path: root/fs/ubifs
2008-09-05UBIFS: make minimum fanout 3Artem Bityutskiy
UBIFS does not really work correctly when fanout is 2, because of the way we manage the indexing tree. It may just become a list and UBIFS screws up. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-09-05UBIFS: fix division by zeroArtem Bityutskiy
If fanout is 3, we have division by zero in 'ubifs_read_superblock()': divide error: 0000 [#1] PREEMPT SMP Pid: 28744, comm: mount Not tainted (2.6.27-rc4-ubifs-2.6 #23) EIP: 0060:[<f8f9e3ef>] EFLAGS: 00010202 CPU: 0 EIP is at ubifs_reported_space+0x2d/0x69 [ubifs] EAX: 00000000 EBX: 00000000 ECX: 00000000 EDX: 00000000 ESI: 00000000 EDI: f0ae64b0 EBP: f1f9fcf4 ESP: f1f9fce0 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-09-03UBIFS: amend f_fsidArtem Bityutskiy
David Woodhouse suggested to be consistent with other FSes and xor the beginning and the end of the UUID. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: fill f_fsidArtem Bityutskiy
UBIFS stores 16-bit UUID in the superblock, and it is a good idea to return part of it in 'f_fsid' filed of kstatfs structure. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: improve statfs reporting even moreArtem Bityutskiy
Since free space we report in statfs is file size which should fit to the FS - change the way we calculate free space and use leb_overhead instead of dark_wm in calculations. Results of "freespace" test (120MiB volume, 16KiB LEB size, 512 bytes page size). Before the change: freespace: Test 1: fill the space we have 3 times freespace: was free: 85204992 bytes 81.3 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 11284480 bytes 10.8 MiB, wrote 13.2% more than predicted freespace: was free: 83554304 bytes 79.7 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 12935168 bytes 12.3 MiB, wrote 15.5% more than predicted freespace: was free: 83554304 bytes 79.7 MiB, wrote: 96493568 bytes 92.0 MiB, delta: 12939264 bytes 12.3 MiB, wrote 15.5% more than predicted freespace: Test 1 finished freespace: Test 2: gradually lessen amount of free space and fill the FS freespace: do 10 steps, lessen free space by 7596218 bytes 7.2 MiB each time freespace: was free: 78675968 bytes 75.0 MiB, wrote: 88903680 bytes 84.8 MiB, delta: 10227712 bytes 9.8 MiB, wrote 13.0% more than predicted freespace: was free: 72015872 bytes 68.7 MiB, wrote: 81514496 bytes 77.7 MiB, delta: 9498624 bytes 9.1 MiB, wrote 13.2% more than predicted freespace: was free: 63938560 bytes 61.0 MiB, wrote: 72589312 bytes 69.2 MiB, delta: 8650752 bytes 8.2 MiB, wrote 13.5% more than predicted freespace: was free: 56127488 bytes 53.5 MiB, wrote: 63762432 bytes 60.8 MiB, delta: 7634944 bytes 7.3 MiB, wrote 13.6% more than predicted freespace: was free: 48336896 bytes 46.1 MiB, wrote: 54935552 bytes 52.4 MiB, delta: 6598656 bytes 6.3 MiB, wrote 13.7% more than predicted freespace: was free: 40587264 bytes 38.7 MiB, wrote: 46157824 bytes 44.0 MiB, delta: 5570560 bytes 5.3 MiB, wrote 13.7% more than predicted freespace: was free: 32841728 bytes 31.3 MiB, wrote: 37384192 bytes 35.7 MiB, delta: 4542464 bytes 4.3 MiB, wrote 13.8% more than predicted freespace: was free: 25100288 bytes 23.9 MiB, wrote: 28618752 bytes 27.3 MiB, delta: 3518464 bytes 3.4 MiB, wrote 14.0% more than predicted freespace: was free: 17342464 bytes 16.5 MiB, wrote: 19841024 bytes 18.9 MiB, delta: 2498560 bytes 2.4 MiB, wrote 14.4% more than predicted freespace: was free: 9605120 bytes 9.2 MiB, wrote: 11063296 bytes 10.6 MiB, delta: 1458176 bytes 1.4 MiB, wrote 15.2% more than predicted freespace: Test 2 finished freespace: Test 3: gradually lessen amount of free space by trashing and fill the FS freespace: do 10 steps, lessen free space by 7606272 bytes 7.3 MiB each time freespace: trashing: was free: 83668992 bytes 79.8 MiB, need free: 7606272 bytes 7.3 MiB, files created: 248297, delete 225724 (90.9% of them) freespace: was free: 70803456 bytes 67.5 MiB, wrote: 82485248 bytes 78.7 MiB, delta: 11681792 bytes 11.1 MiB, wrote 16.5% more than predicted freespace: trashing: was free: 81080320 bytes 77.3 MiB, need free: 15212544 bytes 14.5 MiB, files created: 248711, delete 202047 (81.2% of them) freespace: was free: 59867136 bytes 57.1 MiB, wrote: 71897088 bytes 68.6 MiB, delta: 12029952 bytes 11.5 MiB, wrote 20.1% more than predicted freespace: trashing: was free: 82243584 bytes 78.4 MiB, need free: 22818816 bytes 21.8 MiB, files created: 248866, delete 179817 (72.3% of them) freespace: was free: 50905088 bytes 48.5 MiB, wrote: 63168512 bytes 60.2 MiB, delta: 12263424 bytes 11.7 MiB, wrote 24.1% more than predicted freespace: trashing: was free: 83402752 bytes 79.5 MiB, need free: 30425088 bytes 29.0 MiB, files created: 248920, delete 158114 (63.5% of them) freespace: was free: 42651648 bytes 40.7 MiB, wrote: 55406592 bytes 52.8 MiB, delta: 12754944 bytes 12.2 MiB, wrote 29.9% more than predicted freespace: trashing: was free: 84402176 bytes 80.5 MiB, need free: 38031360 bytes 36.3 MiB, files created: 248709, delete 136641 (54.9% of them) freespace: was free: 35233792 bytes 33.6 MiB, wrote: 48250880 bytes 46.0 MiB, delta: 13017088 bytes 12.4 MiB, wrote 36.9% more than predicted freespace: trashing: was free: 82530304 bytes 78.7 MiB, need free: 45637632 bytes 43.5 MiB, files created: 248778, delete 111208 (44.7% of them) freespace: was free: 27287552 bytes 26.0 MiB, wrote: 40267776 bytes 38.4 MiB, delta: 12980224 bytes 12.4 MiB, wrote 47.6% more than predicted freespace: trashing: was free: 85114880 bytes 81.2 MiB, need free: 53243904 bytes 50.8 MiB, files created: 248508, delete 93052 (37.4% of them) freespace: was free: 22437888 bytes 21.4 MiB, wrote: 35328000 bytes 33.7 MiB, delta: 12890112 bytes 12.3 MiB, wrote 57.4% more than predicted freespace: trashing: was free: 84103168 bytes 80.2 MiB, need free: 60850176 bytes 58.0 MiB, files created: 248637, delete 68743 (27.6% of them) freespace: was free: 15536128 bytes 14.8 MiB, wrote: 28319744 bytes 27.0 MiB, delta: 12783616 bytes 12.2 MiB, wrote 82.3% more than predicted freespace: trashing: was free: 84357120 bytes 80.4 MiB, need free: 68456448 bytes 65.3 MiB, files created: 248567, delete 46852 (18.8% of them) freespace: was free: 9015296 bytes 8.6 MiB, wrote: 22044672 bytes 21.0 MiB, delta: 13029376 bytes 12.4 MiB, wrote 144.5% more than predicted freespace: trashing: was free: 84942848 bytes 81.0 MiB, need free: 76062720 bytes 72.5 MiB, files created: 248636, delete 25993 (10.5% of them) freespace: was free: 6086656 bytes 5.8 MiB, wrote: 8331264 bytes 7.9 MiB, delta: 2244608 bytes 2.1 MiB, wrote 36.9% more than predicted freespace: Test 3 finished freespace: finished successfully After the change: freespace: Test 1: fill the space we have 3 times freespace: was free: 94048256 bytes 89.7 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 2441216 bytes 2.3 MiB, wrote 2.6% more than predicted freespace: was free: 92246016 bytes 88.0 MiB, wrote: 96493568 bytes 92.0 MiB, delta: 4247552 bytes 4.1 MiB, wrote 4.6% more than predicted freespace: was free: 92254208 bytes 88.0 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 4235264 bytes 4.0 MiB, wrote 4.6% more than predicted freespace: Test 1 finished freespace: Test 2: gradually lessen amount of free space and fill the FS freespace: do 10 steps, lessen free space by 8386001 bytes 8.0 MiB each time freespace: was free: 86605824 bytes 82.6 MiB, wrote: 88252416 bytes 84.2 MiB, delta: 1646592 bytes 1.6 MiB, wrote 1.9% more than predicted freespace: was free: 78667776 bytes 75.0 MiB, wrote: 80715776 bytes 77.0 MiB, delta: 2048000 bytes 2.0 MiB, wrote 2.6% more than predicted freespace: was free: 69615616 bytes 66.4 MiB, wrote: 71630848 bytes 68.3 MiB, delta: 2015232 bytes 1.9 MiB, wrote 2.9% more than predicted freespace: was free: 61018112 bytes 58.2 MiB, wrote: 62783488 bytes 59.9 MiB, delta: 1765376 bytes 1.7 MiB, wrote 2.9% more than predicted freespace: was free: 52424704 bytes 50.0 MiB, wrote: 53968896 bytes 51.5 MiB, delta: 1544192 bytes 1.5 MiB, wrote 2.9% more than predicted freespace: was free: 43880448 bytes 41.8 MiB, wrote: 45199360 bytes 43.1 MiB, delta: 1318912 bytes 1.3 MiB, wrote 3.0% more than predicted freespace: was free: 35332096 bytes 33.7 MiB, wrote: 36425728 bytes 34.7 MiB, delta: 1093632 bytes 1.0 MiB, wrote 3.1% more than predicted freespace: was free: 26771456 bytes 25.5 MiB, wrote: 27643904 bytes 26.4 MiB, delta: 872448 bytes 852.0 KiB, wrote 3.3% more than predicted freespace: was free: 18231296 bytes 17.4 MiB, wrote: 18878464 bytes 18.0 MiB, delta: 647168 bytes 632.0 KiB, wrote 3.5% more than predicted freespace: was free: 9674752 bytes 9.2 MiB, wrote: 10088448 bytes 9.6 MiB, delta: 413696 bytes 404.0 KiB, wrote 4.3% more than predicted freespace: Test 2 finished freespace: Test 3: gradually lessen amount of free space by trashing and fill the FS freespace: do 10 steps, lessen free space by 8397544 bytes 8.0 MiB each time freespace: trashing: was free: 92372992 bytes 88.1 MiB, need free: 8397552 bytes 8.0 MiB, files created: 248296, delete 225723 (90.9% of them) freespace: was free: 71909376 bytes 68.6 MiB, wrote: 82472960 bytes 78.7 MiB, delta: 10563584 bytes 10.1 MiB, wrote 14.7% more than predicted freespace: trashing: was free: 88989696 bytes 84.9 MiB, need free: 16795096 bytes 16.0 MiB, files created: 248794, delete 201838 (81.1% of them) freespace: was free: 60354560 bytes 57.6 MiB, wrote: 71782400 bytes 68.5 MiB, delta: 11427840 bytes 10.9 MiB, wrote 18.9% more than predicted freespace: trashing: was free: 90304512 bytes 86.1 MiB, need free: 25192640 bytes 24.0 MiB, files created: 248733, delete 179342 (72.1% of them) freespace: was free: 51187712 bytes 48.8 MiB, wrote: 62943232 bytes 60.0 MiB, delta: 11755520 bytes 11.2 MiB, wrote 23.0% more than predicted freespace: trashing: was free: 91209728 bytes 87.0 MiB, need free: 33590184 bytes 32.0 MiB, files created: 248779, delete 157160 (63.2% of them) freespace: was free: 42704896 bytes 40.7 MiB, wrote: 55050240 bytes 52.5 MiB, delta: 12345344 bytes 11.8 MiB, wrote 28.9% more than predicted freespace: trashing: was free: 92700672 bytes 88.4 MiB, need free: 41987728 bytes 40.0 MiB, files created: 248848, delete 136135 (54.7% of them) freespace: was free: 35250176 bytes 33.6 MiB, wrote: 48115712 bytes 45.9 MiB, delta: 12865536 bytes 12.3 MiB, wrote 36.5% more than predicted freespace: trashing: was free: 93986816 bytes 89.6 MiB, need free: 50385272 bytes 48.1 MiB, files created: 248723, delete 115385 (46.4% of them) freespace: was free: 29995008 bytes 28.6 MiB, wrote: 41582592 bytes 39.7 MiB, delta: 11587584 bytes 11.1 MiB, wrote 38.6% more than predicted freespace: trashing: was free: 91881472 bytes 87.6 MiB, need free: 58782816 bytes 56.1 MiB, files created: 248645, delete 89569 (36.0% of them) freespace: was free: 22511616 bytes 21.5 MiB, wrote: 34705408 bytes 33.1 MiB, delta: 12193792 bytes 11.6 MiB, wrote 54.2% more than predicted freespace: trashing: was free: 91774976 bytes 87.5 MiB, need free: 67180360 bytes 64.1 MiB, files created: 248580, delete 66616 (26.8% of them) freespace: was free: 16908288 bytes 16.1 MiB, wrote: 26898432 bytes 25.7 MiB, delta: 9990144 bytes 9.5 MiB, wrote 59.1% more than predicted freespace: trashing: was free: 92450816 bytes 88.2 MiB, need free: 75577904 bytes 72.1 MiB, files created: 248654, delete 45381 (18.3% of them) freespace: was free: 10170368 bytes 9.7 MiB, wrote: 19111936 bytes 18.2 MiB, delta: 8941568 bytes 8.5 MiB, wrote 87.9% more than predicted freespace: trashing: was free: 93282304 bytes 89.0 MiB, need free: 83975448 bytes 80.1 MiB, files created: 248513, delete 24794 (10.0% of them) freespace: was free: 3911680 bytes 3.7 MiB, wrote: 7872512 bytes 7.5 MiB, delta: 3960832 bytes 3.8 MiB, wrote 101.3% more than predicted freespace: Test 3 finished freespace: finished successfully Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: introduce LEB overheadArtem Bityutskiy
This is a preparational patch for the following statfs() report fix. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: add forgotten gc_idx_lebs componentArtem Bityutskiy
We add this component at other similar places, but not in this one. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: fix assertionArtem Bityutskiy
The assertion was incorrect, because it did not take into account free space. This patch also amends the comments correspondingly, and cleans them up a little. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: improve statfs reportingArtem Bityutskiy
Make free space calculation less pessimistic and more realistic, which in turn improves 'statfs()' reports. Now it lies by 10%-20%, instead of 20%-30% (10% more honest). Results of "freespace" test (120MiB volume, 16KiB LEB size, 512 bytes page size). Before the change: freespace: Test 1: fill the space we have 3 times freespace: was free: 78274560 bytes 74.6 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 18214912 bytes 17.4 MiB, wrote 23.3% more than predicted freespace: was free: 76754944 bytes 73.2 MiB, wrote: 96493568 bytes 92.0 MiB, delta: 19738624 bytes 18.8 MiB, wrote 25.7% more than predicted freespace: was free: 76759040 bytes 73.2 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 19730432 bytes 18.8 MiB, wrote 25.7% more than predicted freespace: Test 1 finished freespace: Test 2: gradually lessen amount of free space and fill the FS freespace: do 10 steps, lessen free space by 6977722 bytes 6.7 MiB each time freespace: was free: 72273920 bytes 68.9 MiB, wrote: 88891392 bytes 84.8 MiB, delta: 16617472 bytes 15.8 MiB, wrote 23.0% more than predicted freespace: was free: 66154496 bytes 63.1 MiB, wrote: 81506304 bytes 77.7 MiB, delta: 15351808 bytes 14.6 MiB, wrote 23.2% more than predicted freespace: was free: 58732544 bytes 56.0 MiB, wrote: 72572928 bytes 69.2 MiB, delta: 13840384 bytes 13.2 MiB, wrote 23.6% more than predicted freespace: was free: 51552256 bytes 49.2 MiB, wrote: 63754240 bytes 60.8 MiB, delta: 12201984 bytes 11.6 MiB, wrote 23.7% more than predicted freespace: was free: 44404736 bytes 42.3 MiB, wrote: 54943744 bytes 52.4 MiB, delta: 10539008 bytes 10.1 MiB, wrote 23.7% more than predicted freespace: was free: 37285888 bytes 35.6 MiB, wrote: 46161920 bytes 44.0 MiB, delta: 8876032 bytes 8.5 MiB, wrote 23.8% more than predicted freespace: was free: 30171136 bytes 28.8 MiB, wrote: 37384192 bytes 35.7 MiB, delta: 7213056 bytes 6.9 MiB, wrote 23.9% more than predicted freespace: was free: 23048192 bytes 22.0 MiB, wrote: 28606464 bytes 27.3 MiB, delta: 5558272 bytes 5.3 MiB, wrote 24.1% more than predicted freespace: was free: 15941632 bytes 15.2 MiB, wrote: 19828736 bytes 18.9 MiB, delta: 3887104 bytes 3.7 MiB, wrote 24.4% more than predicted freespace: was free: 8830976 bytes 8.4 MiB, wrote: 11063296 bytes 10.6 MiB, delta: 2232320 bytes 2.1 MiB, wrote 25.3% more than predicted freespace: Test 2 finished freespace: Test 3: gradually lessen amount of free space by trashing and fill the FS freespace: do 10 steps, lessen free space by 6985541 bytes 6.7 MiB each time freespace: trashing: was free: 76840960 bytes 73.3 MiB, need free: 6985550 bytes 6.7 MiB, files created: 248311, delete 225737 (90.9% of them) freespace: was free: 65228800 bytes 62.2 MiB, wrote: 82530304 bytes 78.7 MiB, delta: 17301504 bytes 16.5 MiB, wrote 26.5% more than predicted freespace: trashing: was free: 74485760 bytes 71.0 MiB, need free: 13971091 bytes 13.3 MiB, files created: 248712, delete 202061 (81.2% of them) freespace: was free: 55025664 bytes 52.5 MiB, wrote: 71925760 bytes 68.6 MiB, delta: 16900096 bytes 16.1 MiB, wrote 30.7% more than predicted freespace: trashing: was free: 75550720 bytes 72.1 MiB, need free: 20956632 bytes 20.0 MiB, files created: 248849, delete 179822 (72.3% of them) freespace: was free: 46669824 bytes 44.5 MiB, wrote: 63197184 bytes 60.3 MiB, delta: 16527360 bytes 15.8 MiB, wrote 35.4% more than predicted freespace: trashing: was free: 76214272 bytes 72.7 MiB, need free: 27942173 bytes 26.6 MiB, files created: 248789, delete 157576 (63.3% of them) freespace: was free: 39129088 bytes 37.3 MiB, wrote: 55164928 bytes 52.6 MiB, delta: 16035840 bytes 15.3 MiB, wrote 41.0% more than predicted freespace: trashing: was free: 77398016 bytes 73.8 MiB, need free: 34927714 bytes 33.3 MiB, files created: 248711, delete 136474 (54.9% of them) freespace: was free: 32325632 bytes 30.8 MiB, wrote: 48234496 bytes 46.0 MiB, delta: 15908864 bytes 15.2 MiB, wrote 49.2% more than predicted freespace: trashing: was free: 75796480 bytes 72.3 MiB, need free: 41913255 bytes 40.0 MiB, files created: 248674, delete 111164 (44.7% of them) freespace: was free: 25079808 bytes 23.9 MiB, wrote: 40775680 bytes 38.9 MiB, delta: 15695872 bytes 15.0 MiB, wrote 62.6% more than predicted freespace: trashing: was free: 78209024 bytes 74.6 MiB, need free: 48898796 bytes 46.6 MiB, files created: 248708, delete 93207 (37.5% of them) freespace: was free: 20582400 bytes 19.6 MiB, wrote: 34844672 bytes 33.2 MiB, delta: 14262272 bytes 13.6 MiB, wrote 69.3% more than predicted freespace: trashing: was free: 77328384 bytes 73.7 MiB, need free: 55884337 bytes 53.3 MiB, files created: 248644, delete 68951 (27.7% of them) freespace: was free: 14368768 bytes 13.7 MiB, wrote: 28278784 bytes 27.0 MiB, delta: 13910016 bytes 13.3 MiB, wrote 96.8% more than predicted freespace: trashing: was free: 77434880 bytes 73.8 MiB, need free: 62869878 bytes 60.0 MiB, files created: 248640, delete 46767 (18.8% of them) freespace: was free: 8286208 bytes 7.9 MiB, wrote: 21811200 bytes 20.8 MiB, delta: 13524992 bytes 12.9 MiB, wrote 163.2% more than predicted freespace: trashing: was free: 77856768 bytes 74.2 MiB, need free: 69855419 bytes 66.6 MiB, files created: 248576, delete 25546 (10.3% of them) freespace: was free: 5570560 bytes 5.3 MiB, wrote: 8187904 bytes 7.8 MiB, delta: 2617344 bytes 2.5 MiB, wrote 47.0% more than predicted freespace: Test 3 finished freespace: finished successfully After the change: freespace: Test 1: fill the space we have 3 times freespace: was free: 85204992 bytes 81.3 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 11284480 bytes 10.8 MiB, wrote 13.2% more than predicted freespace: was free: 83554304 bytes 79.7 MiB, wrote: 96489472 bytes 92.0 MiB, delta: 12935168 bytes 12.3 MiB, wrote 15.5% more than predicted freespace: was free: 83554304 bytes 79.7 MiB, wrote: 96493568 bytes 92.0 MiB, delta: 12939264 bytes 12.3 MiB, wrote 15.5% more than predicted freespace: Test 1 finished freespace: Test 2: gradually lessen amount of free space and fill the FS freespace: do 10 steps, lessen free space by 7596218 bytes 7.2 MiB each time freespace: was free: 78675968 bytes 75.0 MiB, wrote: 88903680 bytes 84.8 MiB, delta: 10227712 bytes 9.8 MiB, wrote 13.0% more than predicted freespace: was free: 72015872 bytes 68.7 MiB, wrote: 81514496 bytes 77.7 MiB, delta: 9498624 bytes 9.1 MiB, wrote 13.2% more than predicted freespace: was free: 63938560 bytes 61.0 MiB, wrote: 72589312 bytes 69.2 MiB, delta: 8650752 bytes 8.2 MiB, wrote 13.5% more than predicted freespace: was free: 56127488 bytes 53.5 MiB, wrote: 63762432 bytes 60.8 MiB, delta: 7634944 bytes 7.3 MiB, wrote 13.6% more than predicted freespace: was free: 48336896 bytes 46.1 MiB, wrote: 54935552 bytes 52.4 MiB, delta: 6598656 bytes 6.3 MiB, wrote 13.7% more than predicted freespace: was free: 40587264 bytes 38.7 MiB, wrote: 46157824 bytes 44.0 MiB, delta: 5570560 bytes 5.3 MiB, wrote 13.7% more than predicted freespace: was free: 32841728 bytes 31.3 MiB, wrote: 37384192 bytes 35.7 MiB, delta: 4542464 bytes 4.3 MiB, wrote 13.8% more than predicted freespace: was free: 25100288 bytes 23.9 MiB, wrote: 28618752 bytes 27.3 MiB, delta: 3518464 bytes 3.4 MiB, wrote 14.0% more than predicted freespace: was free: 17342464 bytes 16.5 MiB, wrote: 19841024 bytes 18.9 MiB, delta: 2498560 bytes 2.4 MiB, wrote 14.4% more than predicted freespace: was free: 9605120 bytes 9.2 MiB, wrote: 11063296 bytes 10.6 MiB, delta: 1458176 bytes 1.4 MiB, wrote 15.2% more than predicted freespace: Test 2 finished freespace: Test 3: gradually lessen amount of free space by trashing and fill the FS freespace: do 10 steps, lessen free space by 7606272 bytes 7.3 MiB each time freespace: trashing: was free: 83668992 bytes 79.8 MiB, need free: 7606272 bytes 7.3 MiB, files created: 248297, delete 225724 (90.9% of them) freespace: was free: 70803456 bytes 67.5 MiB, wrote: 82485248 bytes 78.7 MiB, delta: 11681792 bytes 11.1 MiB, wrote 16.5% more than predicted freespace: trashing: was free: 81080320 bytes 77.3 MiB, need free: 15212544 bytes 14.5 MiB, files created: 248711, delete 202047 (81.2% of them) freespace: was free: 59867136 bytes 57.1 MiB, wrote: 71897088 bytes 68.6 MiB, delta: 12029952 bytes 11.5 MiB, wrote 20.1% more than predicted freespace: trashing: was free: 82243584 bytes 78.4 MiB, need free: 22818816 bytes 21.8 MiB, files created: 248866, delete 179817 (72.3% of them) freespace: was free: 50905088 bytes 48.5 MiB, wrote: 63168512 bytes 60.2 MiB, delta: 12263424 bytes 11.7 MiB, wrote 24.1% more than predicted freespace: trashing: was free: 83402752 bytes 79.5 MiB, need free: 30425088 bytes 29.0 MiB, files created: 248920, delete 158114 (63.5% of them) freespace: was free: 42651648 bytes 40.7 MiB, wrote: 55406592 bytes 52.8 MiB, delta: 12754944 bytes 12.2 MiB, wrote 29.9% more than predicted freespace: trashing: was free: 84402176 bytes 80.5 MiB, need free: 38031360 bytes 36.3 MiB, files created: 248709, delete 136641 (54.9% of them) freespace: was free: 35233792 bytes 33.6 MiB, wrote: 48250880 bytes 46.0 MiB, delta: 13017088 bytes 12.4 MiB, wrote 36.9% more than predicted freespace: trashing: was free: 82530304 bytes 78.7 MiB, need free: 45637632 bytes 43.5 MiB, files created: 248778, delete 111208 (44.7% of them) freespace: was free: 27287552 bytes 26.0 MiB, wrote: 40267776 bytes 38.4 MiB, delta: 12980224 bytes 12.4 MiB, wrote 47.6% more than predicted freespace: trashing: was free: 85114880 bytes 81.2 MiB, need free: 53243904 bytes 50.8 MiB, files created: 248508, delete 93052 (37.4% of them) freespace: was free: 22437888 bytes 21.4 MiB, wrote: 35328000 bytes 33.7 MiB, delta: 12890112 bytes 12.3 MiB, wrote 57.4% more than predicted freespace: trashing: was free: 84103168 bytes 80.2 MiB, need free: 60850176 bytes 58.0 MiB, files created: 248637, delete 68743 (27.6% of them) freespace: was free: 15536128 bytes 14.8 MiB, wrote: 28319744 bytes 27.0 MiB, delta: 12783616 bytes 12.2 MiB, wrote 82.3% more than predicted freespace: trashing: was free: 84357120 bytes 80.4 MiB, need free: 68456448 bytes 65.3 MiB, files created: 248567, delete 46852 (18.8% of them) freespace: was free: 9015296 bytes 8.6 MiB, wrote: 22044672 bytes 21.0 MiB, delta: 13029376 bytes 12.4 MiB, wrote 144.5% more than predicted freespace: trashing: was free: 84942848 bytes 81.0 MiB, need free: 76062720 bytes 72.5 MiB, files created: 248636, delete 25993 (10.5% of them) freespace: was free: 6086656 bytes 5.8 MiB, wrote: 8331264 bytes 7.9 MiB, delta: 2244608 bytes 2.1 MiB, wrote 36.9% more than predicted freespace: Test 3 finished freespace: finished successfully Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: remove incorrect index space checkArtem Bityutskiy
When we report free space to user-space, we should not report 0 if the amount of empty LEBs is too low, because they would be produced by GC when needed. Thus, just call 'ubifs_calc_available()' straight away which would take 'min_idx_lebs' into account anyway. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: push empty flash hack downArtem Bityutskiy
We have a hack which forces the amount of flash space to be equivalent to 'c->blocks_cnt' in case of empty FS. This is to make users happy and see '%0' used in 'df' when they mount an empty FS. This hack is not needed in 'ubifs_calc_available()', but it is only needed the caller, in 'ubifs_budg_get_free_space()'. So push it down there. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-31UBIFS: do not update min_idx_lebs in stafsArtem Bityutskiy
This is bad because the rest of the code should not depend on it, and this may hide bugss, instead of revealing them. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-25UBIFS: allow for racing between GC and TNCAdrian Hunter
The TNC mutex is unlocked prematurely when reading leaf nodes with non-hashed keys. This is unsafe because the node may be moved by garbage collection and the eraseblock unmapped, although that has never actually happened during stress testing. This patch fixes the flaw by detecting the race and retrying with the TNC mutex locked. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-25UBIFS: always read hashed-key nodes under TNC mutexAdrian Hunter
Leaf-nodes that have a hashed key are stored in the leaf-node-cache (LNC) which is protected by the TNC mutex. Consequently, when reading a leaf node with a hashed key (i.e. directory entries, xattr entries) the TNC mutex is always required. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-21UBIFS: fix zero-length truncationsArtem Bityutskiy
Always allow truncations to zero, even if budgeting thinks there is no space. UBIFS reserves some space for deletions anyway. Otherwise, the following happans: 1. create a file, and write as much as possible there, until ENOSPC 2. truncate the file, which fails with ENOSPC, which is not good. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-14UBIFS: xattr bugfixesArtem Bityutskiy
Xattr code has not been tested for a while and there were serveral bugs. One of them is using wrong inode in 'ubifs_jnl_change_xattr()'. The other is a deadlock in 'ubifs_setxattr()': the i_mutex is locked in 'cap_inode_need_killpriv()' path, so deadlock happens when 'ubifs_setxattr()' tries to lock it again. Thanks to Zoltan Sogor for finding these bugs. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: remove unneeded checkArtem Bityutskiy
Commit d70b67c8bc72ee23b55381bd6a884f4796692f77 fixed VFS and it never calls FS lookup function in deleted directories now. We may remove corresponding UBIFS check. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: few commentary fixesArtem Bityutskiy
2008-08-13UBIFS: fix budgeting request alignment in xattr codeZoltan Sogor
Data length has to be aligned in the budgeting request. Code in xattr.c did not do this. Signed-off-by: Zoltan Sogor <weth@inf.u-szeged.hu> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: improve arguments checking in debugging messagesArtem Bityutskiy
Use "if (0) printk()" construct in debugging print macros to make the debugging messages be checked even if debugging is off. This patch also removes some unneeded spaces and blank lines. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: always set i_generation to 0Adrian Hunter
UBIFS does not presently re-use inode numbers, so leaving i_generation zero is most appropriate for now. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: correct spelling of "thrice".Adrian Hunter
2008-08-13UBIFS: support splice_writeZoltan Sogor
2008-08-13UBIFS: minor tweaks in commitArtem Bityutskiy
No functional changes, just lessen the amount of indentations. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: reserve more space for indexArtem Bityutskiy
At the moment UBIFS reserves twice old index size space for the index. But this is not enough in some cases, because if the indexing node are very fragmented and there are many small gaps, while the dirty index has big znodes - in-the-gaps method would fail. Thus, reserve trise as more, in which case we are guaranteed that we can commit in any case. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: print pid in dump functionArtem Bityutskiy
Useful when something fails and there are many processes racing. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: align inode data to eightArtem Bityutskiy
UBIFS aligns node lengths to 8, so budgeting has to do the same. Well, direntry, inode, and page budgets are already aligned, but not inode data budget (e.g., data in special devices or symlinks). Do this for inode data as well. Also, add corresponding debugging checks. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: improve budgeting checksArtem Bityutskiy
Budgeting is a crucial UBIFS subsystem - add more assertions to improve requests checking. This is not compiled in when UBIFS debugging is disabled. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: correct orphan deletion orderAdrian Hunter
The debug function that checks orphans, does so using the TNC mutex. That means it will not see a correct picture if the inode is removed from the orphan tree before it is removed from TNC. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-13UBIFS: fix typos in commentsAdrian Hunter
2008-08-13UBIFS: do not union creat_sqnum and del_cmtnoAdrian Hunter
The values in these two fields need to be preserved independently and so a union cannot be used. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-13UBIFS: optimize deletionsArtem Bityutskiy
Every time anything is deleted, UBIFS writes the deletion inode node twice - once in 'ubifs_jnl_update()' and the second time in 'ubifs_jnl_write_inode()'. However, the second write is not needed if no commit happened after 'ubifs_jnl_update()'. This patch checks that condition and avoids writing the deletion inode for the second time. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: increment commit number earlierArtem Bityutskiy
Increment the commit number at the beginnig of the commit, instead of doing this after the commit. This is needed for further optimizations. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: remove another unneeded function parameterArtem Bityutskiy
The 'last_reference' parameter of 'pack_inode()' is not really needed because 'inode->i_nlink' may be tested instead. Zap it. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: remove unneeded function parameterArtem Bityutskiy
Simplify 'ubifs_jnl_write_inode()' by removing the 'deletion' parameter which is not really needed because we may test inode->i_nlink and check whether this is a deletion or not. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: do not write orphans backArtem Bityutskiy
Orphan inodes are deleted inodes which will disappear after FS re-mount. There is not need to write orphan inodes back, because they are not needed on the flash media. So optimize orphans a little by not writing them back. Just mark them as clean, free the budget, and report success to VFS. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: make ubifs_ro_mode() not inlineAdrian Hunter
We use ubifs_ro_mode() quite a lot, and not in fast-path, so there is no reason to blow the code up by having it inlined. Also, we usually want R/O mode change to be seen to other CPUs as soon as possible, so when we make this a function call, we will automatically have a memory barrier. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: ensure UBIFS switches to read-only on errorAdrian Hunter
UBI transparently handles write errors by automatically copying and remapping the affected eraseblock. If UBI is unable to do that, for example its pool of eraseblocks reserved for bad block handling is empty, then the error is propagated to UBIFS. UBIFS must protect the media from falling into an inconsistent state by immediately switching to read-only mode. In the case of log updates, this was not being done. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-13UBIFS: fix error return in failure modeAdrian Hunter
UBIFS recovery testing debug facility simulates media failures. When simulating an IO error, the error code returned must be -EIO but it was not always if the user switched off the debug recovery testing option at the same time. Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-08-13UBIFS: free budget in delete_inode as wellArtem Bityutskiy
Although the inode is marked as clean when it is being deleted, it might stay and be used as orphan, and be marked as dirty. So we have to free the budget when we delete it. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: improve debuggingArtem Bityutskiy
1. Print inode mode in some of debugging messages 2. Add few more useful assertions Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: fix budgeting calculationsArtem Bityutskiy
The 'ubifs_release_dirty_inode_budget()' was buggy and incorrectly freed the budget, which led to not freeing all dirty data budget. This patch fixes that. Also, this patch fixes ubifs_mkdir() which passed 1 in dirty_ino_d, which makes no sense. Well, it is harmless though. Also, add few more useful assertions. And improve few debugging messages. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-08-13UBIFS: print volume name as wellArtem Bityutskiy
We encouredge people to mount using volume name, not device numbers. So print the name of the mounted UBI volume, not just IDs. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2008-07-26[PATCH] get rid of indirect users of namei.hAl Viro
fs.h needs path.h, not namei.h; nfs_fs.h doesn't need it at all. Several places in the tree needed direct include. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-15UBIFS: include to compilationArtem Bityutskiy
Add UBIFS to Makefile and Kbuild. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
2008-07-15UBIFS: add new flash file systemArtem Bityutskiy
This is a new flash file system. See http://www.linux-mtd.infradead.org/doc/ubifs.html Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Signed-off-by: Adrian Hunter <ext-adrian.hunter@nokia.com>
