commit e237ec37ec154564f8690c5bd1795339955eeef9 upstream.
Check that length specified in a component of a symlink fits in the
input buffer we are reading. Also properly ignore component length for
component types that do not use it. Otherwise we read memory after end
of buffer for corrupted udf image.
Reported-by: Carl Henrik Lunde <chlunde@ping.uio.no>
commit a1d47b262952a45aae62bd49cfaf33dd76c11a2c upstream.
UDF specification allows arbitrarily large symlinks. However we support
only symlinks at most one block large. Check the length of the symlink
so that we don't access memory beyond end of the symlink block.
Reported-by: Carl Henrik Lunde <chlunde@gmail.com>
commit e159332b9af4b04d882dbcfe1bb0117f0a6d4b58 upstream.
Verify that inode size is sane when loading inode with data stored in
ICB. Otherwise we may get confused later when working with the inode and
inode size is too big.
commit 0e5cc9a40ada6046e6bc3bdfcd0c0d7e4b706b14 upstream.
Symlink reading code does not check whether the resulting path fits into
the page provided by the generic code. This isn't as easy as just
checking the symlink size because of various encoding conversions we
perform on path. So we have to check whether there is still enough space
in the buffer on the fly.
commit 6174c2eb8ecef271159bdcde460ce8af54d8f72f upstream.
Some UDF media have special inodes (like VAT or metadata partition
inodes) whose link_count is 0. Thus commit 4071b9136223 (udf: Properly
detect stale inodes) broke loading these inodes because udf_iget()
started returning -ESTALE for them. Since we still need to properly
detect stale inodes queried by NFS, create two variants of udf_iget() -
one which is used for looking up special inodes (which ignores
link_count == 0) and one which is used for other cases which return
ESTALE when link_count == 0.
Fixes: 4071b913622316970d0e1919f7d82b4403fec5f2
Currently udf_iget() (triggered by NFS) can race with udf_new_inode()
leading to two inode structures with the same inode number:
nfsd: iget_locked() creates inode
nfsd: try to read from disk, block on that.
udf_new_inode(): allocate inode with that inumber
udf_new_inode(): insert it into icache, set it up and dirty
udf_write_inode(): write inode into buffer cache
nfsd: get CPU again, look into buffer cache, see nice and sane on-disk
inode, set the in-core inode from it
Fix the problem by putting inode into icache in locked state (I_NEW set)
and unlocking it only after it's fully set up.
boilerplate code in udf_{create,mknod,symlink} taken to new helper
symlink case converted to unique id calculated by udf_new_inode() - no
point finding a new one.
Currently UDF doesn't initialize i_generation in any way and thus NFS
can easily get reallocated inodes from stale file handles. Luckily UDF
already has a unique object identifier associated with each inode -
i_unique. Use that for initialization of i_generation.
NFS can easily ask for inodes that are already deleted. Currently UDF
happily returns such inodes which is a bug. Return -ESTALE if
udf_read_inode() is asked to read deleted inode.
Currently __udf_read_inode() wasn't returning anything and we found out
whether we succeeded reading inode by checking whether inode is bad or
not. udf_iget() returned NULL on failure and inode pointer otherwise.
Make these two functions properly propagate errors up the call stack and
use the return value in callers.
We did not implement any bound on number of indirect ICBs we follow when
loading inode. Thus corrupted medium could cause kernel to go into an
infinite loop, possibly causing a stack overflow.
Fix the possible stack overflow by removing recursion from
__udf_read_inode() and limit number of indirect ICBs we follow to avoid
infinite loops.
There's no good reason to separate these since udf_fill_inode() is
called only from __udf_read_inode() and both do part of the same thing.
If we are writing back inode of unlinked directory, its link count ends
up being (u16)-1. Although the inode is deleted, udf_iget() can load the
inode when NFS uses stale file handle and get confused.
We have released the ->i_data_sem before invoking udf_add_entry(),
so in following error path, we should not release this lock again.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
Valid data within i_size in page cache will be copied to ICB cache when we
writeback the page by invoking udf_adinicb_writepage, so the copy in
udf_adinicb_write_end is redundant.
After we remove the copy, it's better to use simple_write_end directly in
udf_adinicb_aops instead of udf_adinicb_write_end.
This patch cleans up udf_translate_to_linux() a bit by using globally defined
macros instead of custom code.
We can use sprintf(buf, "%04X", ...) there as well, but this one faster.
Fix checkpatch warning
WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
Cc: Jan Kara <jack@suse.cz>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter)
unmodified, for now
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs
Pull ext3 improvements, cleanups, reiserfs fix from Jan Kara:
"various cleanups for ext2, ext3, udf, isofs, a documentation update
for quota, and a fix of a race in reiserfs readdir implementation"
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs:
reiserfs: fix race in readdir
ext2: acl: remove unneeded include of linux/capability.h
ext3: explicitly remove inode from orphan list after failed direct io
fs/isofs/inode.c add __init to init_inodecache()
ext3: Speedup WB_SYNC_ALL pass
fs/quota/Kconfig: Update filesystems
ext3: Update outdated comment before ext3_ordered_writepage()
ext3: Update PF_MEMALLOC handling in ext3_write_inode()
ext2/3: use prandom_u32() instead of get_random_bytes()
ext3: remove an unneeded check in ext3_new_blocks()
ext3: remove unneeded check in ext3_ordered_writepage()
fs: Mark function as static in ext3/xattr_security.c
fs: Mark function as static in ext3/dir.c
fs: Mark function as static in ext2/xattr_security.c
ext3: Add __init macro to init_inodecache
ext2: Add __init macro to init_inodecache
udf: Add __init macro to init_inodecache
fs: udf: parse_options: blocksize check
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
It's always equal to &iocb->ki_pos, where iocb is the value of the 1st
argument.
Previously, the no-op "mount -o mount /dev/xxx" operation when the
file system is already mounted read-write causes an implied,
unconditional syncfs(). This seems pretty stupid, and it's certainly
documented or guaraunteed to do this, nor is it particularly useful,
except in the case where the file system was mounted rw and is getting
remounted read-only.
However, it's possible that there might be some file systems that are
actually depending on this behavior. In most file systems, it's
probably fine to only call sync_filesystem() when transitioning from
read-write to read-only, and there are some file systems where this is
not needed at all (for example, for a pseudo-filesystem or something
like romfs).
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-fsdevel@vger.kernel.org
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Anders Larsen <al@alarsen.net>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: xfs@oss.sgi.com
Cc: linux-btrfs@vger.kernel.org
Cc: linux-cifs@vger.kernel.org
Cc: samba-technical@lists.samba.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: fuse-devel@lists.sourceforge.net
Cc: cluster-devel@redhat.com
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: linux-nfs@vger.kernel.org
Cc: linux-nilfs@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: reiserfs-devel@vger.kernel.org
init_inodecache is only called by __init init_udf_fs.
Both affs and isofs check for blocksize integrity during
parse_options.Do the same thing for udf.
Valid values : 512, 1024, 2048 or 4096 bytes.
UDF has two types of files - files with data stored in inode (ICB in
UDF terminology) and files with data stored in external data blocks. We
convert file from in-inode format to external format in
udf_file_aio_write() when we find out data won't fit into inode any
longer. However the following race between two O_APPEND writes can happen:
CPU1 CPU2
udf_file_aio_write() udf_file_aio_write()
down_write(&iinfo->i_data_sem);
checks that i_size + count1 fits within inode
=> no need to convert
up_write(&iinfo->i_data_sem);
checks that i_size + count2 fits
within inode => no need to convert
- extends file by count1 bytes
- extends file by count2 bytes
Clearly if count1 + count2 doesn't fit into the inode, we overwrite
kernel buffers beyond inode, possibly corrupting the filesystem as well.
Fix the problem by acquiring i_mutex before checking whether write fits
into the inode and using __generic_file_aio_write() afterwards which
puts check and write into one critical section.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Lockdep is complaining about UDF:
[ INFO: possible recursive locking detected ]
3.12.0+ #16 Not tainted
ln/7386 is trying to acquire lock:
(&ei->i_data_sem){+.+...}, at: [<ffffffff8142f06d>] udf_get_block+0x8d/0x130
but task is already holding lock:
(&ei->i_data_sem){+.+...}, at: [<ffffffff81431a8d>] udf_symlink+0x8d/0x690
Possible unsafe locking scenario:
CPU0
lock(&ei->i_data_sem);
*** DEADLOCK ***
This is because we hold i_data_sem of the symlink inode while calling
udf_add_entry() for the directory. I don't think this can ever lead to
deadlocks since we never hold i_data_sem for two inodes in any other
place.
The fix is simple - move unlock of i_data_sem for symlink inode up. We
don't need it for anything when linking symlink inode to directory.
Reported-by: Christoph Hellwig <hch@infradead.org>
The UDF driver was not strict enough about checking the IDs in the
VSDs when mounting, which resulted in reading through all the sectors
of the block device in some unfortunate cases. Eg, trying to mount my
uninitialized 200G SSD partition (all 0xFF bytes) took ~350 minutes to
fail, because the code expected some of the valid IDs or a zero byte.
During this, the mount couldn't be killed, sync from the cmdline
blocked, and the machine froze into the shutdown. Valid filesystems
(extX, btrfs, ntfs) were rejected by the mere accident of having a
zero byte at just the right place in some of their sectors, close
enough to the beginning not to generate excess I/O. The fix adds a
hard limit on the VSD sector offset, adds the two missing VSD IDs, and
stops scanning when encountering an invalid ID. Also replaced the
magic number 32768 with a more meaningful #define, and supressed the
bogus message about failing to read the first sector if no UDF fs was
detected.
Signed-off-by: Peter A. Felvegi <petschy@gmail.com>
A user has reported an oops in udf_statfs() that was caused by
numOfPartitions entry in LVID structure being corrupted. Fix the problem
by verifying whether numOfPartitions makes sense at least to the extent
that LVID fits into a single block as it should.
Reported-by: Juergen Weigert <jw@suse.com>
Pull aio changes from Ben LaHaise:
"First off, sorry for this pull request being late in the merge window.
Al had raised a couple of concerns about 2 items in the series below.
I addressed the first issue (the race introduced by Gu's use of
mm_populate()), but he has not provided any further details on how he
wants to rework the anon_inode.c changes (which were sent out months
ago but have yet to be commented on).
The bulk of the changes have been sitting in the -next tree for a few
months, with all the issues raised being addressed"
* git://git.kvack.org/~bcrl/aio-next: (22 commits)
aio: rcu_read_lock protection for new rcu_dereference calls
aio: fix race in ring buffer page lookup introduced by page migration support
aio: fix rcu sparse warnings introduced by ioctx table lookup patch
aio: remove unnecessary debugging from aio_free_ring()
aio: table lookup: verify ctx pointer
staging/lustre: kiocb->ki_left is removed
aio: fix error handling and rcu usage in "convert the ioctx list to table lookup v3"
aio: be defensive to ensure request batching is non-zero instead of BUG_ON()
aio: convert the ioctx list to table lookup v3
aio: double aio_max_nr in calculations
aio: Kill ki_dtor
aio: Kill ki_users
aio: Kill unneeded kiocb members
aio: Kill aio_rw_vect_retry()
aio: Don't use ctx->tail unnecessarily
aio: io_cancel() no longer returns the io_event
aio: percpu ioctx refcount
aio: percpu reqs_available
aio: reqs_active -> reqs_available
aio: fix build when migration is disabled
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
Refuse RW mount of udf filesystem. So far we just silently changed it
to RO mount but when the media is writeable, block layer won't notice
this change and thus will think device is used RW and will block eject
button of the drive. That is unexpected by users because for
non-writeable media eject button works just fine.
Userspace mount(8) command handles this just fine and retries mounting
with MS_RDONLY set so userspace shouldn't see any regression. Plus any
tool mounting udf is likely confronted with the case of read-only
media where block layer already refuses to mount the filesystem without
MS_RDONLY set so our behavior shouldn't be anything new for it.
Reported-by: Hui Wang <hui.wang@canonical.com>
Change all function used in filesystem discovery during mount to user
standard kernel return values - -errno on error, 0 on success instead
of 1 on failure and 0 on success. This allows us to pass error number
(not just failure / success) so we can abort device scanning earlier
in case of errors like EIO or ENOMEM . Also we will be able to return
EROFS in case writeable mount is requested but writing isn't supported.
This code doesn't serve any purpose anymore, since the aio retry
infrastructure has been removed.
This change should be safe because aio_read/write are also used for
synchronous IO, and called from do_sync_read()/do_sync_write() - and
there's no looping done in the sync case (the read and write syscalls).
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Somehow I failed to add the MODULE_ALIAS_FS for cifs, hostfs, hpfs,
squashfs, and udf despite what I thought were my careful checks :(
Add them now.
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
According to SUSv3:
[EACCES] Permission denied. An attempt was made to access a file in a way
forbidden by its file access permissions.
[EPERM] Operation not permitted. An attempt was made to perform an operation
limited to processes with appropriate privileges or to the owner of a file
or other resource.
So -EPERM should be returned if capability checks fails.
Strictly speaking this is an API change since the error code user sees is
altered.
Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com>
Acked-by: Jan Kara <jack@suse.cz>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ian Kent <raven@themaw.net>
This patch is a follow up on below patch:
[PATCH] exportfs: add FILEID_INVALID to indicate invalid fid_type
commit: 216b6cbdcbd86b1db0754d58886b466ae31f5a63
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Vivek Trivedi <t.vivek@samsung.com>
Acked-by: Sage Weil <sage@inktank.com>
s_extLength was assigned to but the value was never really used. So
just remove the field.
struct udf_bitmap has array of buffer pointers attached to it. The code
unnecessarily used s_block_bitmap as a pointer to the array instead of
the standard trick of using 0 length array in the declaration. Change
that to make code more readable and actually shrink the structure by one
pointer.
