commit 9c2fc0de1a6e638fe58c354a463f544f42a90a09 upstream.
When a file is stored in ICB (inode), we overwrite part of the file, and
the page containing file's data is not in page cache, we end up corrupting
file's data by overwriting them with zeros. The problem is we use
simple_write_begin() which simply zeroes parts of the page which are not
written to. The problem has been introduced by be021ee4 (udf: convert to
new aops).
Fix the problem by providing a ->write_begin function which makes the page
properly uptodate.
Reported-by: Ian Abbott <abbotti@mev.co.uk>
Signed-off-by: Willy Tarreau <w@1wt.eu>
When we close a file, we remove preallocated blocks from it. But this
truncation was not protected by i_mutex and thus it could have raced with a
write through a different fd and cause crashes or even filesystem corruption.
UDF currently doesn't set a llseek method for regular files, which
means it will fall back to default_llseek. This means no one can seek
beyond 2 Gigabytes on udf, and that there's not protection vs
the i_size updates from writers.
There's really no reason to keep udf headers in include/linux as they're
not used by anything but fs/udf/.
This patch merges most of include/linux/udf_fs_i.h into fs/udf/udf_i.h,
include/linux/udf_fs_sb.h into fs/udf/udf_sb.h and
include/linux/udf_fs.h into fs/udf/udfdecl.h.
The only thing remaining in include/linux/ is a stub of udf_fs_i.h
defining the four user-visible udf ioctls. It's also moved from
unifdef-y to headers-y because it can be included unconditionally now.
There's not need to document vfs method invocation rules, we have
Documentation/filesystems/vfs.txt and Documentation/filesystems/Locking
for that. Also a lot of these comments where either plain wrong or
horrible out of date.
cache UDF_I(struct inode *) return values when there are
at least 2 uses in one function
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Acked-by: Jan Kara <jack@suse.cz>
fix coding style errors found by checkpatch:
- assignments in if conditions
- braces {} around single statement blocks
- no spaces after commas
- printks without KERN_*
- lines longer than 80 characters
- spaces between "type *" and variable name
before: 192 errors, 561 warnings, 8987 lines checked
after: 1 errors, 38 warnings, 9468 lines checked
Cc: Jan Kara <jack@suse.cz>
remove macros:
- UDF_SB_PARTMAPS
- UDF_SB_PARTTYPE
- UDF_SB_PARTROOT
- UDF_SB_PARTLEN
- UDF_SB_PARTVSN
- UDF_SB_PARTNUM
- UDF_SB_TYPESPAR
- UDF_SB_TYPEVIRT
- UDF_SB_PARTFUNC
- UDF_SB_PARTFLAGS
- UDF_SB_VOLIDENT
- UDF_SB_NUMPARTS
- UDF_SB_PARTITION
- UDF_SB_SESSION
- UDF_SB_ANCHOR
- UDF_SB_LASTBLOCK
- UDF_SB_LVIDBH
- UDF_SB_LVID
- UDF_SB_UMASK
- UDF_SB_GID
- UDF_SB_UID
- UDF_SB_RECORDTIME
- UDF_SB_SERIALNUM
- UDF_SB_UDFREV
- UDF_SB_FLAGS
- UDF_SB_VAT
- UDF_UPDATE_UDFREV
- UDF_SB_FREE
and open code them
convert UDF_SB_LVIDIU macro to udf_sb_lvidiu function
rename some struct udf_sb_info fields:
- s_volident to s_volume_ident
- s_lastblock to s_last_block
- s_lvidbh to s_lvid_bh
- s_recordtime to s_record_time
- s_serialnum to s_serial_number;
- s_vat to s_vat_inode;
Cc: Ben Fennema <bfennema@falcon.csc.calpoly.edu>
Acked-by: Christoph Hellwig <hch@infradead.org>
Convert udf to new aops. Also seem to have fixed pagecache corruption in
udf_adinicb_commit_write -- page was marked uptodate when it is not. Also,
fixed the silly setup where prepare_write was doing a kmap to be used in
commit_write: just do kmap_atomic in write_end. Use libfs helpers to make
this easier.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: <bfennema@falcon.csc.calpoly.edu>
Cc: Jan Kara <jack@ucw.cz>
This patch fixes up sources after conversion by Lindent.
Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com>
This patch converts UDF coding style to kernel coding style using Lindent.
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
This patch cleans up generic_file_*_read/write() interfaces. Christoph
Hellwig gave me the idea for this clean ups.
In a nutshell, all filesystems should set .aio_read/.aio_write methods and use
do_sync_read/ do_sync_write() as their .read/.write methods. This allows us
to cleanup all variants of generic_file_* routines.
Final available interfaces:
generic_file_aio_read() - read handler
generic_file_aio_write() - write handler
generic_file_aio_write_nolock() - no lock write handler
__generic_file_aio_write_nolock() - internal worker routine
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
fs: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This patch removes pointers to the defunct UDF mailing list.
A few more callers of permission() just want to check for a different access
pattern on an already open file. This patch adds a wrapper for permission()
that takes a file in preparation of per-mount read-only support and to clean
up the callers a little. The helper is not intended for new code, everything
without the interface set in stone should use vfs_permission()
Remove PAGE_BUG - repalce it with BUG and BUG_ON.
Signed-off-by: Matt Mackall <mpm@selenic.com>
infrastructure for it.
Let it rip!
