path: root/fs/sync.c
2009-12-17fold do_sync_file_range into sys_sync_file_rangeChristoph Hellwig
We recently go rid of all callers of do_sync_file_range as they're better served with vfs_fsync or the filemap_write_and_wait. Now that do_sync_file_range is down to a single caller fold it into it so that people don't start using it again accidentally. While at it also switch it from using __filemap_fdatawrite_range(..., WB_SYNC_ALL) to the more clear filemap_fdatawrite_range(). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-10kill wait_on_page_writeback_rangeChristoph Hellwig
All callers really want the more logical filemap_fdatawait_range interface, so convert them to use it and merge wait_on_page_writeback_range into filemap_fdatawait_range. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10vfs: Implement proper O_SYNC semanticsChristoph Hellwig
While Linux provided an O_SYNC flag basically since day 1, it took until Linux 2.4.0-test12pre2 to actually get it implemented for filesystems, since that day we had generic_osync_around with only minor changes and the great "For now, when the user asks for O_SYNC, we'll actually give O_DSYNC" comment. This patch intends to actually give us real O_SYNC semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC patches which are required before this patch it's actually surprisingly simple, we just need to figure out when to set the datasync flag to vfs_fsync_range and when not. This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's numerical value to keep binary compatibility, and adds a new real O_SYNC flag. To guarantee backwards compatiblity it is defined as expanding to both the O_DSYNC and the new additional binary flag (__O_SYNC) to make sure we are backwards-compatible when compiled against the new headers. This also means that all places that don't care about the differences can just check O_DSYNC and get the right behaviour for O_SYNC, too - only places that actuall care need to check __O_SYNC in addition. Drivers and network filesystems have been updated in a fail safe way to always do the full sync magic if O_DSYNC is set. The few places setting O_SYNC for lower layers are kept that way for now to stay failsafe. We enforce that O_DSYNC is set when __O_SYNC is set early in the open path to make sure we always get these sane options. Note that parisc really screwed up their headers as they already define a O_DSYNC that has always been a no-op. We try to repair it by using it for the new O_DSYNC and redefinining O_SYNC to send both the traditional O_SYNC numerical value _and_ the O_DSYNC one. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-23fs/buffer.c: clean up EXPORT* macrosH Hartley Sweeten
According to Documentation/CodingStyle the EXPORT* macro should follow immediately after the closing function brace line. Also, mark_buffer_async_write_endio() and do_thaw_all() are not used elsewhere so they should be marked as static. In addition, file_fsync() is actually in fs/sync.c so move the EXPORT* to that file. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-16fs: Assign bdi in super_blockJens Axboe
We do this automatically in get_sb_bdev() from the set_bdev_super() callback. Filesystems that have their own private backing_dev_info must assign that in ->fill_super(). Note that ->s_bdi assignment is required for proper writeback! Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-14fsync: wait for data writeout completion before calling ->fsyncChristoph Hellwig
Currenly vfs_fsync(_range) first calls filemap_fdatawrite to write out the data, the calls into ->fsync to write out the metadata and then finally calls filemap_fdatawait to wait for the data I/O to complete. What sounds like a clever micro-optimization actually is nast trap for many filesystems. For many modern filesystems i_size or other inode information is only updated on I/O completion and we need to wait for I/O to finish before we can write out the metadata. For old fashionen filesystems that instanciate blocks during the actual write and also update the metadata at that point it opens up a large window were we could expose uninitialized blocks after a crash. While a few filesystems that need it already wait for the I/O to finish inside their ->fsync methods it is rather suboptimal as it is done under the i_mutex and also always for the whole file instead of just a part as we could do for O_SYNC handling. Here is a small audit of all fsync instances in the tree: - spufs_mfc_fsync: - ps3flash_fsync: - vol_cdev_fsync: - printer_fsync: - fb_deferred_io_fsync: - bad_file_fsync: - simple_sync_file: don't care - filesystems/drivers do't use the page cache or are purely in-memory. - simple_fsync: - file_fsync: - affs_file_fsync: - fat_file_fsync: - jfs_fsync: - ubifs_fsync: - reiserfs_dir_fsync: - reiserfs_sync_file: never touch pagecache themselves. We need to wait before if we do not want to expose stale data after an allocation. - afs_fsync: - fuse_fsync_common: do the waiting writeback itself in awkward ways, would benefit from proper semantics - block_fsync: Does a filemap_write_and_wait on the block device inode. Because we now have f_mapping that is the same inode we call it on in vfs_fsync. So just removing it and letting the VFS do the work in one go would be an improvement. - btrfs_sync_file: - cifs_fsync: - xfs_file_fsync: need the wait first and currently do it themselves. would benefit from doing it outside i_mutex. - coda_fsync: - ecryptfs_fsync: - exofs_file_fsync: - shm_fsync: only passes the fsync through to the lower layer - ext3_sync_file: doesn't seem to care, comments are confusing. - ext4_sync_file: would need the wait to work correctly for delalloc mode with late i_size updates. Otherwise the ext3 comment applies. currently implemens it's own writeback and wait in an odd way, could benefit from doing it properly. - gfs2_fsync: not needed for journaled data mode, but probably harmless there. Currently writes back data asynchronously itself. Needs some major audit. - hostfs_fsync: just calls fsync/datasync on the host FD. Without the wait before data might not even be inflight yet if we're unlucky. - hpfs_file_fsync: - ncp_fsync: no-ops. Dangerous before and after. - jffs2_fsync: just calls jffs2_flush_wbuf_gc, not sure how this relates to data. - nfs_fsync_dir: just increments stats, claims all directory operations are synchronous - nfs_file_fsync: only writes out data??? Looks very odd. - nilfs_sync_file: looks like it expects all data done, but not sure from the code - ntfs_dir_fsync: - ntfs_file_fsync: appear to do their own data writeback. Very convoluted code. - ocfs2_sync_file: does it's own data writeback, but no wait. probably needs the wait. - smb_fsync: according to a comment expects all pages written already, probably needs the wait before. This patch only changes vfs_fsync_range, removal of the wait in the methods that have it is left to the filesystem maintainers. Note that most filesystems really do need an audit for their fsync methods given the gems found in this very brief audit. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-14vfs: Introduce new helpers for syncing after writing to O_SYNC file or ↵Jan Kara
IS_SYNC inode Introduce new function for generic inode syncing (vfs_fsync_range) and use it from fsync() path. Introduce also new helper for syncing after a sync write (generic_write_sync) using the generic function. Use these new helpers for syncing from generic VFS functions. This makes O_SYNC writes to block devices acquire i_mutex for syncing. If we really care about this, we can make block_fsync() drop the i_mutex and reacquire it before it returns. CC: Evgeniy Polyakov <zbr@ioremap.net> CC: ocfs2-devel@oss.oracle.com CC: Joel Becker <joel.becker@oracle.com> CC: Felix Blyakher <felixb@sgi.com> CC: xfs@oss.sgi.com CC: Anton Altaparmakov <aia21@cantab.net> CC: linux-ntfs-dev@lists.sourceforge.net CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> CC: linux-ext4@vger.kernel.org CC: tytso@mit.edu Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-11writeback: switch to per-bdi threads for flushing dataJens Axboe
This gets rid of pdflush for bdi writeout and kupdated style cleaning. pdflush writeout suffers from lack of locality and also requires more threads to handle the same workload, since it has to work in a non-blocking fashion against each queue. This also introduces lumpy behaviour and potential request starvation, since pdflush can be starved for queue access if others are accessing it. A sample ffsb workload that does random writes to files is about 8% faster here on a simple SATA drive during the benchmark phase. File layout also seems a LOT more smooth in vmstat: r b swpd free buff cache si so bi bo in cs us sy id wa 0 1 0 608848 2652 375372 0 0 0 71024 604 24 1 10 48 42 0 1 0 549644 2712 433736 0 0 0 60692 505 27 1 8 48 44 1 0 0 476928 2784 505192 0 0 4 29540 553 24 0 9 53 37 0 1 0 457972 2808 524008 0 0 0 54876 331 16 0 4 38 58 0 1 0 366128 2928 614284 0 0 4 92168 710 58 0 13 53 34 0 1 0 295092 3000 684140 0 0 0 62924 572 23 0 9 53 37 0 1 0 236592 3064 741704 0 0 4 58256 523 17 0 8 48 44 0 1 0 165608 3132 811464 0 0 0 57460 560 21 0 8 54 38 0 1 0 102952 3200 873164 0 0 4 74748 540 29 1 10 48 41 0 1 0 48604 3252 926472 0 0 0 53248 469 29 0 7 47 45 where vanilla tends to fluctuate a lot in the creation phase: r b swpd free buff cache si so bi bo in cs us sy id wa 1 1 0 678716 5792 303380 0 0 0 74064 565 50 1 11 52 36 1 0 0 662488 5864 319396 0 0 4 352 302 329 0 2 47 51 0 1 0 599312 5924 381468 0 0 0 78164 516 55 0 9 51 40 0 1 0 519952 6008 459516 0 0 4 78156 622 56 1 11 52 37 1 1 0 436640 6092 541632 0 0 0 82244 622 54 0 11 48 41 0 1 0 436640 6092 541660 0 0 0 8 152 39 0 0 51 49 0 1 0 332224 6200 644252 0 0 4 102800 728 46 1 13 49 36 1 0 0 274492 6260 701056 0 0 4 12328 459 49 0 7 50 43 0 1 0 211220 6324 763356 0 0 0 106940 515 37 1 10 51 39 1 0 0 160412 6376 813468 0 0 0 8224 415 43 0 6 49 45 1 1 0 85980 6452 886556 0 0 4 113516 575 39 1 11 54 34 0 2 0 85968 6452 886620 0 0 0 1640 158 211 0 0 46 54 A 10 disk test with btrfs performs 26% faster with per-bdi flushing. A SSD based writeback test on XFS performs over 20% better as well, with the throughput being very stable around 1GB/sec, where pdflush only manages 750MB/sec and fluctuates wildly while doing so. Random buffered writes to many files behave a lot better as well, as does random mmap'ed writes. A separate thread is added to sync the super blocks. In the long term, adding sync_supers_bdi() functionality could get rid of this thread again. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-11writeback: get rid of generic_sync_sb_inodes() exportJens Axboe
This adds two new exported functions: - writeback_inodes_sb(), which only attempts to writeback dirty inodes on this super_block, for WB_SYNC_NONE writeout. - sync_inodes_sb(), which writes out all dirty inodes on this super_block and also waits for the IO to complete. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-06sys_sync(): fix 16% performance regression in ffsb create_4k testZhang, Yanmin
I run many ffsb test cases on JBODs (typically 13/12 disks). Comparing with kernel 2.6.30, 2.6.31-rc1 has about 16% regression with ffsb_create_4k. The sub test case creates files continuously for 10 minitues and every file is 1MB. Bisect located below patch. 5cee5815d1564bbbd505fea86f4550f1efdb5cd0 is first bad commit commit 5cee5815d1564bbbd505fea86f4550f1efdb5cd0 Author: Jan Kara <jack@suse.cz> Date: Mon Apr 27 16:43:51 2009 +0200 vfs: Make sys_sync() use fsync_super() (version 4) It is unnecessarily fragile to have two places (fsync_super() and do_sync()) doing data integrity sync of the filesystem. Alter __fsync_super() to accommodate needs of both callers and use it. So after this patch __fsync_super() is the only place where we gather all the calls needed to properly send all data on a filesystem to disk. As a matter of fact, ffsb calls sys_sync in the end to make sure all data is flushed to disks and the flushing is counted into the result. vmstat shows ffsb is blocked when syncing for a long time. With 2.6.30, ffsb is blocked for a short time. I checked the patch and did experiments to recover the original methods. Eventually, the root cause is the patch deletes the calling to wakeup_pdflush when syncing, so only ffsb is blocked on disk I/O. wakeup_pdflush could ask pdflush to write back pages with ffsb at the same time. [akpm@linux-foundation.org: restore comment too] Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11remove the call to ->write_super in __sync_filesystemChristoph Hellwig
Now that all filesystems provide ->sync_fs methods we can change __sync_filesystem to only call ->sync_fs. This gives us a clear separation between periodic writeouts which are driven by ->write_super and data integrity syncs that go through ->sync_fs. (modulo file_fsync which is also going away) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11->write_super lock_super pushdownChristoph Hellwig
Push down lock_super into ->write_super instances and remove it from the caller. Following filesystem don't need ->s_lock in ->write_super and are skipped: * bfs, nilfs2 - no other uses of s_lock and have internal locks in ->write_super * ext2 - uses BKL in ext2_write_super and has internal calls without s_lock * reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in ->write_super * xfs - no other uses of s_lock and uses internal lock (buffer lock on superblock buffer) to serialize ->write_super. Also xfs_fs_write_super is superflous and will go away in the next merge window Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11enforce ->sync_fs is only called for rw superblockChristoph Hellwig
Make sure a superblock really is writeable by checking MS_RDONLY under s_umount. sync_filesystems needed some re-arragement for that, but all but one sync_filesystem caller had the correct locking already so that we could add that check there. cachefiles grew s_umount locking. I've also added a WARN_ON to sync_filesystem to assert this for future callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11quota: Introduce writeout_quota_sb() (version 4)Jan Kara
Introduce this function which just writes all the quota structures but avoids all the syncing and cache pruning work to expose quota structures to userspace. Use this function from __sync_filesystem when wait == 0. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11quota: cleanup dquota sync functions (version 4)Christoph Hellwig
Currently the VFS calls vfs_dq_sync to sync out disk quotas for a given superblock. This is a small wrapper around sync_dquots which for the case of a non-NULL superblock is a small wrapper around quota_sync_sb. Just make quota_sync_sb global (rename it to sync_quota_sb) and call it directly. Also call it directly for those cases in quota.c that have a superblock and leave sync_dquots purely an iterator over sync_quota_sb and remove it's superblock argument. To make this nicer move the check for the lack of a quota_sync method from the callers into sync_quota_sb. [folded build fix from Alexander Beregalov <a.beregalov@gmail.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Rename fsync_super() to sync_filesystem() (version 4)Jan Kara
Rename the function so that it better describe what it really does. Also remove the unnecessary include of buffer_head.h. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Move syncing code from super.c to sync.c (version 4)Jan Kara
Move sync_filesystems(), __fsync_super(), fsync_super() from super.c to sync.c where it fits better. [build fixes folded] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Make sys_sync() use fsync_super() (version 4)Jan Kara
It is unnecessarily fragile to have two places (fsync_super() and do_sync()) doing data integrity sync of the filesystem. Alter __fsync_super() to accommodate needs of both callers and use it. So after this patch __fsync_super() is the only place where we gather all the calls needed to properly send all data on a filesystem to disk. Nice bonus is that we get a complete livelock avoidance and write_supers() is now only used for periodic writeback of superblocks. sync_blockdevs() introduced a couple of patches ago is gone now. [build fixes folded] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11vfs: Fix sys_sync() and fsync_super() reliability (version 4)Jan Kara
So far, do_sync() called: sync_inodes(0); sync_supers(); sync_filesystems(0); sync_filesystems(1); sync_inodes(1); This ordering makes it kind of hard for filesystems as sync_inodes(0) need not submit all the IO (for example it skips inodes with I_SYNC set) so e.g. forcing transaction to disk in ->sync_fs() is not really enough. Therefore sys_sync has not been completely reliable on some filesystems (ext3, ext4, reiserfs, ocfs2 and others are hit by this) when racing e.g. with background writeback. A similar problem hits also other filesystems (e.g. ext2) because of write_supers() being called before the sync_inodes(1). Change the ordering of calls in do_sync() - this requires a new function sync_blockdevs() to preserve the property that block devices are always synced after write_super() / sync_fs() call. The same issue is fixed in __fsync_super() function used on umount / remount read-only. [AV: build fixes] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-quota-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-quota-2.6: (27 commits) ext2: Zero our b_size in ext2_quota_read() trivial: fix typos/grammar errors in fs/Kconfig quota: Coding style fixes quota: Remove superfluous inlines quota: Remove uppercase aliases for quota functions. nfsd: Use lowercase names of quota functions jfs: Use lowercase names of quota functions udf: Use lowercase names of quota functions ufs: Use lowercase names of quota functions reiserfs: Use lowercase names of quota functions ext4: Use lowercase names of quota functions ext3: Use lowercase names of quota functions ext2: Use lowercase names of quota functions ramfs: Remove quota call vfs: Use lowercase names of quota functions quota: Remove dqbuf_t and other cleanups quota: Remove NODQUOT macro quota: Make global quota locks cacheline aligned quota: Move quota files into separate directory ext4: quota reservation for delayed allocation ...
2009-03-26Get rid of pdflush_operation() in emergency sync and remountJens Axboe
Opencode a cheasy approach with kevent. The idea here is that we'll add some generic delayed work infrastructure, which probably wont be based on pdflush (or maybe it will, in which case we can just add it back). This is in preparation for getting rid of pdflush completely. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-26vfs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: Alexander Viro <viro@zeniv.linux.org.uk>
2009-01-14[CVE-2009-0029] System call wrappers part 09Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrapper special casesHeiko Carstens
System calls with an unsigned long long argument can't be converted with the standard wrappers since that would include a cast to long, which in turn means that we would lose the upper 32 bit on 32 bit architectures. Also semctl can't use the standard wrapper since it has a 'union' parameter. So we handle them as special case and add some extra wrappers instead. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-06mm: do_sync_mapping_range integrity fixNick Piggin
Chris Mason notices do_sync_mapping_range didn't actually ask for data integrity writeout. Unfortunately, it is advertised as being usable for data integrity operations. This is a data integrity bug. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Chris Mason <chris.mason@oracle.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05add a vfs_fsync helperChristoph Hellwig
Fsync currently has a fdatawrite/fdatawait pair around the method call, and a mutex_lock/unlock of the inode mutex. All callers of fsync have to duplicate this, but we have a few and most of them don't quite get it right. This patch adds a new vfs_fsync that takes care of this. It's a little more complicated as usual as ->fsync might get a NULL file pointer and just a dentry from nfsd, but otherwise gets afile and we want to take the mapping and file operations from it when it is there. Notes on the fsync callers: - ecryptfs wasn't calling filemap_fdatawrite / filemap_fdatawait on the lower file - coda wasn't calling filemap_fdatawrite / filemap_fdatawait on the host file, and returning 0 when ->fsync was missing - shm wasn't calling either filemap_fdatawrite / filemap_fdatawait nor taking i_mutex. Now given that shared memory doesn't have disk backing not doing anything in fsync seems fine and I left it out of the vfs_fsync conversion for now, but in that case we might just not pass it through to the lower file at all but just call the no-op simple_sync_file directly. [and now actually export vfs_fsync] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-24SYNC_FILE_RANGE_WRITE may and will block. Document that.Pavel Machek
[akpm@linux-foundation.org: fix comment text] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29vfs: fix unconditional write_super() call in file_fsync()OGAWA Hirofumi
We need to check ->s_dirt before calling write_super(). It became the cause of an unneeded write. This bug was noticed by Sudhanshu Saxena. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28Introduce fixed sys_sync_file_range2() syscall, implement on PowerPC and ARMDavid Woodhouse
Not all the world is an i386. Many architectures need 64-bit arguments to be aligned in suitable pairs of registers, and the original sys_sync_file_range(int, loff_t, loff_t, int) was therefore wasting an argument register for padding after the first integer. Since we don't normally have more than 6 arguments for system calls, that left no room for the final argument on some architectures. Fix this by introducing sys_sync_file_range2(int, int, loff_t, loff_t) which all fits nicely. In fact, ARM already had that, but called it sys_arm_sync_file_range. Move it to fs/sync.c and rename it, then implement the needed compatibility routine. And stop the missing syscall check from bitching about the absence of sys_sync_file_range() if we've implemented sys_sync_file_range2() instead. Tested on PPC32 and with 32-bit and 64-bit userspace on PPC64. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Remove do_sync_file_range()Mark Fasheh
Remove do_sync_file_range() and convert callers to just use do_sync_mapping_range(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[PATCH] Turn do_sync_file_range() into do_sync_mapping_range()Mark Fasheh
do_sync_file_range() accepts a file * from which it takes an address_space to sync. Abstract out the bulk of the function into do_sync_mapping_range() which takes the address_space directly. This way callers who want to sync an address_space directly can take advantage of the functionality provided. do_sync_file_range() is preserved as a small wrapper around do_sync_mapping_range(). Ocfs2 in particular would like to use this to initiate a sync of a specific inode range during truncate, where a file * may not be available. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] severing fs.h, radix-tree.h -> sched.hAl Viro
2006-09-30[PATCH] BLOCK: Move functions out of buffer code [try #6]David Howells
Move some functions out of the buffering code that aren't strictly buffering specific. This is a precursor to being able to disable the block layer. (*) Moved some stuff out of fs/buffer.c: (*) The file sync and general sync stuff moved to fs/sync.c. (*) The superblock sync stuff moved to fs/super.c. (*) do_invalidatepage() moved to mm/truncate.c. (*) try_to_release_page() moved to mm/filemap.c. (*) Moved some related declarations between header files: (*) declarations for do_invalidatepage() and try_to_release_page() moved to linux/mm.h. (*) __set_page_dirty_buffers() moved to linux/buffer_head.h. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-23[PATCH] writeback: fix range handlingOGAWA Hirofumi
When a writeback_control's `start' and `end' fields are used to indicate a one-byte-range starting at file offset zero, the required values of .start=0,.end=0 mean that the ->writepages() implementation has no way of telling that it is being asked to perform a range request. Because we're currently overloading (start == 0 && end == 0) to mean "this is not a write-a-range request". To make all this sane, the patch changes range of writeback_control. So caller does: If it is calling ->writepages() to write pages, it sets range (range_start/end or range_cyclic) always. And if range_cyclic is true, ->writepages() thinks the range is cyclic, otherwise it just uses range_start and range_end. This patch does, - Add LLONG_MAX, LLONG_MIN, ULLONG_MAX to include/linux/kernel.h -1 is usually ok for range_end (type is long long). But, if someone did, range_end += val; range_end is "val - 1" u64val = range_end >> bits; u64val is "~(0ULL)" or something, they are wrong. So, this adds LLONG_MAX to avoid nasty things, and uses LLONG_MAX for range_end. - All callers of ->writepages() sets range_start/end or range_cyclic. - Fix updates of ->writeback_index. It seems already bit strange. If it starts at 0 and ended by check of nr_to_write, this last index may reduce chance to scan end of file. So, this updates ->writeback_index only if range_cyclic is true or whole-file is scanned. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Nathan Scott <nathans@sgi.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Steven French <sfrench@us.ibm.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] sync_file_range(): use unsigned for flagsAndrew Morton
Ulrich suggested that the `flags' arg to sync_file_range() become unsigned. Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] sys_sync_file_range()Andrew Morton
Remove the recently-added LINUX_FADV_ASYNC_WRITE and LINUX_FADV_WRITE_WAIT fadvise() additions, do it in a new sys_sync_file_range() syscall instead. Reasons: - It's more flexible. Things which would require two or three syscalls with fadvise() can be done in a single syscall. - Using fadvise() in this manner is something not covered by POSIX. The patch wires up the syscall for x86. The sycall is implemented in the new fs/sync.c. The intention is that we can move sys_fsync(), sys_fdatasync() and perhaps sys_sync() into there later. Documentation for the syscall is in fs/sync.c. A test app (sync_file_range.c) is in http://www.zip.com.au/~akpm/linux/patches/stuff/ext3-tools.tar.gz. The available-to-GPL-modules do_sync_file_range() is for knfsd: "A COMMIT can say NFS_DATA_SYNC or NFS_FILE_SYNC. I can skip the ->fsync call for NFS_DATA_SYNC which is hopefully the more common." Note: the `async' writeout mode SYNC_FILE_RANGE_WRITE will turn synchronous if the queue is congested. This is trivial to fix: add a new flag bit, set wbc->nonblocking. But I'm not sure that we want to expose implementation details down to that level. Note: it's notable that we can sync an fd which wasn't opened for writing. Same with fsync() and fdatasync()). Note: the code takes some care to handle attempts to sync file contents outside the 16TB offset on 32-bit machines. It makes such attempts appear to succeed, for best 32-bit/64-bit compatibility. Perhaps it should make such requests fail... Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
