path: root/fs/ubifs/lpt.c
2012-08-31UBIFS: print lessArtem Bityutskiy
UBIFS currently prints a lot of information when it mounts a volume, which bothers some people. Make it less chatty - print only important information by default. Get rid of 'dbg_msg()' macro completely. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: comply with coding styleArtem Bityutskiy
Join all the split printk lines in order to stop checkpatch complaining. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-21UBIFS: fix crash on error pathArtem Bityutskiy
This patch fixes a regression introduced by "4994297 UBIFS: make ubifs_lpt_init clean-up in case of failure" which I've hit while running the 'integck -p' test. When remount the file-system from R/O mode to R/W mode and 'lpt_init_wr()' fails, we free _all_ LPT resources by calling 'ubifs_lpt_free(c, 0)', even those needed for R/O mode. This leads to subsequent crashes, e.g., if we try to unmount the file-system. Cc: stable@vger.kernel.org [v3.5+] Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: Kill data type hintRichard Weinberger
We do not need this feature and to our shame it even was not working and there was a bug found very recently. -- Artem Bityutskiy Without the data type hint UBI2 (fastmap) will be easier to implement. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBIFS: make ubifs_lpt_init clean-up in case of failureArtem Bityutskiy
Most functions in UBIFS follow the following designn pattern: if the function allocates multiple resources, and failss at some point, it frees what it has allocated and returns an error. So the caller can rely on the fact that the callee has cleaned up everything after own failure. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Sidney Amani <seed95@gmail.com>
2012-05-16UBIFS: get rid of dbg_errArtem Bityutskiy
This patch removes the 'dbg_err()' macro and we now use 'ubifs_err()' instead. The idea of 'dbg_err()' was to compile out some error message to make the binary a bit smaller - but I think it was a bad idea. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: remove Kconfig debugging optionArtem Bityutskiy
Have the debugging stuff always compiled-in instead. It simplifies maintanance a lot. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: rename dumping functionsArtem Bityutskiy
This commit re-names all functions which dump something from "dbg_dump_*()" to "ubifs_dump_*()". This is done for consistency with UBI and because this way it will be more logical once we remove the debugging sompilation option. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: get rid of dbg_dump_stackArtem Bityutskiy
In case of errors we almost always need the stack dump - it makes no sense to compile it out. Remove the 'dbg_dump_stack()' function completely. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2011-11-22UBIFS: Use kmemdup rather than duplicating its implementationThomas Meyer
The semantic patch that makes this change is available in scripts/coccinelle/api/memdup.cocci. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2011-07-04UBIFS: switch to I/O helpersArtem Bityutskiy
Switch the rest of direct UBI calls to UBIFS helper functions. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: switch to ubifs_leb_readArtem Bityutskiy
Instead of using 'ubi_read()' function directly, used the 'ubifs_leb_read()' helper function instead. This allows to get rid of several redundant error messages and make sure that we always have a stack dump on read errors. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: introduce helper functions for debugging checks and testsArtem Bityutskiy
This patch introduces helper functions for all debugging checks, so instead of doing if (!(ubifs_chk_flags & UBIFS_CHK_GEN)) we now do if (!dbg_is_chk_gen(c)) This is a preparation to further changes where the flags will go away, and we'll need to only change the helper functions, but the code which utilizes them won't be touched. At the same time this patch removes 'dbg_force_in_the_gaps()', 'dbg_force_in_the_gaps_enabled()', and dbg_failure_mode helpers for consistency. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: dump stack when pnode or nnode reading failsArtem Bityutskiy
When we fail to read a pnode or nnode - print stacktrace if debugging is enabled. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-04-05UBIFS: fix oops on error path in read_pnodeArtem Bityutskiy
Thanks to coverity which spotted that UBIFS will oops if 'kmalloc()' in 'read_pnode()' fails and we dereference a NULL 'pnode' pointer when we 'goto out'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: stable@kernel.org
2010-09-07UBIFS: check return code of ubifs_lpt_lookupVasiliy Kulikov
Function ubifs_lpt_lookup may return ERR_PTR(...). Check for it. [Tweaked by Artem Bityutskiy] Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-06-12UBIFS: use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-12-23UBIFS: use nicer 64-bit mathArtem Bityutskiy
Instead of using do_div(), use better primitives from linux/math64.h. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-03UBIFS: introduce LPT dump functionArtem Bityutskiy
2008-12-03UBIFS: run debugging checks only if they are enabledArtem Bityutskiy
Do not forget to check whether lpt debugging is enabled before running the check functions. This commit also makes some spelling fixes. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-10-19UBIFS: do not read unnecessary bytes when unpacking bitsAdrian Hunter
Fixes the following Oops: BUG: unable to handle kernel paging request at f8d24000 IP: [<f8ff0657>] :ubifs:ubifs_unpack_bits+0xcd/0x231 *pde = 34333067 *pte = 00000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: deflate zlib_deflate lzo lzo_decompress lzo_compress ubifs ubi nandsim nand nand_ids nand_ecc mtd nfsd lockd sunrpc exportfs [last unloaded: nand_ecc] Pid: 7450, comm: sync Not tainted (2.6.27-rc8-ubifs-2.6 #27) EIP: 0060:[<f8ff0657>] EFLAGS: 00010206 CPU: 0 EIP is at ubifs_unpack_bits+0xcd/0x231 [ubifs] EAX: 00000000 EBX: 00000000 ECX: d7e43dc0 EDX: 0000ff00 ESI: 00000004 EDI: f8d23ffe EBP: d7e43db4 ESP: d7e43d8c DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process sync (pid: 7450, ti=d7e42000 task=eb6f9530 task.ti=d7e42000) Stack: 00000400 c0103db4 dc5e8090 d7e43dc0 d7e43dc0 d7e43dc4 0000001c 00000004 f496d1e0 f8d23ffc d7e43dd4 f8ffac7e f8d23ffe 00000000 f8d23ffe f2b7af68 f496d1e0 f8d23ffc d7e43e2c f8ffadc5 00000000 0001f000 00000000 c03b10a7 Call Trace: [<c0103db4>] ? restore_nocheck_notrace+0x0/0xe [<f8ffac7e>] ? is_a_node+0x43/0x92 [ubifs] [<f8ffadc5>] ? dbg_check_ltab+0xf8/0x5c9 [ubifs] [<c03b10a7>] ? mutex_lock_nested+0x1b2/0x2a0 [<f8ffc86e>] ? ubifs_lpt_start_commit+0x49/0xecb [ubifs] [<c03b0ef3>] ? mutex_unlock+0xd/0xf [<f8fef017>] ? ubifs_tnc_start_commit+0x1cf/0xef8 [ubifs] [<f8fe65d8>] ? do_commit+0x18f/0x52d [ubifs] [<f8fe69f6>] ? ubifs_run_commit+0x80/0xca [ubifs] [<f8fd8d35>] ? ubifs_sync_fs+0xdb/0xf6 [ubifs] [<c0181a07>] ? sync_filesystems+0xc6/0x10c [<c019f279>] ? do_sync+0x3b/0x6a [<c019f2ba>] ? sys_sync+0x12/0x18 [<c0103ced>] ? sysenter_do_call+0x12/0x35 ======================= Code: 4d ec 89 01 8b 45 e8 89 10 89 d8 89 f1 d3 e8 85 c0 74 07 29 d6 83 fe 20 75 2a 89 d8 83 c4 1c 5b 5e 5f 5d c3 0f b6 57 01 c1 e2 08 <0f> b6 47 02 c1 e0 10 09 c2 0f b6 07 09 c2 0f b EIP: [<f8ff0657>] ubifs_unpack_bits+0xcd/0x231 [ubifs] SS:ESP 0068:d7e43d8c ---[ end trace 1bbb4c407a6dd816 ]--- Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-09-30UBIFS: add more debugging messages for LPTAdrian Hunter
Also add debugging checks for LPT size and separate out c->check_lpt_free from unrelated bitfields. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-07-15UBIFS: add new flash file systemArtem Bityutskiy
This is a new flash file system. See http://www.linux-mtd.infradead.org/doc/ubifs.html Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
