path: root/fs/ufs/ufs.h
2015-12-06ufs: get rid of ->setattr() for symlinksAl Viro
It was to needed for a couple of months in 2010, until UFS quota support got dropped. Since then it's equivalent to simple_setattr() (i.e. the default) for everything except the regular files. And dropping it there allows to convert all UFS symlinks to {page,simple}_symlink_inode_operations, getting rid of fs/ufs/symlink.c completely. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-06ufs: move truncate code into inode.cAl Viro
It is closely tied to block pointers handling there, can benefit from existing helpers, etc. - no point keeping them apart. Trimmed the trailing whitespaces in inode.c at the same time. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-06ufs: kill lock_ufs()Al Viro
There were 3 remaining users; in two of them we took ->s_lock immediately after lock_ufs() and held it until just before unlock_ufs(); the third one (statfs) could not be called from itself or from other two (remount and sync_fs). Just use ->s_lock in statfs and don't bother with lock_ufs at all. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-06ufs: don't use lock_ufs() for block pointers tree protectionAl Viro
* stores to block pointers are under per-inode seqlock (meta_lock) and mutex (truncate_mutex) * fetches of block pointers are either under truncate_mutex, or wrapped into seqretry loop on meta_lock * all changes of ->i_size are under truncate_mutex and i_mutex * all changes of ->i_lastfrag are under truncate_mutex It's similar to what ext2 is doing; the main difference is that unlike ext2 we can't rely upon the atomicity of stores into block pointers - on UFS2 they are 64bit. So we can't cut the corner when switching a pointer from NULL to non-NULL as we could in ext2_splice_branch() and need to use meta_lock on all modifications. We use seqlock where ext2 uses rwlock; ext2 could probably also benefit from such change... Another non-trivial difference is that with UFS we *cannot* have reader grab truncate_mutex in case of race - it has to keep retrying. That might be possible to change, but not until we lift tail unpacking several levels up in call chain. After that commit we do *NOT* hold fs-wide serialization on accesses to block pointers anymore. Moreover, lock_ufs() can become a normal mutex now - it's only used on statfs, remount and sync_fs and none of those uses are recursive. As the matter of fact, *now* it can be collapsed with ->s_lock, and be eventually replaced with saner per-cylinder-group spinlocks, but that's a separate story. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-06ufs: switch ufs_evict_inode() to trimmed-down variant of ufs_truncate()Al Viro
2015-06-16ufs: don't touch mtime/ctime of directory being movedAl Viro
See "ext2: Do not update mtime of a moved directory" (and followup in "ext2: fix unbalanced kmap()/kunmap()") for background; this is UFS equivalent - the same problem exists here. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-16fs/ufs: restore s_lock mutexFabian Frederick
Commit 0244756edc4b98c ("ufs: sb mutex merge + mutex_destroy") generated deadlocks in read/write mode on mkdir. This patch partially reverts it keeping fixes by Andrew Morton and mutex_destroy() [AV: fixed a missing bit in ufs_remount()] Signed-off-by: Fabian Frederick <fabf@skynet.be> Reported-by: Ian Campbell <ian.campbell@citrix.com> Suggested-by: Jan Kara <jack@suse.cz> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Alexey Khoroshilov <khoroshilov@ispras.ru> Cc: Roger Pau Monne <roger.pau@citrix.com> Cc: Ian Jackson <Ian.Jackson@eu.citrix.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-08-08fs/ufs: convert UFSD printk to pr_debugFabian Frederick
Convert no level printk to pr_debug in UFSD. DEBUG is defined with CONFIG_UFS_DEBUG so pr_debug are emitted here. Also fixing call to UFSD (add;) Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-08fs/ufs: use pr_fmtFabian Frederick
Replace UFS-fs, UFS-fs: and UFS: by pr_fmt with module name "ufs: " Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06ufs: sb mutex merge + mutex_destroyFabian Frederick
Commit 788257d6101d ("ufs: remove the BKL") replaced BKL with mutex protection using functions lock_ufs, unlock_ufs and struct mutex 'mutex' in sb_info. Commit b6963327e052 ("ufs: drop lock/unlock super") removed lock/unlock super and added struct mutex 's_lock' in sb_info. Those 2 mutexes are generally locked/unlocked at the same time except in allocation (balloc, ialloc). This patch merges the 2 mutexes and propagates first commit solution. It also adds mutex destruction before kfree during ufs_fill_super failure and ufs_put_super. [akpm@linux-foundation.org: avoid ifdefs, return -EROFS not -EINVAL] Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: "Chen, Jet" <jet.chen@intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09ufs: drop lock/unlock superMarco Stornelli
Removed lock/unlock super. Added a new private s_lock mutex. Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22fs/ufs: get rid of write_superArtem Bityutskiy
This patch makes UFS stop using the VFS '->write_super()' method along with the 's_dirt' superblock flag, because they are on their way out. The way we implement this is that we schedule a delay job instead relying on 's_dirt' and '->write_super()'. The whole "superblock write-out" VFS infrastructure is served by the 'sync_supers()' kernel thread, which wakes up every 5 (by default) seconds and writes out all dirty superblocks using the '->write_super()' call-back. But the problem with this thread is that it wastes power by waking up the system every 5 seconds, even if there are no diry superblocks, or there are no client file-systems which would need this (e.g., btrfs does not use '->write_super()'). So we want to kill it completely and thus, we need to make file-systems to stop using the '->write_super()' VFS service, and then remove it together with the kernel thread. Tested using fsstress from the LTP project. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03ufs: propagate umode_tAl Viro
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-02ufs: remove the BKLArnd Bergmann
This introduces a new per-superblock mutex in UFS to replace the big kernel lock. I have been careful to avoid nested calls to lock_ufs and to get the lock order right with respect to other mutexes, in particular lock_super. I did not make any attempt to prove that the big kernel lock is not needed in a particular place in the code, which is very possible. The mutex has a significant performance impact, so it is only used on SMP or PREEMPT configurations. As Nick Piggin noticed, any allocation inside of the lock may end up deadlocking when we get to ufs_getfrag_block in the reclaim task, so we now use GFP_NOFS. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Nick Bowler <nbowler@elliptictech.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Nick Piggin <npiggin@gmail.com>
2010-08-09switch ufs to ->evict_inode()Al Viro
2010-05-21ufs: add ufs speciffic ->setattr callDmitry Monakhov
generic setattr not longer responsible for quota transfer. use ufs_setattr for all ufs's inodes. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03sanitize const/signedness of ufs a bitAl Viro
2009-12-16ufs: pass qstr instead of dentry where necessary for NFSAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11switch ufs to simple_fsync()Al Viro
2009-05-09switch ufs directories to ufs_sync_file()Al Viro
2009-03-27ufs: don't truncate longer ufs2 fast symlinksDuane Griffin
ufs2 fast symlinks can be twice as long as ufs ones, however the code was using the ufs size in various places. Fix that so ufs2 symlinks over 60 characters aren't truncated. Note that we copy the entire area instead of using the maxsymlinklen field from the superblock. This way we will be more robust against corruption (of the superblock). While we are at it, use memcpy instead of open-coding it with for loops. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-13ufs: remove unneeded ufs_put_inode prototypeChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ufs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop UFS from using iget() and read_inode()David Howells
Stop the UFS filesystem from using iget() and read_inode(). Replace ufs_read_inode() with ufs_iget(), and call that instead of iget(). ufs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ufs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ufs: move non-layout parts of ufs_fs.h to fs/ufs/Christoph Hellwig
Move prototypes and in-core structures to fs/ufs/ similar to what most other filesystems already do. I made little modifications: move also ufs debug macros and mount options constants into fs/ufs/ufs.h, this stuff also private for ufs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
