commit 72abc8f4b4e8574318189886de627a2bfe6cd0da upstream.
I hit the same assert failed as Dolev Raviv reported in Kernel v3.10
shows like this:
[ 9641.164028] UBIFS assert failed in shrink_tnc at 131 (pid 13297)
[ 9641.234078] CPU: 1 PID: 13297 Comm: mmap.test Tainted: G O 3.10.40 #1
[ 9641.234116] [<c0011a6c>] (unwind_backtrace+0x0/0x12c) from [<c000d0b0>] (show_stack+0x20/0x24)
[ 9641.234137] [<c000d0b0>] (show_stack+0x20/0x24) from [<c0311134>] (dump_stack+0x20/0x28)
[ 9641.234188] [<c0311134>] (dump_stack+0x20/0x28) from [<bf22425c>] (shrink_tnc_trees+0x25c/0x350 [ubifs])
[ 9641.234265] [<bf22425c>] (shrink_tnc_trees+0x25c/0x350 [ubifs]) from [<bf2245ac>] (ubifs_shrinker+0x25c/0x310 [ubifs])
[ 9641.234307] [<bf2245ac>] (ubifs_shrinker+0x25c/0x310 [ubifs]) from [<c00cdad8>] (shrink_slab+0x1d4/0x2f8)
[ 9641.234327] [<c00cdad8>] (shrink_slab+0x1d4/0x2f8) from [<c00d03d0>] (do_try_to_free_pages+0x300/0x544)
[ 9641.234344] [<c00d03d0>] (do_try_to_free_pages+0x300/0x544) from [<c00d0a44>] (try_to_free_pages+0x2d0/0x398)
[ 9641.234363] [<c00d0a44>] (try_to_free_pages+0x2d0/0x398) from [<c00c6a60>] (__alloc_pages_nodemask+0x494/0x7e8)
[ 9641.234382] [<c00c6a60>] (__alloc_pages_nodemask+0x494/0x7e8) from [<c00f62d8>] (new_slab+0x78/0x238)
[ 9641.234400] [<c00f62d8>] (new_slab+0x78/0x238) from [<c031081c>] (__slab_alloc.constprop.42+0x1a4/0x50c)
[ 9641.234419] [<c031081c>] (__slab_alloc.constprop.42+0x1a4/0x50c) from [<c00f80e8>] (kmem_cache_alloc_trace+0x54/0x188)
[ 9641.234459] [<c00f80e8>] (kmem_cache_alloc_trace+0x54/0x188) from [<bf227908>] (do_readpage+0x168/0x468 [ubifs])
[ 9641.234553] [<bf227908>] (do_readpage+0x168/0x468 [ubifs]) from [<bf2296a0>] (ubifs_readpage+0x424/0x464 [ubifs])
[ 9641.234606] [<bf2296a0>] (ubifs_readpage+0x424/0x464 [ubifs]) from [<c00c17c0>] (filemap_fault+0x304/0x418)
[ 9641.234638] [<c00c17c0>] (filemap_fault+0x304/0x418) from [<c00de694>] (__do_fault+0xd4/0x530)
[ 9641.234665] [<c00de694>] (__do_fault+0xd4/0x530) from [<c00e10c0>] (handle_pte_fault+0x480/0xf54)
[ 9641.234690] [<c00e10c0>] (handle_pte_fault+0x480/0xf54) from [<c00e2bf8>] (handle_mm_fault+0x140/0x184)
[ 9641.234716] [<c00e2bf8>] (handle_mm_fault+0x140/0x184) from [<c0316688>] (do_page_fault+0x150/0x3ac)
[ 9641.234737] [<c0316688>] (do_page_fault+0x150/0x3ac) from [<c000842c>] (do_DataAbort+0x3c/0xa0)
[ 9641.234759] [<c000842c>] (do_DataAbort+0x3c/0xa0) from [<c0314e38>] (__dabt_usr+0x38/0x40)
After analyzing the code, I found a condition that may cause this failed
in correct operations. Thus, I think this assertion is wrong and should be
removed.
Suppose there are two clean znodes and one dirty znode in TNC. So the
per-filesystem atomic_t @clean_zn_cnt is (2). If commit start, dirty_znode
is set to COW_ZNODE in get_znodes_to_commit() in case of potentially ops
on this znode. We clear COW bit and DIRTY bit in write_index() without
@tnc_mutex locked. We don't increase @clean_zn_cnt in this place. As the
comments in write_index() shows, if another process hold @tnc_mutex and
dirty this znode after we clean it, @clean_zn_cnt would be decreased to (1).
We will increase @clean_zn_cnt to (2) with @tnc_mutex locked in
free_obsolete_znodes() to keep it right.
If shrink_tnc() performs between decrease and increase, it will release
other 2 clean znodes it holds and found @clean_zn_cnt is less than zero
(1 - 2 = -1), then hit the assertion. Because free_obsolete_znodes() will
soon correct @clean_zn_cnt and no harm to fs in this case, I think this
assertion could be removed.
2 clean zondes and 1 dirty znode, @clean_zn_cnt == 2
Thread A (commit) Thread B (write or others) Thread C (shrinker)
->write_index
->clear_bit(DIRTY_NODE)
->clear_bit(COW_ZNODE)
@clean_zn_cnt == 2
->mutex_locked(&tnc_mutex)
->dirty_cow_znode
->!ubifs_zn_cow(znode)
->!test_and_set_bit(DIRTY_NODE)
->atomic_dec(&clean_zn_cnt)
->mutex_unlocked(&tnc_mutex)
@clean_zn_cnt == 1
->shrink_tnc
->destroy_tnc_subtree
->atomic_sub(&clean_zn_cnt, 2)
->ubifs_assert <- hit
@clean_zn_cnt == -1
->mutex_lock(&tnc_mutex)
->free_obsolete_znodes
->atomic_inc(&clean_zn_cnt)
->mutux_unlock(&tnc_mutex)
@clean_zn_cnt == 0 (correct after shrink)
Signed-off-by: hujianyang <hujianyang@huawei.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 8afd500cb52a5d00bab4525dd5a560d199f979b9 upstream.
The last orphan in the dnext list has its dnext set to NULL. Because
of that, ubifs_delete_orphan assumes that it is not on the dnext list
and frees it immediately instead ignoring it as a second delete. The
orphan is later freed again by erase_deleted.
This change adds an explicit flag to ubifs_orphan indicating whether
it is pending delete.
Signed-off-by: Adam Thomas <adamthomas1111@gmail.com>
[bwh: Backported to 3.2: adjust context]
Cc: Rui Xiang <rui.xiang@huawei.com>
commit 605c912bb843c024b1ed173dc427cd5c08e5d54d upstream.
Al Viro pointed me to the fact that '->readdir()' and '->llseek()' have no
mutual exclusion, which means the 'ubifs_dir_llseek()' can be run while we are
in the middle of 'ubifs_readdir()'.
This means that 'file->private_data' can be freed while 'ubifs_readdir()' uses
it, and this is a very bad bug: not only 'ubifs_readdir()' can return garbage,
but this may corrupt memory and lead to all kinds of problems like crashes an
security holes.
This patch fixes the problem by using the 'file->f_version' field, which
'->llseek()' always unconditionally sets to zero. We set it to 1 in
'ubifs_readdir()' and whenever we detect that it became 0, we know there was a
seek and it is time to clear the state saved in 'file->private_data'.
I tested this patch by writing a user-space program which runds readdir and
seek in parallell. I could easily crash the kernel without these patches, but
could not crash it with these patches.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 33f1a63ae84dfd9ad298cf275b8f1887043ced36 upstream.
First of all, this means that 'file->private_data' can be freed while
'ubifs_readdir()' uses it. But this particular patch does not fix the problem.
This patch is only a preparation, and the fix will follow next.
In this patch we make 'ubifs_readdir()' stop using 'file->f_pos' directly,
because 'file->f_pos' can be changed by '->llseek()' at any point. This may
lead 'ubifs_readdir()' to returning inconsistent data: directory entry names
may correspond to incorrect file positions.
So here we introduce a local variable 'pos', read 'file->f_pose' once at very
the beginning, and then stick to 'pos'. The result of this is that when
'ubifs_dir_llseek()' changes 'file->f_pos' while we are in the middle of
'ubifs_readdir()', the latter "wins".
commit 67e753ca41782913d805ff4a8a2b0f60b26b7915 upstream.
The UBIFS space fixup is a useful feature which allows to fixup the "broken"
flash space at the time of the first mount. The "broken" space is usually the
result of using a "dumb" industrial flasher which is not able to skip empty
NAND pages and just writes all 0xFFs to the empty space, which has grave
side-effects for UBIFS when UBIFS trise to write useful data to those empty
pages.
The fix-up feature works roughly like this:
1. mkfs.ubifs sets the fixup flag in UBIFS superblock when creating the image
(see -F option)
2. when the file-system is mounted for the first time, UBIFS notices the fixup
flag and re-writes the entire media atomically, which may take really a lot
of time.
3. UBIFS clears the fixup flag in the superblock.
This works fine when the file system is mounted R/W for the very first time.
But it did not really work in the case when we first mount the file-system R/O,
and then re-mount R/W. The reason was that we started the fixup procedure too
late, which we cannot really do because we have to fixup the space before it
starts being used.
Reported-by: Mark Jackson <mpfj-list@mimc.co.uk>
commit 782759b9f5f5223e0962af60c3457c912fab755f upstream.
Fix the following compilation warning:
fs/ubifs/dir.c: In function 'ubifs_rename':
fs/ubifs/dir.c:972:15: warning: 'saved_nlink' may be used uninitialized
in this function
Use the 'uninitialized_var()' macro to get rid of this false-positive.
Artem: massaged the patch a bit.
Signed-off-by: Alexandre Pereira da Silva <aletes.xgr@gmail.com>
commit 98a1eebda3cb2a84ecf1f219bb3a95769033d1bf upstream.
This commit is a preparation for a subsequent bugfix. We introduce a
counter for categorized lprops.
commit a28ad42a4a0c6f302f488f26488b8b37c9b30024 upstream.
This is a bugfix for a problem with the following symptoms:
1. A power cut happens
2. After reboot, we try to mount UBIFS
3. Mount fails with "No space left on device" error message
UBIFS complains like this:
UBIFS error (pid 28225): grab_empty_leb: could not find an empty LEB
The root cause of this problem is that when we mount, not all LEBs are
categorized. Only those which were read are. However, the
'ubifs_find_free_leb_for_idx()' function assumes that all LEBs were
categorized and 'c->freeable_cnt' is valid, which is a false assumption.
This patch fixes the problem by teaching 'ubifs_find_free_leb_for_idx()'
to always fall back to LPT scanning if no freeable LEBs were found.
This problem was reported by few people in the past, but Brent Taylor
was able to reproduce it and send me a flash image which cannot be mounted,
which made it easy to hunt the bug. Kudos to Brent.
Reported-by: Brent Taylor <motobud@gmail.com>
commit 65b455b123c7e2b835a0b7148f9bae584f95000e upstream.
When debugging is enabled, we use a temporary on-stack buffer for formatting
the key strings like "(11368871, direntry, 0xcd0750)". The buffer size is
32 bytes and sometimes it is not enough to fit the key string - e.g., when
inode numbers are high. This is not fatal, but the key strings are incomplete
and UBIFS complains like this:
UBIFS assert failed in dbg_snprintf_key at 137 (pid 1)
This is a regression caused by "515315a UBIFS: fix key printing".
Fix the issue by increasing the buffer to 48 bytes.
Reported-by: Michael Hench <michaelhench@gmail.com>
Tested-by: Michael Hench <michaelhench@gmail.com>
commit c6727932cfdb13501108b16c38463c09d5ec7a74 upstream.
UBIFS has a feature called "empty space fix-up" which is a quirk to work-around
limitations of dumb flasher programs. Namely, of those flashers that are unable
to skip NAND pages full of 0xFFs while flashing, resulting in empty space at
the end of half-filled eraseblocks to be unusable for UBIFS. This feature is
relatively new (introduced in v3.0).
The fix-up routine (fixup_free_space()) is executed only once at the very first
mount if the superblock has the 'space_fixup' flag set (can be done with -F
option of mkfs.ubifs). It basically reads all the UBIFS data and metadata and
writes it back to the same LEB. The routine assumes the image is pristine and
does not have anything in the journal.
There was a bug in 'fixup_free_space()' where it fixed up the log incorrectly.
All but one LEB of the log of a pristine file-system are empty. And one
contains just a commit start node. And 'fixup_free_space()' just unmapped this
LEB, which resulted in wiping the commit start node. As a result, some users
were unable to mount the file-system next time with the following symptom:
UBIFS error (pid 1): replay_log_leb: first log node at LEB 3:0 is not CS node
UBIFS error (pid 1): replay_log_leb: log error detected while replaying the log at LEB 3:0
The root-cause of this bug was that 'fixup_free_space()' wrongly assumed
that the beginning of empty space in the log head (c->lhead_offs) was known
on mount. However, it is not the case - it was always 0. UBIFS does not store
in it the master node and finds out by scanning the log on every mount.
The fix is simple - just pass commit start node size instead of 0 to
'fixup_leb()'.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@linux.intel.com>
Reported-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
Tested-by: Iwo Mergler <Iwo.Mergler@netcommwireless.com>
Reported-by: James Nute <newten82@gmail.com>
Pull UBIFS changes from Artem Bityutskiy:
- Improve error messages
- Clean-up i_nlink management
- Minor clean-ups
* tag 'upstream-3.4-rc1' of git://git.infradead.org/linux-ubifs:
UBIFS: improve error messages
UBIFS: kill CUR_MAX_KEY_LEN macro
UBIFS: do not use inc_link when i_nlink is zero
UBIFS: make the dbg_lock spinlock static
UBIFS: increase dumps loglevel
UBIFS: amend recovery debugging message
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Signed-off-by: Cong Wang <amwang@redhat.com>
Ricard complaints that the following error message is odd:
"UBIFS error (pid 1578): validate_sb: bad superblock, error 8"
and he is right. This patch improves the error messages a bit and makes
them more user-friendly.
Reported-by: Ricard Wanderlof <ricard.wanderlof@axis.com>
It is useless and confusing and may make people believe they may just
change it, which is not true, because this will also change the on-flash
format.
This patch changes the 'i_nlink' counter handling in 'ubifs_unlink()',
'ubifs_rmdir()' and 'ubifs_rename()'. In these function 'i_nlink' may become 0,
and if 'ubifs_jnl_update()' failed, we would use 'inc_nlink()' to restore
the previous 'i_nlink' value, which is incorrect from the VFS point of view and
would cause a 'WARN_ON()' (see 'inc_nlink() implementation).
This patches saves the previous 'i_nlink' value in a local variable and uses it
at the error path instead of calling 'inc_nlink()'. We do this only for the
inodes where 'i_nlink' may potentially become zero.
This change has been requested by Al Viro <viro@ZenIV.linux.org.uk>.
Remove the usage of the 'dbg_lock' spinlock from 'dbg_err()' and make
it static.
Most of the time we use the dumping function to dump something in case
of error. We use 'KERN_DEBUG' printk level, and the drawback is that users
do not see them in the console, while they see the other error messages
in the console. The result is that they send bug reports which does not
contain a lot of useful information. This patch changes the printk level
of the dump functions to 'KERN_ERR' to correct the situation.
I documented it in the MTD web site that people have to send the 'dmesg' output
when submitting bug reposts - it did not help.
Print LEB and offset as well.
Fix a brown paperbag bug introduced by me in the previous commit. I was
in hurry and forgot about the non-debug case completely.
Artem: amend the commit message and tweak the patch to preserve alignment.
This made the patch a bit less readable, though.
* 'linux-next' of git://git.infradead.org/ubifs-2.6:
UBIFS: use snprintf instead of sprintf when printing keys
UBIFS: fix debugging messages
UBIFS: make debugging messages light again
UBI: fix debugging messages
UBI: make vid_hdr non-static
Before commit 56e46742e846e4de167dde0e1e1071ace1c882a5 we have had locking
around all printing macros and we could use static buffers for creating
key strings and printing them. However, now we do not have that locking and
we cannot use static buffers. This commit removes the old DBGKEY() macros
and introduces few new helper macros for printing debugging messages plus
a key at the end. Thankfully, all the messages are already structures in
a way that the key is printed in the end.
Switch to 'snprintf()' which is more secure and reliable. This is also a
preparation to the subsequent key printing fixes.
Patch 56e46742e846e4de167dde0e1e1071ace1c882a5 broke UBIFS debugging messages:
before that commit when UBIFS debugging was enabled, users saw few useful
debugging messages after mount. However, that patch turned 'dbg_msg()' into
'pr_debug()', so to enable the debugging messages users have to enable them
first via /sys/kernel/debug/dynamic_debug/control, which is very impractical.
This commit makes 'dbg_msg()' to use 'printk()' instead of 'pr_debug()', just
as it was before the breakage.
Cc: stable@kernel.org [3.0+]
We switch to dynamic debugging in commit
56e46742e846e4de167dde0e1e1071ace1c882a5 but did not take into account that
now we do not control anymore whether a specific message is enabled or not.
So now we lock the "dbg_lock" and release it in every debugging macro, which
make them not so light-weight.
This commit removes the "dbg_lock" protection from the debugging macros to
fix the issue.
The downside is that now our DBGKEY() stuff is broken, but this is not
critical at all and will be fixed later.
UBI: fix use-after-free on error path
UBI: fix missing scrub when there is a bit-flip
UBIFS: Use kmemdup rather than duplicating its implementation
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
new helper (wrapper around mnt_drop_write()) to be used in pair with
mnt_want_write_file().
it's both faster (in case when file has been opened for write) and cleaner.
doing that before you are ready to handle mount() is a Bad Idea(tm)...
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
UBIFS: fix the dark space calculation
UBIFS: introduce a helper to dump scanning info
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Add a 'reason' to wb_writeback_work
writeback: send work item to queue_io, move_expired_inodes
writeback: trace event balance_dirty_pages
writeback: trace event bdi_dirty_ratelimit
writeback: fix ppc compile warnings on do_div(long long, unsigned long)
writeback: per-bdi background threshold
writeback: dirty position control - bdi reserve area
writeback: control dirty pause time
writeback: limit max dirty pause time
writeback: IO-less balance_dirty_pages()
writeback: per task dirty rate limit
writeback: stabilize bdi->dirty_ratelimit
writeback: dirty rate control
writeback: add bg_threshold parameter to __bdi_update_bandwidth()
writeback: account per-bdi accumulated dirtied pages
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
This creates a new 'reason' field in a wb_writeback_work
structure, which unambiguously identifies who initiates
writeback activity. A 'wb_reason' enumeration has been
added to writeback.h, to enumerate the possible reasons.
The 'writeback_work_class' and tracepoint event class and
'writeback_queue_io' tracepoints are updated to include the
symbolic 'reason' in all trace events.
And the 'writeback_inodes_sbXXX' family of routines has had
a wb_stats parameter added to them, so callers can specify
why writeback is being started.
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
The dark space calculation should be 64 bit type-casted, when
assigning to tmp64 (similar to how total_free is calculated).
Overflow will occur for very large flashes.
Signed-off-by: srimugunthan <srimugunthan.dhandapani@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@intel.com>
This commit adds 'dbg_dump_sleb()' helper function to dump scanning
information.
With
$ grep -e UBIFS_FS_DEBUG -e DYNAMIC_DEBUG .config
# CONFIG_UBIFS_FS_DEBUG is not set
CONFIG_DYNAMIC_DEBUG=y
Debug messages are kept in the object files due to the
dynamic_pr_debug() macro, even if they are never going to be printed:
$ make fs/ubifs/super.o
$ strings fs/ubifs/super.o | grep 'compiled on'
compiled on: Aug 11 2011 at 12:21:38
Use plain printk to fix this.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
When the 1st LEB was unmapped and written but 2nd LEB not,
the master node recovery doesn't succeed after power cut.
We see following error when mounting UBIFS partition on NOR
flash:
UBIFS error (pid 1137): ubifs_recover_master_node: failed to recover master node
Correct 2nd master node offset check is needed to fix the
problem. If the 2nd master node is at the end in the 2nd LEB,
first master node is used for recovery. When checking for this
condition we should check whether the master node is exactly at
the end of the LEB (without remaining empty space) or whether
it is followed by an empty space less than the master node size.
Artem: when the error happened, offs2 = 261120, sz = 512, c->leb_size = 262016.
Signed-off-by: Artem Bityutskiy <dedekind1@gmail.com>
This patch cleans-up and improves the power cut testing:
1. Kill custom 'simple_random()' function and use 'random32()' instead.
2. Make timeout larger
3. When cutting the buffer - fill the end with random data sometimes, not
only with 0xFFs.
4. Some times cut in the middle of the buffer, not always at the end.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Since the recovery testing is effectively about emulating power cuts by UBIFS,
use "power cut" as the base term for all the related variables and name them
correspondingly. This is just a minor clean-up for the sake of readability.
