path: root/fs/udf/file.c
2009-09-14udf: Fix possible corruption when close races with writeJan Kara
When we close a file, we remove preallocated blocks from it. But this truncation was not protected by i_mutex and thus it could have raced with a write through a different fd and cause crashes or even filesystem corruption. Signed-off-by: Jan Kara <jack@suse.cz>
2009-06-11switch udf to simple_fsync()Al Viro
2008-09-08udf: add llseek methodChristoph Hellwig
UDF currently doesn't set a llseek method for regular files, which means it will fall back to default_llseek. This means no one can seek beyond 2 Gigabytes on udf, and that there's not protection vs the i_size updates from writers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: move headers out include/linux/Christoph Hellwig
There's really no reason to keep udf headers in include/linux as they're not used by anything but fs/udf/. This patch merges most of include/linux/udf_fs_i.h into fs/udf/udf_i.h, include/linux/udf_fs_sb.h into fs/udf/udf_sb.h and include/linux/udf_fs.h into fs/udf/udfdecl.h. The only thing remaining in include/linux/ is a stub of udf_fs_i.h defining the four user-visible udf ioctls. It's also moved from unifdef-y to headers-y because it can be included unconditionally now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-17udf: kill useless file header comments for vfs method implementationsChristoph Hellwig
There's not need to document vfs method invocation rules, we have Documentation/filesystems/vfs.txt and Documentation/filesystems/Locking for that. Also a lot of these comments where either plain wrong or horrible out of date. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2008-02-08udf: cache struct udf_inode_infoMarcin Slusarz
cache UDF_I(struct inode *) return values when there are at least 2 uses in one function Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove UDF_I_* macros and open code themMarcin Slusarz
2008-02-08udf: fix coding styleMarcin Slusarz
fix coding style errors found by checkpatch: - assignments in if conditions - braces {} around single statement blocks - no spaces after commas - printks without KERN_* - lines longer than 80 characters - spaces between "type *" and variable name before: 192 errors, 561 warnings, 8987 lines checked after: 1 errors, 38 warnings, 9468 lines checked Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Jan Kara <jack@suse.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08udf: remove some ugly macrosMarcin Slusarz
remove macros: - UDF_SB_PARTMAPS - UDF_SB_PARTTYPE - UDF_SB_PARTROOT - UDF_SB_PARTLEN - UDF_SB_PARTVSN - UDF_SB_PARTNUM - UDF_SB_TYPESPAR - UDF_SB_TYPEVIRT - UDF_SB_PARTFUNC - UDF_SB_PARTFLAGS - UDF_SB_VOLIDENT - UDF_SB_NUMPARTS - UDF_SB_PARTITION - UDF_SB_SESSION - UDF_SB_ANCHOR - UDF_SB_LASTBLOCK - UDF_SB_LVIDBH - UDF_SB_LVID - UDF_SB_UMASK - UDF_SB_GID - UDF_SB_UID - UDF_SB_RECORDTIME - UDF_SB_SERIALNUM - UDF_SB_UDFREV - UDF_SB_FLAGS - UDF_SB_VAT - UDF_UPDATE_UDFREV - UDF_SB_FREE and open code them convert UDF_SB_LVIDIU macro to udf_sb_lvidiu function rename some struct udf_sb_info fields: - s_volident to s_volume_ident - s_lastblock to s_last_block - s_lvidbh to s_lvid_bh - s_recordtime to s_record_time - s_serialnum to s_serial_number; - s_vat to s_vat_inode; Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16udf: convert to new aopsNick Piggin
Convert udf to new aops. Also seem to have fixed pagecache corruption in udf_adinicb_commit_write -- page was marked uptodate when it is not. Also, fixed the silly setup where prepare_write was doing a kmap to be used in commit_write: just do kmap_atomic in write_end. Use libfs helpers to make this easier. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: <bfennema@falcon.csc.calpoly.edu> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21UDF: coding style conversion - lindent fixupsCyrill Gorcunov
This patch fixes up sources after conversion by Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19UDF: coding style conversion - lindentCyrill Gorcunov
This patch converts UDF coding style to kernel coding style using Lindent. Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-12-08[PATCH] struct path: convert udfJosef Sipek
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03remove pointers to the defunct UDF mailing listAdrian Bunk
This patch removes pointers to the defunct UDF mailing list. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-09[PATCH] add a file_permission helperChristoph Hellwig
A few more callers of permission() just want to check for a different access pattern on an already open file. This patch adds a wrapper for permission() that takes a file in preparation of per-mount read-only support and to clean up the callers a little. The helper is not intended for new code, everything without the interface set in stone should use vfs_permission() Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
