156s to 164s on my laptop (or 156ns to 164ns per stat operation). - (uid_t)-1 and (gid_t)-1 are reserved as an internal error value. Most uid/gid setting system calls treat these value specially anyway so attempting to use -1 as a uid would likely cause entertaining failures in userspace. - If setuid is called with a uid that can not be mapped setuid fails. I have looked at sendmail, login, ssh and every other program I could think of that would call setuid and they all check for and handle the case where setuid fails. - If stat or a similar system call is called from a context in which we can not map a uid we lie and return overflowuid. The LFS experience suggests not lying and returning an error code might be better, but the historical precedent with uids is different and I can not think of anything that would break by lying about a uid we can't map. - Capabilities are localized to the current user namespace making it safe to give the initial user in a user namespace all capabilities. My git tree covers all of the modifications needed to convert the core kernel and enough changes to make a system bootable to runlevel 1." Fix up trivial conflicts due to nearby independent changes in fs/stat.c * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits) userns: Silence silly gcc warning. cred: use correct cred accessor with regards to rcu read lock userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq userns: Convert cgroup permission checks to use uid_eq userns: Convert tmpfs to use kuid and kgid where appropriate userns: Convert sysfs to use kgid/kuid where appropriate userns: Convert sysctl permission checks to use kuid and kgids. userns: Convert proc to use kuid/kgid where appropriate userns: Convert ext4 to user kuid/kgid where appropriate userns: Convert ext3 to use kuid/kgid where appropriate userns: Convert ext2 to use kuid/kgid where appropriate. userns: Convert devpts to use kuid/kgid where appropriate userns: Convert binary formats to use kuid/kgid where appropriate userns: Add negative depends on entries to avoid building code that is userns unsafe userns: signal remove unnecessary map_cred_ns userns: Teach inode_capable to understand inodes whose uids map to other namespaces. userns: Fail exec for suid and sgid binaries with ids outside our user namespace. userns: Convert stat to return values mapped from kuids and kgids userns: Convert user specfied uids and gids in chown into kuids and kgid userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs ...
2012-05-21Merge branch 'vfs-cleanups' (random vfs cleanups)Linus Torvalds
This teaches vfs_fstat() to use the appropriate f[get|put]_light functions, allowing it to avoid some unnecessary locking for the common case. More noticeably, it also cleans up and simplifies the "getname_flags()" function, which now relies on the architecture strncpy_from_user() doing all the user access checks properly, instead of hacking around the fact that on x86 it didn't use to do it right (see commit 92ae03f2ef99: "x86: merge 32/64-bit versions of 'strncpy_from_user()' and speed it up"). * vfs-cleanups: VFS: make vfs_fstat() use f[get|put]_light() VFS: clean up and simplify getname_flags() x86: make word-at-a-time strncpy_from_user clear bytes at the end
2012-05-15userns: Convert stat to return values mapped from kuids and kgidsEric W. Biederman
- Store uids and gids with kuid_t and kgid_t in struct kstat - Convert uid and gids to userspace usable values with from_kuid and from_kgid Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-05-06vfs: don't force a big memset of stat data just to clear padding fieldsLinus Torvalds
Admittedly this is something that the compiler should be able to just do for us, but gcc just isn't that smart. And trying to use a structure initializer (which would get us the right semantics) ends up resulting in gcc allocating stack space for _two_ 'struct stat', and then copying one into the other. So do it by hand - just have a per-architecture macro that initializes the padding fields. And if the architecture doesn't provide one, fall back to the old behavior of just doing the whole memset() first. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-06vfs: de-crapify "cp_new_stat()" functionLinus Torvalds
It's an unreadable mess of 32-bit vs 64-bit #ifdef's that mostly follow a rather simple pattern. Make a helper #define to handle that pattern, in the process making the code both shorter and more readable. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-28VFS: make vfs_fstat() use f[get|put]_light()Linus Torvalds
Use the *_light() versions that properly avoid doing the file user count updates when they are unnecessary. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-20switch touch_atime to struct pathAl Viro
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-11-02readlinkat: ensure we return ENOENT for the empty pathname for normal lookupsAndy Whitcroft
Since the commit below which added O_PATH support to the *at() calls, the error return for readlink/readlinkat for the empty pathname has switched from ENOENT to EINVAL: commit 65cfc6722361570bfe255698d9cd4dccaf47570d Author: Al Viro <viro@zeniv.linux.org.uk> Date: Sun Mar 13 15:56:26 2011 -0400 readlinkat(), fchownat() and fstatat() with empty relative pathnames This is both unexpected for userspace and makes readlink/readlinkat inconsistant with all other interfaces; and inconsistant with our stated return for these pathnames. As the readlinkat call does not have a flags parameter we cannot use the AT_EMPTY_PATH approach used in the other calls. Therefore expose whether the original path is infact entry via a new user_path_at_empty() path lookup function. Use this to determine whether to default to EINVAL or ENOENT for failures. Addresses http://bugs.launchpad.net/bugs/817187 [akpm@linux-foundation.org: remove unused getname_flags()] Signed-off-by: Andy Whitcroft <apw@canonical.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-09-27vfs: remove LOOKUP_NO_AUTOMOUNT flagLinus Torvalds
That flag no longer makes sense, since we don't look up automount points as eagerly any more. Additionally, it turns out that the NO_AUTOMOUNT handling was buggy to begin with: it would avoid automounting even for cases where we really *needed* to do the automount handling, and could return ENOENT for autofs entries that hadn't been instantiated yet. With our new non-eager automount semantics, one discussion has been about adding a AT_AUTOMOUNT flag to vfs_fstatat (and thus the newfstatat() and fstatat64() system calls), but it's probably not worth it: you can always force at least directory automounting by simply adding the final '/' to the filename, which works for *all* of the stat family system calls, old and new. So AT_NO_AUTOMOUNT (and thus LOOKUP_NO_AUTOMOUNT) really were just a result of our bad default behavior. Acked-by: Ian Kent <raven@themaw.net> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-06vfs: optimize inode cache access patternsLinus Torvalds
The inode structure layout is largely random, and some of the vfs paths really do care. The path lookup in particular is already quite D$ intensive, and profiles show that accessing the 'inode->i_op->xyz' fields is quite costly. We already optimized the dcache to not unnecessarily load the d_op structure for members that are often NULL using the DCACHE_OP_xyz bits in dentry->d_flags, and this does something very similar for the inode ops that are used during pathname lookup. It also re-orders the fields so that the fields accessed by 'stat' are together at the beginning of the inode structure, and roughly in the order accessed. The effect of this seems to be in the 1-2% range for an empty kernel "make -j" run (which is fairly kernel-intensive, mostly in filename lookup), so it's visible. The numbers are fairly noisy, though, and likely depend a lot on exact microarchitecture. So there's more tuning to be done. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15readlinkat(), fchownat() and fstatat() with empty relative pathnamesAl Viro
For readlinkat() we simply allow empty pathname; it will fail unless we have dfd equal to O_PATH-opened symlink, so we are outside of POSIX scope here. For fchownat() and fstatat() we allow AT_EMPTY_PATH; let the caller explicitly ask for such behaviour. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add an AT_NO_AUTOMOUNT flag to suppress terminal automountDavid Howells
Add an AT_NO_AUTOMOUNT flag to suppress terminal automounting of automount point directories. This can be used by fstatat() users to permit the gathering of attributes on an automount point and also prevent mass-automounting of a directory of automount points by ls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-23Add unlocked version of inode_add_bytes() functionDmitry Monakhov
Quota code requires unlocked version of this function. Off course we can just copy-paste the code, but copy-pasting is always an evil. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-20kill vfs_stat_fd / vfs_lstat_fdChristoph Hellwig
There's really no reason to keep vfs_stat_fd and vfs_lstat_fd with Oleg's vfs_fstatat. Use vfs_fstatat for the few cases having the directory fd, and switch all others to vfs_stat / vfs_lstat. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20Separate out common fstatat code into vfs_fstatatOleg Drokin
This is a version incorporating Christoph's suggestion. Separate out common *fstatat functionality into a single function instead of duplicating it all over the code. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-14[CVE-2009-0029] System call wrappers part 30Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 16Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 11Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 10Heiko Carstens
2009-01-05inode->i_op is never NULLAl Viro
We used to have rather schizophrenic set of checks for NULL ->i_op even though it had been eliminated years ago. You'd need to go out of your way to set it to NULL explicitly _and_ a bunch of code would die on such inodes anyway. After killing two remaining places that still did that bogosity, all that crap can go away. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize __user_walk_fd() et.al.Al Viro
* do not pass nameidata; struct path is all the callers want. * switch to new helpers: user_path_at(dfd, pathname, flags, &path) user_path(pathname, &path) user_lpath(pathname, &path) user_path_dir(pathname, &path) (fail if not a directory) The last 3 are trivial macro wrappers for the first one. * remove nameidata in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] vfs_getattr(): remove dead codeAndrew Morton
As Mikulas points out, (1 << anything) won't be evaluating to zero. This code is long-dead. Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] powerpc: Wire up *at syscallsAndreas Schwab
Wire up *at syscalls. This patch has been tested on ppc64 (using glibc's testsuite, both 32bit and 64bit), and compile-tested for ppc32 (I have currently no ppc32 system available, but I expect no problems). Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-11[PATCH] fstatat64 supportUlrich Drepper
The *at patches introduced fstatat and, due to inusfficient research, I used the newfstat functions generally as the guideline. The result is that on 32-bit platforms we don't have all the information needed to implement fstatat64. This patch modifies the code to pass up 64-bit information if __ARCH_WANT_STAT64 is defined. I renamed the syscall entry point to make this clear. Other archs will continue to use the existing code. On x86-64 the compat code is implemented using a new sys32_ function. this is what is done for the other stat syscalls as well. This patch might break some other archs (those which define __ARCH_WANT_STAT64 and which already wired up the syscall). Yet others might need changes to accomodate the compatibility mode. I really don't want to do that work because all this stat handling is a mess (more so in glibc, but the kernel is also affected). It should be done by the arch maintainers. I'll provide some stand-alone test shortly. Those who are eager could compile glibc and run 'make check' (no installation needed). The patch below has been tested on x86 and x86-64. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] vfs: *at functions: coreUlrich Drepper
Here is a series of patches which introduce in total 13 new system calls which take a file descriptor/filename pair instead of a single file name. These functions, openat etc, have been discussed on numerous occasions. They are needed to implement race-free filesystem traversal, they are necessary to implement a virtual per-thread current working directory (think multi-threaded backup software), etc. We have in glibc today implementations of the interfaces which use the /proc/self/fd magic. But this code is rather expensive. Here are some results (similar to what Jim Meyering posted before). The test creates a deep directory hierarchy on a tmpfs filesystem. Then rm -fr is used to remove all directories. Without syscall support I get this: real 0m31.921s user 0m0.688s sys 0m31.234s With syscall support the results are much better: real 0m20.699s user 0m0.536s sys 0m20.149s The interfaces are for obvious reasons currently not much used. But they'll be used. coreutils (and Jeff's posixutils) are already using them. Furthermore, code like ftw/fts in libc (maybe even glob) will also start using them. I expect a patch to make follow soon. Every program which is walking the filesystem tree will benefit. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
