commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
Replace the specification of data structures by variable references
as the parameter for the operator "sizeof" to make the corresponding size
determination a bit safer according to the Linux coding style convention.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
According to commit f90774e1fd27 ("checkpatch: look for symbolic
permissions and suggest octal instead")
Signed-off-by: Fabian Frederick <fabf@skynet.be>
UDF encodes symlinks in a more complex fashion and thus i_size of a
symlink does not match the lenght of a string returned by readlink(2).
This confuses some applications (see bug 191241) and may be considered a
violation of POSIX. Fix the problem by reading the link into page cache
in response to stat(2) call and report the length of the decoded path.
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
This is trivial to do:
- add flags argument to foo_rename()
- check if flags doesn't have any other than RENAME_NOREPLACE
- assign foo_rename() to .rename2 instead of .rename
Filesystems converted:
affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos,
nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat.
Acked-by: Boaz Harrosh <ooo@electrozaur.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: Bob Copeland <me@bobcopeland.com>
Acked-by: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
... and neither can ever be NULL
Code in udf_find_entry() and udf_readdir() used the same buffer for
storing filename that was split among blocks and for the resulting
filename in utf8. This worked because udf_get_filename() first
internally copied the name into a different buffer and only then
performed a conversion into the destination buffer. However we want to
get rid of intermediate buffers so use separate buffer for converted
name and name split between blocks so that we don't have the same source
and destination buffer when converting split names.
Actual name length restriction is 254 bytes, this is used in 'ustr'
structure, and this is what fits into UDF File Ident structures.
And in most cases the constant is used as UDF_NAME_LEN-2.
So, it's better to just modify the constant to make it closer
to reality.
Also, in some cases it's useful to have a separate constant for
the maximum length of file name field in CS0 encoding in UDF File
Ident structures.
Also, remove the unused UDF_PATH_LEN constant.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Make the desired output length a parameter rather than have it
hard-coded to UDF_NAME_LEN. Although all call sites still have
this length the same, this parameterization will make the function
more universal and also consistent with udf_get_filename.
kmap() in page_follow_link_light() needed to go - allowing to hold
an arbitrary number of kmaps for long is a great way to deadlocking
the system.
new helper (inode_nohighmem(inode)) needs to be used for pagecache
symlinks inodes; done for all in-tree cases. page_follow_link_light()
instrumented to yell about anything missed.
The "fh_len" passed to ->fh_to_* is not guaranteed to be that same as
that returned by encode_fh - it may be larger.
With NFSv2, the filehandle is fixed length, so it may appear longer
than expected and be zero-padded.
So we must test that fh_len is at least some value, not exactly equal
to it.
Signed-off-by: NeilBrown <neilb@suse.de>
Return appropriate error from udf_find_entry() instead of just NULL.
That way we can distinguish the fact that some error happened when
looking up filename (and return error to userspace) from the fact that
we just didn't find the filename. Also update callers of
udf_find_entry() accordingly.
[JK: Improved udf_find_entry() documentation]
Suggested-by: Jan Kara <jack@suse.cz>
Return -ENOMEM when allocation fails in udf_get_filename(). Update
udf_pc_to_char(), udf_readdir(), and udf_find_entry() to handle the
error appropriately. This allows us to pass appropriate error to
userspace instead of corrupting symlink contents by omitting some path
elements.
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
that's the bulk of filesystem drivers dealing with inodes of their own
We failed to update ctime & mtime of a directory when new entry was
created in it during rename, link, create, etc. Fix that.
Reported-by: Taesoo Kim <tsgatesv@gmail.com>
buffer_head.h was already included in udfdecl.h
Replace repeated dereferences like dir->i_sb by storing superblock
pointer in a variable and using that.
Symlink reading code does not check whether the resulting path fits into
the page provided by the generic code. This isn't as easy as just
checking the symlink size because of various encoding conversions we
perform on path. So we have to check whether there is still enough space
in the buffer on the fly.
CC: stable@vger.kernel.org
Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no>
Currently udf_iget() (triggered by NFS) can race with udf_new_inode()
leading to two inode structures with the same inode number:
nfsd: iget_locked() creates inode
nfsd: try to read from disk, block on that.
udf_new_inode(): allocate inode with that inumber
udf_new_inode(): insert it into icache, set it up and dirty
udf_write_inode(): write inode into buffer cache
nfsd: get CPU again, look into buffer cache, see nice and sane on-disk
inode, set the in-core inode from it
Fix the problem by putting inode into icache in locked state (I_NEW set)
and unlocking it only after it's fully set up.
boilerplate code in udf_{create,mknod,symlink} taken to new helper
symlink case converted to unique id calculated by udf_new_inode() - no
point finding a new one.
Currently __udf_read_inode() wasn't returning anything and we found out
whether we succeeded reading inode by checking whether inode is bad or
not. udf_iget() returned NULL on failure and inode pointer otherwise.
Make these two functions properly propagate errors up the call stack and
use the return value in callers.
We have released the ->i_data_sem before invoking udf_add_entry(),
so in following error path, we should not release this lock again.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
Lockdep is complaining about UDF:
[ INFO: possible recursive locking detected ]
3.12.0+ #16 Not tainted
ln/7386 is trying to acquire lock:
(&ei->i_data_sem){+.+...}, at: [<ffffffff8142f06d>] udf_get_block+0x8d/0x130
but task is already holding lock:
(&ei->i_data_sem){+.+...}, at: [<ffffffff81431a8d>] udf_symlink+0x8d/0x690
Possible unsafe locking scenario:
CPU0
lock(&ei->i_data_sem);
*** DEADLOCK ***
This is because we hold i_data_sem of the symlink inode while calling
udf_add_entry() for the directory. I don't think this can ever lead to
deadlocks since we never hold i_data_sem for two inodes in any other
place.
The fix is simple - move unlock of i_data_sem for symlink inode up. We
don't need it for anything when linking symlink inode to directory.
Reported-by: Christoph Hellwig <hch@infradead.org>
This patch is a follow up on below patch:
[PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type
commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Vivek Trivedi <t.vivek@samsung.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Sage Weil <sage@inktank.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull misc udf, ext2, ext3, and isofs fixes from Jan Kara:
"Assorted, mostly trivial, fixes for udf, ext2, ext3, and isofs. I'm
on vacation and scarcely checking email since we are expecting baby
any day now but these fixes should be safe to go in and I don't want
to delay them unnecessarily."
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
udf: avoid info leak on export
isofs: avoid info leak on export
udf: Improve table length check to avoid possible overflow
ext3: Check return value of blkdev_issue_flush()
jbd: Check return value of blkdev_issue_flush()
udf: Do not decrement i_blocks when freeing indirect extent block
udf: Fix memory leak when mounting
ext2: cleanup the confused goto label
UDF: Remove unnecessary variable "offset" from udf_fill_inode
udf: stop using s_dirt
ext3: force ro mount if ext3_setup_super() fails
quota: fix checkpatch.pl warning by replacing <asm/uaccess.h> with <linux/uaccess.h>
boolean "does it have to be exclusive?" flag is passed instead;
Local filesystem should just ignore it - the object is guaranteed
not to be there yet.
Just the flags; only NFS cares even about that, but there are
legitimate uses for such argument. And getting rid of that
completely would require splitting ->lookup() into a couple
of methods (at least), so let's leave that alone for now...
For type 0x51 the udf.parent_partref member in struct fid gets copied
uninitialized to userland. Fix this by initializing it to 0.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
pass inode + parent's inode or NULL instead of dentry + bool saying
whether we want the parent or not.
NOTE: that needs ceph fix folded in.
This allows comparing hash and len in one operation on 64-bit
architectures. Right now only __d_lookup_rcu() takes advantage of this,
since that is the case we care most about.
The use of anonymous struct/unions hides the alternate 64-bit approach
from most users, the exception being a few cases where we initialize a
'struct qstr' with a static initializer. This makes the problematic
cases use a new QSTR_INIT() helper function for that (but initializing
just the name pointer with a "{ .name = xyzzy }" initializer remains
valid, as does just copying another qstr structure).
New field of struct super_block - ->s_max_links. Maximal allowed
value of ->i_nlink or 0; in the latter case all checks still need
to be done in ->link/->mkdir/->rename instances. Note that this
limit applies both to directoris and to non-directories.
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue:
vfs: add d_prune dentry operation
vfs: protect i_nlink
filesystems: add set_nlink()
filesystems: add missing nlink wrappers
logfs: remove unnecessary nlink setting
ocfs2: remove unnecessary nlink setting
jfs: remove unnecessary nlink setting
hypfs: remove unnecessary nlink setting
vfs: ignore error on forced remount
readlinkat: ensure we return ENOENT for the empty pathname for normal lookups
vfs: fix dentry leak in simple_fill_super()
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
Rename udf_warning to udf_warn for consistency with normal logging
uses of pr_warn.
Rename function udf_warning to _udf_warn.
Remove __func__ from uses and move __func__ to a new udf_warn
macro that calls _udf_warn.
Add \n's to uses of udf_warn, remove \n from _udf_warn.
Coalesce formats.
Reviewed-by: NamJae Jeon <linkinjeon@gmail.com>
udf does not have problems with references to unlinked directories.
CC: Jan Kara <jack@suse.cz>
Signed-off-by: Sage Weil <sage@newdream.net>
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs
basis.
This does not change behavior for any in-tree file systems.
The exportfs encode handle function should return the minimum required
handle size. This helps user to find out the handle size by passing 0
handle size in the first step and then redoing to the call again with
the returned handle size value.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
(256 << sizeof(x)) - 1 is not the maximal possible value of x...
In reality, the maximal allowed value for UDF FileLinkCount is
65535.
