path: root/fs/ubifs/lpt_commit.c
2015-03-25UBIFS: extend debug/message capabilitiesSheng Yong
In the case where we have more than one volumes on different UBI devices, it may be not that easy to tell which volume prints the messages. Add ubi number and volume id in ubifs_msg/warn/error to help debug. These two values are passed by struct ubifs_info. For those where ubifs_info is not initialized yet, ubifs_* is replaced by pr_*. For those where ubifs_info is not avaliable, ubifs_info is passed to the calling function as a const parameter. The output looks like, [ 95.444879] UBIFS (ubi0:1): background thread "ubifs_bgt0_1" started, PID 696 [ 95.484688] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name "test1" [ 95.484694] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 95.484699] UBIFS (ubi0:1): FS size: 30220288 bytes (28 MiB, 238 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs) [ 95.484703] UBIFS (ubi0:1): reserved for root: 1427378 bytes (1393 KiB) [ 95.484709] UBIFS (ubi0:1): media format: w4/r0 (latest is w4/r0), UUID 40DFFC0E-70BE-4193-8905-F7D6DFE60B17, small LPT model [ 95.489875] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 699 [ 95.529713] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "test2" [ 95.529718] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes [ 95.529724] UBIFS (ubi1:0): FS size: 19808256 bytes (18 MiB, 156 LEBs), journal size 1015809 bytes (0 MiB, 8 LEBs) [ 95.529727] UBIFS (ubi1:0): reserved for root: 935592 bytes (913 KiB) [ 95.529733] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID EEB7779D-F419-4CA9-811B-831CAC7233D4, small LPT model [ 954.264767] UBIFS error (ubi1:0 pid 756): ubifs_read_node: bad node type (255 but expected 6) [ 954.367030] UBIFS error (ubi1:0 pid 756): ubifs_read_node: bad node at LEB 0:0, LEB mapping status 1 Signed-off-by: Sheng Yong <shengyong1@huawei.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-19UBIFS: remove useless statementshujianyang
This patch removes useless and duplicate statements. Signed-off-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-07-19UBIFS: fix error handling in dump_lpt_leb()hujianyang
This patch checks the return value of 'ubifs_unpack_nnode()'. If this function returns an error, 'nnode' may not be initialized, so just print an error message and break. Signed-off-by: hujianyang <hujianyang@huawei.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2014-04-18arch: Mass conversion of smp_mb__*()Peter Zijlstra
Mostly scripted conversion of the smp_mb__* barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/n/tip-55dhyhocezdw1dg7u19hmh1u@git.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-arch@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-15UBIFS: rename random32() to prandom_u32()Akinobu Mita
Use more preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: print lessArtem Bityutskiy
UBIFS currently prints a lot of information when it mounts a volume, which bothers some people. Make it less chatty - print only important information by default. Get rid of 'dbg_msg()' macro completely. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: use pr_ helper instead of printkArtem Bityutskiy
Use 'pr_err()' instead of 'printk(KERN_ERR', etc. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-08-31UBIFS: comply with coding styleArtem Bityutskiy
Join all the split printk lines in order to stop checkpatch complaining. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-20UBI: Kill data type hintRichard Weinberger
We do not need this feature and to our shame it even was not working and there was a bug found very recently. -- Artem Bityutskiy Without the data type hint UBI2 (fastmap) will be easier to implement. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: get rid of dbg_errArtem Bityutskiy
This patch removes the 'dbg_err()' macro and we now use 'ubifs_err()' instead. The idea of 'dbg_err()' was to compile out some error message to make the binary a bit smaller - but I think it was a bad idea. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: remove Kconfig debugging optionArtem Bityutskiy
Have the debugging stuff always compiled-in instead. It simplifies maintanance a lot. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2012-05-16UBIFS: rename dumping functionsArtem Bityutskiy
This commit re-names all functions which dump something from "dbg_dump_*()" to "ubifs_dump_*()". This is done for consistency with UBI and because this way it will be more logical once we remove the debugging sompilation option. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
2011-07-04UBIFS: switch to ubifs_leb_readArtem Bityutskiy
Instead of using 'ubi_read()' function directly, used the 'ubifs_leb_read()' helper function instead. This allows to get rid of several redundant error messages and make sure that we always have a stack dump on read errors. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: lessen amount of debugging check typesArtem Bityutskiy
We have too many different debugging checks - lessen the amount by merging all index-related checks into one. At the same time, move the "force in-the-gap" test to the "index checks" class, because it is too heavy for the "general" class. This patch merges TNC, Old index, and Index size check and calles this just "index checks". Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: introduce helper functions for debugging checks and testsArtem Bityutskiy
This patch introduces helper functions for all debugging checks, so instead of doing if (!(ubifs_chk_flags & UBIFS_CHK_GEN)) we now do if (!dbg_is_chk_gen(c)) This is a preparation to further changes where the flags will go away, and we'll need to only change the helper functions, but the code which utilizes them won't be touched. At the same time this patch removes 'dbg_force_in_the_gaps()', 'dbg_force_in_the_gaps_enabled()', and dbg_failure_mode helpers for consistency. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-07-04UBIFS: use correct flags in lpropsArtem Bityutskiy
The UBIFS lpt tree is in many aspects similar to the TNC tree, and we have similar flags for these trees. And by mistake we use the COW_ZNODE flag for LPT in some places, instead of the right flag COW_CNODE. And this works only because these two constants have the same value. This patch makes all the LPT code to use COW_CNODE and also changes COW_CNODE constant value to make sure we do not misuse the flags any more. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: introduce lsave debuggingArtem Bityutskiy
Try to improve UBIFS testing coverage by randomly picking LEBs to store in lsave, rather than picking them optimally. Create a debugging version of 'populate_lsave()' for these purposes and enable it when general debugging self-checks are enabled. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-05-13UBIFS: fix minor stylistic issuesArtem Bityutskiy
Fix several minor stylistic issues: * lines longer than 80 characters * space before closing parenthesis ')' * spaces in the indentations Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-24UBIFS: use GFP_NOFS properlyArtem Bityutskiy
This patch fixes a brown-paperbag bug which was introduced by me: I used incorrect "GFP_KERNEL | GFP_NOFS" allocation flags to make sure my allocations do not cause write-back. But the correct form is "GFP_NOFS". Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate lpt dump buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'dump_lpt_leb()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-16UBIFS: allocate ltab checking buffer on demandArtem Bityutskiy
Instead of using pre-allocated 'c->dbg->buf' buffer in 'dbg_check_ltab_lnum()', dynamically allocate it when needed. The intend is to get rid of the pre-allocated 'c->dbg->buf' buffer and save 128KiB of RAM (or more if PEB size is larger). Indeed, currently we allocate this memory even if the user never enables any self-check, which is wasteful. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-09-07UBIFS: check return code of pnode_lookupVasiliy Kulikov
Function pnode_lookup may return ERR_PTR(...). Check for it. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-06-12UBIFS: use ERR_CASTJulia Lawall
Use ERR_CAST(x) rather than ERR_PTR(PTR_ERR(x)). The former makes more clear what is the purpose of the operation, which otherwise looks like a no-op. Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-20UBIFS: fix commentariesArtem Bityutskiy
2009-03-16UBIFS: use KERN_CONTArtem Bityutskiy
2009-03-16UBIFS: fix lprops committing bugArtem Bityutskiy
When writing lprop nodes, do not forget to set @from to 0 when switching the LEB. This fixes the following bug: UBIFS error (pid 27768): ubifs_leb_write: writing -15456 bytes at 16:15880, error -22 UBIFS error (pid 27768): do_commit: commit failed, error -22 UBIFS warning (pid 27768): ubifs_ro_mode: switched to read-only mode, error -22 Pid: 27768, comm: freespace Not tainted 2.6.29-rc4-ubifs-2.6 #43 Call Trace: [<ffffffffa00c46d6>] ubifs_ro_mode+0x54/0x56 [ubifs] [<ffffffffa00cfa16>] do_commit+0x4f5/0x50a [ubifs] [<ffffffffa00cfae7>] ubifs_run_commit+0xbc/0xdb [ubifs] [<ffffffffa00d42b9>] ubifs_budget_space+0x742/0x9ed [ubifs] [<ffffffff812daf45>] ? __mutex_lock_common+0x361/0x3ae [<ffffffffa00bc437>] ? ubifs_write_begin+0x18d/0x44c [ubifs] [<ffffffffa00bc5cb>] ubifs_write_begin+0x321/0x44c [ubifs] [<ffffffff8106222b>] ? trace_hardirqs_on_caller+0x1f/0x14d [<ffffffff81097ce2>] generic_file_buffered_write+0x12f/0x2d9 [<ffffffff8109828d>] __generic_file_aio_write_nolock+0x261/0x295 [<ffffffff81098aff>] generic_file_aio_write+0x69/0xc5 [<ffffffffa00bb914>] ubifs_aio_write+0x14c/0x19e [ubifs] [<ffffffff810c8f42>] do_sync_write+0xe7/0x12d [<ffffffff81055378>] ? autoremove_wake_function+0x0/0x38 [<ffffffff81149edc>] ? security_file_permission+0x11/0x13 [<ffffffff810c9827>] vfs_write+0xab/0x105 [<ffffffff810c9945>] sys_write+0x47/0x6f [<ffffffff8100c35b>] system_call_fastpath+0x16/0x1b Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-02-09UBIFS: fix dbg_chk_lpt_sz()Adrian Hunter
The debugging function dbg_chk_lpt_sz() was not working correctly for small min_io_unit size e.g. NOR flash. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2009-01-28UBIFS: fix LPT out-of-space bug (again)Adrian Hunter
The function to traverse and dirty the LPT was still not dirtying all nodes, with the result that the LPT could run out of space. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-31UBIFS: fix numerous spelling mistakesArtem Bityutskiy
2008-12-31UBIFS: fix checkpatch.pl warningsArtem Bityutskiy
These are mostly long lines and wrong indentation warning fixes. But also there are two volatile variables and checkpatch.pl complains about them: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt + volatile int gc_seq; WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt + volatile int gced_lnum; Well, we anyway use smp_wmb() for c->gc_seq and c->gced_lnum, so these 'volatile' modifiers can be just dropped. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-03UBIFS: introduce LPT dump functionArtem Bityutskiy
2008-12-03UBIFS: dump stack in LPT check functionsArtem Bityutskiy
It is useful to know how we got to the checking function when hunting the bugs. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-03UBIFS: run debugging checks only if they are enabledArtem Bityutskiy
Do not forget to check whether lpt debugging is enabled before running the check functions. This commit also makes some spelling fixes. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-12-03UBIFS: separate debugging fields outArtem Bityutskiy
Introduce a new data structure which contains all debugging stuff inside. This is cleaner than having debugging stuff directly in 'c'. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-11-07UBIFS: allow for gaps when dirtying the LPTAdrian Hunter
The LPT may have gaps in it because initially empty LEBs are not added by mkfs.ubifs - because it does not know how many there are. Then UBIFS allocates empty LEBs in the reverse order that they are discovered i.e. they are added to, and removed from, the front of a list. That creates a gap in the middle of the LPT. The function dirtying the LPT tree (for the purpose of small model garbage collection) assumed that a gap could only occur at the very end of the LPT and stopped dirtying prematurely, which in turn resulted in the LPT running out of space - something that is designed to be impossible. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-09-30UBIFS: check buffer length when scanning for LPT nodesAdrian Hunter
'is_a_node()' function was reading from a buffer before checking the buffer length, resulting in an OOPS as follows: BUG: unable to handle kernel paging request at f8f74002 IP: [<f8f9783f>] :ubifs:ubifs_unpack_bits+0xca/0x233 *pde = 19e95067 *pte = 00000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: ubifs ubi mtdchar bio2mtd mtd brd video output [last unloaded: mtd] Pid: 6414, comm: integck Not tainted (2.6.27-rc6ubifs34 #23) EIP: 0060:[<f8f9783f>] EFLAGS: 00010246 CPU: 0 EIP is at ubifs_unpack_bits+0xca/0x233 [ubifs] EAX: 00000000 EBX: f6090630 ECX: d9badcfc EDX: 00000000 ESI: 00000004 EDI: f8f74002 EBP: d9badcec ESP: d9badcc0 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process integck (pid: 6414, ti=d9bac000 task=f727dae0 task.ti=d9bac000) Stack: 00000006 f7306240 00000002 00000000 d9badcfc d9badd00 0000001c 00000000 f6090630 f6090630 f8f74000 d9badd10 f8fa1cc9 00000000 f8f74002 00000000 f8f74002 f60fe128 f6090630 f8f74000 d9badd68 f8fa1e46 00000000 0001e000 Call Trace: [<f8fa1cc9>] ? is_a_node+0x30/0x90 [ubifs] [<f8fa1e46>] ? dbg_check_ltab+0x11d/0x5bd [ubifs] [<f8fa388f>] ? ubifs_lpt_start_commit+0x42/0xed3 [ubifs] [<c038e76a>] ? mutex_unlock+0x8/0xa [<f8f9625d>] ? ubifs_tnc_start_commit+0x1c8/0xedb [ubifs] [<f8f8d90b>] ? do_commit+0x187/0x523 [ubifs] [<c038e76a>] ? mutex_unlock+0x8/0xa [<f8f7ca17>] ? bud_wbuf_callback+0x22/0x28 [ubifs] [<f8f8dd1d>] ? ubifs_run_commit+0x76/0xc0 [ubifs] [<f8f8032c>] ? ubifs_sync_fs+0xd2/0xe6 [ubifs] [<c01a2e97>] ? vfs_quota_sync+0x0/0x17e [<c01a5ba6>] ? quota_sync_sb+0x26/0xbb [<c01a2e97>] ? vfs_quota_sync+0x0/0x17e [<c01a5c5d>] ? sync_dquots+0x22/0x12c [<c0173d1b>] ? __fsync_super+0x19/0x68 [<c0173d75>] ? fsync_super+0xb/0x19 [<c0174065>] ? generic_shutdown_super+0x22/0xe7 [<c01a31fc>] ? vfs_quota_off+0x0/0x5fd [<f8f7cf4d>] ? ubifs_kill_sb+0x31/0x35 [ubifs] [<c01741f9>] ? deactivate_super+0x5e/0x71 [<c0187610>] ? mntput_no_expire+0x82/0xe4 [<c0187905>] ? sys_umount+0x4c/0x2f6 [<c0187bc8>] ? sys_oldumount+0x19/0x1b [<c0103b71>] ? sysenter_do_call+0x12/0x25 ======================= Code: c1 f8 03 8d 04 07 8b 4d e8 89 01 8b 45 e4 89 10 89 d8 89 f1 d3 e8 85 c0 74 07 29 d6 83 fe 20 75 2a 89 d8 83 c4 20 5b 5e 5f 5d EIP: [<f8f9783f>] ubifs_unpack_bits+0xca/0x233 [ubifs] SS:ESP 0068:d9badcc0 ---[ end trace 1f02572436518c13 ]--- Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-09-30UBIFS: add more debugging messages for LPTAdrian Hunter
Also add debugging checks for LPT size and separate out c->check_lpt_free from unrelated bitfields. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-07-15UBIFS: add new flash file systemArtem Bityutskiy
This is a new flash file system. See http://www.linux-mtd.infradead.org/doc/ubifs.html Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
