commit cf610bf4199770420629d3bc273494bd27ad6c1d upstream.
Sometimes VM asks the shrinker to return amount of objects it can shrink,
and we return the ubifs_clean_zn_cnt in that case. However, it is possible
that this counter is negative for a short period of time, due to the way
UBIFS TNC code updates it. And I can observe the following warnings sometimes:
shrink_slab: ubifs_shrinker+0x0/0x2b7 [ubifs] negative objects to delete nr=-8541616642706119788
This patch makes sure UBIFS never returns negative count of objects.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Trivial cleanup, list_del(); list_add{,_tail}() is equivalent
to list_move{,_tail}(). Semantic patch for coccinelle can be
found at www.cccmz.de/~snakebyte/list_move_tail.spatch
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
- (better, more, bigger ...) then -> (...) than
Signed-off-by: Frederik Schwarzer <schwarzerf@gmail.com>
This is a new flash file system. See
http://www.linux-mtd.infradead.org/doc/ubifs.html
Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
