path: root/fs/udf
2017-06-14fs: add i_blocksize()Fabian Frederick
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream. Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs branch. This patch also fixes multiple checkpatch warnings: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' Thanks to Andrew Morton for suggesting more appropriate function instead of macro. [geliangtang@gmail.com: truncate: use i_blocksize()] Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Geliang Tang <geliangtang@gmail.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-09-27fs: Replace current_fs_time() with current_time()Deepa Dinamani
current_fs_time() uses struct super_block* as an argument. As per Linus's suggestion, this is changed to take struct inode* as a parameter instead. This is because the function is primarily meant for vfs inode timestamps. Also the function was renamed as per Arnd's suggestion. Change all calls to current_fs_time() to use the new current_time() function instead. current_fs_time() will be deleted. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27fs: support RENAME_NOREPLACE for local filesystemsMiklos Szeredi
This is trivial to do: - add flags argument to foo_rename() - check if flags doesn't have any other than RENAME_NOREPLACE - assign foo_rename() to .rename2 instead of .rename Filesystems converted: affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos, nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Boaz Harrosh <ooo@electrozaur.com> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Bob Copeland <me@bobcopeland.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Jaegeuk Kim <jaegeuk@kernel.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org>
2016-09-22fs: Give dentry to inode_change_ok() instead of inodeJan Kara
inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2016-09-19udf: don't bother with full-page write optimisations in adinicb caseAl Viro
... it would get converted to regular if such had been attempted Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jan Kara <jack@suse.cz>
2016-09-06udf: Remove useless check in udf_adinicb_write_begin()Jan Kara
As Al properly points out, len is guaranteed to be smaller than PAGE_SIZE when we reach udf_adinicb_write_begin() as otherwise we would have converted the file to the normal format. Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jan Kara <jack@suse.cz>
2016-07-26Merge branch 'for-4.8/drivers' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block driver updates from Jens Axboe: "This branch also contains core changes. I've come to the conclusion that from 4.9 and forward, I'll be doing just a single branch. We often have dependencies between core and drivers, and it's hard to always split them up appropriately without pulling core into drivers when that happens. That said, this contains: - separate secure erase type for the core block layer, from Christoph. - set of discard fixes, from Christoph. - bio shrinking fixes from Christoph, as a followup up to the op/flags change in the core branch. - map and append request fixes from Christoph. - NVMeF (NVMe over Fabrics) code from Christoph. This is pretty exciting! - nvme-loop fixes from Arnd. - removal of ->driverfs_dev from Dan, after providing a device_add_disk() helper. - bcache fixes from Bhaktipriya and Yijing. - cdrom subchannel read fix from Vchannaiah. - set of lightnvm updates from Wenwei, Matias, Johannes, and Javier. - set of drbd updates and fixes from Fabian, Lars, and Philipp. - mg_disk error path fix from Bart. - user notification for failed device add for loop, from Minfei. - NVMe in general: + NVMe delay quirk from Guilherme. + SR-IOV support and command retry limits from Keith. + fix for memory-less NUMA node from Masayoshi. + use UINT_MAX for discard sectors, from Minfei. + cancel IO fixes from Ming. + don't allocate unused major, from Neil. + error code fixup from Dan. + use constants for PSDT/FUSE from James. + variable init fix from Jay. + fabrics fixes from Ming, Sagi, and Wei. + various fixes" * 'for-4.8/drivers' of git://git.kernel.dk/linux-block: (115 commits) nvme/pci: Provide SR-IOV support nvme: initialize variable before logical OR'ing it block: unexport various bio mapping helpers scsi/osd: open code blk_make_request target: stop using blk_make_request block: simplify and export blk_rq_append_bio block: ensure bios return from blk_get_request are properly initialized virtio_blk: use blk_rq_map_kern memstick: don't allow REQ_TYPE_BLOCK_PC requests block: shrink bio size again block: simplify and cleanup bvec pool handling block: get rid of bio_rw and READA block: don't ignore -EOPNOTSUPP blkdev_issue_write_same block: introduce BLKDEV_DISCARD_ZERO to fix zeroout NVMe: don't allocate unused nvme_major nvme: avoid crashes when node 0 is memoryless node. nvme: Limit command retries loop: Make user notify for adding loop device failed nvme-loop: fix nvme-loop Kconfig dependencies nvmet: fix return value check in nvmet_subsys_alloc() ...
2016-07-26Merge branch 'for-4.8/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block updates from Jens Axboe: - the big change is the cleanup from Mike Christie, cleaning up our uses of command types and modified flags. This is what will throw some merge conflicts - regression fix for the above for btrfs, from Vincent - following up to the above, better packing of struct request from Christoph - a 2038 fix for blktrace from Arnd - a few trivial/spelling fixes from Bart Van Assche - a front merge check fix from Damien, which could cause issues on SMR drives - Atari partition fix from Gabriel - convert cfq to highres timers, since jiffies isn't granular enough for some devices these days. From Jan and Jeff - CFQ priority boost fix idle classes, from me - cleanup series from Ming, improving our bio/bvec iteration - a direct issue fix for blk-mq from Omar - fix for plug merging not involving the IO scheduler, like we do for other types of merges. From Tahsin - expose DAX type internally and through sysfs. From Toshi and Yigal * 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits) block: Fix front merge check block: do not merge requests without consulting with io scheduler block: Fix spelling in a source code comment block: expose QUEUE_FLAG_DAX in sysfs block: add QUEUE_FLAG_DAX for devices to advertise their DAX support Btrfs: fix comparison in __btrfs_map_block() block: atari: Return early for unsupported sector size Doc: block: Fix a typo in queue-sysfs.txt cfq-iosched: Charge at least 1 jiffie instead of 1 ns cfq-iosched: Fix regression in bonnie++ rewrite performance cfq-iosched: Convert slice_resid from u64 to s64 block: Convert fifo_time from ulong to u64 blktrace: avoid using timespec block/blk-cgroup.c: Declare local symbols static block/bio-integrity.c: Add #include "blk.h" block/partition-generic.c: Remove a set-but-not-used variable block: bio: kill BIO_MAX_SIZE cfq-iosched: temporarily boost queue priority for idle classes block: drbd: avoid to use BIO_MAX_SIZE block: bio: remove BIO_MAX_SECTORS ...
2016-07-20block: get rid of bio_rw and READAChristoph Hellwig
These two are confusing leftover of the old world order, combining values of the REQ_OP_ and REQ_ namespaces. For callers that don't special case we mostly just replace bi_rw with bio_data_dir or op_is_write, except for the few cases where a switch over the REQ_OP_ values makes more sense. Any check for READA is replaced with an explicit check for REQ_RAHEAD. Also remove the READA alias for REQ_RAHEAD. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Mike Christie <mchristi@redhat.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-06-07fs: have ll_rw_block users pass in op and flags separatelyMike Christie
This has ll_rw_block users pass in the operation and flags separately, so ll_rw_block can setup the bio op and bi_rw flags on the bio that is submitted. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-19udf: Use correct partition reference number for metadataAlden Tondettar
UDF/OSTA terminology is confusing. Partition Numbers (PNs) are arbitrary 16-bit values, one for each physical partition in the volume. Partition Reference Numbers (PRNs) are indices into the the Partition Map Table and do not necessarily equal the PN of the mapped partition. The current metadata code mistakenly uses the PN instead of the PRN when mapping metadata blocks to physical/sparable blocks. Windows-created UDF 2.5 discs for some reason use large, arbitrary PNs, resulting in mount failure and KASAN read warnings in udf_read_inode(). For example, a NetBSD UDF 2.5 partition might look like this: PRN PN Type --- -- ---- 0 0 Sparable 1 0 Metadata Since PRN == PN, we are fine. But Windows could gives us: PRN PN Type --- ---- ---- 0 8192 Sparable 1 8192 Metadata So udf_read_inode() will start out by checking the partition length in sbi->s_partmaps[8192], which is obviously out of bounds. Fix this by creating a new field (s_phys_partition_ref) in struct udf_meta_data, referencing whatever physical or sparable map has the same partition number as the metadata partition. [JK: Add comment about s_phys_partition_ref, change its name] Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-05-19udf: Use IS_ERR when loading metadata mirror file entryAlden Tondettar
Currently when udf_get_pblock_meta25() fails to map a block using the primary metadata file, it will attempt to load the mirror file entry by calling udf_find_metadata_inode_efe(). That function will return a ERR_PTR if it fails, but the return value is only checked against NULL. Test the return value using IS_ERR() and change it to NULL if needed. Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-05-19udf: Don't BUG on missing metadata partition descriptorAlden Tondettar
Currently, if a metadata partition map is missing its partition descriptor, then udf_get_pblock_meta25() will BUG() out the first time it is called. This is rather drastic for a corrupted filesystem, so just treat this case as an invalid mapping instead. Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-05-17Merge branch 'work.preadv2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs cleanups from Al Viro: "More cleanups from Christoph" * 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: use RWF_SYNC fs: add RWF_DSYNC aand RWF_SYNC ceph: use generic_write_sync fs: simplify the generic_write_sync prototype fs: add IOCB_SYNC and IOCB_DSYNC direct-io: remove the offset argument to dio_complete direct-io: eliminate the offset argument to ->direct_IO xfs: eliminate the pos variable in xfs_file_dio_aio_write filemap: remove the pos argument to generic_file_direct_write filemap: remove pos variables in generic_file_read_iter
2016-05-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull UDF fixes from Jan Kara: "A fix for UDF crash on corrupted media and one UDF header fixup" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Export superblock magic to userspace udf: Prevent stack overflow on corrupted filesystem mount
2016-05-17Merge branch 'ovl-fixes' into for-linusAl Viro
Backmerge to resolve a conflict in ovl_lookup_real(); "ovl_lookup_real(): use lookup_one_len_unlocked()" instead, but it was too late in the cycle to rebase.
2016-05-09more trivial ->iterate_shared conversionsAl Viro
2016-05-02Merge getxattr prototype change into work.lookupsAl Viro
The rest of work.xattr stuff isn't needed for this branch
2016-05-01fs: simplify the generic_write_sync prototypeChristoph Hellwig
The kiocb already has the new position, so use that. The only interesting case is AIO, where we currently don't bother updating ki_pos. We're about to free the kiocb after we're done, so we might as well update it to make everyone's life simpler. While we're at it also return the bytes written argument passed in if we were successful so that the boilerplate error switch code in the callers can go away. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-01fs: add IOCB_SYNC and IOCB_DSYNCChristoph Hellwig
This will allow us to do per-I/O sync file writes, as required by a lot of fileservers or storage targets. XXX: Will need a few additional audits for O_DSYNC Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-01direct-io: eliminate the offset argument to ->direct_IOChristoph Hellwig
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually work, so eliminate the superflous argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-28udf: Export superblock magic to userspaceJan Kara
Currently UDF superblock magic doesn't appear in any userspace header files and thus userspace apps have hard time checking for this fs. Let's export the magic to userspace as with any other filesystem. Signed-off-by: Jan Kara <jack@suse.cz>
2016-04-26udf: Prevent stack overflow on corrupted filesystem mountAlden Tondettar
Presently, a corrupted or malicious UDF filesystem containing a very large number (or cycle) of Logical Volume Integrity Descriptor extent indirections may trigger a stack overflow and kernel panic in udf_load_logicalvolint() on mount. Replace the unnecessary recursion in udf_load_logicalvolint() with simple iteration. Set an arbitrary limit of 1000 indirections (which would have almost certainly overflowed the stack without this fix), and treat such cases as if there were no LVID. Signed-off-by: Alden Tondettar <alden.tondettar@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-04-25udf: Fix conversion of 'dstring' fields to UTF8Andrew Gabbasov
Commit 9293fcfbc1812a22ad5ce1b542eb90c1bbe01be1 ("udf: Remove struct ustr as non-needed intermediate storage"), while getting rid of 'struct ustr', does not take any special care of 'dstring' fields and effectively use fixed field length instead of actual string length, encoded in the last byte of the field. Also, commit 484a10f49387e4386bf2708532e75bf78ffea2cb ("udf: Merge linux specific translation into CS0 conversion function") introduced checking of the length of the string being converted, requiring proper alignment to number of bytes constituing each character. The UDF volume identifier is represented as a 32-bytes 'dstring', and needs to be converted from CS0 to UTF8, while mounting UDF filesystem. The changes in mentioned commits can in some cases lead to incorrect handling of volume identifier: - if the actual string in 'dstring' is of maximal length and does not have zero bytes separating it from dstring encoded length in last byte, that last byte may be included in conversion, thus making incorrect resulting string; - if the identifier is encoded with 2-bytes characters (compression code is 16), the length of 31 bytes (32 bytes of field length minus 1 byte of compression code), taken as the string length, is reported as an incorrect (unaligned) length, and the conversion fails, which in its turn leads to volume mounting failure. This patch introduces handling of 'dstring' encoded length field in udf_CS0toUTF8 function, that is used in all and only cases when 'dstring' fields are converted. Currently these cases are processing of Volume Identifier and Volume Set Identifier fields. The function is also renamed to udf_dstrCS0toUTF8 to distinctly indicate that it handles 'dstring' input. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-04-10don't bother with ->d_inode->i_sb - it's always equal to ->d_sbAl Viro
... and neither can ever be NULL Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-09udf: Merge linux specific translation into CS0 conversion functionAndrew Gabbasov
Current implementation of udf_translate_to_linux function does not support multi-bytes characters at all: it counts bytes while calculating extension length, when inserting CRC inside the name it doesn't take into account inter-character boundaries and can break into the middle of the character. The most efficient way to properly support multi-bytes characters is merging of translation operations directly into conversion function. This can help to avoid extra passes along the string or parsing the multi-bytes character back into unicode to find out it's length. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-02-09udf: Remove struct ustr as non-needed intermediate storageAndrew Gabbasov
Although 'struct ustr' tries to structurize the data by combining the string and its length, it doesn't actually make much benefit, since it saves only one parameter, but introduces an extra copying of the whole buffer, serving as an intermediate storage. It looks quite inefficient and not actually needed. This commit gets rid of the struct ustr by changing the parameters of some functions appropriately. Also, it removes using 'dstring' type, since it doesn't make much sense too. Just using the occasion, add a 'const' qualifier to udf_get_filename to make consistent parameters sets. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-02-09udf: Use separate buffer for copying split namesJan Kara
Code in udf_find_entry() and udf_readdir() used the same buffer for storing filename that was split among blocks and for the resulting filename in utf8. This worked because udf_get_filename() first internally copied the name into a different buffer and only then performed a conversion into the destination buffer. However we want to get rid of intermediate buffers so use separate buffer for converted name and name split between blocks so that we don't have the same source and destination buffer when converting split names. Signed-off-by: Jan Kara <jack@suse.cz>
2016-02-09udf: Adjust UDF_NAME_LEN to better reflect actual restrictionsAndrew Gabbasov
Actual name length restriction is 254 bytes, this is used in 'ustr' structure, and this is what fits into UDF File Ident structures. And in most cases the constant is used as UDF_NAME_LEN-2. So, it's better to just modify the constant to make it closer to reality. Also, in some cases it's useful to have a separate constant for the maximum length of file name field in CS0 encoding in UDF File Ident structures. Also, remove the unused UDF_PATH_LEN constant. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-02-09udf: Join functions for UTF8 and NLS conversionsAndrew Gabbasov
There is no much sense to have separate functions for UTF8 and NLS conversions, since UTF8 encoding is actually the special case of NLS. However, although UTF8 is also supported by general NLS framework, it would be good to have separate UTF8 character conversion functions (char2uni and uni2char) locally in UDF code, so that they could be used even if NLS support is not enabled in the kernel configuration. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-02-09udf: Parameterize output length in udf_put_filenameAndrew Gabbasov
Make the desired output length a parameter rather than have it hard-coded to UDF_NAME_LEN. Although all call sites still have this length the same, this parameterization will make the function more universal and also consistent with udf_get_filename. Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-01-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull final vfs updates from Al Viro: - The ->i_mutex wrappers (with small prereq in lustre) - a fix for too early freeing of symlink bodies on shmem (they need to be RCU-delayed) (-stable fodder) - followup to dedupe stuff merged this cycle * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: abort dedupe loop if fatal signals are pending make sure that freeing shmem fast symlinks is RCU-delayed wrappers for ->i_mutex access lustre: remove unused declaration
2016-01-22tree wide: use kvfree() than conditional kfree()/vfree()Tetsuo Handa
There are many locations that do if (memory_was_allocated_by_vmalloc) vfree(ptr); else kfree(ptr); but kvfree() can handle both kmalloc()ed memory and vmalloc()ed memory using is_vmalloc_addr(). Unless callers have special reasons, we can replace this branch with kvfree(). Please check and reply if you found problems. Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Reviewed-by: Andreas Dilger <andreas.dilger@intel.com> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Acked-by: David Rientjes <rientjes@google.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Boris Petkov <bp@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-15Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull UDF fixes and quota cleanups from Jan Kara: "Several UDF fixes and some minor quota cleanups" * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Check output buffer length when converting name to CS0 udf: Prevent buffer overrun with multi-byte characters quota: constify qtree_fmt_operations structures udf: avoid uninitialized variable use udf: Fix lost indirect extent block udf: Factor out code for creating indirect extent udf: limit the maximum number of indirect extents in a row udf: limit the maximum number of TD redirections fs: make quota/dquot.c explicitly non-modular fs: make quota/netlink.c explicitly non-modular
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-04udf: Check output buffer length when converting name to CS0Andrew Gabbasov
If a name contains at least some characters with Unicode values exceeding single byte, the CS0 output should have 2 bytes per character. And if other input characters have single byte Unicode values, then the single input byte is converted to 2 output bytes, and the length of output becomes larger than the length of input. And if the input name is long enough, the output length may exceed the allocated buffer length. All this means that conversion from UTF8 or NLS to CS0 requires checking of output length in order to stop when it exceeds the given output buffer size. [JK: Make code return -ENAMETOOLONG instead of silently truncating the name] CC: stable@vger.kernel.org Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-01-04udf: Prevent buffer overrun with multi-byte charactersAndrew Gabbasov
udf_CS0toUTF8 function stops the conversion when the output buffer length reaches UDF_NAME_LEN-2, which is correct maximum name length, but, when checking, it leaves the space for a single byte only, while multi-bytes output characters can take more space, causing buffer overflow. Similar error exists in udf_CS0toNLS function, that restricts the output length to UDF_NAME_LEN, while actual maximum allowed length is UDF_NAME_LEN-2. In these cases the output can override not only the current buffer length field, causing corruption of the name buffer itself, but also following allocation structures, causing kernel crash. Adjust the output length checks in both functions to prevent buffer overruns in case of multi-bytes UTF8 or NLS characters. CC: stable@vger.kernel.org Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com> Signed-off-by: Jan Kara <jack@suse.cz>
2016-01-04udf: avoid uninitialized variable useArnd Bergmann
A new warning has come up from a recent cleanup: fs/udf/inode.c: In function 'udf_setup_indirect_aext': fs/udf/inode.c:1927:28: warning: 'adsize' may be used uninitialized in this function [-Wmaybe-uninitialized] If the alloc_type is neither ICBTAG_FLAG_AD_SHORT nor ICBTAG_FLAG_AD_LONG, the value of adsize is undefined. Currently, callers of these functions make sure alloc_type is one of the two valid ones but for future proofing make sure we handle the case of invalid alloc type as well. This changes the code to return -EIOin that case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: fcea62babc81 ("udf: Factor out code for creating indirect extent") Signed-off-by: Jan Kara <jack@suse.cz>
2015-12-23udf: Fix lost indirect extent blockJan Kara
When inode ends with empty indirect extent block and we extended that file, udf_do_extend_file() ended up just overwriting pointer to it with another extent and thus effectively leaking the block and also corruptiong length of allocation descriptors. Fix the problem by properly following into next indirect extent when it is present. Signed-off-by: Jan Kara <jack@suse.cz>
2015-12-23udf: Factor out code for creating indirect extentJan Kara
Factor out code for creating indirect extent from udf_add_aext(). It was mostly duplicated in two places. Also remove some opencoded versions of udf_write_aext(). Signed-off-by: Jan Kara <jack@suse.cz>
2015-12-23udf: limit the maximum number of indirect extents in a rowVegard Nossum
udf_next_aext() just follows extent pointers while extents are marked as indirect. This can loop forever for corrupted filesystem. Limit number the of indirect extents we are willing to follow in a row. [JK: Updated changelog, limit, style] Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Cc: stable@vger.kernel.org Cc: Jan Kara <jack@suse.com> Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2015-12-14udf: limit the maximum number of TD redirectionsVegard Nossum
Filesystem fuzzing revealed that we could get stuck in the udf_process_sequence() loop. The maximum limit was chosen arbitrarily but fixes the problem I saw. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06udf: don't duplicate page_symlink_inode_operationsAl Viro
2015-08-20udf: Don't modify filesystem for read-only mountsJan Kara
When read-write mount of a filesystem is requested but we find out we can mount the filesystem only in read-only mode, we still modify LVID in udf_close_lvid(). That is both unnecessary and contrary to expectation that when we fall back to read-only mount we don't modify the filesystem. Make sure we call udf_close_lvid() only if we called udf_open_lvid() so that filesystem gets modified only if we verified we are allowed to write to it. Reported-by: Karel Zak <kzak@redhat.com> Signed-off-by: Jan Kara <jack@suse.com>
