path: root/fs/ufs/balloc.c
2010-08-18remove SWRITE* I/O typesChristoph Hellwig
These flags aren't real I/O types, but tell ll_rw_block to always lock the buffer instead of giving up on a failed trylock. Instead add a new write_dirty_buffer helper that implements this semantic and use it from the existing SWRITE* callers. Note that the ll_rw_block code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which this patch fixes. In the ufs code clean up the helper that used to call ll_rw_block to mirror sync_dirty_buffer, which is the function it implements for compound buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-24ufs: Remove dead quota codeJan Kara
UFS quota is non-functional at least since 2.6.12 because dq_op was set to NULL. Since the filesystem exists mainly to allow cooperation with Solaris and quota format isn't standard, just remove the dead code. CC: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup space allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_space, free_space, reserve_space, claim_space and release_rsv dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Move shared logic into the common __dquot_alloc_space, dquot_claim_space_nodirty and __dquot_free_space low-level methods, and rationalize the wrappers around it to move as much as possible code into the common block for CONFIG_QUOTA vs not. Also rename all these helpers to be named dquot_* instead of vfs_dq_*. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-26ufs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: Evgeniy Dushistov <dushistov@mail.ru>
2008-04-28ufs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19fs/ufs/balloc.c: fix sparc64 printk warningAndrew Morton
fs/ufs/balloc.c: In function `ufs_change_blocknr': fs/ufs/balloc.c:317: warning: long long unsigned int format, long unsigned int arg (arg 2) fs/ufs/balloc.c:317: warning: long long unsigned int format, long unsigned int arg (arg 3) sector_t is u64 and we don't know what type the architecture uses to implement u64. Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08drop linux/ufs_fs.h from userspace export and relocate it to fs/ufs/ufs_fs.hMike Frysinger
Per previous discussions about cleaning up ufs_fs.h, people just want this straight up dropped from userspace export. The only remaining consumer (silo) has been fixed a while ago to not rely on this header. This allows use to move it completely from include/linux/ to fs/ufs/ seeing as how the only in-kernel consumer is fs/ufs/. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jan Kara <jack@ucw.cz> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] ufs: zeroize the rest of block in truncateEvgeniy Dushistov
This patch fix behaviour in such test scenario: lseek(fd, BIG_OFFSET) write(fd, buf, sizeof(buf)) truncate(BIG_OFFSET) truncate(BIG_OFFSET + sizeof(buf)) read(fd, buf...) Because of if file big enough(BIG_OFFSET) we start allocate space by block, ordinary block size > page size, so we should zeroize the rest of block in truncate(except last framgnet, about which VFS should care), to not get garbage, when we extend file. Also patch corrects conversion from pointer to block to physical block number, this helps in case of not common used UFS types. And add to debug output inode number. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] ufs: prepare write + change blocks on the flyEvgeniy Dushistov
This fixes "change blocks numbers on the fly" in case when "prepare write page" is in the call chain, in this case some buffers may be not uptodate and not mapped, we should care to map them and load from disk. This patch was tested with: - ufs regressions simple tests - fsx-linux - ltp(20060306) - untar and build kernel Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] ufs2 write: block allocation updateEvgeniy Dushistov
Patch adds ability to work with 64bit metadata, this made by replacing work with 32bit pointers by inline functions. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] ufs: reallocation fixEvgeniy Dushistov
In blocks reallocation function sometimes does not update some of buffer_head::b_blocknr, which may and cause data damage. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] ufs: alloc metadata null page fixEvgeniy Dushistov
These series of patches result of UFS1 write support stress testing, like running fsx-linux, untar and build linux kernel etc We pass from ufs::get_block_t to levels below: pointer to the current page, to make possible things like reallocation of blocks on the fly, and we also uses this pointer for indication, what actually we allocate data block or meta data block, but currently we make decision about what we allocate on the wrong level, this may and cause oops if we allocate blocks in some special order. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-05[PATCH] fix garbage instead of zeroes in UFSEvgeniy Dushistov
Looks like this is the problem, which point Al Viro some time ago: ufs's get_block callback allocates 16k of disk at a time, and links that entire 16k into the file's metadata. But because get_block is called for only a single buffer_head (a 2k buffer_head in this case?) we are only able to tell the VFS that this 2k is buffer_new(). So when ufs_getfrag_block() is later called to map some more data in the file, and when that data resides within the remaining 14k of this fragment, ufs_getfrag_block() will incorrectly return a !buffer_new() buffer_head. I don't see _right_ way to do nullification of whole block, if use inode page cache, some pages may be outside of inode limits (inode size), and will be lost; if use blockdev page cache it is possible to zero real data, if later inode page cache will be used. The simpliest way, as can I see usage of block device page cache, but not only mark dirty, but also sync it during "nullification". I use my simple tests collection, which I used for check that create,open,write,read,close works on ufs, and I see that this patch makes ufs code 18% slower then before. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] ufs: handle truncated pagesEvgeniy Dushistov
ufs_get_locked_page is called twice in ufs code, one time in ufs_truncate path(we allocated last block), and another time when fragments are reallocated. In ideal world in the second case on allocation/free block layer we should not know that things like `truncate' exists, but now with such crutch like ufs_get_locked_page we can (or should?) skip truncated pages. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] ufs: truncate should allocate block for last byteEvgeniy Dushistov
This patch fixes buggy behaviour of UFS in such kind of scenario: open(, O_TRUNC...) ftruncate(, 1024) ftruncate(, 0) Such a scenario causes ufs_panic and remount read-only. This happen because of according to specification UFS should always allocate block for last byte, and many parts of our implementation rely on this, but `ufs_truncate' doesn't care about this. To make possible return error code and to know about old size, this patch removes `truncate' from ufs inode_operations and uses `setattr' method to call ufs_truncate. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: ubh_ll_rw_block cleanupEvgeniy Dushistov
In ufs code there is function: ubh_ll_rw_block, it has parameter how many ufs_buffer_head it should handle, but it always called with "1" on the place of this parameter. This patch removes unused parameter of "ubh_ll_wr_block". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: make fsck -f happyEvgeniy Dushistov
ufs super block contains some statistic about file systems, like amount of directories, free blocks, inodes and so on. UFS1 hold this information in one location and uses 32bit integers for such information, UFS2 hold statistic in another location and uses 64bit integers. There is transition variant, if UFS1 has type 44BSD and flags field in super block has some special value this mean that we work with statistic like UFS2 does. and this also means that nobody care about old(UFS1) statistic. So if start fsck against such file system, after usage linux ufs driver, it found error: at now only UFS1 like statistic is updated. This patch should fix this. Also it contains some minor cleanup: CodingSytle and remove unused variables. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: missed brelse and wrong baseblkEvgeniy Dushistov
This patch fixes two bugs, which introduced by previous patches: 1) Missed "brelse" 2) Sometimes "baseblk" may be wrongly calculated, if i_size is equal to zero, which lead infinite cycle in "mpage_writepages". Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: unlock_super without lockEvgeniy Dushistov
ufs_free_blocks function looks now in so way: if (err) goto failed; lock_super(); failed: unlock_super(); So if error happen we'll unlock not locked super. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: i_blocks wrong countEvgeniy Dushistov
At now UFS code uses DQUOT_* mechanism, but it also update inode->i_blocks manually, this cause wrong i_blocks value. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: easy debugEvgeniy Dushistov
Currently to turn on debug mode "user" has to edit ~10 files, to turn off he has to do it again. This patch introduce such changes: 1)turn on(off) debug messages via ".config" 2)remove unnecessary duplication of code 3)make "UFSD" macros more similar to function 4)fix some compiler warnings Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: not usual amounts of fragments per blockEvgeniy Dushistov
The writing to UFS file system with block/fragment!=8 may cause bogus behaviour. The problem in "ufs_bitmap_search" function, which doesn't work correctly in "block/fragment!=8" case. The idea is stolen from BSD code. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: wrong type castEvgeniy Dushistov
There are two ugly macros in ufs code: #define UCPI_UBH ((struct ufs_buffer_head *)ucpi) #define USPI_UBH ((struct ufs_buffer_head *)uspi) when uspi looks like struct { struct ufs_buffer_head ; } and USPI_UBH has some sence, ucpi looks like struct { struct not_ufs_buffer_head; } To prevent bugs in future, this patch convert macros to inline function and fix "ucpi" structure. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: change block number on the flyEvgeniy Dushistov
First of all some necessary notes about UFS by it self: To avoid waste of disk space the tail of file consists not from blocks (which is ordinary big enough, 16K usually), it consists from fragments(which is ordinary 2K). When file is growing its tail occupy 1 fragment, 2 fragments... At some stage decision to allocate whole block is made and all fragments are moved to one block. How this situation was handled before: ufs_prepare_write ->block_prepare_write ->ufs_getfrag_block ->... ->ufs_new_fragments: bh = sb_bread bh->b_blocknr = result + i; mark_buffer_dirty (bh); This is wrong solution, because: - it didn't take into consideration that there is another cache: "inode page cache" - because of sb_getblk uses not b_blocknr, (it uses page->index) to find certain block, this breaks sb_getblk. How this situation is handled now: we go though all "page inode cache", if there are no such page in cache we load it into cache, and change b_blocknr. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: right block allocationEvgeniy Dushistov
* After block allocation, we map it on the same "address" as 8 others blocks * We nullify block several times: once in ufs/block.c and once in block_*write_full_page, and use different "caches" for this. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] ufs cleanupEvgeniy
Here is update of ufs cleanup patch, brought on by the recently fixed ubh_get_usb_second() bug that made some ugly code rather painfully obvious. It also includes - fix compilation warnings which appears if debug mode turn on - remove unnecessary duplication of code to support UFS2 I tested it on ufs1 and ufs2 file-systems. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Change ll_rw_block() calls in UFSJan Kara
We need to be sure that current data are sent to disk. Hence we call ll_rw_block() with SWRITE. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
